    Mango not starting ! Disk is full.
    20 Posts 4 Posters 14.0k Views 3 Watching
      stensma @phildunlap
      @phildunlap
      0_1479935503665_Var_log.tiff
        stensma
        Result with Find size
        mango@stensmango:/opt/mango/logs$ sudo find / -size +100M
        find: /proc/26770/task/26770/fd/5': No such file or directory find: /proc/26770/task/26770/fdinfo/5': No such file or directory
        find: /proc/26770/fd/5': No such file or directory find: /proc/26770/fdinfo/5': No such file or directory
          stensma
          SSH picture
          0_1479937347472_SSH.tiff
            Can you check the output of df -i as it may be there are no more inodes. If that is the case that they're 100% utilized, you'll have to find some files (and directories) to delete. They can be any files of any size, but you should of course exercise care.
            A useful command may be:
            #count the number of files and directories in /path/to/dir
            find /path/to/dir | wc -l
              stensma
              0_1479971824621_FS1.tiff
              After :
              0_1479972783363_fs2.tiff
              Then I am able to run basic Webmin functions, but what is creating the problem?
              I have tried no to run apt-get purge and autoremove but there is nothing to clean out.
              Now I work with following command.
              $ for i in /*; do echo $i; find $i |wc -l; done
              This lists the folders and inode number.
              and I fount that /var had over 300k nodes
              I will dig deeper on where exactly
              0_1479973339313_fs3.tiff
              What is creating the files in /var/spool/exim4/input ??
              0_1479973648956_fs4.tiff
                stensma
                I have now removed the files in the /var/spool/exim4/input.
                Now the resources is back on track, but still what is creating the files?
                0_1479974922559_fs5.tiff
                0_1479974958382_fs6.tiff
                  stensma
                  New files are created all the time.
                  There two different contents one is:0_1479975653561_spool.tiff
                  The other has following content:
                  0_1479975737787_spool2.tiff
                  I have now created an empty log.txt file in the missing mango-backups folder,
                  lets see if this does the trick...
                    stensma
                    I found the bad guy !
                    A Cron Job create all the files in /var/spool/exim4/input.
                    When I disable this task, the folder is quiet .
                    But why is this job there ? and what is it suppose to do?
                    0_1479977770085_Cron_job.tiff
                      It was supposed to be constructing a file in /opt/systeminfo/ (I believe, might be /opt/info/ or something like that) which would then be read by a preconfigured ASCII File Data Source for system information like remaining disk space. You can certainly deactivate it without much loss, and you may as well disable the ASCII data source that was preloaded. I will definitely investigate if other MangoES's are having a problem with it creating files in /var/spool/
                        mihairosu
                        I used this command straight from the terminal to list inodes and found it easier:
                        find / -xdev -printf '%h\n' | sort | uniq -c | sort -k 1 -n
                          mihairosu
                          This issue has happened again, and the same folder caused the problem.
                          ASCII File Reader has been off for a long time, so that did not prevent the issue from re-occurring.
                          edit: This is happening on Mango v3, but not on Mango v1 or on an Ubuntu install.
