<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mango Login Issue]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I'm trying to configure a New MangoGT device.</p>
<p dir="auto">After setting it up with a router, I opened up the Mango web ui.</p>
<p dir="auto">In the login, I entered the default username (admin) and password (admin).</p>
<p dir="auto">But it said Login failed - Bad credentials.</p>
<p dir="auto">It doesn't make sense because the device is new and not configured. The default login should be working as it worked for the devices I configured previously.</p>
<p dir="auto">Is there another default login? If not, is it possible to hard reset the mango device?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.mango-os.com/topic/5782/mango-login-issue</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 22:36:01 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5782.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 26 Oct 2023 23:58:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mango Login Issue on Fri, 03 Nov 2023 13:32:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ryanlo" aria-label="Profile: ryanlo">@<bdi>ryanlo</bdi></a> To answer your initial question, the default login is still admin : admin. The easiest way to do a reset would be to stop Mango, move the database (move it to root <code>~/</code>) from the <code>/opt/mango/databases/</code> directory (from directory use, <code>mv mah2.200.* ~/</code> command), then restart Mango. Similar direction could be found on our <a href="https://docs-v5.radixiot.com/how-to-restore-a-h2-database-backup" rel="nofollow ugc">document site</a>, you will not need to do the restore since this is a new unit. Thank you!</p>
]]></description><link>https://forum.mango-os.com/post/28063</link><guid isPermaLink="true">https://forum.mango-os.com/post/28063</guid><dc:creator><![CDATA[joeamiraglia]]></dc:creator><pubDate>Fri, 03 Nov 2023 13:32:31 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Login Issue on Wed, 01 Nov 2023 02:56:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joeamiraglia" aria-label="Profile: joeamiraglia">@<bdi>joeamiraglia</bdi></a> Hi, thanks for your reply. However, I tried opening the page in incognito but still couldn't login to it.</p>
]]></description><link>https://forum.mango-os.com/post/28061</link><guid isPermaLink="true">https://forum.mango-os.com/post/28061</guid><dc:creator><![CDATA[ryanlo]]></dc:creator><pubDate>Wed, 01 Nov 2023 02:56:20 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Login Issue on Fri, 27 Oct 2023 02:31:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ryanlo" aria-label="Profile: ryanlo">@<bdi>ryanlo</bdi></a> This can happen if your browser has a cached version of the page. Try opening the page in incognito or private mode to see if that resolves the issue.</p>
]]></description><link>https://forum.mango-os.com/post/28057</link><guid isPermaLink="true">https://forum.mango-os.com/post/28057</guid><dc:creator><![CDATA[joeamiraglia]]></dc:creator><pubDate>Fri, 27 Oct 2023 02:31:26 GMT</pubDate></item></channel></rss>
