    Use of the DS2406 switch for input
    22 Posts 3 Posters 30.2k Views 1 Watching
      Yes, but that's not with Maxim-IC calls it. Can you specify the exact part that you are having trouble with?
      • F Offline
        fclauson
        check out
        http://www.maxim-ic.com/datasheet/index.mvp/id/2907
          Ah. That's a "2406", not a "2046". They only provide samples for the DS2406+ and DS2406P+. Which are you using?
          • F Offline
            fclauson
            ahh - my apologies
            never could typpppe propperly
            DS2406+
            Francis
            • F Offline
              fclauson
              Hi
              any update on testing ?
                Sadly, no. The samples that Maxim sent i cannot use. When you say it won't work as a sensor, why is that? It should be reading the device's value on each poll.
                • F Offline
                  fclauson
                  ok - let me have a play applying a voltage to the switch side and see what happens - I am away at the mo so this will take a few days to achieve
                  If any one else can have a go at this then please feel free to chip in
                  Francis
                    mhradom
                    OK, I will finally get off my butt and send you one of these like I promised.
                    It works with One Wire Viewer just fine by connecting a switch across it's inputs. I can see the state change in One Wire Viewer.
                    I could really use this functionality from Mango as well.
                    http://www.embeddeddatasystems.com/D2--Low-Cost-2-Channel-Digital-IO-1-Wire-Card_p_12.html
                    Is there any import restrictions to Canada? Special markings?
                    Mike
                      Document it as a gift of 0 value. This will avoid the astonishing duties and taxes that would otherwise be applied.
                        Oh, but if your device doesn't have a RJ connector, don't bother. I'm not set up for integrating components on to boards or anything.
                          mhradom
                          I've got leads soldered to the board now.
                          On the input side: DQ, Com, +5VDC
                          On the output side I/O A, com, I/O B
                          The DS 2406 is mounted on the board with some pullup resistors.
                          I can do RJ-45 on the input side if you needed it.
                            I got test 1-wire equipment from hobbyboards. If yours is compatible with that, it should be fine.
                            • F Offline
                              fclauson
                              Bump
                              any news on this - did you manage to test
                                No news.
