    Advice on moving components / controllers / services out of userModule
    37 Posts 3 Posters 46.4k Views 3 Watching
      @bobday said in Advice on moving components / controllers / services out of userModule:
      ok - do I need to change the base directory?
      Nope, userModule extends the mangoUI
      • B Offline
        BobDay
        well, doing exactly that, and setting the location to /modules/mangoUI/web/dev/userModule.js,
        left me with:
        "Failed to load AMD module modules/mangoUI/web/dev/userModule.js Error: Script error for "modules/mangoUI/web/dev/userModule.js" in Chrome console - no component error logged.
        and this file is there:
        define(['angular', 'require','./components/pushLamp.js'],
          function (angular, require, pushLamp) {
            userModule.filter('unsafe', ['$sce', function($sce) {
               return $sce.trustAsHtml;
            try
              userModule.component('pushLamp',pushLamp);
            catch(e)
              console.log('error: ', e);
          You've got the right idea, the first thing I suggest is to see if you can even manually load the userModule from your web browser
          [mangoURL]/modules/mangoUI/web/dev/userModule.js
          if you can pull that, then try with the components directory
            Hang on, your mango install is in /opt/mango36 ?
            Not in /opt/mango ?
            • B Offline
              BobDay
              yes, but using Mango36 in the url... as in /opt/mango36/overrides/web/modules/mangoUI/web/dev/userModule.js
              hmmm... does it need to live in /mango?
                nope, just wanted to make sure you did have the files inside the mango's installation directory regardless of how it is named.
                Did the http requests from your browser work?
                If the mango is on localhost it'd be localhost/modules/mangoUI/web/dev/userModule.js
                • B Offline
                  BobDay
                  nope. clearly have a path issue here...
                    if you're in linux, can you navigate to the directory where your usermodule is and enter
                    pwd
                    otherwise if in windows, open a command prompt in the location and enter
                    DIR
                    to print the path
                    • B Offline
                      BobDay
                      (osx)
                      pwd
                        nope that's definitely correct, check your directory permissions and the owner.
                        I'll wager mango itself may not have access to the file.
                        Whatever the user runs as in mango set that as your modules etc directories for a start.
                        up to web. everything inside that shouldn't matter.
                        We'll start with that and work our way up from there...
                        sudo chown [user]:[user] /opt/mango36/overrides -R
                        sudo find /opt/mango36/overrides -type d -exec chmod 755 {} \;
                        • B Offline
                          BobDay
                          @mattfox said in Advice on moving components / controllers / services out of userModule:
                          sudo find /opt/mango36/overrides -type d -exec chmod 755 {} ;
                          I assume it runs as root - I have to sudo to start it. In any event, the entire mango36 directory is recursively 755.
                          and still no joy.
                            ps aux | grep java
                            This will tell us what mango runs as. Also can you also print
                            ls -la /opt/mango36/overrides/web/modules/mangoUI/web/dev
                            • B Offline
                              BobDay
                              ps aux | grep java
                              ā–¶ ps aux | grep java
                              root             81841   1.4  5.1  8617284 855636 s000  S     1:51PM   4:13.58 /usr/bin/java -server -cp /opt/mango36/overrides/classes:/opt/mango36/classes:/opt/mango36/overrides/properties:/opt/mango36/overrides/lib/*:/opt/mango36/lib/* -Dma.home=/opt/mango36 -Djava.library.path=/opt/mango36/overrides/lib:/opt/mango36/lib:/usr/lib/jni/:/Users/bullit/.jenv/bin:/Users/bullit/local/n/bin/:/Users/bullit/local/n/bin/node:/opt/local/bin:/opt/local/sbin:/usr/local/bin:/usr/local/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin:/usr/local/git/bin:/Users/bullit/bin:/Users/bullit/local/n/bin:/usr/bin/pear:/usr/local/bin/dayone com.serotonin.m2m2.Main
                              bullit           87269   0.0  0.0  2424612   1248 s001  R+    3:42PM   0:00.00 grep --color=auto --exclude-dir=.bzr --exclude-dir=CVS --exclude-dir=.git --exclude-dir=.hg --exclude-dir=.svn java
                              bullit has read/write access...
                              • B Offline
                                BobDay
                                mangoUI/web/dev
                                ā–¶ cat /opt/mango36/overrides/web/modules/mangoUI/web/dev/userModule.js
                                    try
                                    catch(e)
                                ...just checking
                                  I know what i've done wrong....
                                  I didn't return the user module!
                                  So sorry man!
                                      try
                                      catch(e)
                                   return userModule; //MISSING THIS!!! aerghhh I hate mondays...
                                  Man I need a swift kick...
                                  • B Offline
                                    BobDay
                                    so WE did! same problem tho.
                                    lets take this back to chat...
                                      Fixed, just mixed up the full path of the file with the userModule URL after closer inspection.
                                      • B Offline
                                        BobDay
                                        ok, @MattFox... I feel like a post (as in dumb as one). Can you refresh me again as to how to now break out (and where to declare) the component's controller in its own file?
                                        userModule.js
                                        define(['angular', 'require','./push/pushLamp.js'],
                                            try
                                            catch(e)
                                            return userModule.js;
                                        pushLamp.js:
                                          pushCtrl.$inject = ['$scope','$timeout'];
                                          function pushCtrl($scope,$timeout) {
                                            const $ctrl = this;
                                            $ctrl.$onChanges = function (changes) {
                                              if (changes.points && Array.isArray($ctrl.points)) {
                                                $ctrl.point = $ctrl.points.find(p => p.xid === 'DP_ind_' + $ctrl.target);
                                                $ctrl.switchPoint = $ctrl.points.find(p => p.xid === 'DP_sw_' + $ctrl.target);
                                                $ctrl.ptCSS = { // point css values for color and blink; ex, ng-class=""
                                                  get color(){
                                                    if ($ctrl.point.color < 10) {
                                                      return 0;
                                                    return Math.floor($ctrl.point.value / 10)},
                                                  get blink(){return 'blink' + $ctrl.point.value % 10},
                                                  get colStyle(){return 'color'+this.color}
                                                $timeout(function() {
                                                  console.log('color:', $ctrl.ptCSS.colStyle, 'blink:', $ctrl.ptCSS.blink );
                                                },1000);
                                            $ctrl.pushed = function() {
                                              console.log($ctrl.switchPoint.value);
                                                if ($ctrl.switchPoint) {
                                                    $ctrl.switchPoint.toggleValue();
                                                  console.log('switch ' + $ctrl.target + ' was switched.' );
                                        return {
                                              templateUrl: '/modules/mangoUI/web/dev/push/push.html',
                                              bindings: {
                                                points: '<',
                                                target: '@'
                                              controller: pushCtrl
                                          I'm a little confused as to why you'd want to go that far but I believe you'd do something along the lines of..
                                          /opt/mango36/overrides/web/modules/mangoUI/web/dev/controllers/pushCtrl.js
                                              const $ctrl = this;
                                                    get color(){
                                                        return 0;
                                                  },1000);
                                          return pushCtrl;
                                          )};//define
                                          then pushLamp.js:
                                          define(['angular', 'require','/modules/web/mangoUI/web/dev/controllers/pushCtrl.js'], function (angular, require,pushCtrl) {
                                          return {
                                                bindings: {
                                                  points: '<',
                                                  target: '@'
                                          });//define
                                          I'm confident you can leverage require in the userModule.js to shorten that controller call into a single word but I've not done a great deal of angularJS lately due to other work commitments....
                                          • B Offline
                                            BobDay
                                            Thanks. I tried that, but obviously suffered pilot error in the process. Good point why bother...
