    A Bit Stuck on Writing Multiple MODBUS Registers
    44 Posts 4 Posters 63.3k Views 4 Watching
      Ok, so I can understand using 166774 gives you 0x00028b76, basically just bit shifts the entire thing in. And that by using a holding register implicitly puts a 4 in the front so only 104 is needed... But if the manual states you need a control key into 8 and its 1's complement into register 9, shouldn't it be 0x8B768B76 = 2339801974 DEC?
      • danD Offline
        dan
        OK, now my brain is really hurting, I'll turn on the i/o log and see what mine is outputting.
        Just to clarify a little further, the MODBUS register I need to write to is on 'Page 16', the manual says to multiply 256 x Page then add the Offset, so in this case I'm on (256 x 16) + 8 = 4104
        When reading off battery voltages and other engine diagnostics off this the formula seems to work.
        I'll try again with the decimal.
        Cheers
        • danD Offline
          dan
          • danD Offline
            dan
            Interestingly, when I write the hex values I get this pop up error..
            Nothing written in the log during this time however :/
            • cwangvC Offline
              cwangv @dan
              @dan
              just curious why the 'Number of registers' is '0'? shouldn't be at least '1'?
                It's greyed out and disabled.
                • CraigWebC Offline
                  CraigWeb
                  Hi Dan
                  Regarding the address, I think you are correct. Well since other address work you are correct. If 4104 is not working I would try 4103.
                  I think @MattFox is correct regarding the ones's compliment that needs to be written to address 9. I get a different number tho.
                    I think your answer is right here craig, something is amiss with how I did it, but looking at it now, I think we're all starting to break the back of it.
                    • danD Offline
                      dan
                      Hey Guys, thanks again for helping out. That's a big number. I'll give that one a go, I'll try it into 4104 and 4103.
                      Cheers
                      Dan
                      • danD Offline
                        dan
                        Interestingly I get a timeout message if I try writing the whole decimal number to either data point register.
                        If I change back to a hex value it just comes up with the top blue error again.
                        • danD Offline
                          dan
                          although might actually currently be a timeout in the network, as it's on the top of a mountain in NZ. at the end of a Mimomax link :/
                          I do believe it's snowing up there currently..
                          • danD Offline
                            dan
                            Bugga, still same timeout message when network is responding better.
                            com.serotonin.modbus4j.exception.ModbusTransportException: java.net.SocketTimeoutException: connect timed out
                            If I interrogate a standard read point it works fine.
                              MattFox @dan
                              @dan Sounds like I need to make a roadtrip! Haha
                              • danD Offline
                                dan
                                With a bloody big hammer.
                                • CraigWebC Offline
                                  CraigWeb
                                  Seems like perfect troubleshooting conditions :)
                                  ye so basically no response from the command. Only thing I can suggest is checking if the actual number is causing the "no response" by sending a different digit. is the modbus request going over the network or do you have a local mango instance there ?
                                  • danD Offline
                                    dan
                                    Yeh the Mango instance is a few hundred ms away. It seems to work fine reading in voltages and RPM's and the like. Just been playing up a little today probably due to the weather.
                                    Even when it was working fine the write function still didn't seem to be the correct syntax.
                                    • CraigWebC Offline
                                      CraigWeb
                                      If I was troubleshooting I would create data points instead of using the modbus tool. It looks like you are using quite an old version of mango and I have had issues with the modbus tool in older versions. I think it would be worth cancelling that out of the troubleshooting.
                                      • danD Offline
                                        dan
                                        OK, thanks Craig. I have a data point I made earlier which I will go back to and see what it does.
                                        • danD Offline
                                          dan
                                          So I emailed DSE from their website contact form for shits and giggles, not really expecting to hear back... A nice fella from the UK emailed back almost immediately with all the official docs on the thing. I thought that was awesome.. Anyway, here's a more explanatory version of what I had found originally...
                                          So looking at that, I should be sending 35702 to 4104 and 29833 to 4105
                                          I'll give that a go..
                                          • CraigWebC Offline
                                            CraigWeb
                                            I may be wrong here but I am pretty sure that the only way that mango will write them in the same command is if you use 1 x 4-byte data point.
