    Ubuntu 18 Install failed
    18 Posts 4 Posters 13.4k Views 3 Watching
      Robmalone @tungthanh500
      @tungthanh500 I assumed since the files were being overwritten I didn't need to remove the directories. I removed them and that did the trick. Still can get v3 to work though. Guess I'll just use 4. Thanks for your help.
        @Robmalone
        If you still want to use v3.7.x then you can try this. Where it says to -
        curl -o install-mango.sh https://raw.githubusercontent.com/infiniteautomation/ma-core-public/main/Core/bin/install-mango.sh
        Try this instead -
        curl -o install-mango.sh https://raw.githubusercontent.com/infiniteautomation/ma-core-public/3.7.x/Core/scripts/install-mango.sh
        When it asks for a version, answer 3.7.7
        Alternatively, try the manual installation instructions - https://docs-v3.mango-os.com/linux-installation
          Robmalone @Jared Wiltshire
          @jared-wiltshire Installation stops at
          /opt/mango/bin/genkey.sh: 1: /opt/mango/bin/genkey.sh: 404:: not found
          I will have a lot of these to build over the next few months/year or so (about 300 systems) so it would be great to use the install script rather than having to manually install them all.
          V4 installed fine but @CraigWeb recommend I stick to v3.7.
          T Jared WiltshireJ 2 Replies Last reply Reply Quote 0
          • T Offline
            tungthanh500 @Robmalone
            @robmalone Can you solve the problem with V4? If you cannot access the system on localhost, please try changing port to 8443, (but don't forget to forward that port).
              Hi @tungthanh500 Yes I can get V4 working but as it's not officially released yet I've been advised to use V3.7.7.
              • T Offline
                @robmalone I think I also have to fall back to 3.7.7 because I face point unreliable. Not sure how to fix it. No correct answer in forum yet
                  Jared Wiltshire @Robmalone
                  @robmalone said in Ubuntu 18 Install failed:
                  Try again now. I updated the script for 3.7.x
                    It will be released very soon. Bear in mind that v4 will require a new license however.
                      @jared-wiltshire Thanks Jared. The install seemed to work but I can't access the GUI. Should I see mango running as a service after starting it?```
                      powerpoint@powerpoint-UltraPoint:~$ service --status-all
                      [ + ] acpid
                      [ - ] alsa-utils
                      [ - ] anacron
                      [ + ] apparmor
                      [ + ] apport
                      [ + ] avahi-daemon
                      [ - ] bluetooth
                      [ - ] console-setup.sh
                      [ + ] cron
                      [ + ] cups
                      [ + ] cups-browsed
                      [ + ] dbus
                      [ - ] dns-clean
                      [ + ] gdm3
                      [ + ] grub-common
                      [ - ] hwclock.sh
                      [ + ] irqbalance
                      [ + ] kerneloops
                      [ - ] keyboard-setup.sh
                      [ + ] kmod
                      [ - ] lvm2
                      [ + ] lvm2-lvmetad
                      [ + ] lvm2-lvmpolld
                      [ + ] network-manager
                      [ + ] networking
                      [ - ] plymouth
                      [ - ] plymouth-log
                      [ - ] pppd-dns
                      [ + ] procps
                      [ - ] rsync
                      [ + ] rsyslog
                      [ - ] saned
                      [ + ] speech-dispatcher
                      [ - ] spice-vdagent
                      [ + ] udev
                      [ + ] ufw
                      [ + ] unattended-upgrades
                      [ - ] uuidd
                      [ + ] whoopsie
                      [ - ] x11-common
                        @robmalone The install script installs Mango as a systemd service but does not start it.
                        See bottom of https://docs-v3.mango-os.com/linux-installation to check the status of the service, start/stop commands.
                          @jared-wiltshire Yes I did start it with systemctl start mango
                          When I check the status i get the following:
                          powerpoint@powerpoint-UltraPoint:~$ systemctl status mango
                          ā— mango.service - Mango Automation
                             Loaded: loaded (/opt/mango/overrides/mango.service; enabled; vendor preset: enabled)
                             Active: active (running) since Tue 2021-07-13 17:49:53 IST; 38s ago
                            Process: 2538 ExecStart=/opt/mango/bin/start-mango.sh (code=exited, status=0/SUCCESS)
                           Main PID: 2541 (java)
                              Tasks: 24 (limit: 4447)
                             CGroup: /system.slice/mango.service
                                     └─2541 /snap/openjdk/321/jdk/bin/java -server -Dma.home=/opt/mango com.serotonin.m2m2.Main
                          Jul 13 17:49:53 powerpoint-UltraPoint start-mango.sh[2538]: Starting Mango Automation
                          Jul 13 17:49:53 powerpoint-UltraPoint start-mango.sh[2538]: Mango Automation started with process ID:  2541
                          Jul 13 17:49:53 powerpoint-UltraPoint systemd[1]: Started Mango Automation.
                          Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: Unable to determine the machine id
                          Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: FATAL (com.serotonin.m2m2.Lifecycle.loadLic:592) - Unable to determine the machine
                          Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: ERROR (com.serotonin.m2m2.Main.main:162) - Error during initialization
                          Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]: java.lang.RuntimeException: Unable to determine the machine id
                          Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]:         at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:595) ~[ma-priv-3.7.
                          Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]:         at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:277) ~[ma-priv-3
                          Jul 13 17:50:04 powerpoint-UltraPoint start-mango.sh[2538]:         at com.serotonin.m2m2.Main.main(Main.java:159) ~[ma-priv-3.7.7.jar:?]
                            @robmalone It seems to be installed but its crashing on start. Post your full ma.log file.
                            I would try installing a different JDK, not inside a snap.
                            • G Offline
                              Gordoe @Jared Wiltshire
                              @jared-wiltshire
                              I'm receiving the same error on Ubuntu 20.04LTS
                              Jul 13 18:45:04 onxl4549 start-mango.sh[832]: Starting Mango Automation
                              Jul 13 18:45:04 onxl4549 start-mango.sh[832]: Mango Automation started with process ID: 1020
                              Jul 13 18:45:04 onxl4549 systemd[1]: Started SBIO dTwins.
                              Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: Unable to determine the machine id
                              Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: FATAL (com.serotonin.m2m2.Lifecycle.loadLic:592) - Unable to determine the machine id
                              Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: ERROR (com.serotonin.m2m2.Main.main:162) - Error during initialization
                              Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: java.lang.RuntimeException: Unable to determine the machine id
                              Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:595) ~[ma-priv-3.7.7.jar:?]
                              Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:277) ~[ma-priv-3.7.7.jar:?]
                              Jul 13 18:46:55 onxl4549 start-mango.sh[1020]: at com.serotonin.m2m2.Main.main(Main.java:159) ~[ma-priv-3.7.7.jar:?]
                              • G Offline
                                Gordoe @Gordoe
                                with the contents of ma.log
                                INFO 2021-07-13T18:53:09,828 (com.serotonin.m2m2.Lifecycle.loadLic:583) - Checking license...
                                WARN 2021-07-13T18:53:09,872 (com.serotonin.m2m2.CoreLicenseDefinition.getSpecificGuid:338) - Host exception:
                                java.io.FileNotFoundException: /opt/dTwin/.ma (No such file or directory)
                                at java.io.FileOutputStream.open0(Native Method) ~[?:?]
                                at java.io.FileOutputStream.open(FileOutputStream.java:298) ~[?:?]
                                at java.io.FileOutputStream.<init>(FileOutputStream.java:237) ~[?:?]
                                at java.io.FileOutputStream.<init>(FileOutputStream.java:187) ~[?:?]
                                at java.io.FileWriter.<init>(FileWriter.java:96) ~[?:?]
                                at com.serotonin.m2m2.host.DefaultHost.guid(DefaultHost.java:69) ~[ma-priv-3.7.7.jar:?]
                                at com.serotonin.m2m2.CoreLicenseDefinition.getSpecificGuid(CoreLicenseDefinition.java:333) ~[ma-priv-3.7.7.jar:?]
                                at com.serotonin.m2m2.CoreLicenseDefinition.guid(CoreLicenseDefinition.java:317) ~[ma-priv-3.7.7.jar:?]
                                at com.serotonin.m2m2.CoreLicenseDefinition.initializeLic(CoreLicenseDefinition.java:117) ~[ma-priv-3.7.7.jar:?]
                                at com.serotonin.m2m2.CoreLicenseDefinition.licenseCheck(CoreLicenseDefinition.java:101) ~[ma-priv-3.7.7.jar:?]
                                at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:659) ~[ma-priv-3.7.7.jar:?]
                                at com.serotonin.m2m2.Lifecycle.loadLic(Lifecycle.java:587) ~[ma-priv-3.7.7.jar:?]
                                FATAL 2021-07-13T18:53:09,872 (com.serotonin.m2m2.Lifecycle.loadLic:592) - Unable to determine the machine id
                                ERROR 2021-07-13T18:53:09,872 (com.serotonin.m2m2.Main.main:162) - Error during initialization
                                INFO 2021-07-13T18:53:09,873 (com.serotonin.m2m2.Lifecycle.terminate:400) - Mango Lifecycle terminating...
                                INFO 2021-07-13T18:53:09,915 (com.serotonin.m2m2.Lifecycle.terminate:550) - Mango Lifecycle terminated.
                                  @Gordoe What user is mango running as? The install script should ask you to create a user. What is that user's home directory? Does that user have write permission for their own home directory?
                                  • G Offline
                                    @jared-wiltshire
                                    It's running as Mango.
                                    I'll start a new post as I don't want to hijack this one. Same error but not from the installation script.
