    HSTS causing HTTPS redirect loop
    18 Posts 4 Posters 3.9k Views 4 Watching
    • cbyrneC Offline
      cbyrne
      Hey guys, hoping someone can point out my mistake but I am trying to get HTTPS redirecting working but I currently have a redirect loop happening somewhere.
      I have mango running on a VS with ip $IP.
      I have a DNS A record of my main domain pointing a subdomain to $IP.
      Originally I had a rule in .htaccess to send all http to https but I've taken it out for now.
      I've enabled SSL and HSTS in env.properties and accessing the https://subdomain.domain.com works perfectly. However, when accessing http:... for the first time it causes a redirect loop.
      Disabling HSTS and applying a catch-all http -> https rule in .htaccess doesn't seem to work as you end up at http and no redirect seems to occur.
      If you restart mango while HSTS is enabled, you'll get to see the loading screen for mango as it boots up and then at 100% is stays on "mango is running". Then a refresh of the page causes a redirect loop.
      However, if you manually go to the https first, then try the http you will be redirected properly. Clear the cache and go to to http and you'll get the redirect loop again.
      Firefox inspection:
      If anyone has any ideas, that'd be great!
      Software Developer for GLAS Energy Technology, Ireland
        Mango uses tomcat server not apache 2.4 for the web service so an .htaccess based redirect will not work.
        Are you using the SSL cert within mango? If sure, be sure to follow through with this thread here as someone has worked out how to get SSL working with mango.
        I personally use an apache proxy with mango as I'm running multiple web based domains on the same dedicated server.
        https://forum.infiniteautomation.com/topic/4331/ssl-installation-on-the-mango-cloud/14
        Be sure to also check help.infiniteautomation.com as that provides info on using SSL.
          Hi cbyrne,
          I was going to refrain from answering until I had looked into these questions in specific, but, @MattFox said,
          Mango is using Jetty (tomcat is the webserver in Mango m2m2, so pre-Mango Automation and pre-Infinite Automation), and if all of the webserver traffic is going through Apache you can certainly set up virtual hosts to handle the traffic redirect for you, although probably not through .htaccess files since that scheme is more directed toward file servers / website servers rather than Apache serving as an application proxy.
          As to using SSL, you can also have something like Apache proxying the SSL traffic or you can have Apache handling the encryption and forwarding the traffic on a non-SSL connection to Mango, eliminating the need for a java keystore.
          • cbyrneC Offline
            cbyrne
            Hi guys,
            From following @phildunlap 's instructions in a previous thread, I made my keystore and got mango to use it just fine. So I do have a working https connection to the mango instance.
            The httaccess is on our base webserver, mango lives on a completely separate VPS.
            So the issue isn't with getting SSL working, it does, but rather when redirected to the loop is made.
            In the mean time I'll look into how apache proxy's work as an alternative!
              I use an apache proxy and integrated it with lets encrypt. Happy to offer advice if needed
              cbyrneC 1 Reply Last reply Reply Quote 0
              • cbyrneC Offline
                cbyrne @MattFox
                @mattfox Thanks Matt, I may well do that. I'll try it in the morning and update this post later on in the day.
                • cbyrneC Offline
                  cbyrne
                  All working now. Here's my solution using an Apache proxy as advised by @MattFox.
                  Starting with a mango installation running on port 8080 and not handling ssl.
                  1. Make sure you have httpd and mod_ssl installed.
                  2. Place SSL cert files (your cert, cert bundle and key) in a directory of your choosing.
                  3. Check for ssl.conf. Installing mod_ssl created a ssl.conf in /etc/httpd/conf.d/ which I had to disable (I just named it ssl.conf.old). It overrode my SSL settings below and used the packaged self-signed cert.
                  4. Make a new config file eg. /etc/httpd/conf.d/mango.conf
                  5. Populate is as follows:
                  <VirtualHost *:80>
                      Redirect permanent / https://subdomain.maindomain.com
                  </VirtualHost>
                  <VirtualHost *:443>
                      ProxyPreserveHost On
                      SSLEngine On
                      SSLCertificateFile "path/to/your.crt"
                      SSLCertificateChainFile "/path/to/your.ca-bundle"
                      SSLCertificateKeyFile "/path/to/your_key"
                      ProxyPass / http://127.0.0.1:8080/
                      ProxyPassReverse / http://127.0.0.1:8080/
                  </VirtualHost>
                  1. Restart the httpd service.
                  If anyone notices any loopholes or things I could add to harden it up please let me know.
                    I suspect this thread may be of some assistance: https://forum.infiniteautomation.com/topic/3892/latest-version-3-5-5-appears-to-fail-rendering-data/14
                    I would expect you may be seeing websocket issues currently.
                      You've forgotten the http rewrite to handle web sockets. Proxy only works for http traffic. Add a redirect to ensure websockets get redirected to port 443 to 8080 if I recall correctly.
                        A colleague of mine pointed out that to use the HTTP2 protocol (which should provide faster initial page loading) Mango must be running on SSL with a keystore, and have ALPN enabled (see Mango/bin/ext-available). I would not expect using HTTP2 to have a significant effect on REST requests.
                          Correct, the push provided by HTTP/2 is for file resources only.
                          Although I'm hoping to change that once my dashboard gets moved into a web directory...
                          • terrypackerT Offline
                            terrypacker
                            I wrote this help article not too long ago which may provide some insight into configuring the Apache proxy.
                            https://help.infiniteautomation.com/proxy
                              Thanks Terry! I was unaware that existed on the help site.
                              • cbyrneC Offline
                                cbyrne
                                Perfect, thanks for all your help @terrypacker @MattFox @phildunlap.
                                edit:
                                @terrypacker Quick question regarding the help article
                                0_1565944443039_Screenshot_2019-08-16 Proxy — Infinite Automation Support.png
                                Specifically "we set the Host and Origin to the public facing server".
                                Isn't "mango.example.com" the private facing address?
                                • cbyrneC Offline
                                  cbyrne
                                  Actually I spoke too soon, proxying web sockets isn't working yet. I followed your example in the other thread @phildunlap but unfortunately I'm still getting errors. Perhaps my rewrite rule is incorrect for a localhost address?
                                  My config:
                                  <VirtualHost *:80>
                                      Redirect permanent / https://ems1.glasenergytechnology.ie/
                                  </VirtualHost>
                                  Listen 443
                                  <VirtualHost *:443>
                                      ProxyPreserveHost Off
                                      ServerName sub.domain.com
                                      ServerAlias sub.domain.com
                                      ProxyRequests On
                                      RewriteEngine On
                                      RewriteCond %{HTTP:Upgrade} =websocket
                                      RewriteRule /(.*) ws://127.0.0.1:8080/$1 [P,L]
                                      RewriteCond %{HTTP:Upgrade} !=websocket
                                      RewriteRule /(.*) http://127.0.0.1:8080/$1 [P,L]
                                      RequestHeader set Host sub.domain.com
                                      RequestHeader set Origin "http://sub.domain.com"
                                      Header edit Location ^http://sub.domain.com https://sub.domain.com
                                      CustomLog "/var/log/apache-access-public-mango.log" common
                                      ErrorLog "/var/log/apache-error-public-mango.log"
                                      SSLEngine On
                                      SSLProxyEngine On
                                      SSLCertificateFile "/path/to/crt"
                                      SSLCertificateChainFile "/path/to/ca-bundle"
                                      SSLCertificateKeyFile "/path/to/private_key"
                                  </VirtualHost>
                                    Man your ssl conf file is messy!
                                    You've got an uneccessary rewrite rule. You've got a condition asking for a websocket upgrade check and then applying an http rule to it! Unless you're redirecting, just leave the http stuff to the proxy rules.
                                    Here, follow this:
                                    #STRAIGHT HTTP, THIS REDIRECTS
                                    <VirtualHost *:80>
                                    ServerName subdomain.example.com
                                    DocumentRoot /opt/mango/overrides/web/modules/mangoUI/web
                                      ErrorLog ${APACHE_LOG_DIR}/subdomain.example.com_error.log
                                      # Possible values include: debug, info, notice, warn, error, crit,
                                      # alert, emerg.
                                      LogLevel warn
                                      CustomLog ${APACHE_LOG_DIR}/subdomain.example.com_access.log combined
                                    ProxyRequests Off
                                    RewriteEngine on
                                    RewriteCond %{SERVER_PORT} 80
                                    RewriteRule ^(.*)$ https://subdomain.example.com/$1 [R,L]
                                    RewriteCond %{HTTP:UPGRADE} ^WebSocket$ [NC]
                                    RewriteCond %{HTTP:CONNECTION} Upgrade$ [NC]
                                     ProxyPass /.well-known !
                                            <Location />
                                                ProxyPass http://127.0.0.1:8080/
                                                ProxyPassReverse /
                                            </Location>
                                    </VirtualHost>
                                    #HTTPS PROXY HANDLER
                                    <IfModule mod_ssl.c>
                                    <VirtualHost *:443>
                                    <Directory />
                                    Options Indexes FollowSymLinks
                                    AllowOverride None
                                    Order allow,deny
                                    Allow from all
                                    </Directory>
                                      SSLProxyEngine On
                                      ProxyRequests Off
                                    RewriteEngine on
                                     RewriteCond %{HTTP:Connection} Upgrade [NC]
                                     RewriteCond %{HTTP:Upgrade} websocket [NC]
                                    RequestHeader set Origin "http://subdomain.example.com"
                                    Header edit Location ^http://subdomain.example.com https://subdomain.example.com
                                            <Location />
                                                ProxyPassReverse /
                                            </Location>
                                    SSLCertificateFile /etc/letsencrypt/live/subdomain.example.com/fullchain.pem
                                    SSLCertificateKeyFile /etc/letsencrypt/live/subdomain.example.com/privkey.pem
                                    Include /etc/letsencrypt/options-ssl-apache.conf
                                    </VirtualHost>
                                    </IfModule>
                                    No Because mango.example.com is what is accessible by the public domain. You want that because apache is now the front for mango. The private domain is now the server's own loopback address.
                                    https://developer.mozilla.org/en-US/docs/Web/HTTP/Headers/Origin
                                    The HTTP referer (originally a misspelling of referrer) is an optional HTTP header field that identifies the address of the webpage (i.e. the URI or IRI) that linked to the resource being requested. By checking the referrer, the new webpage can see where the request originated.
                                    • cbyrneC Offline
                                      cbyrne
                                      Amazing, thanks @MattFox. Using your as a guide I managed to get it working.
                                      One or two questions just for my own knowledge/curiosity.
                                      1. Difference/benefits of your mod_rewrites vs. my Redirect permanent for the HTTP virtual host? I get that the rewrite happens on the server and the redirect tells the client to send a new request to the redirect URL; but is there a notable benefit of one over the other?
                                      2. What exactly is happening in the <Proxy *> block?
                                        I like mod_rewrites because you can stack a load of conditions/regexs. That and mod rewrites generally pass header info if I recall correctly. Although it's possible that your permanent will give a 301 http header.
                                        Ignore the proxy* I think that was from my experiment to get letsencrypt working. I succeeded with the proxypass .well-known ! line. I could be wrong and it's there for another reason... shoulda left a comment!!!
                                        But as you know, the * applies to all paths,
