    Installing Windows Service
    Mango Automation Installation
    5
    25
    12.5k
    • R
      Rodrigo
      The documentation in the website about the installation of services, particularly for Windows is for previous versions of Mango "Installing services (Mango 3.5.x and lower)" will this method still work with Mango 3.7.7?
      Thanks!
      • MattFoxM
        No, refer mango 3.6 and later for the 3.7 install
        This is at least about using adopt jdk
        The rest of the windows install is similar except you fire start-mango.bat and not ma-start.bat
        https://docs-v3.mango-os.com/linux-installation
        • R
          Rodrigo
          Hi Matt,
          Thanks for your answer, would you be so kind to explain a little further? I am not familiar with Linux.
          Thanks!
          Rodrigo
          • MattFoxM
            It was more for understanding the type of AdoptJDK version to use, that and the launcher, that's all.
            The rest of windows should be the same.
            Let me know what part exactly you are a bit lost with.
            • R
              Rodrigo
              Hi Matt,
              I was referring to Installing Services, if I understand correctly you are talking about the Mango Installation itself, right?
              I had no problem installing Mango, I'm talking about the yajsw file to install a service for Mango to autostart with Windows
              Rodrigo
              • MattFoxM
                Sorry Rodrigo, I completely missed your question!
                Windows I would imagine would be the same. I can't see how that changes.
                Apologies, I'm a linux guy hence I assumed you meant with the installation process.
                I've just checked my system. all is the same, you should have no issues - sorry for the runaround!
                • R
                  Rodrigo
                  No worries!
                  Thanks for the help Matt!
                  Best,
                  Rodrigo
                  • R
                    Rodrigo
                    Hi guys,
                    Still with problems, installing the service i get this error
                    it says: ""java"" not recognized as an internal or external command, operable program or batch file
                    I have installed the AdoptOpenJDK
                    Can you give me a hand?
                    Thanks!
                    Rodrigo
                    • MattFoxM
                      Look up adding java as an environment variable for windows.
                      It will under advanced in tje system properties panel
                      • R
                        Rodrigo
                        Hi Matt,
                        Thanks for the help, I have been able to install the service, but it does not work, it starts and stops alone and when is running I can't access mango.
                        Any thoughts?
                        Thanks!
                        Rodrigo
                        • R
                          Rodrigo
                          I have found this in the wrapper at C:\Mango\yajsw\log\wrapper
                          WARNING|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|YAJSW: yajsw-stable-11.11
                          WARNING|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|OS   : Windows 10/10.0/amd64
                          WARNING|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|JVM  : AdoptOpenJDK/11.0.9/C:\Program Files\AdoptOpenJDK\jdk-11.0.9.11-hotspot/64
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|ahessian jmx service bound to port 15002
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|working dir C:\Mango\bin
                          [null - INFO] 20-11-05 12:29:58 Error in createScript scripts/trayMessage.gv
                          Exception in org.rzo.yajsw.log.MyLogger: Could not determine the last modified timestamp of "file:///C:/WINDOWS/system32/scripts/trayMessage.gv" because it does not exist.
                            org.apache.commons.vfs2.provider.DefaultFileContent.getLastModifiedTime(DefaultFileContent.java:165)
                            org.rzo.yajsw.script.GroovyScript.getScriptInstance(GroovyScript.java:103)
                            org.rzo.yajsw.script.GroovyScript.<init>(GroovyScript.java:77)
                            org.rzo.yajsw.script.ScriptFactory.createScript(ScriptFactory.java:45)
                            org.rzo.yajsw.wrapper.AbstractWrappedProcess.getTriggerScript(AbstractWrappedProcess.java:1853)
                            org.rzo.yajsw.wrapper.AbstractWrappedProcess.getTriggerActions(AbstractWrappedProcess.java:1738)
                            org.rzo.yajsw.wrapper.AbstractWrappedProcess.startInternal(AbstractWrappedProcess.java:1044)
                            org.rzo.yajsw.wrapper.AbstractWrappedProcess.start(AbstractWrappedProcess.java:923)
                            org.rzo.yajsw.wrapper.WrappedProcessList.startAll(WrappedProcessList.java:11)
                            org.rzo.yajsw.app.WrapperMainServiceWin$1.run(WrapperMainServiceWin.java:153)
                            java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
                            java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
                            java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
                            java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
                            java.base/java.lang.Thread.run(Thread.java:834)
                           INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|error initializing script scripts/trayMessage.gv
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|started process with pid 7976
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|restart process due to default exit code rule
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|restart internal RUNNING
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:58|stopping process with pid/timeout 7976 45000
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:29:59|process exit code: 999
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|working dir C:\Mango\bin
                          [null - INFO] 20-11-05 12:30:04 Error in createScript scripts/trayMessage.gv
                            org.rzo.yajsw.wrapper.AbstractWrappedProcess.restartInternal(AbstractWrappedProcess.java:2565)
                            org.rzo.yajsw.wrapper.WrappedJavaProcess$2.fire(WrappedJavaProcess.java:557)
                            org.rzo.yajsw.controller.AbstractController.handleListeners(AbstractController.java:108)
                            org.rzo.yajsw.controller.AbstractController.setState(AbstractController.java:146)
                            org.rzo.yajsw.controller.jvm.JVMController$4$1.run(JVMController.java:701)
                           INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|error initializing script scripts/trayMessage.gv
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|started process with pid 9660
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|restart process due to default exit code rule
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|restart internal RUNNING
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:04|stopping process with pid/timeout 9660 45000
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:05|process exit code: 999
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:10|working dir C:\Mango\bin
                          [null - INFO] 20-11-05 12:30:10 Error in createScript scripts/trayMessage.gv
                           INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:10|error initializing script scripts/trayMessage.gv
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:10|started process with pid 8796
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:11|restart process due to default exit code rule
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:11|restart internal RUNNING
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:11|stopping process with pid/timeout 8796 45000
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:11|process exit code: 999
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:16|working dir C:\Mango\bin
                          [null - INFO] 20-11-05 12:30:16 Error in createScript scripts/trayMessage.gv
                           INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:16|error initializing script scripts/trayMessage.gv
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:16|started process with pid 2964
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:17|restart process due to default exit code rule
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:17|restart internal RUNNING
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:17|stopping process with pid/timeout 2964 45000
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:17|process exit code: 999
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:22|working dir C:\Mango\bin
                          [null - INFO] 20-11-05 12:30:22 Error in createScript scripts/trayMessage.gv
                           INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:22|error initializing script scripts/trayMessage.gv
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:22|started process with pid 9584
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:23|restart process due to default exit code rule
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:23|restart internal RUNNING
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:23|stopping process with pid/timeout 9584 45000
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:23|process exit code: 999
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|working dir C:\Mango\bin
                          [null - INFO] 20-11-05 12:30:29 Error in createScript scripts/trayMessage.gv
                           INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|error initializing script scripts/trayMessage.gv
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|started process with pid 892
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|too many restarts
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|process not in state RUNNING -> Delaying stop
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|calling onStop
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|Win service stop - timeout: 30000
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|Win service wrapper.control -> stopping application
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|Win service stop - after shutdown
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|Win service stop - before notify
                          INFO|wrapper|Service com.serotonin.m2m2.Main|20-11-05 12:30:29|Win service terminated
                          • MattFoxM
                            Looks like a missing file to me
                            • W
                              Wingnut2.0
                              javaws.jar is not included in AdoptOpenJDK which is required for YAJSW to work.
                              • MattFoxM
                                Thanks Wingnut
                                • R
                                  Rodrigo
                                  Thanks Matt / Wingnut
                                  Can you guys elaborate a little on how to fix it?
                                  Best,
                                  Rodrigo
                                  • W
                                    Wingnut2.0
                                    Hello Rodrigo,
                                    I have found that if you want to run a version of 3.7.7 or lower on Windows as a service your best bet is Installing Oracle JDK 8. I know it doesn't necessarily follow the recommendation's here, but it allows you to run as a service.
                                    https://docs-v3.mango-os.com/installing-java
                                    • For Mango versions 3.6.x and higher we recommend using the latest version of Adopt OpenJDK.
                                    • For Mango versions 3.5.x and lower you should use JDK 8 (OpenJDK 8 should work however we primarily tested on Oracle JDK). Older versions of Mango may not work correctly if you use a newer JDK.
                                    • OpenJDK 8 builds for ARM 32 processors seem to perform extremely poorly, we suggest avoiding this JDK
                                    Another option that I haven't looked into is explained here.
                                    https://docs.microsoft.com/en-us/powershell/module/microsoft.powershell.management/new-service?view=powershell-7
                                    • R
                                      Rodrigo
                                      Wingnut,
                                      You think I should buy an Oracle JDK 8 license?
                                      Best,
                                      Rodrigo
                                      • W
                                        Wingnut2.0
                                        Hello Rodrigo,
                                        Here is another alternative. This works on windows with AdoptOpenJDK 11.
                                        https://nssm.cc/
                                        NSSM - the Non-Sucking Service Manager
                                        • MattFoxM
                                          @wingnut2-0 said in Installing Windows Service:
                                          I laughed a little too hard at that one
                                          • R
                                            Rodrigo
                                            hahaha
                                            I will try to use this and get back to you with news.
                                            Thanks guys!
                                            Best,
                                            Rodrigo
