    HSTS causing HTTPS redirect loop
    18 Posts 4 Posters 6.2k Views 4 Watching
      Hi cbyrne,
      I was going to refrain from answering until I had looked into these questions in specific, but, @MattFox said,
      Mango uses tomcat server not apache 2.4 for the web service so an .htaccess based redirect will not work.
      Mango is using Jetty (tomcat is the webserver in Mango m2m2, so pre-Mango Automation and pre-Infinite Automation), and if all of the webserver traffic is going through Apache you can certainly set up virtual hosts to handle the traffic redirect for you, although probably not through .htaccess files since that scheme is more directed toward file servers / website servers rather than Apache serving as an application proxy.
      As to using SSL, you can also have something like Apache proxying the SSL traffic or you can have Apache handling the encryption and forwarding the traffic on a non-SSL connection to Mango, eliminating the need for a java keystore.
      • cbyrneC Offline
        cbyrne
        Hi guys,
        From following @phildunlap 's instructions in a previous thread, I made my keystore and got mango to use it just fine. So I do have a working https connection to the mango instance.
        The httaccess is on our base webserver, mango lives on a completely separate VPS.
        So the issue isn't with getting SSL working, it does, but rather when redirected to the loop is made.
        In the mean time I'll look into how apache proxy's work as an alternative!
        Software Developer for GLAS Energy Technology, Ireland
          I use an apache proxy and integrated it with lets encrypt. Happy to offer advice if needed
          cbyrneC 1 Reply Last reply Reply Quote 0
          • cbyrneC Offline
            cbyrne @MattFox
            @mattfox Thanks Matt, I may well do that. I'll try it in the morning and update this post later on in the day.
            • cbyrneC Offline
              cbyrne
              All working now. Here's my solution using an Apache proxy as advised by @MattFox.
              Starting with a mango installation running on port 8080 and not handling ssl.
              1. Make sure you have httpd and mod_ssl installed.
              2. Place SSL cert files (your cert, cert bundle and key) in a directory of your choosing.
              3. Check for ssl.conf. Installing mod_ssl created a ssl.conf in /etc/httpd/conf.d/ which I had to disable (I just named it ssl.conf.old). It overrode my SSL settings below and used the packaged self-signed cert.
              4. Make a new config file eg. /etc/httpd/conf.d/mango.conf
              5. Populate is as follows:
              <VirtualHost *:80>
                  Redirect permanent / https://subdomain.maindomain.com
              </VirtualHost>
              <VirtualHost *:443>
                  ProxyPreserveHost On
                  SSLEngine On
                  SSLCertificateFile "path/to/your.crt"
                  SSLCertificateChainFile "/path/to/your.ca-bundle"
                  SSLCertificateKeyFile "/path/to/your_key"
                  ProxyPass / http://127.0.0.1:8080/
                  ProxyPassReverse / http://127.0.0.1:8080/
              </VirtualHost>
              1. Restart the httpd service.
              If anyone notices any loopholes or things I could add to harden it up please let me know.
                I suspect this thread may be of some assistance: https://forum.infiniteautomation.com/topic/3892/latest-version-3-5-5-appears-to-fail-rendering-data/14
                I would expect you may be seeing websocket issues currently.
                  You've forgotten the http rewrite to handle web sockets. Proxy only works for http traffic. Add a redirect to ensure websockets get redirected to port 443 to 8080 if I recall correctly.
                    A colleague of mine pointed out that to use the HTTP2 protocol (which should provide faster initial page loading) Mango must be running on SSL with a keystore, and have ALPN enabled (see Mango/bin/ext-available). I would not expect using HTTP2 to have a significant effect on REST requests.
                      Correct, the push provided by HTTP/2 is for file resources only.
                      Although I'm hoping to change that once my dashboard gets moved into a web directory...
                        I wrote this help article not too long ago which may provide some insight into configuring the Apache proxy.
                        https://help.infiniteautomation.com/proxy
                          Thanks Terry! I was unaware that existed on the help site.
                          • cbyrneC Offline
                            cbyrne
                            Perfect, thanks for all your help @terrypacker @MattFox @phildunlap.
                            edit:
                            @terrypacker Quick question regarding the help article
                            0_1565944443039_Screenshot_2019-08-16 Proxy — Infinite Automation Support.png
                            Specifically "we set the Host and Origin to the public facing server".
                            Isn't "mango.example.com" the private facing address?
                            • cbyrneC Offline
                              cbyrne
                              Actually I spoke too soon, proxying web sockets isn't working yet. I followed your example in the other thread @phildunlap but unfortunately I'm still getting errors. Perhaps my rewrite rule is incorrect for a localhost address?
                              My config:
                              <VirtualHost *:80>
                                  Redirect permanent / https://ems1.glasenergytechnology.ie/
                              </VirtualHost>
                              Listen 443
                              <VirtualHost *:443>
                                  ProxyPreserveHost Off
                                  ServerName sub.domain.com
                                  ServerAlias sub.domain.com
                                  ProxyRequests On
                                  RewriteEngine On
                                  RewriteCond %{HTTP:Upgrade} =websocket
                                  RewriteRule /(.*) ws://127.0.0.1:8080/$1 [P,L]
                                  RewriteCond %{HTTP:Upgrade} !=websocket
                                  RewriteRule /(.*) http://127.0.0.1:8080/$1 [P,L]
                                  RequestHeader set Host sub.domain.com
                                  RequestHeader set Origin "http://sub.domain.com"
                                  Header edit Location ^http://sub.domain.com https://sub.domain.com
                                  CustomLog "/var/log/apache-access-public-mango.log" common
                                  ErrorLog "/var/log/apache-error-public-mango.log"
                                  SSLEngine On
                                  SSLProxyEngine On
                                  SSLCertificateFile "/path/to/crt"
                                  SSLCertificateChainFile "/path/to/ca-bundle"
                                  SSLCertificateKeyFile "/path/to/private_key"
                              </VirtualHost>
                                Man your ssl conf file is messy!
                                You've got an uneccessary rewrite rule. You've got a condition asking for a websocket upgrade check and then applying an http rule to it! Unless you're redirecting, just leave the http stuff to the proxy rules.
                                Here, follow this:
                                #STRAIGHT HTTP, THIS REDIRECTS
                                <VirtualHost *:80>
                                ServerName subdomain.example.com
                                DocumentRoot /opt/mango/overrides/web/modules/mangoUI/web
                                  ErrorLog ${APACHE_LOG_DIR}/subdomain.example.com_error.log
                                  # Possible values include: debug, info, notice, warn, error, crit,
                                  # alert, emerg.
                                  LogLevel warn
                                  CustomLog ${APACHE_LOG_DIR}/subdomain.example.com_access.log combined
                                ProxyRequests Off
                                RewriteEngine on
                                RewriteCond %{SERVER_PORT} 80
                                RewriteRule ^(.*)$ https://subdomain.example.com/$1 [R,L]
                                RewriteCond %{HTTP:UPGRADE} ^WebSocket$ [NC]
                                RewriteCond %{HTTP:CONNECTION} Upgrade$ [NC]
                                 ProxyPass /.well-known !
                                        <Location />
                                            ProxyPass http://127.0.0.1:8080/
                                            ProxyPassReverse /
                                        </Location>
                                </VirtualHost>
                                #HTTPS PROXY HANDLER
                                <IfModule mod_ssl.c>
                                <VirtualHost *:443>
                                <Directory />
                                Options Indexes FollowSymLinks
                                AllowOverride None
                                Order allow,deny
                                Allow from all
                                </Directory>
                                  SSLProxyEngine On
                                  ProxyRequests Off
                                RewriteEngine on
                                 RewriteCond %{HTTP:Connection} Upgrade [NC]
                                 RewriteCond %{HTTP:Upgrade} websocket [NC]
                                RequestHeader set Origin "http://subdomain.example.com"
                                Header edit Location ^http://subdomain.example.com https://subdomain.example.com
                                        <Location />
                                            ProxyPassReverse /
                                        </Location>
                                SSLCertificateFile /etc/letsencrypt/live/subdomain.example.com/fullchain.pem
                                SSLCertificateKeyFile /etc/letsencrypt/live/subdomain.example.com/privkey.pem
                                Include /etc/letsencrypt/options-ssl-apache.conf
                                </VirtualHost>
                                </IfModule>
                                No Because mango.example.com is what is accessible by the public domain. You want that because apache is now the front for mango. The private domain is now the server's own loopback address.
                                https://developer.mozilla.org/en-US/docs/Web/HTTP/Headers/Origin
                                The HTTP referer (originally a misspelling of referrer) is an optional HTTP header field that identifies the address of the webpage (i.e. the URI or IRI) that linked to the resource being requested. By checking the referrer, the new webpage can see where the request originated.
                                • cbyrneC Offline
                                  cbyrne
                                  Amazing, thanks @MattFox. Using your as a guide I managed to get it working.
                                  One or two questions just for my own knowledge/curiosity.
                                  1. Difference/benefits of your mod_rewrites vs. my Redirect permanent for the HTTP virtual host? I get that the rewrite happens on the server and the redirect tells the client to send a new request to the redirect URL; but is there a notable benefit of one over the other?
                                  2. What exactly is happening in the <Proxy *> block?
                                    I like mod_rewrites because you can stack a load of conditions/regexs. That and mod rewrites generally pass header info if I recall correctly. Although it's possible that your permanent will give a 301 http header.
                                    Ignore the proxy* I think that was from my experiment to get letsencrypt working. I succeeded with the proxypass .well-known ! line. I could be wrong and it's there for another reason... shoulda left a comment!!!
                                    But as you know, the * applies to all paths,
