    Why did wind sensor canot received the data via modbus serial port.
    26 Posts 4 Posters 24.0k Views 1 Watching
    • E Offline
      edmond
      as show in the attachment . I use other device via modbus ip to received data .
      and display mango and modbus scan software as below.
      • E Offline
        edmond
        now I modify the connection to rs 485 .
        and I test again
        display "argument type mismatch"
        many data 32 bit float.and mango have no this option.
        • jeremyhJ Offline
          jeremyh
          32 bit = 4 byte
          and I test again
          What did you expect? That your RS232 adapter would turn into a RS485 adapter? :shock:
          • E Offline
            edmond
            in wind sensor side ,have two type:rs422 or rs485,
            before the connection always is rs 422, and I change a adapter to rs485 to test to see have any changing.
            • E Offline
              edmond
              and I test serval times.
              and display"Exception from modbus master:CRC mismatch:given=1536,calc=8432"
              • hussamH Offline
                hussam
                as your attachment, the modscan32 don't receive any value?don't you know what's mean valid slave responses:0?
                • E Offline
                  edmond
                  if in mango,
                  What do this mean "nd I test serval times.
                    This means that you got a response but the CRC did not match so the message was discarded.
                    A CRC of 1536 was given but the calculated CRC was 8432. This indicated that the message might have been corrupted.
                    If you don't know what a CRC is then you should do some research on the Modbus spec and will probably clear that up.
                    • E Offline
                      edmond
                      yes,I change to wind sensor adapter from rs 422 to rs485 adapter,and display above the message."exception from modbus master:CRC mismatch:given=1536,calc=8432"
                      • E Offline
                        edmond
                        How to setting can display normal value.
                        will not display"Exception from modbus master:CRC mismatch:given=1536,calc=8432"
                        BR
                          I don't think that's a question that anyone here can answer. It could be noise on your network or something else.
