    Why did wind sensor canot received the data via modbus serial port.
    26 Posts 4 Posters 24.0k Views 1 Watching
    • E Offline
      edmond
      yes,When I click" read data "button and the usb(virual com port) adapter will flashes.but no data return and display"No response from slave 1".
      • jeremyhJ Offline
        jeremyh
        In one of your other threads (good luck finding it) I pointed out that you need to actually change the weather station to Modbus mode before you can read data using Modbus. Have you definitely done that?
        • E Offline
          edmond
          yes.I am sure now the wind sensor mode is modbus mode. and I can received the data from modbus scan software. But mango is not ok.
          • jeremyhJ Offline
            jeremyh
            Show me where you are receiving the modbus data over serial using Modscan?
            @jeremyh said:
            @edmond said:
            and can received data use modscan32 software.
            Modscan doesn't receive any data..
            Your equipment is not set up correctly
            • E Offline
              edmond
              as show in the attachment . I use other device via modbus ip to received data .
              and display mango and modbus scan software as below.
              • E Offline
                edmond
                now I modify the connection to rs 485 .
                and I test again
                display "argument type mismatch"
                many data 32 bit float.and mango have no this option.
                • jeremyhJ Offline
                  jeremyh
                  32 bit = 4 byte
                  and I test again
                  What did you expect? That your RS232 adapter would turn into a RS485 adapter? :shock:
                  • E Offline
                    edmond
                    in wind sensor side ,have two type:rs422 or rs485,
                    before the connection always is rs 422, and I change a adapter to rs485 to test to see have any changing.
                    • E Offline
                      edmond
                      and I test serval times.
                      and display"Exception from modbus master:CRC mismatch:given=1536,calc=8432"
                      • hussamH Offline
                        hussam
                        as your attachment, the modscan32 don't receive any value?don't you know what's mean valid slave responses:0?
                        • E Offline
                          edmond
                          if in mango,
                          What do this mean "nd I test serval times.
                            This means that you got a response but the CRC did not match so the message was discarded.
                            A CRC of 1536 was given but the calculated CRC was 8432. This indicated that the message might have been corrupted.
                            If you don't know what a CRC is then you should do some research on the Modbus spec and will probably clear that up.
                            • E Offline
                              edmond
                              yes,I change to wind sensor adapter from rs 422 to rs485 adapter,and display above the message."exception from modbus master:CRC mismatch:given=1536,calc=8432"
                              • E Offline
                                edmond
                                How to setting can display normal value.
                                will not display"Exception from modbus master:CRC mismatch:given=1536,calc=8432"
                                BR
                                  I don't think that's a question that anyone here can answer. It could be noise on your network or something else.
