    Ubuntu 18 Install failed
    Mango Automation Installation
    4
    18
    2.7k
    • R
      Robmalone
      Hi all,
      I'm trying to install Mango on Ubuntu 18.4 but it keeps failing. I'm using the install script as I'm not that up on Linux but it keeps failing. I have Installed JDK and set the JAVA_HOME variable.
      I first tried to install Mango Version 3.7.7 which failed with the error below. Then I tried version 4 which indicated it installed correctly and seemed to start but I can't connect to it on 127.0.0.1.
      I then tried to install 3.7.7 again (I though the fact that seemed to install v.4 might help) but I'm still getting the error below - "can't find env.properties file" I did enter "yes" when prompted to overwrite files.
      Any thoughts would be appreciated.
      [sudo] password for powerpoint:
      Where should we store Mango data? [/opt/mango-data]:
      Which OS user should Mango run as? (Will be created if it does not exist) [mango]:
      What type of SQL database? (h2 or mysql) [h2]:
      Installation directory is not empty, delete all files in '/opt/mango'? (May contain H2 databases and time series databases) [no]: yes
      What version of Mango do you want to install? [4.0.0]: 3.7.7
      Install free (personal/educational use, 300 point limit) or enterprise (evaluation) bundle? [enterprise]:
        % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                       Dload  Upload   Total   Spent    Left  Speed
      100  144M  100  144M    0     0  4713k      0  0:00:31  0:00:31 --:--:-- 5286k
      Config file '/opt/mango-data/mango.properties' exists, overwrite it? [no]: yes
      Can't find env.properties file
      powerpoint@powerpoint-UltraPoint:~$
      • T
        tungthanh500 @Robmalone
        @robmalone Hi, I also face hardship installing v3 so I tried v4. It is much easier. Before installing everything, don't forget to delete the residual folder and file.
        In latest v4, env.properties is replace with mango.properties (which is moved to /home/mango)
        • R
          Robmalone @tungthanh500
          @tungthanh500 I assumed since the files were being overwritten I didn't need to remove the directories. I removed them and that did the trick. Still can get v3 to work though. Guess I'll just use 4. Thanks for your help.
          • Jared WiltshireJ
            @Robmalone
            If you still want to use v3.7.x then you can try this. Where it says to -
            curl -o install-mango.sh https://raw.githubusercontent.com/infiniteautomation/ma-core-public/main/Core/bin/install-mango.sh
            Try this instead -
            curl -o install-mango.sh https://raw.githubusercontent.com/infiniteautomation/ma-core-public/3.7.x/Core/scripts/install-mango.sh
            When it asks for a version, answer 3.7.7
            Alternatively, try the manual installation instructions - https://docs-v3.mango-os.com/linux-installation
            • R
              Robmalone @Jared Wiltshire
              @jared-wiltshire Installation stops at
              /opt/mango/bin/genkey.sh: 1: /opt/mango/bin/genkey.sh: 404:: not found
              I will have a lot of these to build over the next few months/year or so (about 300 systems) so it would be great to use the install script rather than having to manually install them all.
              V4 installed fine but @CraigWeb recommend I stick to v3.7.
              T Jared WiltshireJ 2 Replies Last reply Reply Quote 0
              • T
                @robmalone Can you solve the problem with V4? If you cannot access the system on localhost, please try changing port to 8443, (but don't forget to forward that port).
                • R
                  Hi @tungthanh500 Yes I can get V4 working but as it's not officially released yet I've been advised to use V3.7.7.
                  • T
                    @robmalone I think I also have to fall back to 3.7.7 because I face point unreliable. Not sure how to fix it. No correct answer in forum yet
                    • Jared WiltshireJ
                      Jared Wiltshire @Robmalone
                      @robmalone said in Ubuntu 18 Install failed:
                      Try again now. I updated the script for 3.7.x
                      • Jared WiltshireJ
                        It will be released very soon. Bear in mind that v4 will require a new license however.
                        • R
                          @jared-wiltshire Thanks Jared. The install seemed to work but I can't access the GUI. Should I see mango running as a service after starting it?```
                          powerpoint@powerpoint-UltraPoint:~$ service --status-all
                          [ + ] acpid
                          [ - ] alsa-utils
                          [ - ] anacron
                          [ + ] apparmor
                          [ + ] apport
                          [ + ] avahi-daemon
                          [ - ] bluetooth
                          [ - ] console-setup.sh
                          [ + ] cron
                          [ + ] cups
                          [ + ] cups-browsed
                          [ + ] dbus
                          [ - ] dns-clean
                          [ + ] gdm3
                          [ + ] grub-common
                          [ - ] hwclock.sh
                          [ + ] irqbalance
                          [ + ] kerneloops
                          [ - ] keyboard-setup.sh
                          [ + ] kmod
                          [ - ] lvm2
                          [ + ] lvm2-lvmetad
                          [ + ] lvm2-lvmpolld
                          [ + ] network-manager
                          [ + ] networking
                          [ - ] plymouth
                          [ - ] plymouth-log
                          [ - ] pppd-dns
                          [ + ] procps
                          [ - ] rsync
                          [ + ] rsyslog
                          [ - ] saned
                          [ + ] speech-dispatcher
                          [ - ] spice-vdagent
                          [ + ] udev
                          [ + ] ufw
                          [ + ] unattended-upgrades
                          [ - ] uuidd
                          [ + ] whoopsie
                          [ - ] x11-common
                          • Jared WiltshireJ
                            @robmalone The install script installs Mango as a systemd service but does not start it.
                            See bottom of https://docs-v3.mango-os.com/linux-installation to check the status of the service, start/stop commands.
                            • R
                              @jared-wiltshire Yes I did start it with systemctl start mango
                              When I check the status i get the following:
                              powerpoint@powerpoint-UltraPoint:~$ systemctl status mango
                              ā— mango.service - Mango Automation
                                 Loaded: loaded (/opt/mango/overrides/mango.service; enabled; vendor preset: enabled)
                                 Active: active (running) since Tue 2021-07-13 17:49:53 IST; 38s ago
                                Process: 2538 ExecStart=/opt/mango/bin/start-mango.sh (code=exited, status=0/SUCCESS)
                               Main PID: 2541 (java)
                                  Tasks: 24 (limit: 4447)
                                 CGroup: /system.slice/mango.service
                                         └─2541 /snap/openjdk/321/jdk/bin/java -server -Dma.home=/opt/mango com.serotonin.m2m2.Main
                              Jul 13 17:49:53 powerpoint-UltraPoint start-mango.sh[2538]: Starting Mango Automation
                              Jul 13 17:49:53 powerpoint-UltraPoint start-mango.sh[2538]: Mango Automation started with process ID:  2541
                              Jul 13 17:49:53 powerpoint-UltraPoint systemd[1]: Started Mango Automation.
                              Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: Unable to determine the machine id
                              Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: FATAL (com.serotonin.m2m2.Lifecycle.loadLic:592) - Unable to determine the machine
                              Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: ERROR (com.serotonin.m2m2.Main.main:162) - Error during initialization
                              Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: java.lang.RuntimeException: Unable to determine the machine id
                              Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]:         at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:595) ~[ma-priv-3.7.
                              Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]:         at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:277) ~[ma-priv-3
                              Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]:         at com.serotonin.m2m2.Main.main(Main.java:159) ~[ma-priv-3.7.7.jar:?]
                              • Jared WiltshireJ
                                @robmalone It seems to be installed but its crashing on start. Post your full ma.log file.
                                I would try installing a different JDK, not inside a snap.
                                • G
                                  Gordoe @Jared Wiltshire
                                  @jared-wiltshire
                                  I'm receiving the same error on Ubuntu 20.04LTS
                                  Jul 13 18:45:04 onxl4549 start-mango.sh[832]: Starting Mango Automation
                                  Jul 13 18:45:04 onxl4549 start-mango.sh[832]: Mango Automation started with process ID: 1020
                                  Jul 13 18:45:04 onxl4549 systemd[1]: Started SBIO dTwins.
                                  Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: Unable to determine the machine id
                                  Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: FATAL (com.serotonin.m2m2.Lifecycle.loadLic:592) - Unable to determine the machine id
                                  Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: ERROR (com.serotonin.m2m2.Main.main:162) - Error during initialization
                                  Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: java.lang.RuntimeException: Unable to determine the machine id
                                  Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:595) ~[ma-priv-3.7.7.jar:?]
                                  Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:277) ~[ma-priv-3.7.7.jar:?]
                                  Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: at com.serotonin.m2m2.Main.main(Main.java:159) ~[ma-priv-3.7.7.jar:?]
                                  • G
                                    Gordoe @Gordoe
                                    with the contents of ma.log
                                    INFO 2021-07-13T18:53:09,828 (com.serotonin.m2m2.Lifecycle.loadLic:583) - Checking license...
                                    WARN 2021-07-13T18:53:09,872 (com.serotonin.m2m2.CoreLicenseDefinition.getSpecificGuid:338) - Host exception:
                                    java.io.FileNotFoundException: /opt/dTwin/.ma (No such file or directory)
                                    at java.io.FileOutputStream.open0(Native Method) ~[?:?]
                                    at java.io.FileOutputStream.open(FileOutputStream.java:298) ~[?:?]
                                    at java.io.FileOutputStream.<init>(FileOutputStream.java:237) ~[?:?]
                                    at java.io.FileOutputStream.<init>(FileOutputStream.java:187) ~[?:?]
                                    at java.io.FileWriter.<init>(FileWriter.java:96) ~[?:?]
                                    at com.serotonin.m2m2.host.DefaultHost.guid(DefaultHost.java:69) ~[ma-priv-3.7.7.jar:?]
                                    at com.serotonin.m2m2.CoreLicenseDefinition.getSpecificGuid(CoreLicenseDefinition.java:333) ~[ma-priv-3.7.7.jar:?]
                                    at com.serotonin.m2m2.CoreLicenseDefinition.guid(CoreLicenseDefinition.java:317) ~[ma-priv-3.7.7.jar:?]
                                    at com.serotonin.m2m2.CoreLicenseDefinition.initializeLic(CoreLicenseDefinition.java:117) ~[ma-priv-3.7.7.jar:?]
                                    at com.serotonin.m2m2.CoreLicenseDefinition.licenseCheck(CoreLicenseDefinition.java:101) ~[ma-priv-3.7.7.jar:?]
                                    at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:659) ~[ma-priv-3.7.7.jar:?]
                                    at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:587) ~[ma-priv-3.7.7.jar:?]
                                    FATAL 2021-07-13T18:53:09,872 (com.serotonin.m2m2.Lifecycle.loadLic:592) - Unable to determine the machine id
                                    ERROR 2021-07-13T18:53:09,872 (com.serotonin.m2m2.Main.main:162) - Error during initialization
                                    INFO 2021-07-13T18:53:09,873 (com.serotonin.m2m2.Lifecycle.terminate:400) - Mango Lifecycle terminating...
                                    INFO 2021-07-13T18:53:09,915 (com.serotonin.m2m2.Lifecycle.terminate:550) - Mango Lifecycle terminated.
                                    • Jared WiltshireJ
                                      @Gordoe What user is mango running as? The install script should ask you to create a user. What is that user's home directory? Does that user have write permission for their own home directory?
                                      • G
                                        @jared-wiltshire
                                        It's running as Mango.
                                        I'll start a new post as I don't want to hijack this one. Same error but not from the installation script.
