    [SOLVED] Daily Report didn't run today and has this error
    26 Posts 3 Posters 20.8k Views 1 Watching
      Dan,
      I'm a developer for Infinite Automation and am happy to try and help you out.
      It looks like something went wrong in the upgrade of the reports module.
      What version were you previously using? And what was your report configuration if you have the old JSON export or are able to get the existing one back out?
      I will dig into this first thing tomorrow morning and let you know what I find.
      Terry
      • danD Offline
        dan
        Gidday. Thanks for your message. I think it started playing up before I upgraded as I upgraded in an attempt to fix this issue I think.
        Dan
          Dan,
          Can you tell me the previous version of the Reports Module you were using when the report starting playing up?
          Terry
            Dan,
            Another option that would fix this if you don't have reports that you need to keep would be to mark the module for deletion from the modules page, restart Mango. Then shut mango down and install the latest module.
            Terry
            • danD Offline
              dan
              Gidday, I'm not sure what version was running before. I think Mango itself was 2.2.2 maybe.
              I will try the delete option.
              Dan
              • danD Offline
                dan
                Hey Guys, I'm just trying this again, I'll see if deleting the module altogether helps.
                • danD Offline
                  dan
                  Hrm, it's still not running any reports, I've tried creating all new ones. It almost looks like the DB table might be corrupt?
                  I'm familiar with MYSQL somewhat but not with the Mango DB ?
                  • danD Offline
                    dan
                    This was the error log:
                    ERROR 2014-09-16 12:02:43,812 (com.serotonin.m2m2.web.dwr.util.ExceptionDetectionFilter.doFilter:38) - DWR invocation exception
                    org.springframework.dao.DataIntegrityViolationException: PreparedStatementCallback; SQL [insert into reportInstances   (userId, reportId, name, template, includeEvents, includeUserComments, reportStartTime, reportEndTime, runStartTime,      runEndTime, recordCount, preventPurge, mapping)   values (?,?,?,?,?,?,?,?,?,?,?,?,?)]; An attempt was made to get a data value of type 'BLOB' from a data value of type 'java.io.ByteArrayInputStream'.; nested exception is java.sql.SQLDataException: An attempt was made to get a data value of type 'BLOB' from a data value of type 'java.io.ByteArrayInputStream'.
                      It looks like something is wrong in the database. When you deleted the module did you use the Mark for Deletion button on the modules page and then restarted Mango? This should remove the old table. You can then put the latest reports module back in the modules folder and restart again. After the first restart you can use the SQL console to check and make sure the reports table is removed.
                      • danD Offline
                        dan
                        Gidday.. yeh I used the mark for deletion button and it greyed out the whole reports module in red. Then I hit restart this instance button..
                          Hi Dan,
                          I'm not sure what to say at this point. Probably best to get on a remote support session. Contact me tomorrow as early as you can if possible.
                          • danD Offline
                            dan
                            Attached the output of the show tables command..
                            I can't see a reports table in there now that I've deleted the reports module.
                            If I was to delete the whole instance of Mango, if I backed up the config script, does that take all the scripts and data points with that?
                            Then how do I back the Graphical Overview up? Or would I have to set that one up manually again?
                            Dan
                              I don't see any of the reports tables. Is this with the module installed? If not then I think it needs to be installed again. I'm sure you know but just to clarify, to install a module you place the zip file in the modules folder and DON'T unzip it. When mango starts up it will install it the module and create it's needed database tables.
                              • danD Offline
                                dan
                                yeh sorry mate, this was after I removed it to check that it dropped the table. I'll reinstall now..
                                • danD Offline
                                  dan
                                  Yep I got the report tables back:
                                  REPORTINSTANCEDATA
                                  REPORTINSTANCEDATAANNOTATIONS
                                  REPORTINSTANCEEVENTS
                                  REPORTINSTANCEPOINTS
                                  REPORTINSTANCES
                                  REPORTINSTANCEUSERCOMMENTS
                                  REPORTS
                                  • danD Offline
                                    dan
                                    still same error :(
                                      This seems to have been resolved by converting the Derby database to H2. For others interested to know the conversion settings are in the env.properties file and it's really easy to do. H2 is a much better database than derby so we recommend everyone either converts away from Derby to either H2 or MySQL.
                                      • danD Offline
                                        dan
                                        Thanks for your time on this Joel, it's great to get a resolution and have the reports running again.
                                        Dan
