    Advice on moving components / controllers / services out of userModule
    37 Posts 3 Posters 47.7k Views 3 Watching
      Cool, if you're copying my structure, this is my advice:
      /opt/mango/overrides/web/modules/mangoUI/web/dev/userModule.js
      define(['angular', 'require','./components/pushLamp.js'],
      function (angular, require,pushLamp) {
      userModule.filter('unsafe', ['$sce', function($sce) {
            return $sce.trustAsHtml;
      try
      userModule.component('pushLamp',pushLamp);
      catch(e)
      console.log(e);
      /opt/mango/overrides/web/modules/mangoUI/web/dev/components/pushLamp.js
      pushCtrl.$inject = ['$scope','$timeout'];
        function pushCtrl($scope,$timeout) {
          const $ctrl = this;
          $ctrl.$onChanges = function (changes) {
            if (changes.points && Array.isArray($ctrl.points)) {
              $ctrl.point = $ctrl.points.find(p => p.xid === 'DP_ind_' + $ctrl.target);
              $ctrl.switchPoint = $ctrl.points.find(p => p.xid === 'DP_sw_' + $ctrl.target);
              $ctrl.ptCSS = { // point css values for color and blink; ex, ng-class=""
                get color(){
                  if ($ctrl.point.color < 10) {
                    return 0;
                  return Math.floor($ctrl.point.value / 10)},
                get blink(){return 'blink' + $ctrl.point.value % 10},
                get colStyle(){return 'color'+this.color}
              $timeout(function() {
                console.log('color:', $ctrl.ptCSS.colStyle, 'blink:', $ctrl.ptCSS.blink );
              },1000);
          $ctrl.pushed = function() {
            console.log($ctrl.switchPoint.value);
              if ($ctrl.switchPoint) {
                  $ctrl.switchPoint.toggleValue();
                console.log('switch ' + $ctrl.target + ' was switched.' );
       const template = '<div class="inner-circle" ng-class="[$ctrl.ptCSS.colStyle, $ctrl.ptCSS.blink]" ng-click="$ctrl.pushed()"><span class="buttonText" ng-bind-html="$ctrl.point.tags.indText | unsafe"></span> </div>'; // using $sce here to get pass <br>'s in text; flex-wrap also on
      // (used single quotes instead of backticks for post...)
      return {
            template: template,
            bindings: {
              points: '<',
              target: '@'
            controller: pushCtrl
      If you use try-catches you can identify errors that don't result in your usermodule breaking and thus losing all components in it.
      • B Offline
        BobDay
        ok - do I need to change the base directory?
          @bobday said in Advice on moving components / controllers / services out of userModule:
          Nope, userModule extends the mangoUI
          • B Offline
            BobDay
            well, doing exactly that, and setting the location to /modules/mangoUI/web/dev/userModule.js,
            left me with:
            "Failed to load AMD module modules/mangoUI/web/dev/userModule.js Error: Script error for "modules/mangoUI/web/dev/userModule.js" in Chrome console - no component error logged.
            and this file is there:
              function (angular, require, pushLamp) {
                try
                catch(e)
                  console.log('error: ', e);
              You've got the right idea, the first thing I suggest is to see if you can even manually load the userModule from your web browser
              [mangoURL]/modules/mangoUI/web/dev/userModule.js
              if you can pull that, then try with the components directory
                Hang on, your mango install is in /opt/mango36 ?
                Not in /opt/mango ?
                • B Offline
                  BobDay
                  yes, but using Mango36 in the url... as in /opt/mango36/overrides/web/modules/mangoUI/web/dev/userModule.js
                  hmmm... does it need to live in /mango?
                    nope, just wanted to make sure you did have the files inside the mango's installation directory regardless of how it is named.
                    Did the http requests from your browser work?
                    If the mango is on localhost it'd be localhost/modules/mangoUI/web/dev/userModule.js
                    • B Offline
                      BobDay
                      nope. clearly have a path issue here...
                        if you're in linux, can you navigate to the directory where your usermodule is and enter
                        pwd
                        otherwise if in windows, open a command prompt in the location and enter
                        DIR
                        to print the path
                        • B Offline
                          BobDay
                          (osx)
                          pwd
                            nope that's definitely correct, check your directory permissions and the owner.
                            I'll wager mango itself may not have access to the file.
                            Whatever the user runs as in mango set that as your modules etc directories for a start.
                            up to web. everything inside that shouldn't matter.
                            We'll start with that and work our way up from there...
                            sudo chown [user]:[user] /opt/mango36/overrides -R
                            sudo find /opt/mango36/overrides -type d -exec chmod 755 {} \;
                            • B Offline
                              BobDay
                              @mattfox said in Advice on moving components / controllers / services out of userModule:
                              sudo find /opt/mango36/overrides -type d -exec chmod 755 {} ;
                              I assume it runs as root - I have to sudo to start it. In any event, the entire mango36 directory is recursively 755.
                              and still no joy.
                                ps aux | grep java
                                This will tell us what mango runs as. Also can you also print
                                ls -la /opt/mango36/overrides/web/modules/mangoUI/web/dev
                                • B Offline
                                  BobDay
                                  ps aux | grep java
                                  ā–¶ ps aux | grep java
                                  root             81841   1.4  5.1  8617284 855636 s000  S     1:51PM   4:13.58 /usr/bin/java -server -cp /opt/mango36/overrides/classes:/opt/mango36/classes:/opt/mango36/overrides/properties:/opt/mango36/overrides/lib/*:/opt/mango36/lib/* -Dma.home=/opt/mango36 -Djava.library.path=/opt/mango36/overrides/lib:/opt/mango36/lib:/usr/lib/jni/:/Users/bullit/.jenv/bin:/Users/bullit/local/n/bin/:/Users/bullit/local/n/bin/node:/opt/local/bin:/opt/local/sbin:/usr/local/bin:/usr/local/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin:/usr/local/git/bin:/Users/bullit/bin:/Users/bullit/local/n/bin:/usr/bin/pear:/usr/local/bin/dayone com.serotonin.m2m2.Main
                                  bullit           87269   0.0  0.0  2424612   1248 s001  R+    3:42PM   0:00.00 grep --color=auto --exclude-dir=.bzr --exclude-dir=CVS --exclude-dir=.git --exclude-dir=.hg --exclude-dir=.svn java
                                  bullit has read/write access...
                                  • B Offline
                                    BobDay
                                    mangoUI/web/dev
                                    ā–¶ cat /opt/mango36/overrides/web/modules/mangoUI/web/dev/userModule.js
                                        try
                                        catch(e)
                                    ...just checking
                                      I know what i've done wrong....
                                      I didn't return the user module!
                                      So sorry man!
                                          try
                                          catch(e)
                                       return userModule; //MISSING THIS!!! aerghhh I hate mondays...
                                      Man I need a swift kick...
                                      • B Offline
                                        BobDay
                                        so WE did! same problem tho.
                                        lets take this back to chat...
                                          Fixed, just mixed up the full path of the file with the userModule URL after closer inspection.
                                          • B Offline
                                            BobDay
                                            ok, @MattFox... I feel like a post (as in dumb as one). Can you refresh me again as to how to now break out (and where to declare) the component's controller in its own file?
                                            userModule.js
                                            define(['angular', 'require','./push/pushLamp.js'],
                                                try
                                                catch(e)
                                                return userModule.js;
                                            pushLamp.js:
                                                const $ctrl = this;
                                                      get color(){
                                                          return 0;
                                                    },1000);
                                            return {
                                                  templateUrl: '/modules/mangoUI/web/dev/push/push.html',
                                                  bindings: {
                                                    points: '<',
                                                    target: '@'
