    Ubuntu 18 Install failed
    18 Posts 4 Posters 13.8k Views 3 Watching
      Robmalone @tungthanh500
      Hi @tungthanh500 Yes I can get V4 working but as it's not officially released yet I've been advised to use V3.7.7.
      T Jared WiltshireJ 2 Replies Last reply Reply Quote 0
      • T Offline
        tungthanh500 @Robmalone
        @robmalone I think I also have to fall back to 3.7.7 because I face point unreliable. Not sure how to fix it. No correct answer in forum yet
          Jared Wiltshire @Robmalone
          @robmalone said in Ubuntu 18 Install failed:
          @jared-wiltshire Installation stops at
          /opt/mango/bin/genkey.sh: 1: /opt/mango/bin/genkey.sh: 404:: not found
          I will have a lot of these to build over the next few months/year or so (about 300 systems) so it would be great to use the install script rather than having to manually install them all.
          Try again now. I updated the script for 3.7.x
            It will be released very soon. Bear in mind that v4 will require a new license however.
              Robmalone @Jared Wiltshire
              @jared-wiltshire Thanks Jared. The install seemed to work but I can't access the GUI. Should I see mango running as a service after starting it?```
              powerpoint@powerpoint-UltraPoint:~$ service --status-all
              [ + ] acpid
              [ - ] alsa-utils
              [ - ] anacron
              [ + ] apparmor
              [ + ] apport
              [ + ] avahi-daemon
              [ - ] bluetooth
              [ - ] console-setup.sh
              [ + ] cron
              [ + ] cups
              [ + ] cups-browsed
              [ + ] dbus
              [ - ] dns-clean
              [ + ] gdm3
              [ + ] grub-common
              [ - ] hwclock.sh
              [ + ] irqbalance
              [ + ] kerneloops
              [ - ] keyboard-setup.sh
              [ + ] kmod
              [ - ] lvm2
              [ + ] lvm2-lvmetad
              [ + ] lvm2-lvmpolld
              [ + ] network-manager
              [ + ] networking
              [ - ] plymouth
              [ - ] plymouth-log
              [ - ] pppd-dns
              [ + ] procps
              [ - ] rsync
              [ + ] rsyslog
              [ - ] saned
              [ + ] speech-dispatcher
              [ - ] spice-vdagent
              [ + ] udev
              [ + ] ufw
              [ + ] unattended-upgrades
              [ - ] uuidd
              [ + ] whoopsie
              [ - ] x11-common
                @robmalone The install script installs Mango as a systemd service but does not start it.
                See bottom of https://docs-v3.mango-os.com/linux-installation to check the status of the service, start/stop commands.
                  @jared-wiltshire Yes I did start it with systemctl start mango
                  When I check the status i get the following:
                  powerpoint@powerpoint-UltraPoint:~$ systemctl status mango
                  ā— mango.service - Mango Automation
                     Loaded: loaded (/opt/mango/overrides/mango.service; enabled; vendor preset: enabled)
                     Active: active (running) since Tue 2021-07-13 17:49:53 IST; 38s ago
                    Process: 2538 ExecStart=/opt/mango/bin/start-mango.sh (code=exited, status=0/SUCCESS)
                   Main PID: 2541 (java)
                      Tasks: 24 (limit: 4447)
                     CGroup: /system.slice/mango.service
                             └─2541 /snap/openjdk/321/jdk/bin/java -server -Dma.home=/opt/mango com.serotonin.m2m2.Main
                  Jul 13 17:49:53 powerpoint-UltraPoint start-mango.sh[2538]: Starting Mango Automation
                  Jul 13 17:49:53 powerpoint-UltraPoint start-mango.sh[2538]: Mango Automation started with process ID:  2541
                  Jul 13 17:49:53 powerpoint-UltraPoint systemd[1]: Started Mango Automation.
                  Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: Unable to determine the machine id
                  Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: FATAL (com.serotonin.m2m2.Lifecycle.loadLic:592) - Unable to determine the machine
                  Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: ERROR (com.serotonin.m2m2.Main.main:162) - Error during initialization
                  Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: java.lang.RuntimeException: Unable to determine the machine id
                  Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]:         at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:595) ~[ma-priv-3.7.
                  Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]:         at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:277) ~[ma-priv-3
                  Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]:         at com.serotonin.m2m2.Main.main(Main.java:159) ~[ma-priv-3.7.7.jar:?]
                    @robmalone It seems to be installed but its crashing on start. Post your full ma.log file.
                    I would try installing a different JDK, not inside a snap.
                    • G Offline
                      Gordoe @Jared Wiltshire
                      @jared-wiltshire
                      I'm receiving the same error on Ubuntu 20.04LTS
                      Jul 13 18:45:04 onxl4549 start-mango.sh[832]: Starting Mango Automation
                      Jul 13 18:45:04 onxl4549 start-mango.sh[832]: Mango Automation started with process ID: 1020
                      Jul 13 18:45:04 onxl4549 systemd[1]: Started SBIO dTwins.
                      Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: Unable to determine the machine id
                      Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: FATAL (com.serotonin.m2m2.Lifecycle.loadLic:592) - Unable to determine the machine id
                      Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: ERROR (com.serotonin.m2m2.Main.main:162) - Error during initialization
                      Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: java.lang.RuntimeException: Unable to determine the machine id
                      Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:595) ~[ma-priv-3.7.7.jar:?]
                      Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:277) ~[ma-priv-3.7.7.jar:?]
                      Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: at com.serotonin.m2m2.Main.main(Main.java:159) ~[ma-priv-3.7.7.jar:?]
                      • G Offline
                        Gordoe @Gordoe
                        with the contents of ma.log
                        INFO 2021-07-13T18:53:09,828 (com.serotonin.m2m2.Lifecycle.loadLic:583) - Checking license...
                        WARN 2021-07-13T18:53:09,872 (com.serotonin.m2m2.CoreLicenseDefinition.getSpecificGuid:338) - Host exception:
                        java.io.FileNotFoundException: /opt/dTwin/.ma (No such file or directory)
                        at java.io.FileOutputStream.open0(Native Method) ~[?:?]
                        at java.io.FileOutputStream.open(FileOutputStream.java:298) ~[?:?]
                        at java.io.FileOutputStream.<init>(FileOutputStream.java:237) ~[?:?]
                        at java.io.FileOutputStream.<init>(FileOutputStream.java:187) ~[?:?]
                        at java.io.FileWriter.<init>(FileWriter.java:96) ~[?:?]
                        at com.serotonin.m2m2.host.DefaultHost.guid(DefaultHost.java:69) ~[ma-priv-3.7.7.jar:?]
                        at com.serotonin.m2m2.CoreLicenseDefinition.getSpecificGuid(CoreLicenseDefinition.java:333) ~[ma-priv-3.7.7.jar:?]
                        at com.serotonin.m2m2.CoreLicenseDefinition.guid(CoreLicenseDefinition.java:317) ~[ma-priv-3.7.7.jar:?]
                        at com.serotonin.m2m2.CoreLicenseDefinition.initializeLic(CoreLicenseDefinition.java:117) ~[ma-priv-3.7.7.jar:?]
                        at com.serotonin.m2m2.CoreLicenseDefinition.licenseCheck(CoreLicenseDefinition.java:101) ~[ma-priv-3.7.7.jar:?]
                        at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:659) ~[ma-priv-3.7.7.jar:?]
                        at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:587) ~[ma-priv-3.7.7.jar:?]
                        FATAL 2021-07-13T18:53:09,872 (com.serotonin.m2m2.Lifecycle.loadLic:592) - Unable to determine the machine id
                        ERROR 2021-07-13T18:53:09,872 (com.serotonin.m2m2.Main.main:162) - Error during initialization
                        INFO 2021-07-13T18:53:09,873 (com.serotonin.m2m2.Lifecycle.terminate:400) - Mango Lifecycle terminating...
                        INFO 2021-07-13T18:53:09,915 (com.serotonin.m2m2.Lifecycle.terminate:550) - Mango Lifecycle terminated.
                          @Gordoe What user is mango running as? The install script should ask you to create a user. What is that user's home directory? Does that user have write permission for their own home directory?
                          • G Offline
                            @jared-wiltshire
                            It's running as Mango.
                            I'll start a new post as I don't want to hijack this one. Same error but not from the installation script.
