    Installing Windows Service
    25 Posts 5 Posters 38.0k Views 5 Watching
      Rodrigo
      Hi Matt,
      I was referring to Installing Services, if I understand correctly you are talking about the Mango Installation itself, right?
      I had no problem installing Mango, I'm talking about the yajsw file to install a service for Mango to autostart with Windows
      Rodrigo
        Sorry Rodrigo, I completely missed your question!
        Windows I would imagine would be the same. I can't see how that changes.
        Apologies, I'm a linux guy hence I assumed you meant with the installation process.
        I've just checked my system. all is the same, you should have no issues - sorry for the runaround!
          Rodrigo
          No worries!
          Thanks for the help Matt!
          Best,
          Rodrigo
            Rodrigo
            Hi guys,
            Still with problems, installing the service i get this error
            it says: ""java"" not recognized as an internal or external command, operable program or batch file
            I have installed the AdoptOpenJDK
            Can you give me a hand?
            Thanks!
            Rodrigo
              Look up adding java as an environment variable for windows.
              It will under advanced in tje system properties panel
                Rodrigo
                Hi Matt,
                Thanks for the help, I have been able to install the service, but it does not work, it starts and stops alone and when is running I can't access mango.
                Any thoughts?
                Thanks!
                Rodrigo
                  Rodrigo
                  I have found this in the wrapper at C:\Mango\yajsw\log\wrapper
                  WARNING|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|YAJSW: yajsw-stable-11.11
                  WARNING|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|OS   : Windows 10/10.0/amd64
                  WARNING|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|JVM  : AdoptOpenJDK/11.0.9/C:\Program Files\AdoptOpenJDK\jdk-11.0.9.11-hotspot/64
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|ahessian jmx service bound to port 15002
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|working dir C:\Mango\bin
                  [null - INFO] 20-11-05 12:29:58 Error in createScript scripts/trayMessage.gv
                  Exception in org.rzo.yajsw.log.MyLogger: Could not determine the last modified timestamp of "file:///C:/WINDOWS/system32/scripts/trayMessage.gv" because it does not exist.
                    org.apache.commons.vfs2.provider.DefaultFileContent.getLastModifiedTime(DefaultFileContent.java:165)
                    org.rzo.yajsw.script.GroovyScript.getScriptInstance(GroovyScript.java:103)
                    org.rzo.yajsw.script.GroovyScript.<init>(GroovyScript.java:77)
                    org.rzo.yajsw.script.ScriptFactory.createScript(ScriptFactory.java:45)
                    org.rzo.yajsw.wrapper.AbstractWrappedProcess.getTriggerScript(AbstractWrappedProcess.java:1853)
                    org.rzo.yajsw.wrapper.AbstractWrappedProcess.getTriggerActions(AbstractWrappedProcess.java:1738)
                    org.rzo.yajsw.wrapper.AbstractWrappedProcess.startInternal(AbstractWrappedProcess.java:1044)
                    org.rzo.yajsw.wrapper.AbstractWrappedProcess.start(AbstractWrappedProcess.java:923)
                    org.rzo.yajsw.wrapper.WrappedProcessList.startAll(WrappedProcessList.java:11)
                    org.rzo.yajsw.app.WrapperMainServiceWin$1.run(WrapperMainServiceWin.java:153)
                    java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
                    java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
                    java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
                    java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
                    java.base/java.lang.Thread.run(Thread.java:834)
                   INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|error initializing script scripts/trayMessage.gv
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|started process with pid 7976
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|restart process due to default exit code rule
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|restart internal RUNNING
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|stopping process with pid/timeout 7976 45000
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:59|process exit code: 999
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|working dir C:\Mango\bin
                  [null - INFO] 20-11-05 12:30:04 Error in createScript scripts/trayMessage.gv
                    org.rzo.yajsw.wrapper.AbstractWrappedProcess.restartInternal(AbstractWrappedProcess.java:2565)
                    org.rzo.yajsw.wrapper.WrappedJavaProcess$2.fire(WrappedJavaProcess.java:557)
                    org.rzo.yajsw.controller.AbstractController.handleListeners(AbstractController.java:108)
                    org.rzo.yajsw.controller.AbstractController.setState(AbstractController.java:146)
                    org.rzo.yajsw.controller.jvm.JVMController$4$1.run(JVMController.java:701)
                   INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|error initializing script scripts/trayMessage.gv
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|started process with pid 9660
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|restart process due to default exit code rule
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|restart internal RUNNING
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|stopping process with pid/timeout 9660 45000
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:05|process exit code: 999
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:10|working dir C:\Mango\bin
                  [null - INFO] 20-11-05 12:30:10 Error in createScript scripts/trayMessage.gv
                   INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:10|error initializing script scripts/trayMessage.gv
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:10|started process with pid 8796
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:11|restart process due to default exit code rule
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:11|restart internal RUNNING
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:11|stopping process with pid/timeout 8796 45000
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:11|process exit code: 999
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:16|working dir C:\Mango\bin
                  [null - INFO] 20-11-05 12:30:16 Error in createScript scripts/trayMessage.gv
                   INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:16|error initializing script scripts/trayMessage.gv
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:16|started process with pid 2964
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:17|restart process due to default exit code rule
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:17|restart internal RUNNING
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:17|stopping process with pid/timeout 2964 45000
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:17|process exit code: 999
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:22|working dir C:\Mango\bin
                  [null - INFO] 20-11-05 12:30:22 Error in createScript scripts/trayMessage.gv
                   INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:22|error initializing script scripts/trayMessage.gv
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:22|started process with pid 9584
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:23|restart process due to default exit code rule
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:23|restart internal RUNNING
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:23|stopping process with pid/timeout 9584 45000
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:23|process exit code: 999
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|working dir C:\Mango\bin
                  [null - INFO] 20-11-05 12:30:29 Error in createScript scripts/trayMessage.gv
                   INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|error initializing script scripts/trayMessage.gv
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|started process with pid 892
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|too many restarts
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|process not in state RUNNING -> Delaying stop
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|calling onStop
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|Win service stop - timeout: 30000
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|Win service wrapper.control -> stopping application
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|Win service stop - after shutdown
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|Win service stop - before notify
                  INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|Win service terminated
                    Looks like a missing file to me
                    • W Offline
                      Wingnut2.0
                      javaws.jar is not included in AdoptOpenJDK which is required for YAJSW to work.
                        Thanks Wingnut
                          Rodrigo
                          Thanks Matt / Wingnut
                          Can you guys elaborate a little on how to fix it?
                          Best,
                          Rodrigo
                          • W Offline
                            Wingnut2.0
                            Hello Rodrigo,
                            I have found that if you want to run a version of 3.7.7 or lower on Windows as a service your best bet is Installing Oracle JDK 8. I know it doesn't necessarily follow the recommendation's here, but it allows you to run as a service.
                            https://docs-v3.mango-os.com/installing-java
                            • For Mango versions 3.6.x and higher we recommend using the latest version of Adopt OpenJDK.
                            • For Mango versions 3.5.x and lower you should use JDK 8 (OpenJDK 8 should work however we primarily tested on Oracle JDK). Older versions of Mango may not work correctly if you use a newer JDK.
                            • OpenJDK 8 builds for ARM 32 processors seem to perform extremely poorly, we suggest avoiding this JDK
                            Another option that I haven't looked into is explained here.
                            https://docs.microsoft.com/en-us/powershell/module/microsoft.powershell.management/new-service?view=powershell-7
                              Rodrigo
                              Wingnut,
                              You think I should buy an Oracle JDK 8 license?
                              Best,
                              Rodrigo
                              • W Offline
                                Wingnut2.0
                                Hello Rodrigo,
                                Here is another alternative. This works on windows with AdoptOpenJDK 11.
                                https://nssm.cc/
                                NSSM - the Non-Sucking Service Manager
                                  @wingnut2-0 said in Installing Windows Service:
                                  I laughed a little too hard at that one
                                    Rodrigo
                                    hahaha
                                    I will try to use this and get back to you with news.
                                    Thanks guys!
                                    Best,
                                    Rodrigo
                                    • W Offline
                                      Wingnut2.0
                                      When changing to a service on windows your GUID will more than likely change (Thank you Dave)
                                      This will require a request to transfer you license from the old GUID to the new one.
                                      If you run into that - below is the link to request the transfer.
                                      https://mango-os.com/license-help
                                        Rodrigo
                                        Hi guys,
                                        I have not been able to solve this. I don't know how to use this https://nssm.cc/
                                        What can I do?
                                        @Wingnut2-0 you recommended Oracle JDK 8, is it free for this use?
                                        Rodrigo
                                        • T Offline
                                          tungthanh500
                                          Hi, I just installed Mango V4 latest beta. However, Mango service cannot start automatically. I have to run mango.cmd in command promt as administrator.
                                          When I tried to start the service in Services.msc, error 1067 occurrs.
                                          I already installed AdoptJDK 11 and assign environment variable.
                                          dschaibleD 1 Reply Last reply Reply Quote 0
                                          • dschaibleD Offline
                                            dschaible @tungthanh500
                                            @tungthanh500
                                            Did you check this page: https://docs-v4.mango-os.com/windows-installation
                                            Are you seeing any errors in eventviewer that you can share?
