    Installing Windows Service
    25 Posts 5 Posters 38.0k Views 5 Watching
      It was more for understanding the type of AdoptJDK version to use, that and the launcher, that's all.
      The rest of windows should be the same.
      Let me know what part exactly you are a bit lost with.
        Rodrigo
        Hi Matt,
        I was referring to Installing Services, if I understand correctly you are talking about the Mango Installation itself, right?
        I had no problem installing Mango, I'm talking about the yajsw file to install a service for Mango to autostart with Windows
        Rodrigo
          Sorry Rodrigo, I completely missed your question!
          Windows I would imagine would be the same. I can't see how that changes.
          Apologies, I'm a linux guy hence I assumed you meant with the installation process.
          I've just checked my system. all is the same, you should have no issues - sorry for the runaround!
            Rodrigo
            No worries!
            Thanks for the help Matt!
            Best,
            Rodrigo
              Rodrigo
              Hi guys,
              Still with problems, installing the service i get this error
              it says: ""java"" not recognized as an internal or external command, operable program or batch file
              I have installed the AdoptOpenJDK
              Can you give me a hand?
              Thanks!
              Rodrigo
                Look up adding java as an environment variable for windows.
                It will under advanced in tje system properties panel
                  Rodrigo
                  Hi Matt,
                  Thanks for the help, I have been able to install the service, but it does not work, it starts and stops alone and when is running I can't access mango.
                  Any thoughts?
                  Thanks!
                  Rodrigo
                    Rodrigo
                    I have found this in the wrapper at C:\Mango\yajsw\log\wrapper
                    WARNING|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|YAJSW: yajsw-stable-11.11
                    WARNING|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|OS   : Windows 10/10.0/amd64
                    WARNING|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|JVM  : AdoptOpenJDK/11.0.9/C:\Program Files\AdoptOpenJDK\jdk-11.0.9.11-hotspot/64
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|ahessian jmx service bound to port 15002
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|working dir C:\Mango\bin
                    [null - INFO] 20-11-05 12:29:58 Error in createScript scripts/trayMessage.gv
                    Exception in org.rzo.yajsw.log.MyLogger: Could not determine the last modified timestamp of "file:///C:/WINDOWS/system32/scripts/trayMessage.gv" because it does not exist.
                      org.apache.commons.vfs2.provider.DefaultFileContent.getLastModifiedTime(DefaultFileContent.java:165)
                      org.rzo.yajsw.script.GroovyScript.getScriptInstance(GroovyScript.java:103)
                      org.rzo.yajsw.script.GroovyScript.<init>(GroovyScript.java:77)
                      org.rzo.yajsw.script.ScriptFactory.createScript(ScriptFactory.java:45)
                      org.rzo.yajsw.wrapper.AbstractWrappedProcess.getTriggerScript(AbstractWrappedProcess.java:1853)
                      org.rzo.yajsw.wrapper.AbstractWrappedProcess.getTriggerActions(AbstractWrappedProcess.java:1738)
                      org.rzo.yajsw.wrapper.AbstractWrappedProcess.startInternal(AbstractWrappedProcess.java:1044)
                      org.rzo.yajsw.wrapper.AbstractWrappedProcess.start(AbstractWrappedProcess.java:923)
                      org.rzo.yajsw.wrapper.WrappedProcessList.startAll(WrappedProcessList.java:11)
                      org.rzo.yajsw.app.WrapperMainServiceWin$1.run(WrapperMainServiceWin.java:153)
                      java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
                      java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
                      java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
                      java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
                      java.base/java.lang.Thread.run(Thread.java:834)
                     INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|error initializing script scripts/trayMessage.gv
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|started process with pid 7976
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|restart process due to default exit code rule
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|restart internal RUNNING
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|stopping process with pid/timeout 7976 45000
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:59|process exit code: 999
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|working dir C:\Mango\bin
                    [null - INFO] 20-11-05 12:30:04 Error in createScript scripts/trayMessage.gv
                      org.rzo.yajsw.wrapper.AbstractWrappedProcess.restartInternal(AbstractWrappedProcess.java:2565)
                      org.rzo.yajsw.wrapper.WrappedJavaProcess$2.fire(WrappedJavaProcess.java:557)
                      org.rzo.yajsw.controller.AbstractController.handleListeners(AbstractController.java:108)
                      org.rzo.yajsw.controller.AbstractController.setState(AbstractController.java:146)
                      org.rzo.yajsw.controller.jvm.JVMController$4$1.run(JVMController.java:701)
                     INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|error initializing script scripts/trayMessage.gv
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|started process with pid 9660
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|restart process due to default exit code rule
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|restart internal RUNNING
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|stopping process with pid/timeout 9660 45000
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:05|process exit code: 999
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:10|working dir C:\Mango\bin
                    [null - INFO] 20-11-05 12:30:10 Error in createScript scripts/trayMessage.gv
                     INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:10|error initializing script scripts/trayMessage.gv
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:10|started process with pid 8796
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:11|restart process due to default exit code rule
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:11|restart internal RUNNING
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:11|stopping process with pid/timeout 8796 45000
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:11|process exit code: 999
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:16|working dir C:\Mango\bin
                    [null - INFO] 20-11-05 12:30:16 Error in createScript scripts/trayMessage.gv
                     INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:16|error initializing script scripts/trayMessage.gv
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:16|started process with pid 2964
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:17|restart process due to default exit code rule
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:17|restart internal RUNNING
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:17|stopping process with pid/timeout 2964 45000
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:17|process exit code: 999
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:22|working dir C:\Mango\bin
                    [null - INFO] 20-11-05 12:30:22 Error in createScript scripts/trayMessage.gv
                     INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:22|error initializing script scripts/trayMessage.gv
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:22|started process with pid 9584
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:23|restart process due to default exit code rule
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:23|restart internal RUNNING
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:23|stopping process with pid/timeout 9584 45000
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:23|process exit code: 999
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|working dir C:\Mango\bin
                    [null - INFO] 20-11-05 12:30:29 Error in createScript scripts/trayMessage.gv
                     INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|error initializing script scripts/trayMessage.gv
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|started process with pid 892
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|too many restarts
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|process not in state RUNNING -> Delaying stop
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|calling onStop
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|Win service stop - timeout: 30000
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|Win service wrapper.control -> stopping application
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|Win service stop - after shutdown
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|Win service stop - before notify
                    INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|Win service terminated
                      Looks like a missing file to me
                      • W Offline
                        Wingnut2.0
                        javaws.jar is not included in AdoptOpenJDK which is required for YAJSW to work.
                          Thanks Wingnut
                            Rodrigo
                            Thanks Matt / Wingnut
                            Can you guys elaborate a little on how to fix it?
                            Best,
                            Rodrigo
                            • W Offline
                              Wingnut2.0
                              Hello Rodrigo,
                              I have found that if you want to run a version of 3.7.7 or lower on Windows as a service your best bet is Installing Oracle JDK 8. I know it doesn't necessarily follow the recommendation's here, but it allows you to run as a service.
                              https://docs-v3.mango-os.com/installing-java
                              • For Mango versions 3.6.x and higher we recommend using the latest version of Adopt OpenJDK.
                              • For Mango versions 3.5.x and lower you should use JDK 8 (OpenJDK 8 should work however we primarily tested on Oracle JDK). Older versions of Mango may not work correctly if you use a newer JDK.
                              • OpenJDK 8 builds for ARM 32 processors seem to perform extremely poorly, we suggest avoiding this JDK
                              Another option that I haven't looked into is explained here.
                              https://docs.microsoft.com/en-us/powershell/module/microsoft.powershell.management/new-service?view=powershell-7
                                Rodrigo
                                Wingnut,
                                You think I should buy an Oracle JDK 8 license?
                                Best,
                                Rodrigo
                                • W Offline
                                  Wingnut2.0
                                  Hello Rodrigo,
                                  Here is another alternative. This works on windows with AdoptOpenJDK 11.
                                  https://nssm.cc/
                                  NSSM - the Non-Sucking Service Manager
                                    @wingnut2-0 said in Installing Windows Service:
                                    I laughed a little too hard at that one
                                      Rodrigo
                                      hahaha
                                      I will try to use this and get back to you with news.
                                      Thanks guys!
                                      Best,
                                      Rodrigo
                                      • W Offline
                                        Wingnut2.0
                                        When changing to a service on windows your GUID will more than likely change (Thank you Dave)
                                        This will require a request to transfer you license from the old GUID to the new one.
                                        If you run into that - below is the link to request the transfer.
                                        https://mango-os.com/license-help
                                          Rodrigo
                                          Hi guys,
                                          I have not been able to solve this. I don't know how to use this https://nssm.cc/
                                          What can I do?
                                          @Wingnut2-0 you recommended Oracle JDK 8, is it free for this use?
                                          Rodrigo
                                          • T Offline
                                            tungthanh500
                                            Hi, I just installed Mango V4 latest beta. However, Mango service cannot start automatically. I have to run mango.cmd in command promt as administrator.
                                            When I tried to start the service in Services.msc, error 1067 occurrs.
                                            I already installed AdoptJDK 11 and assign environment variable.
                                            dschaibleD 1 Reply Last reply Reply Quote 0
