    [SOLVED] Daily Report didn't run today and has this error
    26 Posts 3 Posters 19.8k Views 1 Watching
    • danD Offline
      dan
      Hrm, it's still not running any reports, I've tried creating all new ones. It almost looks like the DB table might be corrupt?
      I'm familiar with MYSQL somewhat but not with the Mango DB ?
      • danD Offline
        dan
        This was the error log:
        ERROR 2014-09-16 12:02:43,812 (com.serotonin.m2m2.web.dwr.util.ExceptionDetectionFilter.doFilter:38) - DWR invocation exception
        org.springframework.dao.DataIntegrityViolationException: PreparedStatementCallback; SQL [insert into reportInstances   (userId, reportId, name, template, includeEvents, includeUserComments, reportStartTime, reportEndTime, runStartTime,      runEndTime, recordCount, preventPurge, mapping)   values (?,?,?,?,?,?,?,?,?,?,?,?,?)]; An attempt was made to get a data value of type 'BLOB' from a data value of type 'java.io.ByteArrayInputStream'.; nested exception is java.sql.SQLDataException: An attempt was made to get a data value of type 'BLOB' from a data value of type 'java.io.ByteArrayInputStream'.
          It looks like something is wrong in the database. When you deleted the module did you use the Mark for Deletion button on the modules page and then restarted Mango? This should remove the old table. You can then put the latest reports module back in the modules folder and restart again. After the first restart you can use the SQL console to check and make sure the reports table is removed.
          • danD Offline
            dan
            Gidday.. yeh I used the mark for deletion button and it greyed out the whole reports module in red. Then I hit restart this instance button..
              Hi Dan,
              I'm not sure what to say at this point. Probably best to get on a remote support session. Contact me tomorrow as early as you can if possible.
              • danD Offline
                dan
                Attached the output of the show tables command..
                I can't see a reports table in there now that I've deleted the reports module.
                If I was to delete the whole instance of Mango, if I backed up the config script, does that take all the scripts and data points with that?
                Then how do I back the Graphical Overview up? Or would I have to set that one up manually again?
                Dan
                  I don't see any of the reports tables. Is this with the module installed? If not then I think it needs to be installed again. I'm sure you know but just to clarify, to install a module you place the zip file in the modules folder and DON'T unzip it. When mango starts up it will install it the module and create it's needed database tables.
                  • danD Offline
                    dan
                    yeh sorry mate, this was after I removed it to check that it dropped the table. I'll reinstall now..
                    • danD Offline
                      dan
                      Yep I got the report tables back:
                      REPORTINSTANCEDATA
                      REPORTINSTANCEDATAANNOTATIONS
                      REPORTINSTANCEEVENTS
                      REPORTINSTANCEPOINTS
                      REPORTINSTANCES
                      REPORTINSTANCEUSERCOMMENTS
                      REPORTS
                      • danD Offline
                        dan
                        still same error :(
                          This seems to have been resolved by converting the Derby database to H2. For others interested to know the conversion settings are in the env.properties file and it's really easy to do. H2 is a much better database than derby so we recommend everyone either converts away from Derby to either H2 or MySQL.
                          • danD Offline
                            dan
                            Thanks for your time on this Joel, it's great to get a resolution and have the reports running again.
                            Dan
