    Use of the DS2406 switch for input
    22 Posts 3 Posters 30.5k Views 1 Watching
    • F Offline
      fclauson
      Hi
      the DS2046 does work as a switch but not as a sensor (which its also capabale)
      Rather than me send you one - can I ask if you can go to
      https://shop.maxim-ic.com/storefront/searchsample.do?menuitem=Sample&event=SampleSearchLoad
      where you can order free samples of all of the 1-wire componets
      Francis
        What specific part number are you using? They don't seem to have much in the way of samples at the moment.
          My bad, I was looking for a DS2046. There is a MAX2046ETJ+ available. Is this similar enough to what you are using?
          • F Offline
            fclauson
            its DS2406
              Yes, but that's not with Maxim-IC calls it. Can you specify the exact part that you are having trouble with?
              • F Offline
                fclauson
                check out
                http://www.maxim-ic.com/datasheet/index.mvp/id/2907
                  Ah. That's a "2406", not a "2046". They only provide samples for the DS2406+ and DS2406P+. Which are you using?
                  • F Offline
                    fclauson
                    ahh - my apologies
                    never could typpppe propperly
                    DS2406+
                    Francis
                    • F Offline
                      fclauson
                      Hi
                      any update on testing ?
                        Sadly, no. The samples that Maxim sent i cannot use. When you say it won't work as a sensor, why is that? It should be reading the device's value on each poll.
                        • F Offline
                          fclauson
                          ok - let me have a play applying a voltage to the switch side and see what happens - I am away at the mo so this will take a few days to achieve
                          If any one else can have a go at this then please feel free to chip in
                          Francis
                            mhradom
                            OK, I will finally get off my butt and send you one of these like I promised.
                            It works with One Wire Viewer just fine by connecting a switch across it's inputs. I can see the state change in One Wire Viewer.
                            I could really use this functionality from Mango as well.
                            http://www.embeddeddatasystems.com/D2--Low-Cost-2-Channel-Digital-IO-1-Wire-Card_p_12.html
                            Is there any import restrictions to Canada? Special markings?
                            Mike
                              Document it as a gift of 0 value. This will avoid the astonishing duties and taxes that would otherwise be applied.
                                Oh, but if your device doesn't have a RJ connector, don't bother. I'm not set up for integrating components on to boards or anything.
                                  mhradom
                                  I've got leads soldered to the board now.
                                  On the input side: DQ, Com, +5VDC
                                  On the output side I/O A, com, I/O B
                                  The DS 2406 is mounted on the board with some pullup resistors.
                                  I can do RJ-45 on the input side if you needed it.
                                    I got test 1-wire equipment from hobbyboards. If yours is compatible with that, it should be fine.
                                    • F Offline
                                      fclauson
                                      Bump
                                      any news on this - did you manage to test
                                        No news.
