    Fresh install - problems with m2m2-start.bat
    14 Posts 2 Posters 9.1k Views 1 Watching
    • K Offline
      Koen
      Hi guys,
      I just downloaded tried installing Mango Automation on a new Windows machine. First I installed Java SE Development Kit 6 version 35. Then I downloaded the Mango zip file, and unzipped it to a new folder in the 'program files'.
      When I start 'm2m2-start.bat' in the command window, I get a number of fault messages, and I don't get a page up on http://localhost:8080
      Any help?
      Koen
        Hi Koen,
        For now, can you try removing the spaces in your path and try again?
          Actually, that may not be it. Can you check your Java path. Currently it's pointing to "C:\Program Files\Java\jre6...". I believe it should point to something like "C:\Program Files\Java\jdk1.6.0_xx...". You may need to add a JAVA_HOME env var to set this. It should be set to "C:\Program Files\Java\jdk1.6.0_xx" where "xx" is the micro version of Java you have installed.
          • K Offline
            Koen
            Thanks for you quick help,
            I entered the JAVA_HOME env var through the Control Panel -> System etc...
            Then I ran the startup script again, it made a difference, but now I have a different problem it seems. See screenshot.
              Weird, i just downloaded the core now, ran the bat file and it worked fine. At line 35 in the bat file there is the line "rem echo %M2M2_CP%". Can you remove the "rem" part so that it writes the classpath it is starting with?
              • K Offline
                Koen
                Hi Matthew,
                I did as you asked, see attached screenshot.
                Koen
                  What version of Windows are you using?
                  • K Offline
                    Koen
                    Windows 7
                      Hmm. Can you try the following commands in a command prompt? Check if the results you get are different from mine.
                      C:\Users\Matthew>setlocal
                      C:\Users\Matthew>for
                      The syntax of the command is incorrect.
                      C:\Users\Matthew>
                      • K Offline
                        Koen
                        Hi Matthew,
                        I get the same.
                        Koen
                          Ha! Now it is a problem with spaces in your path. We'll look into a fix for this, but can you try removing the spaces?
                          • K Offline
                            Koen
                            Hi Matthew,
                            I think you nailed it. It started up now.
                            So in short:
                            1. Make sure you set an env var for JAVA_HOME
                            2. Make sure Mango is installed in a directory without spaces in its path.
                            Maybe best to put that in the readme file or so, for future users?
                            Thanks heaps for your help!
                            How come I don't have to install Apache Tomcat for Mango Automation?
                            Koen
                              Well, we'll look into fixing the script so that spaces aren't an issue, but it seems like 1. may be necessary, yes.
                              Rather than having MA run within Tomcat, we switched things around so that the web server (Jetty) runs within MA.
