    Mango not starting ! Disk is full.
    20 Posts 4 Posters 14.3k Views 3 Watching
      stensma
      Please look at my error in the past with unaccessable Mango
        Hi stensma,
        Whenever a disk is full there's only one course of action: free up some space. I would use the command line, and SSH into the device. If you are using a Mac or a Linux OS, you can type 'ssh -p 2222 mango@ip' into a terminal to begin the SSH connection, or if you are on Windows you may need to download Putty as the SSH client. The login credentials will probably be the same over SSH as they were through Webmin
        I would start by checking the size of Mango's files, specifically:
        du -sh /opt/mango/backup
        du -sh /opt/mango/logs
        du -sh /opt/mango
        Emptying the logs directory and the backup directory (or copying them elsewhere) is a good first step.
        Here are some helpful commands, where %d is a file or directory name:
        #Size of a file or directory:
        du -sh %d
        #List 20 largest files:
        sudo du -ahx / | sort -rh | head -20
        #Find all files over 100 MB:
        sudo find / -size +100MB
        #Remove a file
        rm %d
        #Remove a directory
        rm -r %d
        Please do share where the space has gone when you find some large files, if you can.
          mihairosu
          I have had an issue with full disk size with the publisher logs (Mine was 4.6 GB):
          Example location: /opt/mango/logs/processLog.PersistentPublisher-1.log
          Make sure Log Level is set to None for your publisher:
          Hopefully that's what it is.
            What Mihai says is true! Or, was true. That problem was among those fixed in 2.8.x and there are no more logs which can easily grow indefinitely anymore.
              stensma
              Hi all !
              Mango still has some issues.
              There was not room for the temp files needed in the commands.
              What is wrong ? Where do I find space?
              mango@stensmango:/$ sudo du -ahx / | sort -rh | head -20
              [sudo] password for mango:
              Sorry, try again.
              sort: cannot create temporary file in ‘/tmp’: No space left on device
              ot local0_1479906901198_Backup.tiff
              0_1479906979486_Interna metrics.tiff
              Filesystem from Webmin:
              0_1479907094278_FS.tiff
                Weird... why does / report as only being 47% full if the disk is full? I would restart the device if I saw that.
                You could see if there's an abundance of logging from something else
                sudo du -sh /var/log/*
                  I would check your /opt/mango/backup folder. You may have a lot of NoSQL database backups which you can delete to free up space. You can turn off incremental backups on the system settings page under the NoSQL settings.
                    stensma
                    Hi this pictures was taken right after a cold boot.
                    And ALL backup are moved to an external disk.
                      stensma @phildunlap
                      @phildunlap
                      0_1479935503665_Var_log.tiff
                        stensma
                        Result with Find size
                        mango@stensmango:/opt/mango/logs$ sudo find / -size +100M
                        find: /proc/26770/task/26770/fd/5': No such file or directory find: /proc/26770/task/26770/fdinfo/5': No such file or directory
                        find: /proc/26770/fd/5': No such file or directory find: /proc/26770/fdinfo/5': No such file or directory
                          stensma
                          SSH picture
                          0_1479937347472_SSH.tiff
                            Can you check the output of df -i as it may be there are no more inodes. If that is the case that they're 100% utilized, you'll have to find some files (and directories) to delete. They can be any files of any size, but you should of course exercise care.
                            A useful command may be:
                            #count the number of files and directories in /path/to/dir
                            find /path/to/dir | wc -l
                              stensma
                              0_1479971824621_FS1.tiff
                              After :
                              0_1479972783363_fs2.tiff
                              Then I am able to run basic Webmin functions, but what is creating the problem?
                              I have tried no to run apt-get purge and autoremove but there is nothing to clean out.
                              Now I work with following command.
                              $ for i in /*; do echo $i; find $i |wc -l; done
                              This lists the folders and inode number.
                              and I fount that /var had over 300k nodes
                              I will dig deeper on where exactly
                              0_1479973339313_fs3.tiff
                              What is creating the files in /var/spool/exim4/input ??
                              0_1479973648956_fs4.tiff
                                stensma
                                I have now removed the files in the /var/spool/exim4/input.
                                Now the resources is back on track, but still what is creating the files?
                                0_1479974922559_fs5.tiff
                                0_1479974958382_fs6.tiff
                                  stensma
                                  New files are created all the time.
                                  There two different contents one is:0_1479975653561_spool.tiff
                                  The other has following content:
                                  0_1479975737787_spool2.tiff
                                  I have now created an empty log.txt file in the missing mango-backups folder,
                                  lets see if this does the trick...
                                    stensma
                                    I found the bad guy !
                                    A Cron Job create all the files in /var/spool/exim4/input.
                                    When I disable this task, the folder is quiet .
                                    But why is this job there ? and what is it suppose to do?
                                    0_1479977770085_Cron_job.tiff
                                      It was supposed to be constructing a file in /opt/systeminfo/ (I believe, might be /opt/info/ or something like that) which would then be read by a preconfigured ASCII File Data Source for system information like remaining disk space. You can certainly deactivate it without much loss, and you may as well disable the ASCII data source that was preloaded. I will definitely investigate if other MangoES's are having a problem with it creating files in /var/spool/
                                        mihairosu
                                        I used this command straight from the terminal to list inodes and found it easier:
                                        find / -xdev -printf '%h\n' | sort | uniq -c | sort -k 1 -n
                                          mihairosu
                                          This issue has happened again, and the same folder caused the problem.
                                          ASCII File Reader has been off for a long time, so that did not prevent the issue from re-occurring.
                                          edit: This is happening on Mango v3, but not on Mango v1 or on an Ubuntu install.
