<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fresh install - problems with m2m2-start.bat]]></title><description><![CDATA[<p dir="auto">Hi guys,</p>
<p dir="auto">I just downloaded tried installing Mango Automation on a new Windows machine. First I installed Java SE Development Kit 6 version 35. Then I downloaded the Mango zip file, and unzipped it   to a new folder in the 'program files'.</p>
<p dir="auto">When I start 'm2m2-start.bat' in the command window, I get a number of fault messages, and I don't get a page up on <a href="http://localhost:8080" rel="nofollow ugc">http://localhost:8080</a></p>
<p dir="auto">Any help?</p>
<p dir="auto">Koen</p>
<p dir="auto">Attachment: <a href="http://archive.infiniteautomation.com/forum/posts/downloadAttach/176.page" rel="nofollow ugc">download link</a></p>
]]></description><link>https://forum.mango-os.com/topic/1137/fresh-install-problems-with-m2m2-start-bat</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 00:26:53 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1137.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 21 Sep 2012 18:34:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fresh install - problems with m2m2-start.bat on Fri, 21 Sep 2012 20:09:05 GMT]]></title><description><![CDATA[<p dir="auto">Well, we'll look into fixing the script so that spaces aren't an issue, but it seems like 1. may be necessary, yes.</p>
<p dir="auto">Rather than having MA run within Tomcat, we switched things around so that the web server (Jetty) runs within MA.</p>
]]></description><link>https://forum.mango-os.com/post/6970</link><guid isPermaLink="true">https://forum.mango-os.com/post/6970</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Fri, 21 Sep 2012 20:09:05 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install - problems with m2m2-start.bat on Fri, 21 Sep 2012 20:06:49 GMT]]></title><description><![CDATA[<p dir="auto">Hi Matthew,</p>
<p dir="auto">I think you nailed it. It started up now.</p>
<p dir="auto">So in short:</p>
<li>Make sure you set an env var for JAVA_HOME</li>
<li>Make sure Mango is installed in a directory without spaces in its path.</li>
<p dir="auto">Maybe best to put that in the readme file or so, for future users?</p>
<p dir="auto">Thanks heaps for your help!</p>
<p dir="auto">How come I don't have to install Apache Tomcat for Mango Automation?</p>
]]></description><link>https://forum.mango-os.com/post/6969</link><guid isPermaLink="true">https://forum.mango-os.com/post/6969</guid><dc:creator><![CDATA[Koen]]></dc:creator><pubDate>Fri, 21 Sep 2012 20:06:49 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install - problems with m2m2-start.bat on Fri, 21 Sep 2012 20:00:21 GMT]]></title><description><![CDATA[<p dir="auto">Ha! Now it <em>is</em> a problem with spaces in your path. We'll look into a fix for this, but can you try removing the spaces?</p>
]]></description><link>https://forum.mango-os.com/post/6968</link><guid isPermaLink="true">https://forum.mango-os.com/post/6968</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Fri, 21 Sep 2012 20:00:21 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install - problems with m2m2-start.bat on Fri, 21 Sep 2012 19:47:04 GMT]]></title><description><![CDATA[<p dir="auto">Hi Matthew,</p>
<p dir="auto">I get the same.</p>
<p dir="auto">Attachment: <a href="http://archive.infiniteautomation.com/forum/posts/downloadAttach/179.page" rel="nofollow ugc">download link</a></p>
]]></description><link>https://forum.mango-os.com/post/6967</link><guid isPermaLink="true">https://forum.mango-os.com/post/6967</guid><dc:creator><![CDATA[Koen]]></dc:creator><pubDate>Fri, 21 Sep 2012 19:47:04 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install - problems with m2m2-start.bat on Fri, 21 Sep 2012 19:37:54 GMT]]></title><description><![CDATA[<p dir="auto">Hmm. Can you try the following commands in a command prompt? Check if the results you get are different from mine.</p>
<pre><code>
C:\Users\Matthew&amp;gt;setlocal
C:\Users\Matthew&amp;gt;for
The syntax of the command is incorrect.
]]></description><link>https://forum.mango-os.com/post/6966</link><guid isPermaLink="true">https://forum.mango-os.com/post/6966</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Fri, 21 Sep 2012 19:37:54 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install - problems with m2m2-start.bat on Fri, 21 Sep 2012 19:28:28 GMT]]></title><description><![CDATA[<p dir="auto">Windows 7</p>
]]></description><link>https://forum.mango-os.com/post/6965</link><guid isPermaLink="true">https://forum.mango-os.com/post/6965</guid><dc:creator><![CDATA[Koen]]></dc:creator><pubDate>Fri, 21 Sep 2012 19:28:28 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install - problems with m2m2-start.bat on Fri, 21 Sep 2012 19:22:10 GMT]]></title><description><![CDATA[<p dir="auto">What version of Windows are you using?</p>
]]></description><link>https://forum.mango-os.com/post/6964</link><guid isPermaLink="true">https://forum.mango-os.com/post/6964</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Fri, 21 Sep 2012 19:22:10 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install - problems with m2m2-start.bat on Fri, 21 Sep 2012 19:17:34 GMT]]></title><description><![CDATA[<p dir="auto">Hi Matthew,</p>
<p dir="auto">I did as you asked, see attached screenshot.</p>
<p dir="auto">Attachment: <a href="http://archive.infiniteautomation.com/forum/posts/downloadAttach/178.page" rel="nofollow ugc">download link</a></p>
]]></description><link>https://forum.mango-os.com/post/6963</link><guid isPermaLink="true">https://forum.mango-os.com/post/6963</guid><dc:creator><![CDATA[Koen]]></dc:creator><pubDate>Fri, 21 Sep 2012 19:17:34 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install - problems with m2m2-start.bat on Fri, 21 Sep 2012 19:07:50 GMT]]></title><description><![CDATA[<p dir="auto">Weird, i just downloaded the core now, ran the bat file and it worked fine. At line 35 in the bat file there is the line "rem echo %M2M2_CP%". Can you remove the "rem" part so that it writes the classpath it is starting with?</p>
]]></description><link>https://forum.mango-os.com/post/6962</link><guid isPermaLink="true">https://forum.mango-os.com/post/6962</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Fri, 21 Sep 2012 19:07:50 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install - problems with m2m2-start.bat on Fri, 21 Sep 2012 18:56:36 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for you quick help,</p>
<p dir="auto">I entered the JAVA_HOME env var through the Control Panel -&gt; System etc...</p>
<p dir="auto">Then I ran the startup script again, it made a difference, but now I have a different problem it seems. See screenshot.</p>
<p dir="auto">Attachment: <a href="http://archive.infiniteautomation.com/forum/posts/downloadAttach/177.page" rel="nofollow ugc">download link</a></p>
]]></description><link>https://forum.mango-os.com/post/6961</link><guid isPermaLink="true">https://forum.mango-os.com/post/6961</guid><dc:creator><![CDATA[Koen]]></dc:creator><pubDate>Fri, 21 Sep 2012 18:56:36 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install - problems with m2m2-start.bat on Fri, 21 Sep 2012 18:45:46 GMT]]></title><description><![CDATA[<p dir="auto">Actually, that may not be it. Can you check your Java path. Currently it's pointing to "C:\Program Files\Java\jre6...". I believe it should point to something like "C:\Program Files\Java\jdk1.6.0_xx...". You may need to add a JAVA_HOME env var to set this. It should be set to "C:\Program Files\Java\jdk1.6.0_xx" where "xx" is the micro version of Java you have installed.</p>
]]></description><link>https://forum.mango-os.com/post/6960</link><guid isPermaLink="true">https://forum.mango-os.com/post/6960</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Fri, 21 Sep 2012 18:45:46 GMT</pubDate></item><item><title><![CDATA[Reply to Fresh install - problems with m2m2-start.bat on Fri, 21 Sep 2012 18:41:21 GMT]]></title><description><![CDATA[<p dir="auto">Hi Koen,</p>
<p dir="auto">For now, can you try removing the spaces in your path and try again?</p>
]]></description><link>https://forum.mango-os.com/post/6959</link><guid isPermaLink="true">https://forum.mango-os.com/post/6959</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Fri, 21 Sep 2012 18:41:21 GMT</pubDate></item></channel></rss>
