    Data Sources Does Not Appear
    17 Posts 7 Posters 12.2k Views 6 Watching
      @phildunlap said in Data Sources Does Not Appear:
      Uncaught ReferenceError: normal is not defined
      Also further references -
      https://stackoverflow.com/questions/50672599/dojo-uncaught-referenceerror-normal-is-not-defined
      https://github.com/kriszyp/xstyle/issues/44#issuecomment-76512785
      • L Offline
        leoboeng
        Ah ok, thank you !! It worked, was testing on 2 different PCs and all 2 were with Google Chrome.
          Phillip Weeks
          Guys that is wonderful news and I have updated the all our V3 servers. However this same chrome error exists on our 2.8.8 systems as well. Will you be updating the code for 2.8.8 to fix this ?
          • O Offline
            ordosays
            Here for the same problem.
            EDIT - the update seems to have fixed it. Now to the next issue. Memory leak/cpu usage.
              phildunlap @ordosays
              @ordosays said in Data Sources Does Not Appear:
              Sounds like it would belong in its own thread if you want to ask us anything about what's going on.
                Jared Wiltshire @Phillip Weeks
                @phillip-weeks said in Data Sources Does Not Appear:
                Probably not. You can however easily fix it by downloading xstyle from here - https://github.com/kriszyp/xstyle/archive/master.zip
                You will need to extract it to ${MA_HOME}/overrides/web/resources/xstyle
                  Phillip Weeks @Jared Wiltshire
                  @jared-wiltshire Thank-you millions Jared
                  • danD Offline
                    dan
                    Now I remember this fixed my other 2.8.8 systems. I couldn't find it for the life of me.
                    Comment for searchability for next time :-P
                    • danD Offline
                      dan
                      Had this come up again on an instance of v3.4.0
                      Found putting the xstyle into the /overrides/web/resources folder it didn't take it, so ended up replacing the xstyle folder in /web/resources folder
                      N 1 Reply Last reply Reply Quote 1
                      • N Offline
                        NinoK @dan
                        @dan I have the same issue after updating Mango to the core v3.7.7
                        Chrome version is 92.0.4515.131 (Official Build) (64-bit)
                        When I switch to the old interface and switch to the Datasources tab, the list of data sources does not appear, just the empty white space. The data point tab works well. In the new interface, everything is alright.
                        When checking the browser's console I found there a bunch of errors like this ones:
                        Note: The actual IP address is removed and changed with <IP_address> tag.
                        DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/layout/TabController.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                        DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/layout/StackController.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                        DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/Menu.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                        DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/DropDownMenu.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                        DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/_MenuBase.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                        DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/_KeyNavContainer.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                        DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/_KeyNavMixin.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                        DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/MenuItem.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                        DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/layout/ScrollingTabController.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                        DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/PopupMenuItem.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                        DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/_WidgetsInTemplateMixin.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                        DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/CheckedMenuItem.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                        DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/MenuSeparator.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                        • Jared WiltshireJ Jared Wiltshire referenced this topic on
