    Reports module not working
    7 Posts 4 Posters 4.6k Views 2 Watching
    • C Offline
      catkins
      When I open the Reports module, I get this immediate message. response.data.reports* is null
      When I make a new report template, the point list does not show up.
      How do I fix this?
        I'm not familiar with these issues. Something might have gone wrong with the reports information stored in the database tables. If you don't have any existing reports the easiest way to resolve might be to uninstall the reports module and then install it again. This should delete all the reports database tables and then create them again.
        To do this go to the Modules page. Then mark the Reports module for deletion and restart Mango. Log back in and go to the Modules page and check for updates. Under the "Modules available to install section fine the Reports module and select it. Then click Do upgrade and after the reboot test the reports again.
        Note this will delete all your existing reports so if you have report you want to keep do not follow this procedure. If you continue to have issues please check your Log file for any errors and post them here.
        C 1 Reply Last reply Reply Quote 0
        • C Offline
          catkins @JoelHaggar
          @JoelHaggar Did that. Now Im getting another error
          org.springframework.web.util.NestedServletException: Request processing failed; nested exception is com.serotonin.ShouldNeverHappenException: freemarker.core.ParseException: Encountered "?" at line 119, column 33.
          Was expecting:
          <ID> ...
          at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:973)
          at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:852)
          at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
          at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:837)
          at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
          at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:769)
          at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1667)
          at com.serotonin.m2m2.web.filter.WebContextFilter.doFilter(WebContextFilter.java:43)
          at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1650)
          at com.serotonin.m2m2.web.filter.LoggedInFilter.doFilter(LoggedInFilter.java:121)
          at com.serotonin.m2m2.web.filter.UrlSecurityFilter.doFilter(UrlSecurityFilter.java:88)
          at com.serotonin.web.filter.CharacterSetFilter.doFilter(CharacterSetFilter.java:37)
          at org.eclipse.jetty.servlets.UserAgentFilter.doFilter(UserAgentFilter.java:83)
          at org.eclipse.jetty.servlets.GzipFilter.doFilter(GzipFilter.java:364)
          at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:583)
          at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
          at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
          at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
          at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1125)
          at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
          at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
          at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1059)
          at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
          at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:215)
          at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
          at org.eclipse.jetty.server.Server.handle(Server.java:485)
          at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:290)
          at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:248)
          at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
          at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:606)
          at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:535)
          Caused by: com.serotonin.ShouldNeverHappenException: freemarker.core.ParseException: Encountered "?" at line 119, column 33.
          Was expecting:
          <ID> ...
          at com.serotonin.m2m2.reports.web.ReportChartCreator.createContent(ReportChartCreator.java:219)
          at com.serotonin.m2m2.reports.web.ReportChartHandler.handleRequest(ReportChartHandler.java:36)
          at com.serotonin.m2m2.web.mvc.UrlHandlerController.handleRequest(UrlHandlerController.java:36)
          at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
          at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:938)
          at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:870)
          at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:961)
          ... 35 more
          Caused by: freemarker.core.ParseException: Encountered "?" at line 119, column 33.
          Was expecting:
          <ID> ...
          at freemarker.core.FMParser.generateParseException(FMParser.java:4461)
          at freemarker.core.FMParser.jj_consume_token(FMParser.java:4332)
          at freemarker.core.FMParser.BuiltIn(FMParser.java:740)
          at freemarker.core.FMParser.AddSubExpression(FMParser.java:726)
          at freemarker.core.FMParser.PrimaryExpression(FMParser.java:257)
          at freemarker.core.FMParser.UnaryExpression(FMParser.java:303)
          at freemarker.core.FMParser.MultiplicativeExpression(FMParser.java:419)
          at freemarker.core.FMParser.AdditiveExpression(FMParser.java:369)
          at freemarker.core.FMParser.RangeExpression(FMParser.java:553)
          at freemarker.core.FMParser.RelationalExpression(FMParser.java:500)
          at freemarker.core.FMParser.EqualityExpression(FMParser.java:460)
          at freemarker.core.FMParser.AndExpression(FMParser.java:585)
          at freemarker.core.FMParser.OrExpression(FMParser.java:608)
          at freemarker.core.FMParser.Expression(FMParser.java:205)
          at freemarker.core.FMParser.If(FMParser.java:1122)
          at freemarker.core.FMParser.FreemarkerDirective(FMParser.java:2274)
          at freemarker.core.FMParser.Content(FMParser.java:2518)
          at freemarker.core.FMParser.OptionalBlock(FMParser.java:2686)
          at freemarker.core.FMParser.List(FMParser.java:1209)
          at freemarker.core.FMParser.FreemarkerDirective(FMParser.java:2277)
          at freemarker.core.FMParser.Root(FMParser.java:2858)
          at freemarker.template.Template.<init>(Template.java:148)
          at freemarker.cache.TemplateCache.loadTemplate(TemplateCache.java:376)
          at freemarker.cache.TemplateCache.getTemplate(TemplateCache.java:347)
          at freemarker.cache.TemplateCache.getTemplate(TemplateCache.java:229)
          at freemarker.template.Configuration.getTemplate(Configuration.java:439)
          at freemarker.template.Configuration.getTemplate(Configuration.java:404)
          at com.serotonin.m2m2.reports.web.ReportChartCreator.createContent(ReportChartCreator.java:215)
          ... 41 more
          REQUEST URL
          http://192.169.232.112:8080/exception/error.jsp
          REQUEST PARAMETERS
          instanceId=1
          REQUEST HEADERS
          Accept-Language=en-US,en;q=0.5
          Cookie=MANGO8080=2mun36v8mey6em15b5fmqkn8
          Host=192.169.232.112:8080
          Accept-Encoding=gzip, deflate
          Referer=http://192.169.232.112:8080/reports.shtm
          User-Agent=Mozilla/5.0 (Windows NT 6.3; WOW64; rv:39.0) Gecko/20100101 Firefox/39.0
          Connection=keep-alive
          Accept=text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8
          REQUEST ATTRIBUTES
          instanceDescription=My Mango Automation
          javax.servlet.forward.request_uri=/reportChart.shtm
          org.springframework.web.servlet.DispatcherServlet.THEME_SOURCE=WebApplicationContext for namespace 'springDispatcher-servlet': startup date [Tue Jul 28 09:40:03 MST 2015]; parent: Root WebApplicationContext
          org.springframework.web.servlet.DispatcherServlet.THEME_RESOLVER=org.springframework.web.servlet.theme.FixedThemeResolver@7d25b817
          javax.servlet.forward.context_path=
          javax.servlet.error.servlet_name=springDispatcher
          NEW_ID=-1
          lang=en
          javax.servlet.forward.servlet_path=/reportChart.shtm
          javax.servlet.error.message=org.springframework.web.util.NestedServletException: Request processing failed; nested exception is com.serotonin.ShouldNeverHappenException: freemarker.core.ParseException: Encountered "?" at line 119, column 33.
          Was expecting:
          <ID> ...
          javax.servlet.jsp.jstl.fmt.locale.request=en_US
          sessionUser=User [id=1, username=admin, password=L6ksURIHFXZK7zN90m4SyCrlPl0=, email=chris@summaes.com, phone=8012306534, admin=true, disabled=false, dataSourcePermissions=[], dataPointPermissions=[], homeUrl=, lastLogin=1438101442353, receiveAlarmEmails=0, receiveOwnAuditEvents=false, timezone=America/Boise]
          javax.servlet.error.request_uri=/reportChart.shtm
          javax.servlet.jsp.jstl.fmt.localizationContext.request=org.springframework.web.servlet.support.JstlUtils$SpringLocalizationContext@72fdf298
          org.springframework.web.servlet.HandlerMapping.introspectTypeLevelMapping=false
          javax.servlet.forward.query_string=instanceId=1
          org.springframework.web.servlet.DispatcherServlet.FLASH_MAP_MANAGER=org.springframework.web.servlet.support.SessionFlashMapManager@3fe7af5a
          org.springframework.web.servlet.DispatcherServlet.CONTEXT=WebApplicationContext for namespace 'springDispatcher-servlet': startup date [Tue Jul 28 09:40:03 MST 2015]; parent: Root WebApplicationContext
          javax.servlet.error.status_code=500
          javax.servlet.error.exception_type=class org.springframework.web.util.NestedServletException
          availableLanguages=[]
          org.springframework.web.servlet.HandlerMapping.pathWithinHandlerMapping=/reportChart.shtm
          org.springframework.web.context.request.async.WebAsyncManager.WEB_ASYNC_MANAGER=org.springframework.web.context.request.async.WebAsyncManager@7e421422
          org.springframework.web.servlet.DispatcherServlet.OUTPUT_FLASH_MAP=FlashMap [attributes={}, targetRequestPath=null, targetRequestParams={}]
          org.eclipse.jetty.server.error_page=/exception/error.jsp
          org.springframework.web.servlet.HandlerMapping.bestMatchingPattern=/reportChart.shtm
          javax.servlet.error.exception=org.springframework.web.util.NestedServletException: Request processing failed; nested exception is com.serotonin.ShouldNeverHappenException: freemarker.core.ParseException: Encountered "?" at line 119, column 33.
          Was expecting:
          <ID> ...
          org.springframework.web.servlet.DispatcherServlet.LOCALE_RESOLVER=org.springframework.web.servlet.i18n.SessionLocaleResolver@647a626b
          SESSION ATTRIBUTES
          LONG_POLL_DATA_TIMEOUT=1438101624855
          LONG_POLL_DATA=[com.serotonin.m2m2.web.dwr.longPoll.LongPollData@1ed39256, com.serotonin.m2m2.web.dwr.longPoll.LongPollData@542c5be9, com.serotonin.m2m2.web.dwr.longPoll.LongPollData@2c46492b, com.serotonin.m2m2.web.dwr.longPoll.LongPollData@243804f0, com.serotonin.m2m2.web.dwr.longPoll.LongPollData@59cc3b23]
          CONTEXT ATTRIBUTES
          constants.AuditEventType.TYPE_DATA_POINT=DATA_POINT
          org.springframework.web.servlet.FrameworkServlet.CONTEXT.springDispatcher=WebApplicationContext for namespace 'springDispatcher-servlet': startup date [Tue Jul 28 09:40:03 MST 2015]; parent: Root WebApplicationContext
          constants.Permissions.DataPointAccessTypes.DATA_SOURCE=3
          constants.SystemEventType.TYPE_EMAIL_SEND_FAILURE=EMAIL_SEND_FAILURE
          constants.SystemEventType.TYPE_UPGRADE_CHECK=UPGRADE_CHECK
          DwrContainer=org.directwebremoting.impl.DefaultContainer@3a6dbcc2
          constants.SystemEventType.TYPE_USER_LOGIN=USER_LOGIN
          constants.EventType.EventTypeNames.PUBLISHER=PUBLISHER
          constants.SystemEventType.TYPE_PROCESS_FAILURE=PROCESS_FAILURE
          ReportsDwr=com.serotonin.m2m2.reports.web.ReportsDwr@7a838285
          constants.DataTypes.IMAGE=5
          constants.Permissions.DataPointAccessTypes.READ=1
          constants.EventType.EventTypeNames.DATA_POINT=DATA_POINT
          org.springframework.web.context.support.ServletContextScope=org.springframework.web.context.support.ServletContextScope@4fee2899
          constants.SystemEventType.TYPE_SYSTEM_STARTUP=SYSTEM_STARTUP
          constants.Permissions.DataPointAccessTypes.NONE=0
          constants.Common.NEW_ID=-1
          javax.servlet.ServletConfig=org.eclipse.jetty.servlet.ServletHolder$Config@1cab7dce
          constants.Permissions.DataPointAccessTypes.ADMIN=4
          org.eclipse.jetty.server.Executor=qtp1082301057{STARTED,8<=14<=200,i=3,q=0}
          constants.UserComment.TYPE_EVENT=1
          org.directwebremoting.WebContextFactory$WebContextBuilder=org.directwebremoting.impl.DefaultWebContextBuilder@3ed06e16
          constants.AuditEventType.TYPE_POINT_EVENT_DETECTOR=POINT_EVENT_DETECTOR
          constants.EventType.EventTypeNames.AUDIT=AUDIT
          constants.EventType.EventTypeNames.SYSTEM=SYSTEM
          constants.DataTypes.MULTISTATE=2
          org.directwebremoting.impl.ServerContext=org.directwebremoting.impl.DefaultServerContext@65eb8691
          javax.servlet.http.HttpServlet=org.directwebremoting.servlet.DwrServlet@49cfcddd
          MiscDwr=com.serotonin.m2m2.web.dwr.MiscDwr@69d48e06
          javax.servlet.context.tempdir=/home/proxyem/mango/work
          DataPointDetailsDwr=com.serotonin.m2m2.web.dwr.DataPointDetailsDwr@1b86232
          constants.DataTypes.ALPHANUMERIC=4
          constants.SystemEventType.TYPE_MAX_ALARM_LEVEL_CHANGED=MAX_ALARM_LEVEL_CHANGED
          mangoMessageKeys=[Ljava.lang.String;@6f3ea4e3
          org.apache.catalina.jsp_classpath=/home/proxyem/mango/web/modules/modbus/classes:/home/proxyem/mango/web/modules/modbus/lib/commons-logging-1.1.1.jar:/home/proxyem/mango/web/modules/modbus/lib/httpcore-4.3.2.jar:/home/proxyem/mango/web/modules/modbus/lib/log4j-1.2.17.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-tx-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-context-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-expression-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/commons-pool-1.6.jar:/home/proxyem/mango/web/modules/modbus/lib/ant-1.8.1.jar:/home/proxyem/mango/web/modules/modbus/lib/annotations-api-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/commons-codec-1.6.jar:/home/proxyem/mango/web/modules/modbus/lib/m2m2-modbus-1.5.4.jar:/home/proxyem/mango/web/modules/modbus/lib/serotonin-timer-2.0.7.jar:/home/proxyem/mango/web/modules/modbus/lib/mail-1.5.0-b01.jar:/home/proxyem/mango/web/modules/modbus/lib/catalina-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/serotonin-utils-2.1.7.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-jdbc-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-webmvc-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/jsp-api-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/ecj-4.3.1.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-web-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/javax.servlet.jsp-api-2.3.1.jar:/home/proxyem/mango/web/modules/modbus/lib/servlet-api-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/coyote-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/activation-1.1.jar:/home/proxyem/mango/web/modules/modbus/lib/aopalliance-1.0.jar:/home/proxyem/mango/web/modules/modbus/lib/commons-io-2.1.jar:/home/proxyem/mango/web/modules/modbus/lib/juli-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/jssc-2.8.0.jar:/home/proxyem/mango/web/modules/modbus/lib/httpclient-4.3.2.jar:/home/proxyem/mango/web/modules/modbus/lib/el-api-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-aop-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/modbus4j-2.0.9.jar:/home/proxyem/mango/web/modules/modbus/lib/freemarker-2.3.11.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-context-support-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/servlet-api-2.5.jar:/home/proxyem/mango/web/modules/modbus/lib/jasper-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/ant-launcher-1.8.1.jar:/home/proxyem/mango/web/modules/modbus/lib/commons-httpclient-3.1.jar:/home/proxyem/mango/web/modules/modbus/lib/joda-time-2.3.jar:/home/proxyem/mango/web/modules/modbus/lib/commons-dbcp-1.4.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-core-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/commons-lang3-3.0.jar:/home/proxyem/mango/web/modules/modbus/lib/jasper-el-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/jstl-1.2.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-beans-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/twilio/classes:/home/proxyem/mango/web/modules/twilio/lib/m2m2-twilio-1.0.4.jar:/home/proxyem/mango/web/modules/twilio/lib/twilio-java-sdk-3.4.1-jar-with-dependencies.jar:/home/proxyem/mango/web/modules/pop3/classes:/home/proxyem/mango/web/modules/pop3/lib/m2m2-pop3-1.4.5.jar:/home/proxyem/mango/web/modules/sstGraphics/classes:/home/proxyem/mango/web/modules/sstGraphics/lib/m2m2-sstGraphics-1.0.6.jar:/home/proxyem/mango/web/modules/scheduledEvents/classes:/home/proxyem/mango/web/modules/scheduledEvents/lib/m2m2-scheduledEvents-1.4.7.jar:/home/proxyem/mango/web/modules/dglux/classes:/home/proxyem/mango/web/modules/dglux/lib/m2m2-dglux-1.2.0.jar:/home/proxyem/mango/web/modules/dglux/lib/JoSQL-2.2.jar:/home/proxyem/mango/web/modules/dglux/lib/gentlyWEB-utils-1.1.jar:/home/proxyem/mango/web/modules/pointLinks/classes:/home/proxyem/mango/web/modules/pointLinks/lib/m2m2-pointLinks-1.4.6.jar:/home/proxyem/mango/web/modules/abpccc/classes:/home/proxyem/mango/web/modules/abpccc/lib/log4j-1.2.17.jar:/home/proxyem/mango/web/modules/abpccc/lib/m2m2-abpccc-1.0.5.jar:/home/proxyem/mango/web/modules/abpccc/lib/plc-1.1.4.jar:/home/proxyem/mango/web/modules/onewire/classes:/home/proxyem/mango/web/modules/onewire/lib/OneWireAPI.jar:/home/proxyem/mango/web/modules/onewire/lib/RXTXcomm.jar:/home/proxyem/mango/web/modules/onewire/lib/m2m2-onewire-1.4.6.jar:/home/proxyem/mango/web/modules/jspViews/classes:/home/proxyem/mango/web/modules/jspViews/lib/m2m2-jspViews-2.0.5.jar:/home/proxyem/mango/web/modules/internal/classes:/home/proxyem/mango/web/modules/internal/lib/m2m2-internal-1.4.6.jar:/home/proxyem/mango/web/modules/maintenanceEvents/classes:/home/proxyem/mango/web/modules/maintenanceEvents/lib/m2m2-maintenanceEvents-1.4.8.jar:/home/proxyem/mango/web/modules/sstGlobalScripts/classes:/home/proxyem/mango/web/modules/sstGlobalScripts/lib/m2m2-sstGlobalScripts-1.4.6.jar:/home/proxyem/mango/web/modules/opcda/classes:/home/proxyem/mango/web/modules/opcda/lib/m2m2-opcda-1.5.7.jar:/home/proxyem/mango/web/modules/opcda/lib/org.openscada.opc.lib_0.9.0.201203290910.jar:/home/proxyem/mango/web/modules/opcda/lib/slf4j-log4j12-1.0.jar:/home/proxyem/mango/web/modules/opcda/lib/org.openscada.utils_0.17.0.201203290908.jar:/home/proxyem/mango/web/modules/opcda/lib/jcifs-1.2.19.jar:/home/proxyem/mango/web/modules/opcda/lib/org.openscada.opc.dcom_0.7.0.201203290910.jar:/home/proxyem/mango/web/modules/opcda/lib/j-interop-2.0.10.jar:/home/proxyem/mango/web/modules/opcda/lib/j-interopdeps-2.01.jar:/home/proxyem/mango/web/modules/log4JReset/classes:/home/proxyem/mango/web/modules/log4JReset/lib/m2m2-log4JReset-1.0.6.jar:/home/proxyem/mango/web/modules/jmxds/classes:/home/proxyem/mango/web/modules/jmxds/lib/m2m2-jmxds-1.4.5.jar:/home/proxyem/mango/web/modules/loggingConsole/classes:/home/proxyem/mango/web/modules/loggingConsole/lib/m2m2-loggingConsole-1.0.2.jar:/home/proxyem/mango/web/modules/log4jDS/classes:/home/proxyem/mango/web/modules/log4jDS/lib/m2m2-log4jDS-1.0.2.jar:/home/proxyem/mango/web/modules/sqlConsole/classes:/home/proxyem/mango/web/modules/sqlConsole/lib/m2m2-sqlConsole-1.4.5.jar:/home/proxyem/mango/web/modules/asciiFile/classes:/home/proxyem/mango/web/modules/asciiFile/lib/m2m2-asciiFile-1.1.5.jar:/home/proxyem/mango/web/modules/abeip/classes:/home/proxyem/mango/web/modules/abeip/lib/log4j-1.2.17.jar:/home/proxyem/mango/web/modules/abeip/lib/m2m2-abeip-1.0.7.jar:/home/proxyem/mango/web/modules/abeip/lib/plc-1.1.4.jar:/home/proxyem/mango/web/modules/mangoNoSqlDatabase/classes:/home/proxyem/mango/web/modules/mangoNoSqlDatabase/lib/mangoNoSQL-1.0.10.jar:/home/proxyem/mango/web/modules/mangoNoSqlDatabase/lib/m2m2-mangoNoSqlDatabase-1.1.7.jar:/home/proxyem/mango/web/modules/meta/classes:/home/proxyem/mango/web/modules/meta/lib/m2m2-meta-2.1.1.jar:/home/proxyem/mango/web/modules/meta/lib/mvel2-2.1.3.Final.jar:/home/proxyem/mango/web/modules/BACnet/classes:/home/proxyem/mango/web/modules/BACnet/lib/bacnet4J.jar:/home/proxyem/mango/web/modules/BACnet/lib/m2m2-BACnet-2.1.3.jar:/home/proxyem/mango/web/modules/virtualDS/classes:/home/proxyem/mango/web/modules/virtualDS/lib/m2m2-virtualDS-1.4.5.jar:/home/proxyem/mango/web/modules/http/classes:/home/proxyem/mango/web/modules/http/lib/m2m2-http-1.4.7.jar:/home/proxyem/mango/web/modules/graphicalViews/classes:/home/proxyem/mango/web/modules/graphicalViews/lib/m2m2-graphicalViews-1.5.2.jar:/home/proxyem/mango/web/modules/snmp/classes:/home/proxyem/mango/web/modules/snmp/lib/m2m2-snmp-1.4.6.jar:/home/proxyem/mango/web/modules/snmp/lib/SNMP4J.jar:/home/proxyem/mango/web/modules/scripting/classes:/home/proxyem/mango/web/modules/scripting/lib/m2m2-scripting-1.0.8.jar:/home/proxyem/mango/web/modules/dashboards/classes:/home/proxyem/mango/web/modules/dashboards/lib/m2m2-dashboards-1.0.3.jar:/home/proxyem/mango/web/modules/mbus/classes:/home/proxyem/mango/web/modules/mbus/lib/commons-logging-1.1.1.jar:/home/proxyem/mango/web/modules/mbus/lib/spsw-java-0.0.4.jar:/home/proxyem/mango/web/modules/mbus/lib/commons-beanutils-1.8.3.jar:/home/proxyem/mango/web/modules/mbus/lib/m2m2-mbus-1.0.7.jar:/home/proxyem/mango/web/modules/mbus/lib/commons-collections-3.2.1.jar:/home/proxyem/mango/web/modules/mbus/lib/commons-lang-2.4.jar:/home/proxyem/mango/web/modules/mbus/lib/mbus4j-core-0.1.5.jar:/home/proxyem/mango/web/modules/mbus/lib/ezmorph-1.0.6.jar:/home/proxyem/mango/web/modules/mbus/lib/json-lib-2.4-jdk15.jar:/home/proxyem/mango/web/modules/mbus/lib/mbus4j-master-0.1.5.jar:/home/proxyem/mango/web/modules/reports/classes:/home/proxyem/mango/web/modules/reports/lib/m2m2-reports-2.1.3.jar:/home/proxyem/mango/web/modules/sqlds/classes:/home/proxyem/mango/web/modules/sqlds/lib/m2m2-sqlds-1.5.7.jar:/home/proxyem/mango/web/modules/sqlds/lib/opencsv-2.3.jar:/home/proxyem/mango/web/modules/galil/classes:/home/proxyem/mango/web/modules/galil/lib/m2m2-galil-1.4.5.jar:/home/proxyem/mango/web/modules/serial/classes:/home/proxyem/mango/web/modules/serial/lib/m2m2-serial-1.1.5.jar:/home/proxyem/mango/web/modules/sstTheme/classes:/home/proxyem/mango/web/modules/sstTheme/lib/m2m2-sstTheme-1.0.6.jar:/home/proxyem/mango/web/modules/mangoApi/classes:/home/proxyem/mango/web/modules/mangoApi/lib/m2m2-mangoApi-1.0.3.jar:/home/proxyem/mango/web/modules/dataImport/classes:/home/proxyem/mango/web/modules/dataImport/lib/m2m2-dataImport-1.3.6.jar:/home/proxyem/mango/web/modules/dataImport/lib/opencsv-2.2.jar:/home/proxyem/mango/web/modules/persistent/classes:/home/proxyem/mango/web/modules/persistent/lib/m2m2-persistent-1.5.8.jar:/home/proxyem/mango/web/modules/dataFile/classes:/home/proxyem/mango/web/modules/dataFile/lib/jaxb-jxc.jar:/home/proxyem/mango/web/modules/dataFile/lib/m2m2-dataFile-1.0.8.jar:/home/proxyem/mango/web/modules/dataFile/lib/jaxb-api.jar:/home/proxyem/mango/web/modules/dataFile/lib/jaxb-core.jar:/home/proxyem/mango/web/modules/dataFile/lib/opencsv-2.3.jar:/home/proxyem/mango/web/modules/dataFile/lib/jaxb-impl.jar:/home/proxyem/mango/web/modules/dataFile/lib/jaxb-xjc.jar:/home/proxyem/mango/web/modules/vmstat/classes:/home/proxyem/mango/web/modules/vmstat/lib/m2m2-vmstat-1.4.7.jar:/home/proxyem/mango/web/modules/watchlists/classes:/home/proxyem/mango/web/modules/watchlists/lib/m2m2-watchlists-1.6.1.jar:/home/proxyem/mango/web/modules/dnp3/classes:/home/proxyem/mango/web/modules/dnp3/lib/dnp34j.jar:/home/proxyem/mango/web/modules/dnp3/lib/m2m2-dnp3-1.5.0.jar:/home/proxyem/mango/web/modules/openv4j/classes:/home/proxyem/mango/web/modules/openv4j/lib/RXTXcomm.jar:/home/proxyem/mango/web/modules/openv4j/lib/openv4j-core-0.1.3.jar:/home/proxyem/mango/web/modules/openv4j/lib/mbus4j-core-0.1.3.jar:/home/proxyem/mango/web/modules/openv4j/lib/mbus4j-master-0.1.3.jar:/home/proxyem/mango/web/modules/openv4j/lib/m2m2-openv4j-1.0.5.jar:/home/proxyem/mango/web/modules/pachube/classes:/home/proxyem/mango/web/modules/pachube/lib/m2m2-pachube-1.4.8.jar:/home/proxyem/mango/web/modules/templateConfig/classes:/home/proxyem/mango/web/modules/templateConfig/lib/m2m2-templateConfig-1.0.5.jar
          org.directwebremoting.ContainerList=[org.directwebremoting.impl.DefaultContainer@3a6dbcc2]
          constants.SystemEventType.TYPE_SET_POINT_HANDLER_FAILURE=SET_POINT_HANDLER_FAILURE
          constants.DataTypes.BINARY=1
          org.apache.jasper.runtime.JspApplicationContextImpl=org.apache.jasper.runtime.JspApplicationContextImpl@1ad9b267
          org.directwebremoting.Container=org.directwebremoting.impl.DefaultContainer@3a6dbcc2
          org.springframework.web.context.WebApplicationContext.ROOT=Root WebApplicationContext: startup date [Tue Jul 28 09:40:02 MST 2015]; root of context hierarchy
          constants.EventType.EventTypeNames.DATA_SOURCE=DATA_SOURCE
          constants.SystemEventType.TYPE_LICENSE_CHECK=LICENSE_CHECK
          org.eclipse.jetty.tmpdirConfigured=true
          constants.Permissions.DataPointAccessTypes.SET=2
          constants.AuditEventType.TYPE_EVENT_HANDLER=EVENT_HANDLER
          clientSideMessages={js.help.lastUpdated=com.serotonin.m2m2.i18n.TranslatableMessage@729293fd, js.help.error=com.serotonin.m2m2.i18n.TranslatableMessage@f876c0, common.disabledToggle=com.serotonin.m2m2.i18n.TranslatableMessage@d7f89333, header.mute=com.serotonin.m2m2.i18n.TranslatableMessage@43df3cba, js.email.testSent=com.serotonin.m2m2.i18n.TranslatableMessage@f59d9881, common.administrator=com.serotonin.m2m2.i18n.TranslatableMessage@a467f3ea, js.help.related=com.serotonin.m2m2.i18n.TranslatableMessage@3dce6ae3, common.sendTestEmail=com.serotonin.m2m2.i18n.TranslatableMessage@8fd89c9f, js.email.noRecipForEmail=com.serotonin.m2m2.i18n.TranslatableMessage@4b694592, common.enabledToggle=com.serotonin.m2m2.i18n.TranslatableMessage@ea5c2f12, js.email.addAddress=com.serotonin.m2m2.i18n.TranslatableMessage@cbb9a38a, header.unmute=com.serotonin.m2m2.i18n.TranslatableMessage@d635aa93, js.email.addMailingList=com.serotonin.m2m2.i18n.TranslatableMessage@6fa4a69f, common.alarmLevel.lifeSafety=com.serotonin.m2m2.i18n.TranslatableMessage@1c71626, common.loading=com.serotonin.m2m2.i18n.TranslatableMessage@cf5f0419, common.minimize=com.serotonin.m2m2.i18n.TranslatableMessage@5d740b21, js.email.addUser=com.serotonin.m2m2.i18n.TranslatableMessage@49cc77b5, common.maximize=com.serotonin.m2m2.i18n.TranslatableMessage@c752a74f, js.email.noRecipients=com.serotonin.m2m2.i18n.TranslatableMessage@d78563d2, common.user=com.serotonin.m2m2.i18n.TranslatableMessage@8a9479ce, common.alarmLevel.none=com.serotonin.m2m2.i18n.TranslatableMessage@223c1a70, common.access.set=com.serotonin.m2m2.i18n.TranslatableMessage@a3e5309b, events.silence=com.serotonin.m2m2.i18n.TranslatableMessage@8376c0ac, common.disabled=com.serotonin.m2m2.i18n.TranslatableMessage@be9bfeff, common.access.read=com.serotonin.m2m2.i18n.TranslatableMessage@d8bff83d, common.alarmLevel.critical=com.serotonin.m2m2.i18n.TranslatableMessage@2b076d7, common.alarmLevel.info=com.serotonin.m2m2.i18n.TranslatableMessage@2239cfe6, events.unsilence=com.serotonin.m2m2.i18n.TranslatableMessage@29ad6533, common.alarmLevel.urgent=com.serotonin.m2m2.i18n.TranslatableMessage@8fa9c879}
          constants.SystemEventType.TYPE_SYSTEM_SHUTDOWN=SYSTEM_SHUTDOWN
          constants.UserComment.TYPE_POINT=2
          constants.DataTypes.NUMERIC=3
          constants.AuditEventType.TYPE_DATA_SOURCE=DATA_SOURCE
          • terrypackerT Offline
            terrypacker
            It appears that there is an error in one of your free marker templates. Is it possible that you have customized one of the free marker templates that Mango uses?
            Unfortunately the name of the template with the error is not in the stack trace, but it does tell you that on line 119 at column 33 of that template there is a problem.
            Hope this helps,
            Terry
            • C Offline
              catkins
              I couldnt have customized thie free marker template. I barely installed the report module and haven't even made a report.
              • L Offline
                LarryE
                I am getting the Error:
                report error.jpg When I try to open the reports module? I only have one report set up. Looks like the same thing. Not sure how to change this?
                  I would try removing the reports module on the modules page and then installing it again.
