    Ubuntu 18 Install failed
    18 Posts 4 Posters 13.5k Views 3 Watching
    • T Offline
      tungthanh500 @Robmalone
      @robmalone I think I also have to fall back to 3.7.7 because I face point unreliable. Not sure how to fix it. No correct answer in forum yet
        Jared Wiltshire @Robmalone
        @robmalone said in Ubuntu 18 Install failed:
        @jared-wiltshire Installation stops at
        /opt/mango/bin/genkey.sh: 1: /opt/mango/bin/genkey.sh: 404:: not found
        I will have a lot of these to build over the next few months/year or so (about 300 systems) so it would be great to use the install script rather than having to manually install them all.
        Try again now. I updated the script for 3.7.x
          Hi @tungthanh500 Yes I can get V4 working but as it's not officially released yet I've been advised to use V3.7.7.
          It will be released very soon. Bear in mind that v4 will require a new license however.
            Robmalone @Jared Wiltshire
            @jared-wiltshire Thanks Jared. The install seemed to work but I can't access the GUI. Should I see mango running as a service after starting it?```
            powerpoint@powerpoint-UltraPoint:~$ service --status-all
            [ + ] acpid
            [ - ] alsa-utils
            [ - ] anacron
            [ + ] apparmor
            [ + ] apport
            [ + ] avahi-daemon
            [ - ] bluetooth
            [ - ] console-setup.sh
            [ + ] cron
            [ + ] cups
            [ + ] cups-browsed
            [ + ] dbus
            [ - ] dns-clean
            [ + ] gdm3
            [ + ] grub-common
            [ - ] hwclock.sh
            [ + ] irqbalance
            [ + ] kerneloops
            [ - ] keyboard-setup.sh
            [ + ] kmod
            [ - ] lvm2
            [ + ] lvm2-lvmetad
            [ + ] lvm2-lvmpolld
            [ + ] network-manager
            [ + ] networking
            [ - ] plymouth
            [ - ] plymouth-log
            [ - ] pppd-dns
            [ + ] procps
            [ - ] rsync
            [ + ] rsyslog
            [ - ] saned
            [ + ] speech-dispatcher
            [ - ] spice-vdagent
            [ + ] udev
            [ + ] ufw
            [ + ] unattended-upgrades
            [ - ] uuidd
            [ + ] whoopsie
            [ - ] x11-common
              @robmalone The install script installs Mango as a systemd service but does not start it.
              See bottom of https://docs-v3.mango-os.com/linux-installation to check the status of the service, start/stop commands.
                @jared-wiltshire Yes I did start it with systemctl start mango
                When I check the status i get the following:
                powerpoint@powerpoint-UltraPoint:~$ systemctl status mango
                ā— mango.service - Mango Automation
                   Loaded: loaded (/opt/mango/overrides/mango.service; enabled; vendor preset: enabled)
                   Active: active (running) since Tue 2021-07-13 17:49:53 IST; 38s ago
                  Process: 2538 ExecStart=/opt/mango/bin/start-mango.sh (code=exited, status=0/SUCCESS)
                 Main PID: 2541 (java)
                    Tasks: 24 (limit: 4447)
                   CGroup: /system.slice/mango.service
                           └─2541 /snap/openjdk/321/jdk/bin/java -server -Dma.home=/opt/mango com.serotonin.m2m2.Main
                Jul 13 17:49:53 powerpoint-UltraPoint start-mango.sh[2538]: Starting Mango Automation
                Jul 13 17:49:53 powerpoint-UltraPoint start-mango.sh[2538]: Mango Automation started with process ID:  2541
                Jul 13 17:49:53 powerpoint-UltraPoint systemd[1]: Started Mango Automation.
                Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: Unable to determine the machine id
                Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: FATAL (com.serotonin.m2m2.Lifecycle.loadLic:592) - Unable to determine the machine
                Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: ERROR (com.serotonin.m2m2.Main.main:162) - Error during initialization
                Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: java.lang.RuntimeException: Unable to determine the machine id
                Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]:         at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:595) ~[ma-priv-3.7.
                Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]:         at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:277) ~[ma-priv-3
                Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]:         at com.serotonin.m2m2.Main.main(Main.java:159) ~[ma-priv-3.7.7.jar:?]
                  @robmalone It seems to be installed but its crashing on start. Post your full ma.log file.
                  I would try installing a different JDK, not inside a snap.
                  • G Offline
                    Gordoe @Jared Wiltshire
                    @jared-wiltshire
                    I'm receiving the same error on Ubuntu 20.04LTS
                    Jul 13 18:45:04 onxl4549 start-mango.sh[832]: Starting Mango Automation
                    Jul 13 18:45:04 onxl4549 start-mango.sh[832]: Mango Automation started with process ID: 1020
                    Jul 13 18:45:04 onxl4549 systemd[1]: Started SBIO dTwins.
                    Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: Unable to determine the machine id
                    Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: FATAL (com.serotonin.m2m2.Lifecycle.loadLic:592) - Unable to determine the machine id
                    Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: ERROR (com.serotonin.m2m2.Main.main:162) - Error during initialization
                    Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: java.lang.RuntimeException: Unable to determine the machine id
                    Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:595) ~[ma-priv-3.7.7.jar:?]
                    Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:277) ~[ma-priv-3.7.7.jar:?]
                    Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: at com.serotonin.m2m2.Main.main(Main.java:159) ~[ma-priv-3.7.7.jar:?]
                    • G Offline
                      Gordoe @Gordoe
                      with the contents of ma.log
                      INFO 2021-07-13T18:53:09,828 (com.serotonin.m2m2.Lifecycle.loadLic:583) - Checking license...
                      WARN 2021-07-13T18:53:09,872 (com.serotonin.m2m2.CoreLicenseDefinition.getSpecificGuid:338) - Host exception:
                      java.io.FileNotFoundException: /opt/dTwin/.ma (No such file or directory)
                      at java.io.FileOutputStream.open0(Native Method) ~[?:?]
                      at java.io.FileOutputStream.open(FileOutputStream.java:298) ~[?:?]
                      at java.io.FileOutputStream.<init>(FileOutputStream.java:237) ~[?:?]
                      at java.io.FileOutputStream.<init>(FileOutputStream.java:187) ~[?:?]
                      at java.io.FileWriter.<init>(FileWriter.java:96) ~[?:?]
                      at com.serotonin.m2m2.host.DefaultHost.guid(DefaultHost.java:69) ~[ma-priv-3.7.7.jar:?]
                      at com.serotonin.m2m2.CoreLicenseDefinition.getSpecificGuid(CoreLicenseDefinition.java:333) ~[ma-priv-3.7.7.jar:?]
                      at com.serotonin.m2m2.CoreLicenseDefinition.guid(CoreLicenseDefinition.java:317) ~[ma-priv-3.7.7.jar:?]
                      at com.serotonin.m2m2.CoreLicenseDefinition.initializeLic(CoreLicenseDefinition.java:117) ~[ma-priv-3.7.7.jar:?]
                      at com.serotonin.m2m2.CoreLicenseDefinition.licenseCheck(CoreLicenseDefinition.java:101) ~[ma-priv-3.7.7.jar:?]
                      at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:659) ~[ma-priv-3.7.7.jar:?]
                      at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:587) ~[ma-priv-3.7.7.jar:?]
                      FATAL 2021-07-13T18:53:09,872 (com.serotonin.m2m2.Lifecycle.loadLic:592) - Unable to determine the machine id
                      ERROR 2021-07-13T18:53:09,872 (com.serotonin.m2m2.Main.main:162) - Error during initialization
                      INFO 2021-07-13T18:53:09,873 (com.serotonin.m2m2.Lifecycle.terminate:400) - Mango Lifecycle terminating...
                      INFO 2021-07-13T18:53:09,915 (com.serotonin.m2m2.Lifecycle.terminate:550) - Mango Lifecycle terminated.
                        @Gordoe What user is mango running as? The install script should ask you to create a user. What is that user's home directory? Does that user have write permission for their own home directory?
                        • G Offline
                          @jared-wiltshire
                          It's running as Mango.
                          I'll start a new post as I don't want to hijack this one. Same error but not from the installation script.
