Scripting Data Source to create a parameter
Hello all,
In Mango 3.7.12, Can anyone tell me how to write a script in the Scripting Data Source that would create a parameter that can then be picked up by a SQL Data Source script to use for setting a value in the MySQL database table?This to replace the Point Links feature where the source and target were from drop down lists.
Brian
@BG the context points I mentioned in your other post where the source point is the context point that updates the context is ticked, the target is a context point that you set the value with the value of the source point.
Point 1, variable name: source, updates context: true
Point 2, var name: target, updates context: falseIn the script enter:
target.set( source.value)Fox
@MattFox Hello Matt,
Thank you very much for spelling that out to me.
Here's the rub though.I am trying to use a timestamp to update an integer. So on validation I got this message:
Setting point 0100raw - 0100-zflag to 2024-03-14 09:20:00.0 @ 12 Apr 2024 07:54:01 UTC
What I really need is the parameter to set a 1 when the timestamp updates.
In the old point links I had a simple line,Return '(1)';
So I tried something actually quite simple once you know. I left the timestamp as the update context and used this script:
target.set('(1)')
I assumed that the example Phil put on the forum all those years ago required me to assign the target and source point in the script code.
Sometime I can't see the forest for the trees.
So HUGE THANKS Matt. I can now get my system running and I now know how to take it into Mango 4 hopefully.
Brian -
@BG meta are virtual datapoints that can return a value. Scripting datasource scripts are functions that run an alert or can send/set data to a variety of destinations. The benefit of a scripting datasource though is it doesn't cost you your datapoint count.
But do note that because it's a datasource, it doesn't retain a valueAlso, fantastic news on your progress. I'm always about and happy to assist if you need me. Email is fine too!
