<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Data Sources Does Not Appear]]></title><description><![CDATA[<p dir="auto">I set up the date soucer and when I opened the page did not load the data soucer present in the system. I thought it might be a bug so I reinstalled the program and opened without backing up my files and still did not even show Data Soucer Internal.</p>
<p dir="auto"><img src="https://camo.nodebb.org/08e468d409d304eea8c2dca0c19a6ee54fab076e?url=https%3A%2F%2Fi.imgur.com%2FSharGjL.png" alt="0_1528130745945_Capturar2313213.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">In the Data Point Detail part all Data Point and Data Sourcer appear but in the specific page for setting the date soucer and data point nothing appears.</p>
<p dir="auto"><img src="https://camo.nodebb.org/2e090964ca060ee4edcf1bb09189c58b39e9510a?url=https%3A%2F%2Fi.imgur.com%2FzcLj06B.png" alt="0_1528130753416_Capturar243242423.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/topic/3551/data-sources-does-not-appear</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 00:31:17 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3551.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 04 Jun 2018 16:45:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Data Sources Does Not Appear on Sat, 21 Aug 2021 11:23:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dan" aria-label="Profile: dan">@<bdi>dan</bdi></a> I have the same issue after updating Mango to the core v3.7.7<br />
Chrome version is  92.0.4515.131 (Official Build) (64-bit)</p>
<p dir="auto">When I switch to the old interface and switch to the Datasources tab, the list of data sources does not appear, just the empty white space. The data point tab works well. In the new interface, everything is alright.</p>
<p dir="auto">When checking the browser's console I found there a bunch of errors like this ones:</p>
<p dir="auto">Note: The actual IP address is removed and changed with &lt;IP_address&gt; tag.</p>
<p dir="auto">DevTools failed to load source map: Could not load content for http://&lt;IP_address&gt;/resources/dijit/layout/TabController.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE<br />
DevTools failed to load source map: Could not load content for http://&lt;IP_address&gt;/resources/dijit/layout/StackController.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE<br />
DevTools failed to load source map: Could not load content for http://&lt;IP_address&gt;/resources/dijit/Menu.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE<br />
DevTools failed to load source map: Could not load content for http://&lt;IP_address&gt;/resources/dijit/DropDownMenu.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE<br />
DevTools failed to load source map: Could not load content for http://&lt;IP_address&gt;/resources/dijit/_MenuBase.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE<br />
DevTools failed to load source map: Could not load content for http://&lt;IP_address&gt;/resources/dijit/_KeyNavContainer.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE<br />
DevTools failed to load source map: Could not load content for http://&lt;IP_address&gt;/resources/dijit/_KeyNavMixin.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE<br />
DevTools failed to load source map: Could not load content for http://&lt;IP_address&gt;/resources/dijit/MenuItem.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE<br />
DevTools failed to load source map: Could not load content for http://&lt;IP_address&gt;/resources/dijit/layout/ScrollingTabController.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE<br />
DevTools failed to load source map: Could not load content for http://&lt;IP_address&gt;/resources/dijit/PopupMenuItem.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE<br />
DevTools failed to load source map: Could not load content for http://&lt;IP_address&gt;/resources/dijit/_WidgetsInTemplateMixin.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE<br />
DevTools failed to load source map: Could not load content for http://&lt;IP_address&gt;/resources/dijit/CheckedMenuItem.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE<br />
DevTools failed to load source map: Could not load content for http://&lt;IP_address&gt;/resources/dijit/MenuSeparator.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE</p>
]]></description><link>https://forum.mango-os.com/post/26955</link><guid isPermaLink="true">https://forum.mango-os.com/post/26955</guid><dc:creator><![CDATA[NinoK]]></dc:creator><pubDate>Sat, 21 Aug 2021 11:23:27 GMT</pubDate></item><item><title><![CDATA[Reply to Data Sources Does Not Appear on Wed, 10 Mar 2021 03:29:59 GMT]]></title><description><![CDATA[<p dir="auto">Had this come up again on an instance of v3.4.0<br />
Found putting the xstyle into the  /overrides/web/resources folder it didn't take it, so ended up replacing the xstyle folder in /web/resources folder</p>
]]></description><link>https://forum.mango-os.com/post/26393</link><guid isPermaLink="true">https://forum.mango-os.com/post/26393</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 10 Mar 2021 03:29:59 GMT</pubDate></item><item><title><![CDATA[Reply to Data Sources Does Not Appear on Tue, 26 Jan 2021 21:38:15 GMT]]></title><description><![CDATA[<p dir="auto">Now I remember this fixed my other 2.8.8 systems. I couldn't find it for the life of me.</p>
<p dir="auto">Comment for searchability for next time :-P<br />
Cheers</p>
]]></description><link>https://forum.mango-os.com/post/26223</link><guid isPermaLink="true">https://forum.mango-os.com/post/26223</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 26 Jan 2021 21:38:15 GMT</pubDate></item><item><title><![CDATA[Reply to Data Sources Does Not Appear on Tue, 19 Jun 2018 17:33:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jared-wiltshire" aria-label="Profile: jared-wiltshire">@<bdi>jared-wiltshire</bdi></a> Thank-you millions Jared</p>
]]></description><link>https://forum.mango-os.com/post/18958</link><guid isPermaLink="true">https://forum.mango-os.com/post/18958</guid><dc:creator><![CDATA[Phillip Weeks]]></dc:creator><pubDate>Tue, 19 Jun 2018 17:33:12 GMT</pubDate></item><item><title><![CDATA[Reply to Data Sources Does Not Appear on Mon, 11 Jun 2018 16:46:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phillip-weeks" aria-label="Profile: phillip-weeks">@<bdi>phillip-weeks</bdi></a> said in <a href="/post/18791">Data Sources Does Not Appear</a>:</p>
<p dir="auto">Guys that is wonderful news and I have updated the all our V3 servers.  However this same chrome error exists on our 2.8.8 systems as well.  Will you be updating the code for 2.8.8 to fix this ?</p>
<p dir="auto">Probably not. You can however easily fix it by downloading xstyle from here - <a href="https://github.com/kriszyp/xstyle/archive/master.zip" rel="nofollow ugc">https://github.com/kriszyp/xstyle/archive/master.zip</a></p>
<p dir="auto">You will need to extract it to <code>${MA_HOME}/overrides/web/resources/xstyle</code></p>
]]></description><link>https://forum.mango-os.com/post/18810</link><guid isPermaLink="true">https://forum.mango-os.com/post/18810</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Mon, 11 Jun 2018 16:46:30 GMT</pubDate></item><item><title><![CDATA[Reply to Data Sources Does Not Appear on Mon, 11 Jun 2018 14:18:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ordosays" aria-label="Profile: ordosays">@<bdi>ordosays</bdi></a> said in <a href="/post/18792">Data Sources Does Not Appear</a>:</p>
<p dir="auto">Here for the same problem.</p>
<p dir="auto">EDIT - the update seems to have fixed it. Now to the next issue. Memory leak/cpu usage.</p>
<p dir="auto">Sounds like it would belong in its own thread if you want to ask us anything about what's going on.</p>
]]></description><link>https://forum.mango-os.com/post/18798</link><guid isPermaLink="true">https://forum.mango-os.com/post/18798</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 11 Jun 2018 14:18:23 GMT</pubDate></item><item><title><![CDATA[Reply to Data Sources Does Not Appear on Fri, 08 Jun 2018 22:04:18 GMT]]></title><description><![CDATA[<p dir="auto">Here for the same problem.</p>
]]></description><link>https://forum.mango-os.com/post/18792</link><guid isPermaLink="true">https://forum.mango-os.com/post/18792</guid><dc:creator><![CDATA[ordosays]]></dc:creator><pubDate>Fri, 08 Jun 2018 22:04:18 GMT</pubDate></item><item><title><![CDATA[Reply to Data Sources Does Not Appear on Fri, 08 Jun 2018 20:22:42 GMT]]></title><description><![CDATA[<p dir="auto">Guys that is wonderful news and I have updated the all our V3 servers.  However this same chrome error exists on our 2.8.8 systems as well.  Will you be updating the code for 2.8.8 to fix this ?</p>
]]></description><link>https://forum.mango-os.com/post/18791</link><guid isPermaLink="true">https://forum.mango-os.com/post/18791</guid><dc:creator><![CDATA[Phillip Weeks]]></dc:creator><pubDate>Fri, 08 Jun 2018 20:22:42 GMT</pubDate></item><item><title><![CDATA[Reply to Data Sources Does Not Appear on Mon, 04 Jun 2018 19:12:20 GMT]]></title><description><![CDATA[<p dir="auto">Ah ok, thank you !! It worked, was testing on 2 different PCs and all 2 were with Google Chrome.</p>
]]></description><link>https://forum.mango-os.com/post/18732</link><guid isPermaLink="true">https://forum.mango-os.com/post/18732</guid><dc:creator><![CDATA[leoboeng]]></dc:creator><pubDate>Mon, 04 Jun 2018 19:12:20 GMT</pubDate></item><item><title><![CDATA[Reply to Data Sources Does Not Appear on Mon, 04 Jun 2018 19:11:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> said in <a href="/post/18729">Data Sources Does Not Appear</a>:</p>
<p dir="auto">Uncaught ReferenceError: normal is not defined</p>
<p dir="auto">Also further references -<br />
<a href="https://stackoverflow.com/questions/50672599/dojo-uncaught-referenceerror-normal-is-not-defined" rel="nofollow ugc">https://stackoverflow.com/questions/50672599/dojo-uncaught-referenceerror-normal-is-not-defined</a><br />
<a href="https://github.com/kriszyp/xstyle/issues/44#issuecomment-76512785" rel="nofollow ugc">https://github.com/kriszyp/xstyle/issues/44#issuecomment-76512785</a></p>
]]></description><link>https://forum.mango-os.com/post/18731</link><guid isPermaLink="true">https://forum.mango-os.com/post/18731</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Mon, 04 Jun 2018 19:11:31 GMT</pubDate></item><item><title><![CDATA[Reply to Data Sources Does Not Appear on Mon, 04 Jun 2018 18:54:18 GMT]]></title><description><![CDATA[<p dir="auto">For searchability:</p>
<p dir="auto"><code>Uncaught ReferenceError: normal is not defined</code></p>
]]></description><link>https://forum.mango-os.com/post/18729</link><guid isPermaLink="true">https://forum.mango-os.com/post/18729</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 04 Jun 2018 18:54:18 GMT</pubDate></item><item><title><![CDATA[Reply to Data Sources Does Not Appear on Mon, 04 Jun 2018 18:50:28 GMT]]></title><description><![CDATA[<p dir="auto">Aha! Thanks for getting that information. This was caused by a very recent Chrome update that took issue with the code in one of the JavaScript libraries, xstyle. We've already found and fixed this in the  upcoming release by updating the xstyle library, so that'll be core 3.4.3 which will probably occur today or tomorrow. You may be able to use Firefox or Edge in the interim.</p>
]]></description><link>https://forum.mango-os.com/post/18728</link><guid isPermaLink="true">https://forum.mango-os.com/post/18728</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 04 Jun 2018 18:50:28 GMT</pubDate></item><item><title><![CDATA[Reply to Data Sources Does Not Appear on Mon, 04 Jun 2018 18:46:00 GMT]]></title><description><![CDATA[<p dir="auto">Follow the photos:</p>
<p dir="auto"><img src="https://camo.nodebb.org/7d43ccafd03c5d283e4e95926b8221716fbe075f?url=https%3A%2F%2Fi.imgur.com%2FcAicGEa.png" alt="8_1528137948373_123313.PNG" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/7789cc5b1e4fe7686835f7b1a76c77b10ab4d171?url=https%3A%2F%2Fi.imgur.com%2FtIzluxr.png" alt="7_1528137948373_1233124.PNG" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/02944066036766d71f172fffa7bb10e15bb61ae5?url=https%3A%2F%2Fi.imgur.com%2FVuBUx5i.png" alt="6_1528137948373_2143125.PNG" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/278dce0473a115e19e32c59630cd5df5e9507115?url=https%3A%2F%2Fi.imgur.com%2F4NUdePV.png" alt="5_1528137948373_1351461.PNG" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/2ccdaf767dc01e8c9a1ba31683787aee665ba437?url=https%3A%2F%2Fi.imgur.com%2FgfyeIDM.png" alt="4_1528137948373_1351451.PNG" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/0cd9189b0ad3cdc25f7030c9df31820bd97a5627?url=https%3A%2F%2Fi.imgur.com%2FLmIvY7h.png" alt="3_1528137948373_13514514.PNG" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/0e8d7fd71e386fea80a7c2fe0d88296e84c81365?url=https%3A%2F%2Fi.imgur.com%2FF3U4sc6.png" alt="2_1528137948372_1351541.PNG" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/b02a866e0369f551d24b137b66e77576133c2470?url=https%3A%2F%2Fi.imgur.com%2FCpOoL6v.png" alt="1_1528137948371_134541564.PNG" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/54353d8858222da95e86976ff600280ece0ca34f?url=https%3A%2F%2Fi.imgur.com%2FIp5fKLA.png" alt="0_1528137948370_12351446.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">The following errors appear in the browser:</p>
<p dir="auto"><img src="https://camo.nodebb.org/101246c8af62a780a4bda7a4c771ff07eba0555c?url=https%3A%2F%2Fi.imgur.com%2FWGyZBzx.png" alt="0_1528138090607_21414141.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/18727</link><guid isPermaLink="true">https://forum.mango-os.com/post/18727</guid><dc:creator><![CDATA[leoboeng]]></dc:creator><pubDate>Mon, 04 Jun 2018 18:46:00 GMT</pubDate></item><item><title><![CDATA[Reply to Data Sources Does Not Appear on Mon, 04 Jun 2018 18:36:28 GMT]]></title><description><![CDATA[<p dir="auto">No errors where? In your log file or your developer console? "I got the last version on the site" is NOT the information I requested. I wanted a version number.</p>
<p dir="auto">That page will <em>definitely</em> report that it has experienced a timeout if it has requested the resources and they haven't responded unless there is a JavaScript error occurring in your developer console. You can open the developer console by right clicking on the page and clicking 'inspect' then navigating the the console tab.</p>
]]></description><link>https://forum.mango-os.com/post/18726</link><guid isPermaLink="true">https://forum.mango-os.com/post/18726</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 04 Jun 2018 18:36:28 GMT</pubDate></item><item><title><![CDATA[Reply to Data Sources Does Not Appear on Mon, 04 Jun 2018 18:27:27 GMT]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">but no error appears, it stays in that page always not loading the data souce. I got the last version on the site, I started to give this problem and I downloaded the last version, I just started it and I keep the same thing.</p>
]]></description><link>https://forum.mango-os.com/post/18725</link><guid isPermaLink="true">https://forum.mango-os.com/post/18725</guid><dc:creator><![CDATA[leoboeng]]></dc:creator><pubDate>Mon, 04 Jun 2018 18:27:27 GMT</pubDate></item><item><title><![CDATA[Reply to Data Sources Does Not Appear on Mon, 04 Jun 2018 17:14:28 GMT]]></title><description><![CDATA[<p dir="auto">Hi leoboeng,</p>
<p dir="auto">Is there any output to the Mango/logs/ma.log or Mango/bin/logs/ma.log file when you try to open the data source page?</p>
<p dir="auto">What version of the Mango core do you have installed? Get this information either from /ui/administration/modules or /modules.shtm</p>
<p dir="auto">The image you shared doesn't appear to have an error coming back, or you didn't wait long enough to get a timeout message when trying to load the page. This makes me thing you could try deleting your Mango/work/jsp directory or that you may need to open your developer tools in the browser to check if there's an error loading the page.</p>
]]></description><link>https://forum.mango-os.com/post/18724</link><guid isPermaLink="true">https://forum.mango-os.com/post/18724</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 04 Jun 2018 17:14:28 GMT</pubDate></item></channel></rss>
