    Mango not starting ! Disk is full.
    20 Posts 4 Posters 14.3k Views 3 Watching
      stensma
      Hi all !
      Mango still has some issues.
      There was not room for the temp files needed in the commands.
      What is wrong ? Where do I find space?
      mango@stensmango:/$ sudo du -ahx / | sort -rh | head -20
      [sudo] password for mango:
      Sorry, try again.
      sort: cannot create temporary file in ‘/tmp’: No space left on device
      ot local0_1479906901198_Backup.tiff
      0_1479906979486_Interna metrics.tiff
      Filesystem from Webmin:
      0_1479907094278_FS.tiff
        Weird... why does / report as only being 47% full if the disk is full? I would restart the device if I saw that.
        You could see if there's an abundance of logging from something else
        sudo du -sh /var/log/*
          I would check your /opt/mango/backup folder. You may have a lot of NoSQL database backups which you can delete to free up space. You can turn off incremental backups on the system settings page under the NoSQL settings.
            stensma
            Hi this pictures was taken right after a cold boot.
            And ALL backup are moved to an external disk.
              stensma @phildunlap
              @phildunlap
              0_1479935503665_Var_log.tiff
                stensma
                Result with Find size
                mango@stensmango:/opt/mango/logs$ sudo find / -size +100M
                find: /proc/26770/task/26770/fd/5': No such file or directory find: /proc/26770/task/26770/fdinfo/5': No such file or directory
                find: /proc/26770/fd/5': No such file or directory find: /proc/26770/fdinfo/5': No such file or directory
                  stensma
                  SSH picture
                  0_1479937347472_SSH.tiff
                    Can you check the output of df -i as it may be there are no more inodes. If that is the case that they're 100% utilized, you'll have to find some files (and directories) to delete. They can be any files of any size, but you should of course exercise care.
                    A useful command may be:
                    #count the number of files and directories in /path/to/dir
                    find /path/to/dir | wc -l
                      stensma
                      0_1479971824621_FS1.tiff
                      After :
                      0_1479972783363_fs2.tiff
                      Then I am able to run basic Webmin functions, but what is creating the problem?
                      I have tried no to run apt-get purge and autoremove but there is nothing to clean out.
                      Now I work with following command.
                      $ for i in /*; do echo $i; find $i |wc -l; done
                      This lists the folders and inode number.
                      and I fount that /var had over 300k nodes
                      I will dig deeper on where exactly
                      0_1479973339313_fs3.tiff
                      What is creating the files in /var/spool/exim4/input ??
                      0_1479973648956_fs4.tiff
                        stensma
                        I have now removed the files in the /var/spool/exim4/input.
                        Now the resources is back on track, but still what is creating the files?
                        0_1479974922559_fs5.tiff
                        0_1479974958382_fs6.tiff
                          stensma
                          New files are created all the time.
                          There two different contents one is:0_1479975653561_spool.tiff
                          The other has following content:
                          0_1479975737787_spool2.tiff
                          I have now created an empty log.txt file in the missing mango-backups folder,
                          lets see if this does the trick...
                            stensma
                            I found the bad guy !
                            A Cron Job create all the files in /var/spool/exim4/input.
                            When I disable this task, the folder is quiet .
                            But why is this job there ? and what is it suppose to do?
                            0_1479977770085_Cron_job.tiff
                              It was supposed to be constructing a file in /opt/systeminfo/ (I believe, might be /opt/info/ or something like that) which would then be read by a preconfigured ASCII File Data Source for system information like remaining disk space. You can certainly deactivate it without much loss, and you may as well disable the ASCII data source that was preloaded. I will definitely investigate if other MangoES's are having a problem with it creating files in /var/spool/
                                mihairosu
                                I used this command straight from the terminal to list inodes and found it easier:
                                find / -xdev -printf '%h\n' | sort | uniq -c | sort -k 1 -n
                                  mihairosu
                                  This issue has happened again, and the same folder caused the problem.
                                  ASCII File Reader has been off for a long time, so that did not prevent the issue from re-occurring.
                                  edit: This is happening on Mango v3, but not on Mango v1 or on an Ubuntu install.
