Reports module not working
When I open the Reports module, I get this immediate message. response.data.reports* is null
When I make a new report template, the point list does not show up.
How do I fix this?
I'm not familiar with these issues. Something might have gone wrong with the reports information stored in the database tables. If you don't have any existing reports the easiest way to resolve might be to uninstall the reports module and then install it again. This should delete all the reports database tables and then create them again.
To do this go to the Modules page. Then mark the Reports module for deletion and restart Mango. Log back in and go to the Modules page and check for updates. Under the "Modules available to install section fine the Reports module and select it. Then click Do upgrade and after the reboot test the reports again.
Note this will delete all your existing reports so if you have report you want to keep do not follow this procedure. If you continue to have issues please check your Log file for any errors and post them here.
@JoelHaggar Did that. Now Im getting another error
org.springframework.web.util.NestedServletException: Request processing failed; nested exception is com.serotonin.ShouldNeverHappenException: freemarker.core.ParseException: Encountered "?" at line 119, column 33.
Was expecting:
<ID> ...at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:973) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:852) at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:837) at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:769) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1667) at com.serotonin.m2m2.web.filter.WebContextFilter.doFilter(WebContextFilter.java:43) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1650) at com.serotonin.m2m2.web.filter.LoggedInFilter.doFilter(LoggedInFilter.java:121) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1650) at com.serotonin.m2m2.web.filter.UrlSecurityFilter.doFilter(UrlSecurityFilter.java:88) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1650) at com.serotonin.web.filter.CharacterSetFilter.doFilter(CharacterSetFilter.java:37) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1650) at org.eclipse.jetty.servlets.UserAgentFilter.doFilter(UserAgentFilter.java:83) at org.eclipse.jetty.servlets.GzipFilter.doFilter(GzipFilter.java:364) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1650) at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:583) at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577) at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223) at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1125) at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515) at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1059) at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:215) at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97) at org.eclipse.jetty.server.Server.handle(Server.java:485) at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:290) at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:248) at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540) at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:606) at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:535) at java.lang.Thread.run(Thread.java:745)Caused by: com.serotonin.ShouldNeverHappenException: freemarker.core.ParseException: Encountered "?" at line 119, column 33.
Was expecting:
<ID> ...at com.serotonin.m2m2.reports.web.ReportChartCreator.createContent(ReportChartCreator.java:219) at com.serotonin.m2m2.reports.web.ReportChartHandler.handleRequest(ReportChartHandler.java:36) at com.serotonin.m2m2.web.mvc.UrlHandlerController.handleRequest(UrlHandlerController.java:36) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:938) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:870) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:961) ... 35 moreCaused by: freemarker.core.ParseException: Encountered "?" at line 119, column 33.
Was expecting:
<ID> ...at freemarker.core.FMParser.generateParseException(FMParser.java:4461) at freemarker.core.FMParser.jj_consume_token(FMParser.java:4332) at freemarker.core.FMParser.BuiltIn(FMParser.java:740) at freemarker.core.FMParser.AddSubExpression(FMParser.java:726) at freemarker.core.FMParser.PrimaryExpression(FMParser.java:257) at freemarker.core.FMParser.UnaryExpression(FMParser.java:303) at freemarker.core.FMParser.MultiplicativeExpression(FMParser.java:419) at freemarker.core.FMParser.AdditiveExpression(FMParser.java:369) at freemarker.core.FMParser.RangeExpression(FMParser.java:553) at freemarker.core.FMParser.RelationalExpression(FMParser.java:500) at freemarker.core.FMParser.EqualityExpression(FMParser.java:460) at freemarker.core.FMParser.AndExpression(FMParser.java:585) at freemarker.core.FMParser.OrExpression(FMParser.java:608) at freemarker.core.FMParser.Expression(FMParser.java:205) at freemarker.core.FMParser.If(FMParser.java:1122) at freemarker.core.FMParser.FreemarkerDirective(FMParser.java:2274) at freemarker.core.FMParser.Content(FMParser.java:2518) at freemarker.core.FMParser.OptionalBlock(FMParser.java:2686) at freemarker.core.FMParser.List(FMParser.java:1209) at freemarker.core.FMParser.FreemarkerDirective(FMParser.java:2277) at freemarker.core.FMParser.Content(FMParser.java:2518) at freemarker.core.FMParser.OptionalBlock(FMParser.java:2686) at freemarker.core.FMParser.Root(FMParser.java:2858) at freemarker.template.Template.<init>(Template.java:148) at freemarker.cache.TemplateCache.loadTemplate(TemplateCache.java:376) at freemarker.cache.TemplateCache.getTemplate(TemplateCache.java:347) at freemarker.cache.TemplateCache.getTemplate(TemplateCache.java:229) at freemarker.template.Configuration.getTemplate(Configuration.java:439) at freemarker.template.Configuration.getTemplate(Configuration.java:404) at com.serotonin.m2m2.reports.web.ReportChartCreator.createContent(ReportChartCreator.java:215) ... 41 moreREQUEST URL
http://192.169.232.112:8080/exception/error.jspREQUEST PARAMETERS
instanceId=1REQUEST HEADERS
Accept-Language=en-US,en;q=0.5
Cookie=MANGO8080=2mun36v8mey6em15b5fmqkn8
Host=192.169.232.112:8080
Accept-Encoding=gzip, deflate
Referer=http://192.169.232.112:8080/reports.shtm
User-Agent=Mozilla/5.0 (Windows NT 6.3; WOW64; rv:39.0) Gecko/20100101 Firefox/39.0
Connection=keep-alive
Accept=text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8REQUEST ATTRIBUTES
instanceDescription=My Mango Automation
javax.servlet.forward.request_uri=/reportChart.shtm
org.springframework.web.servlet.DispatcherServlet.THEME_SOURCE=WebApplicationContext for namespace 'springDispatcher-servlet': startup date [Tue Jul 28 09:40:03 MST 2015]; parent: Root WebApplicationContext
org.springframework.web.servlet.DispatcherServlet.THEME_RESOLVER=org.springframework.web.servlet.theme.FixedThemeResolver@7d25b817
javax.servlet.forward.context_path=
javax.servlet.error.servlet_name=springDispatcher
NEW_ID=-1
lang=en
javax.servlet.forward.servlet_path=/reportChart.shtm
javax.servlet.error.message=org.springframework.web.util.NestedServletException: Request processing failed; nested exception is com.serotonin.ShouldNeverHappenException: freemarker.core.ParseException: Encountered "?" at line 119, column 33.
Was expecting:
<ID> ...javax.servlet.jsp.jstl.fmt.locale.request=en_US
sessionUser=User [id=1, username=admin, password=L6ksURIHFXZK7zN90m4SyCrlPl0=, email=chris@summaes.com, phone=8012306534, admin=true, disabled=false, dataSourcePermissions=[], dataPointPermissions=[], homeUrl=, lastLogin=1438101442353, receiveAlarmEmails=0, receiveOwnAuditEvents=false, timezone=America/Boise]
javax.servlet.error.request_uri=/reportChart.shtm
javax.servlet.jsp.jstl.fmt.localizationContext.request=org.springframework.web.servlet.support.JstlUtils$SpringLocalizationContext@72fdf298
org.springframework.web.servlet.HandlerMapping.introspectTypeLevelMapping=false
javax.servlet.forward.query_string=instanceId=1
org.springframework.web.servlet.DispatcherServlet.FLASH_MAP_MANAGER=org.springframework.web.servlet.support.SessionFlashMapManager@3fe7af5a
org.springframework.web.servlet.DispatcherServlet.CONTEXT=WebApplicationContext for namespace 'springDispatcher-servlet': startup date [Tue Jul 28 09:40:03 MST 2015]; parent: Root WebApplicationContext
javax.servlet.error.status_code=500
javax.servlet.error.exception_type=class org.springframework.web.util.NestedServletException
availableLanguages=[]
org.springframework.web.servlet.HandlerMapping.pathWithinHandlerMapping=/reportChart.shtm
org.springframework.web.context.request.async.WebAsyncManager.WEB_ASYNC_MANAGER=org.springframework.web.context.request.async.WebAsyncManager@7e421422
org.springframework.web.servlet.DispatcherServlet.OUTPUT_FLASH_MAP=FlashMap [attributes={}, targetRequestPath=null, targetRequestParams={}]
org.eclipse.jetty.server.error_page=/exception/error.jsp
org.springframework.web.servlet.HandlerMapping.bestMatchingPattern=/reportChart.shtm
javax.servlet.error.exception=org.springframework.web.util.NestedServletException: Request processing failed; nested exception is com.serotonin.ShouldNeverHappenException: freemarker.core.ParseException: Encountered "?" at line 119, column 33.
Was expecting:
<ID> ...org.springframework.web.servlet.DispatcherServlet.LOCALE_RESOLVER=org.springframework.web.servlet.i18n.SessionLocaleResolver@647a626b
SESSION ATTRIBUTES
LONG_POLL_DATA_TIMEOUT=1438101624855
LONG_POLL_DATA=[com.serotonin.m2m2.web.dwr.longPoll.LongPollData@1ed39256, com.serotonin.m2m2.web.dwr.longPoll.LongPollData@542c5be9, com.serotonin.m2m2.web.dwr.longPoll.LongPollData@2c46492b, com.serotonin.m2m2.web.dwr.longPoll.LongPollData@243804f0, com.serotonin.m2m2.web.dwr.longPoll.LongPollData@59cc3b23]
sessionUser=User [id=1, username=admin, password=L6ksURIHFXZK7zN90m4SyCrlPl0=, email=chris@summaes.com, phone=8012306534, admin=true, disabled=false, dataSourcePermissions=[], dataPointPermissions=[], homeUrl=, lastLogin=1438101442353, receiveAlarmEmails=0, receiveOwnAuditEvents=false, timezone=America/Boise]CONTEXT ATTRIBUTES
constants.AuditEventType.TYPE_DATA_POINT=DATA_POINT
org.springframework.web.servlet.FrameworkServlet.CONTEXT.springDispatcher=WebApplicationContext for namespace 'springDispatcher-servlet': startup date [Tue Jul 28 09:40:03 MST 2015]; parent: Root WebApplicationContext
constants.Permissions.DataPointAccessTypes.DATA_SOURCE=3
constants.SystemEventType.TYPE_EMAIL_SEND_FAILURE=EMAIL_SEND_FAILURE
constants.SystemEventType.TYPE_UPGRADE_CHECK=UPGRADE_CHECK
DwrContainer=org.directwebremoting.impl.DefaultContainer@3a6dbcc2
constants.SystemEventType.TYPE_USER_LOGIN=USER_LOGIN
constants.EventType.EventTypeNames.PUBLISHER=PUBLISHER
constants.SystemEventType.TYPE_PROCESS_FAILURE=PROCESS_FAILURE
ReportsDwr=com.serotonin.m2m2.reports.web.ReportsDwr@7a838285
constants.DataTypes.IMAGE=5
constants.Permissions.DataPointAccessTypes.READ=1
constants.EventType.EventTypeNames.DATA_POINT=DATA_POINT
org.springframework.web.context.support.ServletContextScope=org.springframework.web.context.support.ServletContextScope@4fee2899
constants.SystemEventType.TYPE_SYSTEM_STARTUP=SYSTEM_STARTUP
constants.Permissions.DataPointAccessTypes.NONE=0
constants.Common.NEW_ID=-1
javax.servlet.ServletConfig=org.eclipse.jetty.servlet.ServletHolder$Config@1cab7dce
constants.Permissions.DataPointAccessTypes.ADMIN=4
org.eclipse.jetty.server.Executor=qtp1082301057{STARTED,8<=14<=200,i=3,q=0}
constants.UserComment.TYPE_EVENT=1
org.directwebremoting.WebContextFactory$WebContextBuilder=org.directwebremoting.impl.DefaultWebContextBuilder@3ed06e16
constants.AuditEventType.TYPE_POINT_EVENT_DETECTOR=POINT_EVENT_DETECTOR
constants.EventType.EventTypeNames.AUDIT=AUDIT
constants.EventType.EventTypeNames.SYSTEM=SYSTEM
constants.DataTypes.MULTISTATE=2
org.directwebremoting.impl.ServerContext=org.directwebremoting.impl.DefaultServerContext@65eb8691
javax.servlet.http.HttpServlet=org.directwebremoting.servlet.DwrServlet@49cfcddd
MiscDwr=com.serotonin.m2m2.web.dwr.MiscDwr@69d48e06
javax.servlet.context.tempdir=/home/proxyem/mango/work
DataPointDetailsDwr=com.serotonin.m2m2.web.dwr.DataPointDetailsDwr@1b86232
constants.DataTypes.ALPHANUMERIC=4
constants.SystemEventType.TYPE_MAX_ALARM_LEVEL_CHANGED=MAX_ALARM_LEVEL_CHANGED
mangoMessageKeys=[Ljava.lang.String;@6f3ea4e3
org.apache.catalina.jsp_classpath=/home/proxyem/mango/web/modules/modbus/classes:/home/proxyem/mango/web/modules/modbus/lib/commons-logging-1.1.1.jar:/home/proxyem/mango/web/modules/modbus/lib/httpcore-4.3.2.jar:/home/proxyem/mango/web/modules/modbus/lib/log4j-1.2.17.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-tx-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-context-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-expression-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/commons-pool-1.6.jar:/home/proxyem/mango/web/modules/modbus/lib/ant-1.8.1.jar:/home/proxyem/mango/web/modules/modbus/lib/annotations-api-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/commons-codec-1.6.jar:/home/proxyem/mango/web/modules/modbus/lib/m2m2-modbus-1.5.4.jar:/home/proxyem/mango/web/modules/modbus/lib/serotonin-timer-2.0.7.jar:/home/proxyem/mango/web/modules/modbus/lib/mail-1.5.0-b01.jar:/home/proxyem/mango/web/modules/modbus/lib/catalina-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/serotonin-utils-2.1.7.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-jdbc-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-webmvc-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/jsp-api-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/ecj-4.3.1.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-web-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/javax.servlet.jsp-api-2.3.1.jar:/home/proxyem/mango/web/modules/modbus/lib/servlet-api-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/coyote-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/activation-1.1.jar:/home/proxyem/mango/web/modules/modbus/lib/aopalliance-1.0.jar:/home/proxyem/mango/web/modules/modbus/lib/commons-io-2.1.jar:/home/proxyem/mango/web/modules/modbus/lib/juli-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/jssc-2.8.0.jar:/home/proxyem/mango/web/modules/modbus/lib/httpclient-4.3.2.jar:/home/proxyem/mango/web/modules/modbus/lib/el-api-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-aop-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/modbus4j-2.0.9.jar:/home/proxyem/mango/web/modules/modbus/lib/freemarker-2.3.11.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-context-support-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/servlet-api-2.5.jar:/home/proxyem/mango/web/modules/modbus/lib/jasper-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/ant-launcher-1.8.1.jar:/home/proxyem/mango/web/modules/modbus/lib/commons-httpclient-3.1.jar:/home/proxyem/mango/web/modules/modbus/lib/joda-time-2.3.jar:/home/proxyem/mango/web/modules/modbus/lib/commons-dbcp-1.4.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-core-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/modbus/lib/commons-lang3-3.0.jar:/home/proxyem/mango/web/modules/modbus/lib/jasper-el-6.0.41.jar:/home/proxyem/mango/web/modules/modbus/lib/jstl-1.2.jar:/home/proxyem/mango/web/modules/modbus/lib/spring-beans-4.0.5.RELEASE.jar:/home/proxyem/mango/web/modules/twilio/classes:/home/proxyem/mango/web/modules/twilio/lib/m2m2-twilio-1.0.4.jar:/home/proxyem/mango/web/modules/twilio/lib/twilio-java-sdk-3.4.1-jar-with-dependencies.jar:/home/proxyem/mango/web/modules/pop3/classes:/home/proxyem/mango/web/modules/pop3/lib/m2m2-pop3-1.4.5.jar:/home/proxyem/mango/web/modules/sstGraphics/classes:/home/proxyem/mango/web/modules/sstGraphics/lib/m2m2-sstGraphics-1.0.6.jar:/home/proxyem/mango/web/modules/scheduledEvents/classes:/home/proxyem/mango/web/modules/scheduledEvents/lib/m2m2-scheduledEvents-1.4.7.jar:/home/proxyem/mango/web/modules/dglux/classes:/home/proxyem/mango/web/modules/dglux/lib/m2m2-dglux-1.2.0.jar:/home/proxyem/mango/web/modules/dglux/lib/JoSQL-2.2.jar:/home/proxyem/mango/web/modules/dglux/lib/gentlyWEB-utils-1.1.jar:/home/proxyem/mango/web/modules/pointLinks/classes:/home/proxyem/mango/web/modules/pointLinks/lib/m2m2-pointLinks-1.4.6.jar:/home/proxyem/mango/web/modules/abpccc/classes:/home/proxyem/mango/web/modules/abpccc/lib/log4j-1.2.17.jar:/home/proxyem/mango/web/modules/abpccc/lib/m2m2-abpccc-1.0.5.jar:/home/proxyem/mango/web/modules/abpccc/lib/plc-1.1.4.jar:/home/proxyem/mango/web/modules/onewire/classes:/home/proxyem/mango/web/modules/onewire/lib/OneWireAPI.jar:/home/proxyem/mango/web/modules/onewire/lib/RXTXcomm.jar:/home/proxyem/mango/web/modules/onewire/lib/m2m2-onewire-1.4.6.jar:/home/proxyem/mango/web/modules/jspViews/classes:/home/proxyem/mango/web/modules/jspViews/lib/m2m2-jspViews-2.0.5.jar:/home/proxyem/mango/web/modules/internal/classes:/home/proxyem/mango/web/modules/internal/lib/m2m2-internal-1.4.6.jar:/home/proxyem/mango/web/modules/maintenanceEvents/classes:/home/proxyem/mango/web/modules/maintenanceEvents/lib/m2m2-maintenanceEvents-1.4.8.jar:/home/proxyem/mango/web/modules/sstGlobalScripts/classes:/home/proxyem/mango/web/modules/sstGlobalScripts/lib/m2m2-sstGlobalScripts-1.4.6.jar:/home/proxyem/mango/web/modules/opcda/classes:/home/proxyem/mango/web/modules/opcda/lib/m2m2-opcda-1.5.7.jar:/home/proxyem/mango/web/modules/opcda/lib/org.openscada.opc.lib_0.9.0.201203290910.jar:/home/proxyem/mango/web/modules/opcda/lib/slf4j-log4j12-1.0.jar:/home/proxyem/mango/web/modules/opcda/lib/org.openscada.utils_0.17.0.201203290908.jar:/home/proxyem/mango/web/modules/opcda/lib/jcifs-1.2.19.jar:/home/proxyem/mango/web/modules/opcda/lib/org.openscada.opc.dcom_0.7.0.201203290910.jar:/home/proxyem/mango/web/modules/opcda/lib/j-interop-2.0.10.jar:/home/proxyem/mango/web/modules/opcda/lib/j-interopdeps-2.01.jar:/home/proxyem/mango/web/modules/log4JReset/classes:/home/proxyem/mango/web/modules/log4JReset/lib/m2m2-log4JReset-1.0.6.jar:/home/proxyem/mango/web/modules/jmxds/classes:/home/proxyem/mango/web/modules/jmxds/lib/m2m2-jmxds-1.4.5.jar:/home/proxyem/mango/web/modules/loggingConsole/classes:/home/proxyem/mango/web/modules/loggingConsole/lib/m2m2-loggingConsole-1.0.2.jar:/home/proxyem/mango/web/modules/log4jDS/classes:/home/proxyem/mango/web/modules/log4jDS/lib/m2m2-log4jDS-1.0.2.jar:/home/proxyem/mango/web/modules/sqlConsole/classes:/home/proxyem/mango/web/modules/sqlConsole/lib/m2m2-sqlConsole-1.4.5.jar:/home/proxyem/mango/web/modules/asciiFile/classes:/home/proxyem/mango/web/modules/asciiFile/lib/m2m2-asciiFile-1.1.5.jar:/home/proxyem/mango/web/modules/abeip/classes:/home/proxyem/mango/web/modules/abeip/lib/log4j-1.2.17.jar:/home/proxyem/mango/web/modules/abeip/lib/m2m2-abeip-1.0.7.jar:/home/proxyem/mango/web/modules/abeip/lib/plc-1.1.4.jar:/home/proxyem/mango/web/modules/mangoNoSqlDatabase/classes:/home/proxyem/mango/web/modules/mangoNoSqlDatabase/lib/mangoNoSQL-1.0.10.jar:/home/proxyem/mango/web/modules/mangoNoSqlDatabase/lib/m2m2-mangoNoSqlDatabase-1.1.7.jar:/home/proxyem/mango/web/modules/meta/classes:/home/proxyem/mango/web/modules/meta/lib/m2m2-meta-2.1.1.jar:/home/proxyem/mango/web/modules/meta/lib/mvel2-2.1.3.Final.jar:/home/proxyem/mango/web/modules/BACnet/classes:/home/proxyem/mango/web/modules/BACnet/lib/bacnet4J.jar:/home/proxyem/mango/web/modules/BACnet/lib/m2m2-BACnet-2.1.3.jar:/home/proxyem/mango/web/modules/virtualDS/classes:/home/proxyem/mango/web/modules/virtualDS/lib/m2m2-virtualDS-1.4.5.jar:/home/proxyem/mango/web/modules/http/classes:/home/proxyem/mango/web/modules/http/lib/m2m2-http-1.4.7.jar:/home/proxyem/mango/web/modules/graphicalViews/classes:/home/proxyem/mango/web/modules/graphicalViews/lib/m2m2-graphicalViews-1.5.2.jar:/home/proxyem/mango/web/modules/snmp/classes:/home/proxyem/mango/web/modules/snmp/lib/m2m2-snmp-1.4.6.jar:/home/proxyem/mango/web/modules/snmp/lib/SNMP4J.jar:/home/proxyem/mango/web/modules/scripting/classes:/home/proxyem/mango/web/modules/scripting/lib/m2m2-scripting-1.0.8.jar:/home/proxyem/mango/web/modules/dashboards/classes:/home/proxyem/mango/web/modules/dashboards/lib/m2m2-dashboards-1.0.3.jar:/home/proxyem/mango/web/modules/mbus/classes:/home/proxyem/mango/web/modules/mbus/lib/commons-logging-1.1.1.jar:/home/proxyem/mango/web/modules/mbus/lib/spsw-java-0.0.4.jar:/home/proxyem/mango/web/modules/mbus/lib/commons-beanutils-1.8.3.jar:/home/proxyem/mango/web/modules/mbus/lib/m2m2-mbus-1.0.7.jar:/home/proxyem/mango/web/modules/mbus/lib/commons-collections-3.2.1.jar:/home/proxyem/mango/web/modules/mbus/lib/commons-lang-2.4.jar:/home/proxyem/mango/web/modules/mbus/lib/mbus4j-core-0.1.5.jar:/home/proxyem/mango/web/modules/mbus/lib/ezmorph-1.0.6.jar:/home/proxyem/mango/web/modules/mbus/lib/json-lib-2.4-jdk15.jar:/home/proxyem/mango/web/modules/mbus/lib/mbus4j-master-0.1.5.jar:/home/proxyem/mango/web/modules/reports/classes:/home/proxyem/mango/web/modules/reports/lib/m2m2-reports-2.1.3.jar:/home/proxyem/mango/web/modules/sqlds/classes:/home/proxyem/mango/web/modules/sqlds/lib/m2m2-sqlds-1.5.7.jar:/home/proxyem/mango/web/modules/sqlds/lib/opencsv-2.3.jar:/home/proxyem/mango/web/modules/galil/classes:/home/proxyem/mango/web/modules/galil/lib/m2m2-galil-1.4.5.jar:/home/proxyem/mango/web/modules/serial/classes:/home/proxyem/mango/web/modules/serial/lib/m2m2-serial-1.1.5.jar:/home/proxyem/mango/web/modules/sstTheme/classes:/home/proxyem/mango/web/modules/sstTheme/lib/m2m2-sstTheme-1.0.6.jar:/home/proxyem/mango/web/modules/mangoApi/classes:/home/proxyem/mango/web/modules/mangoApi/lib/m2m2-mangoApi-1.0.3.jar:/home/proxyem/mango/web/modules/dataImport/classes:/home/proxyem/mango/web/modules/dataImport/lib/m2m2-dataImport-1.3.6.jar:/home/proxyem/mango/web/modules/dataImport/lib/opencsv-2.2.jar:/home/proxyem/mango/web/modules/persistent/classes:/home/proxyem/mango/web/modules/persistent/lib/m2m2-persistent-1.5.8.jar:/home/proxyem/mango/web/modules/dataFile/classes:/home/proxyem/mango/web/modules/dataFile/lib/jaxb-jxc.jar:/home/proxyem/mango/web/modules/dataFile/lib/m2m2-dataFile-1.0.8.jar:/home/proxyem/mango/web/modules/dataFile/lib/jaxb-api.jar:/home/proxyem/mango/web/modules/dataFile/lib/jaxb-core.jar:/home/proxyem/mango/web/modules/dataFile/lib/opencsv-2.3.jar:/home/proxyem/mango/web/modules/dataFile/lib/jaxb-impl.jar:/home/proxyem/mango/web/modules/dataFile/lib/jaxb-xjc.jar:/home/proxyem/mango/web/modules/vmstat/classes:/home/proxyem/mango/web/modules/vmstat/lib/m2m2-vmstat-1.4.7.jar:/home/proxyem/mango/web/modules/watchlists/classes:/home/proxyem/mango/web/modules/watchlists/lib/m2m2-watchlists-1.6.1.jar:/home/proxyem/mango/web/modules/dnp3/classes:/home/proxyem/mango/web/modules/dnp3/lib/dnp34j.jar:/home/proxyem/mango/web/modules/dnp3/lib/m2m2-dnp3-1.5.0.jar:/home/proxyem/mango/web/modules/openv4j/classes:/home/proxyem/mango/web/modules/openv4j/lib/RXTXcomm.jar:/home/proxyem/mango/web/modules/openv4j/lib/openv4j-core-0.1.3.jar:/home/proxyem/mango/web/modules/openv4j/lib/mbus4j-core-0.1.3.jar:/home/proxyem/mango/web/modules/openv4j/lib/mbus4j-master-0.1.3.jar:/home/proxyem/mango/web/modules/openv4j/lib/m2m2-openv4j-1.0.5.jar:/home/proxyem/mango/web/modules/pachube/classes:/home/proxyem/mango/web/modules/pachube/lib/m2m2-pachube-1.4.8.jar:/home/proxyem/mango/web/modules/templateConfig/classes:/home/proxyem/mango/web/modules/templateConfig/lib/m2m2-templateConfig-1.0.5.jar
org.directwebremoting.ContainerList=[org.directwebremoting.impl.DefaultContainer@3a6dbcc2]
constants.SystemEventType.TYPE_SET_POINT_HANDLER_FAILURE=SET_POINT_HANDLER_FAILURE
constants.DataTypes.BINARY=1
org.apache.jasper.runtime.JspApplicationContextImpl=org.apache.jasper.runtime.JspApplicationContextImpl@1ad9b267
org.directwebremoting.Container=org.directwebremoting.impl.DefaultContainer@3a6dbcc2
org.springframework.web.context.WebApplicationContext.ROOT=Root WebApplicationContext: startup date [Tue Jul 28 09:40:02 MST 2015]; root of context hierarchy
constants.EventType.EventTypeNames.DATA_SOURCE=DATA_SOURCE
constants.SystemEventType.TYPE_LICENSE_CHECK=LICENSE_CHECK
org.eclipse.jetty.tmpdirConfigured=true
constants.Permissions.DataPointAccessTypes.SET=2
constants.AuditEventType.TYPE_EVENT_HANDLER=EVENT_HANDLER
clientSideMessages={js.help.lastUpdated=com.serotonin.m2m2.i18n.TranslatableMessage@729293fd, js.help.error=com.serotonin.m2m2.i18n.TranslatableMessage@f876c0, common.disabledToggle=com.serotonin.m2m2.i18n.TranslatableMessage@d7f89333, header.mute=com.serotonin.m2m2.i18n.TranslatableMessage@43df3cba, js.email.testSent=com.serotonin.m2m2.i18n.TranslatableMessage@f59d9881, common.administrator=com.serotonin.m2m2.i18n.TranslatableMessage@a467f3ea, js.help.related=com.serotonin.m2m2.i18n.TranslatableMessage@3dce6ae3, common.sendTestEmail=com.serotonin.m2m2.i18n.TranslatableMessage@8fd89c9f, js.email.noRecipForEmail=com.serotonin.m2m2.i18n.TranslatableMessage@4b694592, common.enabledToggle=com.serotonin.m2m2.i18n.TranslatableMessage@ea5c2f12, js.email.addAddress=com.serotonin.m2m2.i18n.TranslatableMessage@cbb9a38a, header.unmute=com.serotonin.m2m2.i18n.TranslatableMessage@d635aa93, js.email.addMailingList=com.serotonin.m2m2.i18n.TranslatableMessage@6fa4a69f, common.alarmLevel.lifeSafety=com.serotonin.m2m2.i18n.TranslatableMessage@1c71626, common.loading=com.serotonin.m2m2.i18n.TranslatableMessage@cf5f0419, common.minimize=com.serotonin.m2m2.i18n.TranslatableMessage@5d740b21, js.email.addUser=com.serotonin.m2m2.i18n.TranslatableMessage@49cc77b5, common.maximize=com.serotonin.m2m2.i18n.TranslatableMessage@c752a74f, js.email.noRecipients=com.serotonin.m2m2.i18n.TranslatableMessage@d78563d2, common.user=com.serotonin.m2m2.i18n.TranslatableMessage@8a9479ce, common.alarmLevel.none=com.serotonin.m2m2.i18n.TranslatableMessage@223c1a70, common.access.set=com.serotonin.m2m2.i18n.TranslatableMessage@a3e5309b, events.silence=com.serotonin.m2m2.i18n.TranslatableMessage@8376c0ac, common.disabled=com.serotonin.m2m2.i18n.TranslatableMessage@be9bfeff, common.access.read=com.serotonin.m2m2.i18n.TranslatableMessage@d8bff83d, common.alarmLevel.critical=com.serotonin.m2m2.i18n.TranslatableMessage@2b076d7, common.alarmLevel.info=com.serotonin.m2m2.i18n.TranslatableMessage@2239cfe6, events.unsilence=com.serotonin.m2m2.i18n.TranslatableMessage@29ad6533, common.alarmLevel.urgent=com.serotonin.m2m2.i18n.TranslatableMessage@8fa9c879}
constants.SystemEventType.TYPE_SYSTEM_SHUTDOWN=SYSTEM_SHUTDOWN
constants.UserComment.TYPE_POINT=2
constants.DataTypes.NUMERIC=3
constants.AuditEventType.TYPE_DATA_SOURCE=DATA_SOURCE -
It appears that there is an error in one of your free marker templates. Is it possible that you have customized one of the free marker templates that Mango uses?
Unfortunately the name of the template with the error is not in the stack trace, but it does tell you that on line 119 at column 33 of that template there is a problem.
Hope this helps,
Terry -
I couldnt have customized thie free marker template. I barely installed the report module and haven't even made a report.
I am getting the Error:
When I try to open the reports module? I only have one report set up. Looks like the same thing. Not sure how to change this? -
I would try removing the reports module on the modules page and then installing it again.
