    Data Sources Does Not Appear
    17 Posts 7 Posters 12.8k Views 6 Watching
      Hi leoboeng,
      Is there any output to the Mango/logs/ma.log or Mango/bin/logs/ma.log file when you try to open the data source page?
      What version of the Mango core do you have installed? Get this information either from /ui/administration/modules or /modules.shtm
      The image you shared doesn't appear to have an error coming back, or you didn't wait long enough to get a timeout message when trying to load the page. This makes me thing you could try deleting your Mango/work/jsp directory or that you may need to open your developer tools in the browser to check if there's an error loading the page.
      • L Offline
        leoboeng
        Hi
        but no error appears, it stays in that page always not loading the data souce. I got the last version on the site, I started to give this problem and I downloaded the last version, I just started it and I keep the same thing.
          No errors where? In your log file or your developer console? "I got the last version on the site" is NOT the information I requested. I wanted a version number.
          That page will definitely report that it has experienced a timeout if it has requested the resources and they haven't responded unless there is a JavaScript error occurring in your developer console. You can open the developer console by right clicking on the page and clicking 'inspect' then navigating the the console tab.
          • L Offline
            leoboeng
            Follow the photos:
            8_1528137948373_123313.PNG 7_1528137948373_1233124.PNG 6_1528137948373_2143125.PNG 5_1528137948373_1351461.PNG 4_1528137948373_1351451.PNG 3_1528137948373_13514514.PNG 2_1528137948372_1351541.PNG 1_1528137948371_134541564.PNG 0_1528137948370_12351446.PNG
            The following errors appear in the browser:
              Aha! Thanks for getting that information. This was caused by a very recent Chrome update that took issue with the code in one of the JavaScript libraries, xstyle. We've already found and fixed this in the upcoming release by updating the xstyle library, so that'll be core 3.4.3 which will probably occur today or tomorrow. You may be able to use Firefox or Edge in the interim.
                For searchability:
                Uncaught ReferenceError: normal is not defined
                  @phildunlap said in Data Sources Does Not Appear:
                  Also further references -
                  https://stackoverflow.com/questions/50672599/dojo-uncaught-referenceerror-normal-is-not-defined
                  https://github.com/kriszyp/xstyle/issues/44#issuecomment-76512785
                  • L Offline
                    leoboeng
                    Ah ok, thank you !! It worked, was testing on 2 different PCs and all 2 were with Google Chrome.
                      Phillip Weeks
                      Guys that is wonderful news and I have updated the all our V3 servers. However this same chrome error exists on our 2.8.8 systems as well. Will you be updating the code for 2.8.8 to fix this ?
                      • O Offline
                        ordosays
                        Here for the same problem.
                        EDIT - the update seems to have fixed it. Now to the next issue. Memory leak/cpu usage.
                          phildunlap @ordosays
                          @ordosays said in Data Sources Does Not Appear:
                          Sounds like it would belong in its own thread if you want to ask us anything about what's going on.
                            Jared Wiltshire @Phillip Weeks
                            @phillip-weeks said in Data Sources Does Not Appear:
                            Probably not. You can however easily fix it by downloading xstyle from here - https://github.com/kriszyp/xstyle/archive/master.zip
                            You will need to extract it to ${MA_HOME}/overrides/web/resources/xstyle
                              Phillip Weeks @Jared Wiltshire
                              @jared-wiltshire Thank-you millions Jared
                              • danD Offline
                                dan
                                Now I remember this fixed my other 2.8.8 systems. I couldn't find it for the life of me.
                                Comment for searchability for next time :-P
                                • danD Offline
                                  dan
                                  Had this come up again on an instance of v3.4.0
                                  Found putting the xstyle into the /overrides/web/resources folder it didn't take it, so ended up replacing the xstyle folder in /web/resources folder
                                  N 1 Reply Last reply Reply Quote 1
                                  • N Offline
                                    NinoK @dan
                                    @dan I have the same issue after updating Mango to the core v3.7.7
                                    Chrome version is 92.0.4515.131 (Official Build) (64-bit)
                                    When I switch to the old interface and switch to the Datasources tab, the list of data sources does not appear, just the empty white space. The data point tab works well. In the new interface, everything is alright.
                                    When checking the browser's console I found there a bunch of errors like this ones:
                                    Note: The actual IP address is removed and changed with <IP_address> tag.
                                    DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/layout/TabController.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                    DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/layout/StackController.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                    DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/Menu.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                    DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/DropDownMenu.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                    DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/_MenuBase.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                    DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/_KeyNavContainer.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                    DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/_KeyNavMixin.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                    DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/MenuItem.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                    DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/layout/ScrollingTabController.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                    DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/PopupMenuItem.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                    DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/_WidgetsInTemplateMixin.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                    DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/CheckedMenuItem.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                    DevTools failed to load source map: Could not load content for http://<IP_address>/resources/dijit/MenuSeparator.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                    • Jared WiltshireJ Jared Wiltshire referenced this topic on
