    HSTS causing HTTPS redirect loop
    18 Posts 4 Posters 6.0k Views 4 Watching
    • cbyrneC Offline
      cbyrne @MattFox
      @mattfox Thanks Matt, I may well do that. I'll try it in the morning and update this post later on in the day.
      Software Developer for GLAS Energy Technology, Ireland
      • cbyrneC Offline
        cbyrne
        All working now. Here's my solution using an Apache proxy as advised by @MattFox.
        Starting with a mango installation running on port 8080 and not handling ssl.
        1. Make sure you have httpd and mod_ssl installed.
        2. Place SSL cert files (your cert, cert bundle and key) in a directory of your choosing.
        3. Check for ssl.conf. Installing mod_ssl created a ssl.conf in /etc/httpd/conf.d/ which I had to disable (I just named it ssl.conf.old). It overrode my SSL settings below and used the packaged self-signed cert.
        4. Make a new config file eg. /etc/httpd/conf.d/mango.conf
        5. Populate is as follows:
        <VirtualHost *:80>
            Redirect permanent / https://subdomain.maindomain.com
        </VirtualHost>
        <VirtualHost *:443>
            ProxyPreserveHost On
            SSLEngine On
            SSLCertificateFile "path/to/your.crt"
            SSLCertificateChainFile "/path/to/your.ca-bundle"
            SSLCertificateKeyFile "/path/to/your_key"
            ProxyPass / http://127.0.0.1:8080/
            ProxyPassReverse / http://127.0.0.1:8080/
        </VirtualHost>
        1. Restart the httpd service.
        If anyone notices any loopholes or things I could add to harden it up please let me know.
          I suspect this thread may be of some assistance: https://forum.infiniteautomation.com/topic/3892/latest-version-3-5-5-appears-to-fail-rendering-data/14
          I would expect you may be seeing websocket issues currently.
            You've forgotten the http rewrite to handle web sockets. Proxy only works for http traffic. Add a redirect to ensure websockets get redirected to port 443 to 8080 if I recall correctly.
              A colleague of mine pointed out that to use the HTTP2 protocol (which should provide faster initial page loading) Mango must be running on SSL with a keystore, and have ALPN enabled (see Mango/bin/ext-available). I would not expect using HTTP2 to have a significant effect on REST requests.
                Correct, the push provided by HTTP/2 is for file resources only.
                Although I'm hoping to change that once my dashboard gets moved into a web directory...
                  I wrote this help article not too long ago which may provide some insight into configuring the Apache proxy.
                  https://help.infiniteautomation.com/proxy
                    Thanks Terry! I was unaware that existed on the help site.
                    • cbyrneC Offline
                      cbyrne
                      Perfect, thanks for all your help @terrypacker @MattFox @phildunlap.
                      edit:
                      @terrypacker Quick question regarding the help article
                      0_1565944443039_Screenshot_2019-08-16 Proxy — Infinite Automation Support.png
                      Specifically "we set the Host and Origin to the public facing server".
                      Isn't "mango.example.com" the private facing address?
                      • cbyrneC Offline
                        cbyrne
                        Actually I spoke too soon, proxying web sockets isn't working yet. I followed your example in the other thread @phildunlap but unfortunately I'm still getting errors. Perhaps my rewrite rule is incorrect for a localhost address?
                        My config:
                        <VirtualHost *:80>
                            Redirect permanent / https://ems1.glasenergytechnology.ie/
                        </VirtualHost>
                        Listen 443
                        <VirtualHost *:443>
                            ProxyPreserveHost Off
                            ServerName sub.domain.com
                            ServerAlias sub.domain.com
                            ProxyRequests On
                            RewriteEngine On
                            RewriteCond %{HTTP:Upgrade} =websocket
                            RewriteRule /(.*) ws://127.0.0.1:8080/$1 [P,L]
                            RewriteCond %{HTTP:Upgrade} !=websocket
                            RewriteRule /(.*) http://127.0.0.1:8080/$1 [P,L]
                            RequestHeader set Host sub.domain.com
                            RequestHeader set Origin "http://sub.domain.com"
                            Header edit Location ^http://sub.domain.com https://sub.domain.com
                            CustomLog "/var/log/apache-access-public-mango.log" common
                            ErrorLog "/var/log/apache-error-public-mango.log"
                            SSLEngine On
                            SSLProxyEngine On
                            SSLCertificateFile "/path/to/crt"
                            SSLCertificateChainFile "/path/to/ca-bundle"
                            SSLCertificateKeyFile "/path/to/private_key"
                        </VirtualHost>
                          Man your ssl conf file is messy!
                          You've got an uneccessary rewrite rule. You've got a condition asking for a websocket upgrade check and then applying an http rule to it! Unless you're redirecting, just leave the http stuff to the proxy rules.
                          Here, follow this:
                          #STRAIGHT HTTP, THIS REDIRECTS
                          <VirtualHost *:80>
                          ServerName subdomain.example.com
                          DocumentRoot /opt/mango/overrides/web/modules/mangoUI/web
                            ErrorLog ${APACHE_LOG_DIR}/subdomain.example.com_error.log
                            # Possible values include: debug, info, notice, warn, error, crit,
                            # alert, emerg.
                            LogLevel warn
                            CustomLog ${APACHE_LOG_DIR}/subdomain.example.com_access.log combined
                          ProxyRequests Off
                          RewriteEngine on
                          RewriteCond %{SERVER_PORT} 80
                          RewriteRule ^(.*)$ https://subdomain.example.com/$1 [R,L]
                          RewriteCond %{HTTP:UPGRADE} ^WebSocket$ [NC]
                          RewriteCond %{HTTP:CONNECTION} Upgrade$ [NC]
                           ProxyPass /.well-known !
                                  <Location />
                                      ProxyPass http://127.0.0.1:8080/
                                      ProxyPassReverse /
                                  </Location>
                          </VirtualHost>
                          #HTTPS PROXY HANDLER
                          <IfModule mod_ssl.c>
                          <VirtualHost *:443>
                          <Directory />
                          Options Indexes FollowSymLinks
                          AllowOverride None
                          Order allow,deny
                          Allow from all
                          </Directory>
                            SSLProxyEngine On
                            ProxyRequests Off
                          RewriteEngine on
                           RewriteCond %{HTTP:Connection} Upgrade [NC]
                           RewriteCond %{HTTP:Upgrade} websocket [NC]
                          RequestHeader set Origin "http://subdomain.example.com"
                          Header edit Location ^http://subdomain.example.com https://subdomain.example.com
                                  <Location />
                                      ProxyPassReverse /
                                  </Location>
                          SSLCertificateFile /etc/letsencrypt/live/subdomain.example.com/fullchain.pem
                          SSLCertificateKeyFile /etc/letsencrypt/live/subdomain.example.com/privkey.pem
                          Include /etc/letsencrypt/options-ssl-apache.conf
                          </VirtualHost>
                          </IfModule>
                          No Because mango.example.com is what is accessible by the public domain. You want that because apache is now the front for mango. The private domain is now the server's own loopback address.
                          https://developer.mozilla.org/en-US/docs/Web/HTTP/Headers/Origin
                          The HTTP referer (originally a misspelling of referrer) is an optional HTTP header field that identifies the address of the webpage (i.e. the URI or IRI) that linked to the resource being requested. By checking the referrer, the new webpage can see where the request originated.
                          • cbyrneC Offline
                            cbyrne
                            Amazing, thanks @MattFox. Using your as a guide I managed to get it working.
                            One or two questions just for my own knowledge/curiosity.
                            1. Difference/benefits of your mod_rewrites vs. my Redirect permanent for the HTTP virtual host? I get that the rewrite happens on the server and the redirect tells the client to send a new request to the redirect URL; but is there a notable benefit of one over the other?
                            2. What exactly is happening in the <Proxy *> block?
                              I like mod_rewrites because you can stack a load of conditions/regexs. That and mod rewrites generally pass header info if I recall correctly. Although it's possible that your permanent will give a 301 http header.
                              Ignore the proxy* I think that was from my experiment to get letsencrypt working. I succeeded with the proxypass .well-known ! line. I could be wrong and it's there for another reason... shoulda left a comment!!!
                              But as you know, the * applies to all paths,
