    Installing Windows Service
    25 Posts 5 Posters 38.0k Views 5 Watching
    • W Offline
      Wingnut2.0
      Hello Rodrigo,
      I have found that if you want to run a version of 3.7.7 or lower on Windows as a service your best bet is Installing Oracle JDK 8. I know it doesn't necessarily follow the recommendation's here, but it allows you to run as a service.
      https://docs-v3.mango-os.com/installing-java
      • For Mango versions 3.6.x and higher we recommend using the latest version of Adopt OpenJDK.
      • For Mango versions 3.5.x and lower you should use JDK 8 (OpenJDK 8 should work however we primarily tested on Oracle JDK). Older versions of Mango may not work correctly if you use a newer JDK.
      • OpenJDK 8 builds for ARM 32 processors seem to perform extremely poorly, we suggest avoiding this JDK
      Another option that I haven't looked into is explained here.
      https://docs.microsoft.com/en-us/powershell/module/microsoft.powershell.management/new-service?view=powershell-7
        Rodrigo
        Wingnut,
        You think I should buy an Oracle JDK 8 license?
        Best,
        Rodrigo
        • W Offline
          Wingnut2.0
          Hello Rodrigo,
          Here is another alternative. This works on windows with AdoptOpenJDK 11.
          https://nssm.cc/
          NSSM - the Non-Sucking Service Manager
            @wingnut2-0 said in Installing Windows Service:
            I laughed a little too hard at that one
              Rodrigo
              hahaha
              I will try to use this and get back to you with news.
              Thanks guys!
              Best,
              Rodrigo
              • W Offline
                Wingnut2.0
                When changing to a service on windows your GUID will more than likely change (Thank you Dave)
                This will require a request to transfer you license from the old GUID to the new one.
                If you run into that - below is the link to request the transfer.
                https://mango-os.com/license-help
                  Rodrigo
                  Hi guys,
                  I have not been able to solve this. I don't know how to use this https://nssm.cc/
                  What can I do?
                  @Wingnut2-0 you recommended Oracle JDK 8, is it free for this use?
                  Rodrigo
                  • T Offline
                    tungthanh500
                    Hi, I just installed Mango V4 latest beta. However, Mango service cannot start automatically. I have to run mango.cmd in command promt as administrator.
                    When I tried to start the service in Services.msc, error 1067 occurrs.
                    I already installed AdoptJDK 11 and assign environment variable.
                    dschaibleD 1 Reply Last reply Reply Quote 0
                    • dschaibleD Offline
                      dschaible @tungthanh500
                      @tungthanh500
                      Did you check this page: https://docs-v4.mango-os.com/windows-installation
                      Are you seeing any errors in eventviewer that you can share?
                      • T Offline
                        tungthanh500 @dschaible
                        @dschaible said in Installing Windows Service:
                        @tungthanh500
                        I just found out the reason. Of course I follow above instruction but instead of installing mango in C drive, I created a folder named SCADA in C:\Program Files\ and have mango and mango_data folder in SCADA folder. Maybe the name Program Files is not easy to identify with windows services. This should be added in the instruction.
