    Fresh install - problems with m2m2-start.bat
    14 Posts 2 Posters 9.4k Views 1 Watching
    • K Offline
      Koen
      Thanks for you quick help,
      I entered the JAVA_HOME env var through the Control Panel -> System etc...
      Then I ran the startup script again, it made a difference, but now I have a different problem it seems. See screenshot.
        Weird, i just downloaded the core now, ran the bat file and it worked fine. At line 35 in the bat file there is the line "rem echo %M2M2_CP%". Can you remove the "rem" part so that it writes the classpath it is starting with?
        • K Offline
          Koen
          Hi Matthew,
          I did as you asked, see attached screenshot.
          Koen
            What version of Windows are you using?
            • K Offline
              Koen
              Windows 7
                Hmm. Can you try the following commands in a command prompt? Check if the results you get are different from mine.
                C:\Users\Matthew>setlocal
                C:\Users\Matthew>for
                The syntax of the command is incorrect.
                C:\Users\Matthew>
                • K Offline
                  Koen
                  Hi Matthew,
                  I get the same.
                  Koen
                    Ha! Now it is a problem with spaces in your path. We'll look into a fix for this, but can you try removing the spaces?
                    • K Offline
                      Koen
                      Hi Matthew,
                      I think you nailed it. It started up now.
                      So in short:
                      1. Make sure you set an env var for JAVA_HOME
                      2. Make sure Mango is installed in a directory without spaces in its path.
                      Maybe best to put that in the readme file or so, for future users?
                      Thanks heaps for your help!
                      How come I don't have to install Apache Tomcat for Mango Automation?
                      Koen
                        Well, we'll look into fixing the script so that spaces aren't an issue, but it seems like 1. may be necessary, yes.
                        Rather than having MA run within Tomcat, we switched things around so that the web server (Jetty) runs within MA.
