    Advice on moving components / controllers / services out of userModule
    37 Posts 3 Posters 47.6k Views 3 Watching
    • B Offline
      BobDay
      @mattfox said in Advice on moving components / controllers / services out of userModule:
      sudo find /opt/mango36/overrides -type d -exec chmod 755 {} ;
      I assume it runs as root - I have to sudo to start it. In any event, the entire mango36 directory is recursively 755.
      and still no joy.
        ps aux | grep java
        This will tell us what mango runs as. Also can you also print
        ls -la /opt/mango36/overrides/web/modules/mangoUI/web/dev
        • B Offline
          BobDay
          ps aux | grep java
          ā–¶ ps aux | grep java
          root             81841   1.4  5.1  8617284 855636 s000  S     1:51PM   4:13.58 /usr/bin/java -server -cp /opt/mango36/overrides/classes:/opt/mango36/classes:/opt/mango36/overrides/properties:/opt/mango36/overrides/lib/*:/opt/mango36/lib/* -Dma.home=/opt/mango36 -Djava.library.path=/opt/mango36/overrides/lib:/opt/mango36/lib:/usr/lib/jni/:/Users/bullit/.jenv/bin:/Users/bullit/local/n/bin/:/Users/bullit/local/n/bin/node:/opt/local/bin:/opt/local/sbin:/usr/local/bin:/usr/local/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin:/usr/local/git/bin:/Users/bullit/bin:/Users/bullit/local/n/bin:/usr/bin/pear:/usr/local/bin/dayone com.serotonin.m2m2.Main
          bullit           87269   0.0  0.0  2424612   1248 s001  R+    3:42PM   0:00.00 grep --color=auto --exclude-dir=.bzr --exclude-dir=CVS --exclude-dir=.git --exclude-dir=.hg --exclude-dir=.svn java
          bullit has read/write access...
          • B Offline
            BobDay
            mangoUI/web/dev
            ā–¶ cat /opt/mango36/overrides/web/modules/mangoUI/web/dev/userModule.js
            define(['angular', 'require','./components/pushLamp.js'],
              function (angular, require, pushLamp) {
                userModule.filter('unsafe', ['$sce', function($sce) {
                   return $sce.trustAsHtml;
                try
                  userModule.component('pushLamp',pushLamp);
                catch(e)
                  console.log('error: ', e);
            ...just checking
              I know what i've done wrong....
              I didn't return the user module!
              So sorry man!
                  try
                  catch(e)
               return userModule; //MISSING THIS!!! aerghhh I hate mondays...
              Man I need a swift kick...
              • B Offline
                BobDay
                so WE did! same problem tho.
                lets take this back to chat...
                  Fixed, just mixed up the full path of the file with the userModule URL after closer inspection.
                  • B Offline
                    BobDay
                    ok, @MattFox... I feel like a post (as in dumb as one). Can you refresh me again as to how to now break out (and where to declare) the component's controller in its own file?
                    userModule.js
                    define(['angular', 'require','./push/pushLamp.js'],
                        try
                        catch(e)
                        return userModule.js;
                    pushLamp.js:
                    define(['angular', 'require'], function (angular, require) {
                      pushCtrl.$inject = ['$scope','$timeout'];
                      function pushCtrl($scope,$timeout) {
                        const $ctrl = this;
                        $ctrl.$onChanges = function (changes) {
                          if (changes.points && Array.isArray($ctrl.points)) {
                            $ctrl.point = $ctrl.points.find(p => p.xid === 'DP_ind_' + $ctrl.target);
                            $ctrl.switchPoint = $ctrl.points.find(p => p.xid === 'DP_sw_' + $ctrl.target);
                            $ctrl.ptCSS = { // point css values for color and blink; ex, ng-class=""
                              get color(){
                                if ($ctrl.point.color < 10) {
                                  return 0;
                                return Math.floor($ctrl.point.value / 10)},
                              get blink(){return 'blink' + $ctrl.point.value % 10},
                              get colStyle(){return 'color'+this.color}
                            $timeout(function() {
                              console.log('color:', $ctrl.ptCSS.colStyle, 'blink:', $ctrl.ptCSS.blink );
                            },1000);
                        $ctrl.pushed = function() {
                          console.log($ctrl.switchPoint.value);
                            if ($ctrl.switchPoint) {
                                $ctrl.switchPoint.toggleValue();
                              console.log('switch ' + $ctrl.target + ' was switched.' );
                    return {
                          templateUrl: '/modules/mangoUI/web/dev/push/push.html',
                          bindings: {
                            points: '<',
                            target: '@'
                          controller: pushCtrl
                      I'm a little confused as to why you'd want to go that far but I believe you'd do something along the lines of..
                      /opt/mango36/overrides/web/modules/mangoUI/web/dev/controllers/pushCtrl.js
                          const $ctrl = this;
                                get color(){
                                    return 0;
                              },1000);
                      return pushCtrl;
                      )};//define
                      then pushLamp.js:
                      define(['angular', 'require','/modules/web/mangoUI/web/dev/controllers/pushCtrl.js'], function (angular, require,pushCtrl) {
                      return {
                            bindings: {
                              points: '<',
                              target: '@'
                      });//define
                      I'm confident you can leverage require in the userModule.js to shorten that controller call into a single word but I've not done a great deal of angularJS lately due to other work commitments....
                      • B Offline
                        BobDay
                        Thanks. I tried that, but obviously suffered pilot error in the process. Good point why bother...
                          Just be careful with splitting out your user modules into too many files, you may hit the REST rate limiter and your page could fail to load. Test it out with cache disabled to make sure. You can adjust the rate limits in env.properties.
                          As I mentioned in the other thread, you may want to consider using Webpack if your project becomes cumbersome.
                          • B Offline
                            BobDay
                            yes - that occurred to me - might make things a little more straightforward. Thanks - didn't think about the REST rate issue. Is there anything about using Webpack with mango?
                              @bobday said in Advice on moving components / controllers / services out of userModule:
                              Not currently but I could put together a little help section tomorrow.
                                Sorry to storm in but I think that'd be beneficial for a lot of people Jared. Also thanks for your input, I think I've lost sight of a few things lately!
                                • B Offline
                                  BobDay
                                  Thanks, @Jared-Wiltshire. Let me bug you when things appear to be getting out of hand!
                                  • B Offline
                                    BobDay
                                    well, on second thought then, that would be super!
                                      @BobDay @MattFox
                                      https://forum.infiniteautomation.com/topic/4607/using-webpack-with-user-modules
                                      With your input, this post could be even better šŸ’—
