    Advice on moving components / controllers / services out of userModule
    37 Posts 3 Posters 47.7k Views 3 Watching
    • B Offline
      BobDay
      so WE did! same problem tho.
      lets take this back to chat...
        Fixed, just mixed up the full path of the file with the userModule URL after closer inspection.
        • B Offline
          BobDay
          ok, @MattFox... I feel like a post (as in dumb as one). Can you refresh me again as to how to now break out (and where to declare) the component's controller in its own file?
          userModule.js
          define(['angular', 'require','./push/pushLamp.js'],
            function (angular, require, pushLamp) {
              userModule.filter('unsafe', ['$sce', function($sce) {
                 return $sce.trustAsHtml;
              try
                userModule.component('pushLamp',pushLamp);
              catch(e)
                console.log('error: ', e);
              return userModule.js;
          pushLamp.js:
            pushCtrl.$inject = ['$scope','$timeout'];
            function pushCtrl($scope,$timeout) {
              const $ctrl = this;
              $ctrl.$onChanges = function (changes) {
                if (changes.points && Array.isArray($ctrl.points)) {
                  $ctrl.point = $ctrl.points.find(p => p.xid === 'DP_ind_' + $ctrl.target);
                  $ctrl.switchPoint = $ctrl.points.find(p => p.xid === 'DP_sw_' + $ctrl.target);
                  $ctrl.ptCSS = { // point css values for color and blink; ex, ng-class=""
                    get color(){
                      if ($ctrl.point.color < 10) {
                        return 0;
                      return Math.floor($ctrl.point.value / 10)},
                    get blink(){return 'blink' + $ctrl.point.value % 10},
                    get colStyle(){return 'color'+this.color}
                  $timeout(function() {
                    console.log('color:', $ctrl.ptCSS.colStyle, 'blink:', $ctrl.ptCSS.blink );
                  },1000);
              $ctrl.pushed = function() {
                console.log($ctrl.switchPoint.value);
                  if ($ctrl.switchPoint) {
                      $ctrl.switchPoint.toggleValue();
                    console.log('switch ' + $ctrl.target + ' was switched.' );
          return {
                templateUrl: '/modules/mangoUI/web/dev/push/push.html',
                bindings: {
                  points: '<',
                  target: '@'
                controller: pushCtrl
            I'm a little confused as to why you'd want to go that far but I believe you'd do something along the lines of..
            /opt/mango36/overrides/web/modules/mangoUI/web/dev/controllers/pushCtrl.js
                const $ctrl = this;
                      get color(){
                          return 0;
                    },1000);
            return pushCtrl;
            )};//define
            then pushLamp.js:
            define(['angular', 'require','/modules/web/mangoUI/web/dev/controllers/pushCtrl.js'], function (angular, require,pushCtrl) {
            return {
                  bindings: {
                    points: '<',
                    target: '@'
            });//define
            I'm confident you can leverage require in the userModule.js to shorten that controller call into a single word but I've not done a great deal of angularJS lately due to other work commitments....
            • B Offline
              BobDay
              Thanks. I tried that, but obviously suffered pilot error in the process. Good point why bother...
                Just be careful with splitting out your user modules into too many files, you may hit the REST rate limiter and your page could fail to load. Test it out with cache disabled to make sure. You can adjust the rate limits in env.properties.
                As I mentioned in the other thread, you may want to consider using Webpack if your project becomes cumbersome.
                • B Offline
                  BobDay
                  yes - that occurred to me - might make things a little more straightforward. Thanks - didn't think about the REST rate issue. Is there anything about using Webpack with mango?
                    @bobday said in Advice on moving components / controllers / services out of userModule:
                    Not currently but I could put together a little help section tomorrow.
                      Sorry to storm in but I think that'd be beneficial for a lot of people Jared. Also thanks for your input, I think I've lost sight of a few things lately!
                      • B Offline
                        BobDay
                        Thanks, @Jared-Wiltshire. Let me bug you when things appear to be getting out of hand!
                        • B Offline
                          BobDay
                          well, on second thought then, that would be super!
                            @BobDay @MattFox
                            https://forum.infiniteautomation.com/topic/4607/using-webpack-with-user-modules
