    Mango Login Issue
    4 Posts 2 Posters 1.3k Views 2 Watching
      ryanlo
      Hi all,
      I'm trying to configure a New MangoGT device.
      After setting it up with a router, I opened up the Mango web ui.
      In the login, I entered the default username (admin) and password (admin).
      But it said Login failed - Bad credentials.
      It doesn't make sense because the device is new and not configured. The default login should be working as it worked for the devices I configured previously.
      Is there another default login? If not, is it possible to hard reset the mango device?
      Thanks.
      joeamiragliaJ 1 Reply Last reply Reply Quote 0
      • joeamiragliaJ Offline
        joeamiraglia @ryanlo
        @ryanlo This can happen if your browser has a cached version of the page. Try opening the page in incognito or private mode to see if that resolves the issue.
          ryanlo @joeamiraglia
          @joeamiraglia Hi, thanks for your reply. However, I tried opening the page in incognito but still couldn't login to it.
            @ryanlo To answer your initial question, the default login is still admin : admin. The easiest way to do a reset would be to stop Mango, move the database (move it to root ~/) from the /opt/mango/databases/ directory (from directory use, mv mah2.200.* ~/ command), then restart Mango. Similar direction could be found on our document site, you will not need to do the restore since this is a new unit. Thank you!
