    Scripting Data Source to create a parameter
    4 Posts 2 Posters 1.5k Views 2 Watching
    • BGB Offline
      BG
      Hello all,
      In Mango 3.7.12, Can anyone tell me how to write a script in the Scripting Data Source that would create a parameter that can then be picked up by a SQL Data Source script to use for setting a value in the MySQL database table?
      This to replace the Point Links feature where the source and target were from drop down lists.
      Cheers
      Brian
        MattFox @BG
        @BG the context points I mentioned in your other post where the source point is the context point that updates the context is ticked, the target is a context point that you set the value with the value of the source point.
        Point 1, variable name: source, updates context: true
        Point 2, var name: target, updates context: false
        In the script enter:
        target.set( source.value)
        BGB 1 Reply Last reply Reply Quote 0
        • BGB Offline
          BG @MattFox
          @MattFox Hello Matt,
          Thank you very much for spelling that out to me.
          Here's the rub though.
          I am trying to use a timestamp to update an integer. So on validation I got this message:
          Setting point 0100raw - 0100-zflag to 2024-03-14 09:20:00.0 @ 12 Apr 2024 07:54:01 UTC
          What I really need is the parameter to set a 1 when the timestamp updates.
          In the old point links I had a simple line,
          Return '(1)';
          So I tried something actually quite simple once you know. I left the timestamp as the update context and used this script:
          target.set('(1)')
          I assumed that the example Phil put on the forum all those years ago required me to assign the target and source point in the script code.
          Sometime I can't see the forest for the trees.
          So HUGE THANKS Matt. I can now get my system running and I now know how to take it into Mango 4 hopefully.
          Cheers
          Brian
          MattFoxM 1 Reply Last reply Reply Quote 1
            MattFox @BG
            @BG meta are virtual datapoints that can return a value. Scripting datasource scripts are functions that run an alert or can send/set data to a variety of destinations. The benefit of a scripting datasource though is it doesn't cost you your datapoint count.
            But do note that because it's a datasource, it doesn't retain a value
            Also, fantastic news on your progress. I'm always about and happy to assist if you need me. Email is fine too!
