    44 Posts 4 Posters 63.3k Views 4 Watching
      I think your answer is right here craig, something is amiss with how I did it, but looking at it now, I think we're all starting to break the back of it.
      • danD Offline
        dan
        Hey Guys, thanks again for helping out. That's a big number. I'll give that one a go, I'll try it into 4104 and 4103.
        Dan
        • danD Offline
          dan
          Interestingly I get a timeout message if I try writing the whole decimal number to either data point register.
          If I change back to a hex value it just comes up with the top blue error again.
          • danD Offline
            dan
            although might actually currently be a timeout in the network, as it's on the top of a mountain in NZ. at the end of a Mimomax link :/
            I do believe it's snowing up there currently..
            • danD Offline
              dan
              Bugga, still same timeout message when network is responding better.
              com.serotonin.modbus4j.exception.ModbusTransportException: java.net.SocketTimeoutException: connect timed out
              If I interrogate a standard read point it works fine.
                MattFox @dan
                @dan Sounds like I need to make a roadtrip! Haha
                • danD Offline
                  dan
                  With a bloody big hammer.
                    Seems like perfect troubleshooting conditions :)
                    ye so basically no response from the command. Only thing I can suggest is checking if the actual number is causing the "no response" by sending a different digit. is the modbus request going over the network or do you have a local mango instance there ?
                    • danD Offline
                      dan
                      Yeh the Mango instance is a few hundred ms away. It seems to work fine reading in voltages and RPM's and the like. Just been playing up a little today probably due to the weather.
                      Even when it was working fine the write function still didn't seem to be the correct syntax.
                        If I was troubleshooting I would create data points instead of using the modbus tool. It looks like you are using quite an old version of mango and I have had issues with the modbus tool in older versions. I think it would be worth cancelling that out of the troubleshooting.
                        • danD Offline
                          dan
                          OK, thanks Craig. I have a data point I made earlier which I will go back to and see what it does.
                          • danD Offline
                            dan
                            So I emailed DSE from their website contact form for shits and giggles, not really expecting to hear back... A nice fella from the UK emailed back almost immediately with all the official docs on the thing. I thought that was awesome.. Anyway, here's a more explanatory version of what I had found originally...
                            So looking at that, I should be sending 35702 to 4104 and 29833 to 4105
                            I'll give that a go..
                              I may be wrong here but I am pretty sure that the only way that mango will write them in the same command is if you use 1 x 4-byte data point.
                              • danD Offline
                                dan
                                ok sweet as, thanks for that I'll give it a go
                                  You should capture the command with Wireshark and see if it matches what you are expecting.
                                  • danD Offline
                                    dan
                                    I tried a little bit of script magic to see if it would do it at the same time, but I think still not quick enough..
                                    I guess I need to combine the two 16 bit values into one 32 bit value, then write that to the single register, which should extend to the second yeh?
                                      exactly
