    Advice on moving components / controllers / services out of userModule
    37 Posts 3 Posters 46.6k Views 3 Watching
    • B Offline
      BobDay
      yes, but using Mango36 in the url... as in /opt/mango36/overrides/web/modules/mangoUI/web/dev/userModule.js
      hmmm... does it need to live in /mango?
        nope, just wanted to make sure you did have the files inside the mango's installation directory regardless of how it is named.
        Did the http requests from your browser work?
        If the mango is on localhost it'd be localhost/modules/mangoUI/web/dev/userModule.js
        • B Offline
          BobDay
          nope. clearly have a path issue here...
            if you're in linux, can you navigate to the directory where your usermodule is and enter
            pwd
            otherwise if in windows, open a command prompt in the location and enter
            DIR
            to print the path
            • B Offline
              BobDay
              (osx)
              pwd
                nope that's definitely correct, check your directory permissions and the owner.
                I'll wager mango itself may not have access to the file.
                Whatever the user runs as in mango set that as your modules etc directories for a start.
                up to web. everything inside that shouldn't matter.
                We'll start with that and work our way up from there...
                sudo chown [user]:[user] /opt/mango36/overrides -R
                sudo find /opt/mango36/overrides -type d -exec chmod 755 {} \;
                • B Offline
                  BobDay
                  @mattfox said in Advice on moving components / controllers / services out of userModule:
                  sudo find /opt/mango36/overrides -type d -exec chmod 755 {} ;
                  I assume it runs as root - I have to sudo to start it. In any event, the entire mango36 directory is recursively 755.
                  and still no joy.
                    ps aux | grep java
                    This will tell us what mango runs as. Also can you also print
                    ls -la /opt/mango36/overrides/web/modules/mangoUI/web/dev
                    • B Offline
                      BobDay
                      ps aux | grep java
                      ā–¶ ps aux | grep java
                      root             81841   1.4  5.1  8617284 855636 s000  S     1:51PM   4:13.58 /usr/bin/java -server -cp /opt/mango36/overrides/classes:/opt/mango36/classes:/opt/mango36/overrides/properties:/opt/mango36/overrides/lib/*:/opt/mango36/lib/* -Dma.home=/opt/mango36 -Djava.library.path=/opt/mango36/overrides/lib:/opt/mango36/lib:/usr/lib/jni/:/Users/bullit/.jenv/bin:/Users/bullit/local/n/bin/:/Users/bullit/local/n/bin/node:/opt/local/bin:/opt/local/sbin:/usr/local/bin:/usr/local/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin:/usr/local/git/bin:/Users/bullit/bin:/Users/bullit/local/n/bin:/usr/bin/pear:/usr/local/bin/dayone com.serotonin.m2m2.Main
                      bullit           87269   0.0  0.0  2424612   1248 s001  R+    3:42PM   0:00.00 grep --color=auto --exclude-dir=.bzr --exclude-dir=CVS --exclude-dir=.git --exclude-dir=.hg --exclude-dir=.svn java
                      bullit has read/write access...
                      • B Offline
                        BobDay
                        mangoUI/web/dev
                        ā–¶ cat /opt/mango36/overrides/web/modules/mangoUI/web/dev/userModule.js
                        define(['angular', 'require','./components/pushLamp.js'],
                          function (angular, require, pushLamp) {
                            userModule.filter('unsafe', ['$sce', function($sce) {
                               return $sce.trustAsHtml;
                            try
                              userModule.component('pushLamp',pushLamp);
                            catch(e)
                              console.log('error: ', e);
                        ...just checking
                          I know what i've done wrong....
                          I didn't return the user module!
                          So sorry man!
                              try
                              catch(e)
                           return userModule; //MISSING THIS!!! aerghhh I hate mondays...
                          Man I need a swift kick...
                          • B Offline
                            BobDay
                            so WE did! same problem tho.
                            lets take this back to chat...
                              Fixed, just mixed up the full path of the file with the userModule URL after closer inspection.
                              • B Offline
                                BobDay
                                ok, @MattFox... I feel like a post (as in dumb as one). Can you refresh me again as to how to now break out (and where to declare) the component's controller in its own file?
                                userModule.js
                                define(['angular', 'require','./push/pushLamp.js'],
                                    try
                                    catch(e)
                                    return userModule.js;
                                pushLamp.js:
                                  pushCtrl.$inject = ['$scope','$timeout'];
                                  function pushCtrl($scope,$timeout) {
                                    const $ctrl = this;
                                    $ctrl.$onChanges = function (changes) {
                                      if (changes.points && Array.isArray($ctrl.points)) {
                                        $ctrl.point = $ctrl.points.find(p => p.xid === 'DP_ind_' + $ctrl.target);
                                        $ctrl.switchPoint = $ctrl.points.find(p => p.xid === 'DP_sw_' + $ctrl.target);
                                        $ctrl.ptCSS = { // point css values for color and blink; ex, ng-class=""
                                          get color(){
                                            if ($ctrl.point.color < 10) {
                                              return 0;
                                            return Math.floor($ctrl.point.value / 10)},
                                          get blink(){return 'blink' + $ctrl.point.value % 10},
                                          get colStyle(){return 'color'+this.color}
                                        $timeout(function() {
                                          console.log('color:', $ctrl.ptCSS.colStyle, 'blink:', $ctrl.ptCSS.blink );
                                        },1000);
                                    $ctrl.pushed = function() {
                                      console.log($ctrl.switchPoint.value);
                                        if ($ctrl.switchPoint) {
                                            $ctrl.switchPoint.toggleValue();
                                          console.log('switch ' + $ctrl.target + ' was switched.' );
                                return {
                                      templateUrl: '/modules/mangoUI/web/dev/push/push.html',
                                      bindings: {
                                        points: '<',
                                        target: '@'
                                      controller: pushCtrl
                                  I'm a little confused as to why you'd want to go that far but I believe you'd do something along the lines of..
                                  /opt/mango36/overrides/web/modules/mangoUI/web/dev/controllers/pushCtrl.js
                                      const $ctrl = this;
                                            get color(){
                                                return 0;
                                          },1000);
                                  return pushCtrl;
                                  )};//define
                                  then pushLamp.js:
                                  define(['angular', 'require','/modules/web/mangoUI/web/dev/controllers/pushCtrl.js'], function (angular, require,pushCtrl) {
                                  return {
                                        bindings: {
                                          points: '<',
                                          target: '@'
                                  });//define
                                  I'm confident you can leverage require in the userModule.js to shorten that controller call into a single word but I've not done a great deal of angularJS lately due to other work commitments....
                                  • B Offline
                                    BobDay
                                    Thanks. I tried that, but obviously suffered pilot error in the process. Good point why bother...
                                      Just be careful with splitting out your user modules into too many files, you may hit the REST rate limiter and your page could fail to load. Test it out with cache disabled to make sure. You can adjust the rate limits in env.properties.
                                      As I mentioned in the other thread, you may want to consider using Webpack if your project becomes cumbersome.
                                      • B Offline
                                        BobDay
                                        yes - that occurred to me - might make things a little more straightforward. Thanks - didn't think about the REST rate issue. Is there anything about using Webpack with mango?
                                          @bobday said in Advice on moving components / controllers / services out of userModule:
                                          Not currently but I could put together a little help section tomorrow.
                                            Sorry to storm in but I think that'd be beneficial for a lot of people Jared. Also thanks for your input, I think I've lost sight of a few things lately!
