    Ubuntu 18 Install failed
    18 Posts 4 Posters 13.6k Views 3 Watching
      Jared Wiltshire @Robmalone
      @robmalone said in Ubuntu 18 Install failed:
      @jared-wiltshire Installation stops at
      /opt/mango/bin/genkey.sh: 1: /opt/mango/bin/genkey.sh: 404:: not found
      I will have a lot of these to build over the next few months/year or so (about 300 systems) so it would be great to use the install script rather than having to manually install them all.
      Try again now. I updated the script for 3.7.x
        Hi @tungthanh500 Yes I can get V4 working but as it's not officially released yet I've been advised to use V3.7.7.
        It will be released very soon. Bear in mind that v4 will require a new license however.
          Robmalone @Jared Wiltshire
          @jared-wiltshire Thanks Jared. The install seemed to work but I can't access the GUI. Should I see mango running as a service after starting it?```
          powerpoint@powerpoint-UltraPoint:~$ service --status-all
          [ + ] acpid
          [ - ] alsa-utils
          [ - ] anacron
          [ + ] apparmor
          [ + ] apport
          [ + ] avahi-daemon
          [ - ] bluetooth
          [ - ] console-setup.sh
          [ + ] cron
          [ + ] cups
          [ + ] cups-browsed
          [ + ] dbus
          [ - ] dns-clean
          [ + ] gdm3
          [ + ] grub-common
          [ - ] hwclock.sh
          [ + ] irqbalance
          [ + ] kerneloops
          [ - ] keyboard-setup.sh
          [ + ] kmod
          [ - ] lvm2
          [ + ] lvm2-lvmetad
          [ + ] lvm2-lvmpolld
          [ + ] network-manager
          [ + ] networking
          [ - ] plymouth
          [ - ] plymouth-log
          [ - ] pppd-dns
          [ + ] procps
          [ - ] rsync
          [ + ] rsyslog
          [ - ] saned
          [ + ] speech-dispatcher
          [ - ] spice-vdagent
          [ + ] udev
          [ + ] ufw
          [ + ] unattended-upgrades
          [ - ] uuidd
          [ + ] whoopsie
          [ - ] x11-common
            @robmalone The install script installs Mango as a systemd service but does not start it.
            See bottom of https://docs-v3.mango-os.com/linux-installation to check the status of the service, start/stop commands.
              @jared-wiltshire Yes I did start it with systemctl start mango
              When I check the status i get the following:
              powerpoint@powerpoint-UltraPoint:~$ systemctl status mango
              ā— mango.service - Mango Automation
                 Loaded: loaded (/opt/mango/overrides/mango.service; enabled; vendor preset: enabled)
                 Active: active (running) since Tue 2021-07-13 17:49:53 IST; 38s ago
                Process: 2538 ExecStart=/opt/mango/bin/start-mango.sh (code=exited, status=0/SUCCESS)
               Main PID: 2541 (java)
                  Tasks: 24 (limit: 4447)
                 CGroup: /system.slice/mango.service
                         └─2541 /snap/openjdk/321/jdk/bin/java -server -Dma.home=/opt/mango com.serotonin.m2m2.Main
              Jul 13 17:49:53 powerpoint-UltraPoint start-mango.sh[2538]: Starting Mango Automation
              Jul 13 17:49:53 powerpoint-UltraPoint start-mango.sh[2538]: Mango Automation started with process ID:  2541
              Jul 13 17:49:53 powerpoint-UltraPoint systemd[1]: Started Mango Automation.
              Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: Unable to determine the machine id
              Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: FATAL (com.serotonin.m2m2.Lifecycle.loadLic:592) - Unable to determine the machine
              Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: ERROR (com.serotonin.m2m2.Main.main:162) - Error during initialization
              Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: java.lang.RuntimeException: Unable to determine the machine id
              Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]:         at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:595) ~[ma-priv-3.7.
              Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]:         at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:277) ~[ma-priv-3
              Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]:         at com.serotonin.m2m2.Main.main(Main.java:159) ~[ma-priv-3.7.7.jar:?]
                @robmalone It seems to be installed but its crashing on start. Post your full ma.log file.
                I would try installing a different JDK, not inside a snap.
                • G Offline
                  Gordoe @Jared Wiltshire
                  @jared-wiltshire
                  I'm receiving the same error on Ubuntu 20.04LTS
                  Jul 13 18:45:04 onxl4549 start-mango.sh[832]: Starting Mango Automation
                  Jul 13 18:45:04 onxl4549 start-mango.sh[832]: Mango Automation started with process ID: 1020
                  Jul 13 18:45:04 onxl4549 systemd[1]: Started SBIO dTwins.
                  Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: Unable to determine the machine id
                  Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: FATAL (com.serotonin.m2m2.Lifecycle.loadLic:592) - Unable to determine the machine id
                  Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: ERROR (com.serotonin.m2m2.Main.main:162) - Error during initialization
                  Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: java.lang.RuntimeException: Unable to determine the machine id
                  Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:595) ~[ma-priv-3.7.7.jar:?]
                  Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:277) ~[ma-priv-3.7.7.jar:?]
                  Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: at com.serotonin.m2m2.Main.main(Main.java:159) ~[ma-priv-3.7.7.jar:?]
                  • G Offline
                    Gordoe @Gordoe
                    with the contents of ma.log
                    INFO 2021-07-13T18:53:09,828 (com.serotonin.m2m2.Lifecycle.loadLic:583) - Checking license...
                    WARN 2021-07-13T18:53:09,872 (com.serotonin.m2m2.CoreLicenseDefinition.getSpecificGuid:338) - Host exception:
                    java.io.FileNotFoundException: /opt/dTwin/.ma (No such file or directory)
                    at java.io.FileOutputStream.open0(Native Method) ~[?:?]
                    at java.io.FileOutputStream.open(FileOutputStream.java:298) ~[?:?]
                    at java.io.FileOutputStream.<init>(FileOutputStream.java:237) ~[?:?]
                    at java.io.FileOutputStream.<init>(FileOutputStream.java:187) ~[?:?]
                    at java.io.FileWriter.<init>(FileWriter.java:96) ~[?:?]
                    at com.serotonin.m2m2.host.DefaultHost.guid(DefaultHost.java:69) ~[ma-priv-3.7.7.jar:?]
                    at com.serotonin.m2m2.CoreLicenseDefinition.getSpecificGuid(CoreLicenseDefinition.java:333) ~[ma-priv-3.7.7.jar:?]
                    at com.serotonin.m2m2.CoreLicenseDefinition.guid(CoreLicenseDefinition.java:317) ~[ma-priv-3.7.7.jar:?]
                    at com.serotonin.m2m2.CoreLicenseDefinition.initializeLic(CoreLicenseDefinition.java:117) ~[ma-priv-3.7.7.jar:?]
                    at com.serotonin.m2m2.CoreLicenseDefinition.licenseCheck(CoreLicenseDefinition.java:101) ~[ma-priv-3.7.7.jar:?]
                    at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:659) ~[ma-priv-3.7.7.jar:?]
                    at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:587) ~[ma-priv-3.7.7.jar:?]
                    FATAL 2021-07-13T18:53:09,872 (com.serotonin.m2m2.Lifecycle.loadLic:592) - Unable to determine the machine id
                    ERROR 2021-07-13T18:53:09,872 (com.serotonin.m2m2.Main.main:162) - Error during initialization
                    INFO 2021-07-13T18:53:09,873 (com.serotonin.m2m2.Lifecycle.terminate:400) - Mango Lifecycle terminating...
                    INFO 2021-07-13T18:53:09,915 (com.serotonin.m2m2.Lifecycle.terminate:550) - Mango Lifecycle terminated.
                      @Gordoe What user is mango running as? The install script should ask you to create a user. What is that user's home directory? Does that user have write permission for their own home directory?
                      • G Offline
                        @jared-wiltshire
                        It's running as Mango.
                        I'll start a new post as I don't want to hijack this one. Same error but not from the installation script.
