    Installing Windows Service
    25 Posts 5 Posters 37.6k Views 5 Watching
    • W Offline
      Wingnut2.0
      javaws.jar is not included in AdoptOpenJDK which is required for YAJSW to work.
        Thanks Wingnut
          Rodrigo
          Thanks Matt / Wingnut
          Can you guys elaborate a little on how to fix it?
          Best,
          Rodrigo
          • W Offline
            Wingnut2.0
            Hello Rodrigo,
            I have found that if you want to run a version of 3.7.7 or lower on Windows as a service your best bet is Installing Oracle JDK 8. I know it doesn't necessarily follow the recommendation's here, but it allows you to run as a service.
            https://docs-v3.mango-os.com/installing-java
            • For Mango versions 3.6.x and higher we recommend using the latest version of Adopt OpenJDK.
            • For Mango versions 3.5.x and lower you should use JDK 8 (OpenJDK 8 should work however we primarily tested on Oracle JDK). Older versions of Mango may not work correctly if you use a newer JDK.
            • OpenJDK 8 builds for ARM 32 processors seem to perform extremely poorly, we suggest avoiding this JDK
            Another option that I haven't looked into is explained here.
            https://docs.microsoft.com/en-us/powershell/module/microsoft.powershell.management/new-service?view=powershell-7
              Rodrigo
              Wingnut,
              You think I should buy an Oracle JDK 8 license?
              Best,
              Rodrigo
              • W Offline
                Wingnut2.0
                Hello Rodrigo,
                Here is another alternative. This works on windows with AdoptOpenJDK 11.
                https://nssm.cc/
                NSSM - the Non-Sucking Service Manager
                  @wingnut2-0 said in Installing Windows Service:
                  I laughed a little too hard at that one
                    Rodrigo
                    hahaha
                    I will try to use this and get back to you with news.
                    Thanks guys!
                    Best,
                    Rodrigo
                    • W Offline
                      Wingnut2.0
                      When changing to a service on windows your GUID will more than likely change (Thank you Dave)
                      This will require a request to transfer you license from the old GUID to the new one.
                      If you run into that - below is the link to request the transfer.
                      https://mango-os.com/license-help
                        Rodrigo
                        Hi guys,
                        I have not been able to solve this. I don't know how to use this https://nssm.cc/
                        What can I do?
                        @Wingnut2-0 you recommended Oracle JDK 8, is it free for this use?
                        Rodrigo
                        • T Offline
                          tungthanh500
                          Hi, I just installed Mango V4 latest beta. However, Mango service cannot start automatically. I have to run mango.cmd in command promt as administrator.
                          When I tried to start the service in Services.msc, error 1067 occurrs.
                          I already installed AdoptJDK 11 and assign environment variable.
                          dschaibleD 1 Reply Last reply Reply Quote 0
                          • dschaibleD Offline
                            dschaible @tungthanh500
                            @tungthanh500
                            Did you check this page: https://docs-v4.mango-os.com/windows-installation
                            Are you seeing any errors in eventviewer that you can share?
                            • T Offline
                              tungthanh500 @dschaible
                              @dschaible said in Installing Windows Service:
                              @tungthanh500
                              I just found out the reason. Of course I follow above instruction but instead of installing mango in C drive, I created a folder named SCADA in C:\Program Files\ and have mango and mango_data folder in SCADA folder. Maybe the name Program Files is not easy to identify with windows services. This should be added in the instruction.
