<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Removing extreme values manually]]></title><description><![CDATA[<p dir="auto">Is there a way to manually remove extreme values, if the default settings were not enough, and we did not manually set them to something reasonable?</p>
<p dir="auto">For example, I have a value of 6000 F for outdoor temperature, and since I'm using a meta point for averaging daily and monthly temperature, this will throw it off.</p>
<p dir="auto">The extreme value discard did not catch this.  How can I manually remove this value?.</p>
]]></description><link>https://forum.mango-os.com/topic/2589/removing-extreme-values-manually</link><generator>RSS for Node</generator><lastBuildDate>Fri, 09 Oct 2026 16:45:22 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2589.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Dec 2016 15:08:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Removing extreme values manually on Sat, 10 Dec 2016 16:49:17 GMT]]></title><description><![CDATA[<p dir="auto">OK that was pretty easy.  Thanks fellas.</p>
<p dir="auto">Also, for future reference, I did just type the text value "delete" (without quotes) in the modify column, that worked.</p>
]]></description><link>https://forum.mango-os.com/post/13474</link><guid isPermaLink="true">https://forum.mango-os.com/post/13474</guid><dc:creator><![CDATA[mihairosu]]></dc:creator><pubDate>Sat, 10 Dec 2016 16:49:17 GMT</pubDate></item><item><title><![CDATA[Reply to Removing extreme values manually on Sat, 10 Dec 2016 16:43:07 GMT]]></title><description><![CDATA[<p dir="auto">Try the Legacy Point Details page or the Watch List.  On those two pages you should get the right format and have the option to export in xls format.</p>
]]></description><link>https://forum.mango-os.com/post/13473</link><guid isPermaLink="true">https://forum.mango-os.com/post/13473</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Sat, 10 Dec 2016 16:43:07 GMT</pubDate></item><item><title><![CDATA[Reply to Removing extreme values manually on Sat, 10 Dec 2016 15:55:36 GMT]]></title><description><![CDATA[<ol>
<li>I tried to export the data through the point details page, and I think this isn't the way, but I couldn't find another way:</li>
<p dir="auto"><img src="https://camo.nodebb.org/a29c189576631cac27101c11461ac05f2ec5ad59?url=https%3A%2F%2Fi.imgur.com%2FRDZWVtA.png" alt="0_1481385208208_dataexport.png" class=" img-fluid img-markdown" /></p>
<ol start="2">
<li>However, I don't have enough information to fill in all these columns that are required =(</li>
<p dir="auto">I can manually enter the XID, Device Name and Point Name.</p>
<p dir="auto">How can I get the Time, Rendered, and Annotation values?</p>
<p dir="auto">Also, am I supposed to type in either "add" or "delete" in the Modify column, as text?</p>
<p dir="auto"><img src="https://camo.nodebb.org/192d79e1ead10e05c997648a364af0c9bf9d4658?url=https%3A%2F%2Fi.imgur.com%2FhKelweO.png" alt="0_1481385231093_dataimportexample.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/13468</link><guid isPermaLink="true">https://forum.mango-os.com/post/13468</guid><dc:creator><![CDATA[mihairosu]]></dc:creator><pubDate>Sat, 10 Dec 2016 15:55:36 GMT</pubDate></item><item><title><![CDATA[Reply to Removing extreme values manually on Sat, 10 Dec 2016 15:29:06 GMT]]></title><description><![CDATA[<p dir="auto">You can remove individual point values via the dataImport module.  The basic process is:</p>
<li>Export the data around the time you want to delete into CSV/Excel</li>
<li>Import data you want to modify (check the file format as there is a column to indicate add/delete)</li>
]]></description><link>https://forum.mango-os.com/post/13467</link><guid isPermaLink="true">https://forum.mango-os.com/post/13467</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Sat, 10 Dec 2016 15:29:06 GMT</pubDate></item></channel></rss>
