    Removing extreme values manually
    User help
    3
    5
    1.8k
    • M
      mihairosu
      Is there a way to manually remove extreme values, if the default settings were not enough, and we did not manually set them to something reasonable?
      For example, I have a value of 6000 F for outdoor temperature, and since I'm using a meta point for averaging daily and monthly temperature, this will throw it off.
      The extreme value discard did not catch this. How can I manually remove this value?.
      • terrypackerT
        You can remove individual point values via the dataImport module. The basic process is:
        1. Export the data around the time you want to delete into CSV/Excel
        2. Import data you want to modify (check the file format as there is a column to indicate add/delete)
        • M
          mihairosu
          1. I tried to export the data through the point details page, and I think this isn't the way, but I couldn't find another way:
          1. However, I don't have enough information to fill in all these columns that are required =(
          I can manually enter the XID, Device Name and Point Name.
          How can I get the Time, Rendered, and Annotation values?
          Also, am I supposed to type in either "add" or "delete" in the Modify column, as text?
          • JoelHaggarJ
            Try the Legacy Point Details page or the Watch List. On those two pages you should get the right format and have the option to export in xls format.
            • M
              mihairosu
              OK that was pretty easy. Thanks fellas.
              Also, for future reference, I did just type the text value "delete" (without quotes) in the modify column, that worked.
