    Use of the DS2406 switch for input
    22 Posts 3 Posters 26.3k Views 1 Watching
      mhradom
      Can the DS2406 switch be used as an input to Mango? I see I can set the output binary value. My DS2406 is found by Mango but when I close contacts in the field, the state does not change in Mango. Dallas One Wire Viewer does see the field contact closure. For example, I want to sense air flow paddle switches and current switches such as CR Magnetics CR9321.
      If not, can anyone suggest another way to do this with another kind of 1-wire input device?
      Thanks for your help in advance,
      Mike
      • F Offline
        fclauson
        Bump
        any ideas on how you can sense in a 1-wire circuit ?
        Many thanks
          The DS2406 should already be supported via the SwitchContainer. If you are finding otherwise you can ship us a sample and test it out.
          • F Offline
            fclauson
            Hi
            the DS2046 does work as a switch but not as a sensor (which its also capabale)
            Rather than me send you one - can I ask if you can go to
            https://shop.maxim-ic.com/storefront/searchsample.do?menuitem=Sample&event=SampleSearchLoad
            where you can order free samples of all of the 1-wire componets
            Francis
              What specific part number are you using? They don't seem to have much in the way of samples at the moment.
                My bad, I was looking for a DS2046. There is a MAX2046ETJ+ available. Is this similar enough to what you are using?
                • F Offline
                  fclauson
                  its DS2406
                    Yes, but that's not with Maxim-IC calls it. Can you specify the exact part that you are having trouble with?
                    • F Offline
                      fclauson
                      check out
                      http://www.maxim-ic.com/datasheet/index.mvp/id/2907
                        Ah. That's a "2406", not a "2046". They only provide samples for the DS2406+ and DS2406P+. Which are you using?
                        • F Offline
                          fclauson
                          ahh - my apologies
                          never could typpppe propperly
                          DS2406+
                          Francis
                          • F Offline
                            fclauson
                            Hi
                            any update on testing ?
                              Sadly, no. The samples that Maxim sent i cannot use. When you say it won't work as a sensor, why is that? It should be reading the device's value on each poll.
                              • F Offline
                                fclauson
                                ok - let me have a play applying a voltage to the switch side and see what happens - I am away at the mo so this will take a few days to achieve
                                If any one else can have a go at this then please feel free to chip in
                                Francis
                                  mhradom
                                  OK, I will finally get off my butt and send you one of these like I promised.
                                  It works with One Wire Viewer just fine by connecting a switch across it's inputs. I can see the state change in One Wire Viewer.
                                  I could really use this functionality from Mango as well.
                                  http://www.embeddeddatasystems.com/D2--Low-Cost-2-Channel-Digital-IO-1-Wire-Card_p_12.html
                                  Is there any import restrictions to Canada? Special markings?
                                  Mike
                                    Document it as a gift of 0 value. This will avoid the astonishing duties and taxes that would otherwise be applied.
                                      Oh, but if your device doesn't have a RJ connector, don't bother. I'm not set up for integrating components on to boards or anything.
                                        mhradom
                                        I've got leads soldered to the board now.
                                        On the input side: DQ, Com, +5VDC
                                        On the output side I/O A, com, I/O B
                                        The DS 2406 is mounted on the board with some pullup resistors.
                                        I can do RJ-45 on the input side if you needed it.
                                          I got test 1-wire equipment from hobbyboards. If yours is compatible with that, it should be fine.
                                          • F Offline
                                            fclauson
                                            Bump
                                            any news on this - did you manage to test
