    Advice on moving components / controllers / services out of userModule
    37 Posts 3 Posters 47.6k Views 3 Watching
      No such thing as a stupid question if you learn something from it!
      This is a forum post I helped with a while ago. Sorry I should have been more explicit with my answer before
      https://forum.infiniteautomation.com/topic/3720/pop-up-window-face-plate/18
      It explains the directory structure I like to use and why.
      @bobday said in Advice on moving components / controllers / services out of userModule:
      also assume views/components/controllers, etc. directories would be siblings to userModule.js in the last child .../web folder
      Correct!
      • B Offline
        BobDay
        Thanks. still missing something...
        My userModule.js file is located at:
        '.../modules/mangoUI/web/dev/userModule.js,
        my userModule URL (in UI settings) changed to:
        /modules/mangoUI/web/dev/userModule.js, (from /rest/v2/file-stores/public...)
        and templateUrl at:
        templateUrl: '/modules/mangoUI/web/dev/views/push.html'
        How do I inform my app what my "base directory" is?
          If you've stored your userModule.js in /opt/mango/overrides/web/modules/mangoUI/web
          your usermodule under UI Settings will be
          modules/mangoUI/web/userModule.js
          base directory is stated in the app.js and /ui/index.html for mango which is compressed into the webpack that Jared compiled.
          Can you show me what you have now and I can likely assist with helping you getting one component working.
          • B Offline
            BobDay
            sure...
            with my userModule.js stored at opt/Mango36/filestore/public/userModule.js, and its UI location set at /rest/v2/file-stores/public/userModule.js,
            all works well.
            when stored at /opt/mango/overrides/web/modules/mangoUI/web/dev/userModule.js,
            and UI location set at /modules/mangoUI/web/dev/userModule.js,
            the component is not found.
            js:
              pushCtrl.$inject = ['$scope','$timeout'];
              function pushCtrl($scope,$timeout) {
                const $ctrl = this;
                $ctrl.$onChanges = function (changes) {
                  if (changes.points && Array.isArray($ctrl.points)) {
                    $ctrl.point = $ctrl.points.find(p => p.xid === 'DP_ind_' + $ctrl.target);
                    $ctrl.switchPoint = $ctrl.points.find(p => p.xid === 'DP_sw_' + $ctrl.target);
                    $ctrl.ptCSS = { // point css values for color and blink; ex, ng-class=""
                      get color(){
                        if ($ctrl.point.color < 10) {
                          return 0;
                        return Math.floor($ctrl.point.value / 10)},
                      get blink(){return 'blink' + $ctrl.point.value % 10},
                      get colStyle(){return 'color'+this.color}
                    $timeout(function() {
                      console.log('color:', $ctrl.ptCSS.colStyle, 'blink:', $ctrl.ptCSS.blink );
                    },1000);
                $ctrl.pushed = function() {
                  console.log($ctrl.switchPoint.value);
                    if ($ctrl.switchPoint) {
                        $ctrl.switchPoint.toggleValue();
                      console.log('switch ' + $ctrl.target + ' was switched.' );
              const template = '<div class="inner-circle" ng-class="[$ctrl.ptCSS.colStyle, $ctrl.ptCSS.blink]" ng-click="$ctrl.pushed()"><span class="buttonText" ng-bind-html="$ctrl.point.tags.indText | unsafe"></span> </div>'; // using $sce here to get pass <br>'s in text; flex-wrap also on
            // (used single quotes instead of backticks for post...)
              var userModule = angular.module('userModule', ['maUiApp'])
                .filter('unsafe', ['$sce', function($sce) {
                  return $sce.trustAsHtml;
                .component('pushLamp', {
                  template: template,
                  bindings: {
                    points: '<',
                    target: '@'
                  controller: pushCtrl
                return userModule;
            }); //define
            html:
            <style>
            html {
                font-size: 16px;
            @keyframes blink {
                80% {
                    background-color: #000;
                    color: #000;
                    text-shadow: none;
                100% {
                    color: #000;
                    text-shadow: none;
                    /*border: 5px solid #6565f2;*/
                box-sizing:border-box;
            .holder {
                height: 140px;
                width: 250px;
                display: flex;
                flex-direction: row;
                align-items: center;
                justify-content: space-between;
            .ring {
                position: relative;
                width: 104px;
                height: 104px;
                border-radius: 50%;
                /*background: #888;*/
                background: linear-gradient(#dadada, #7a7a7a);
            .inner-circle {
                position: relative;
                display: flex;
                flex-wrap: wrap;
              justify-content: center;
                top: 5px;
                left: 5px;
                width: 94px;
                height: 94px;
                /*background: green;*/
                border-radius: 50%;
                /*border: 5px solid rgba(255,255,255,0.1);*/
            span.buttonText {
                width: 80%;
                text-align:center; /*flex doesn't center all lines...*/
                overflow:none;
                text-decoration: none;
                font-size: 1.15rem;
                line-height: 1em;
                font-weight: 600;
                letter-spacing: -.065em;
                font-family: "Hammersmith One", sans-serif;
            .no-color,
            .color0 {
                background-color: #4a4a4a;
                color: #777;
                border: 4px solid rgba(255, 255, 255, 0.15);
            .red,
            .color1 {
                background-color: #ef3932;
                color: #faf9c3;
                text-shadow: 1px 1px 0 rgba(0, 0, 0, .15);
                border: 4px solid rgba(0, 0, 0, 0.15);
            .green,
            .color2 {
                background-color: #01c826;
                color: #faf697;
            .yellow,
            .color3 {
                background-color: rgba(252, 227, 1, 2);
                color: #8c1c00;
                text-shadow: 1px 1px 0 rgba(255, 255, 255, .9);
            .blue,
            .color4 {
                background: #00c8ff;
                color: #faf9c3;
            .white,
            .color5 {
                background: #fafafa;
                color: #8c1c00;
                text-shadow: 1px 1px 0 rgba(0, 0, 0, .1);
                border: 4px solid rgba(0, 0, 0, 0.1);
            .blink0 {
                animation: none;
            .blink1 {
                animation: none;
                /*animation: blink 2s infinite;*/
            .blink2 {
                animation: none;
                /*animation: blink 2s step-end infinite;*/
            .blink3 {
                animation: none;
            </style>
            <div ng-init="page = {}"></div>
            <ma-watch-list-get ng-model="indicatorWl.watchlist" parameters="indicatorWl.parameters" on-points-change="page.points = $points" id="wl-indicator-id" watch-list-xid="WL_Indicator"></ma-watch-list-get>
            <ma-get-point-value points="page.points"></ma-get-point-value>
            <div>
                <div class="holder">
                    <div class="ring">
                        <push-lamp points="page.points" target="H2OT1"></push-lamp>
                    <ma-point-value id="bf63d154-4359-4780-8440-e75ab17179c2" enable-popup="hide" point="page.points | filter:{name:'T1-Water-Valve'}:true | maFirst"></ma-point-value>
                    <div class="ring">
                        <push-lamp points="page.points" target="H2OT2"></push-lamp>
                    <ma-point-value id="bf63d154-4359-4780-8440-e75ab17179c2" enable-popup="hide" point="page.points | filter:{name:'T2-Water-Valve'}:true | maFirst"></ma-point-value> <!-- _sw_ values for toggle testing -->
                    <div class="ring">
                        <push-lamp points="page.points" target="H2OT3"></push-lamp>
                    <ma-point-value id="bf63d154-4359-4780-8440-e75ab17179c2" enable-popup="hide" point="page.points | filter:{name:'T3-Water-Valve'}:true | maFirst"></ma-point-value>
                    <div class="ring">
                        <push-lamp points="page.points" target="H2OMX"></push-lamp>
                    <ma-point-value id="bf63d154-4359-4780-8440-e75ab17179c2" enable-popup="hide" point="page.points | filter:{name:'MX-Water-Valve'}:true | maFirst"></ma-point-value>
            do you need some points?
              Cool, if you're copying my structure, this is my advice:
              define(['angular', 'require','./components/pushLamp.js'],
              function (angular, require,pushLamp) {
              userModule.filter('unsafe', ['$sce', function($sce) {
              try
              userModule.component('pushLamp',pushLamp);
              catch(e)
              console.log(e);
              /opt/mango/overrides/web/modules/mangoUI/web/dev/components/pushLamp.js
                  const $ctrl = this;
                        get color(){
                            return 0;
                      },1000);
              return {
                    template: template,
                    bindings: {
                      points: '<',
                      target: '@'
              If you use try-catches you can identify errors that don't result in your usermodule breaking and thus losing all components in it.
              • B Offline
                BobDay
                ok - do I need to change the base directory?
                  Nope, userModule extends the mangoUI
                  • B Offline
                    BobDay
                    well, doing exactly that, and setting the location to /modules/mangoUI/web/dev/userModule.js,
                    left me with:
                    "Failed to load AMD module modules/mangoUI/web/dev/userModule.js Error: Script error for "modules/mangoUI/web/dev/userModule.js" in Chrome console - no component error logged.
                    and this file is there:
                      function (angular, require, pushLamp) {
                        try
                        catch(e)
                          console.log('error: ', e);
                      You've got the right idea, the first thing I suggest is to see if you can even manually load the userModule from your web browser
                      [mangoURL]/modules/mangoUI/web/dev/userModule.js
                      if you can pull that, then try with the components directory
                        Hang on, your mango install is in /opt/mango36 ?
                        Not in /opt/mango ?
                        • B Offline
                          BobDay
                          yes, but using Mango36 in the url... as in /opt/mango36/overrides/web/modules/mangoUI/web/dev/userModule.js
                          hmmm... does it need to live in /mango?
                            nope, just wanted to make sure you did have the files inside the mango's installation directory regardless of how it is named.
                            Did the http requests from your browser work?
                            If the mango is on localhost it'd be localhost/modules/mangoUI/web/dev/userModule.js
                            • B Offline
                              BobDay
                              nope. clearly have a path issue here...
                                if you're in linux, can you navigate to the directory where your usermodule is and enter
                                pwd
                                otherwise if in windows, open a command prompt in the location and enter
                                DIR
                                to print the path
                                • B Offline
                                  BobDay
                                  (osx)
                                  pwd
                                    nope that's definitely correct, check your directory permissions and the owner.
                                    I'll wager mango itself may not have access to the file.
                                    Whatever the user runs as in mango set that as your modules etc directories for a start.
                                    up to web. everything inside that shouldn't matter.
                                    We'll start with that and work our way up from there...
                                    sudo chown [user]:[user] /opt/mango36/overrides -R
                                    sudo find /opt/mango36/overrides -type d -exec chmod 755 {} \;
                                    • B Offline
                                      BobDay
                                      @mattfox said in Advice on moving components / controllers / services out of userModule:
                                      sudo find /opt/mango36/overrides -type d -exec chmod 755 {} ;
                                      I assume it runs as root - I have to sudo to start it. In any event, the entire mango36 directory is recursively 755.
                                      and still no joy.
                                        ps aux | grep java
                                        This will tell us what mango runs as. Also can you also print
                                        ls -la /opt/mango36/overrides/web/modules/mangoUI/web/dev
                                        • B Offline
                                          BobDay
                                          ps aux | grep java
                                          ā–¶ ps aux | grep java
                                          root             81841   1.4  5.1  8617284 855636 s000  S     1:51PM   4:13.58 /usr/bin/java -server -cp /opt/mango36/overrides/classes:/opt/mango36/classes:/opt/mango36/overrides/properties:/opt/mango36/overrides/lib/*:/opt/mango36/lib/* -Dma.home=/opt/mango36 -Djava.library.path=/opt/mango36/overrides/lib:/opt/mango36/lib:/usr/lib/jni/:/Users/bullit/.jenv/bin:/Users/bullit/local/n/bin/:/Users/bullit/local/n/bin/node:/opt/local/bin:/opt/local/sbin:/usr/local/bin:/usr/local/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin:/usr/local/git/bin:/Users/bullit/bin:/Users/bullit/local/n/bin:/usr/bin/pear:/usr/local/bin/dayone com.serotonin.m2m2.Main
                                          bullit           87269   0.0  0.0  2424612   1248 s001  R+    3:42PM   0:00.00 grep --color=auto --exclude-dir=.bzr --exclude-dir=CVS --exclude-dir=.git --exclude-dir=.hg --exclude-dir=.svn java
                                          bullit has read/write access...
                                          • B Offline
                                            BobDay
                                            mangoUI/web/dev
                                            ā–¶ cat /opt/mango36/overrides/web/modules/mangoUI/web/dev/userModule.js
                                                try
                                                catch(e)
                                            ...just checking
