    ma.log filling up with NoSQL Batch Writer Fatal Error
    23 Posts 4 Posters 27.7k Views 4 Watching
    • cmusselmC Offline
      cmusselm
      After trying various things with the file; elevating my privileges in Windows to System and still failing to do anything with it, we stopped Mango and tried to manipulate the file with no luck.
      The good news is that when we restarted Mango, it looks like it removed the trouble file for us and all is good now.
      Chad
      • cmusselmC Offline
        cmusselm
        I wanted to provide another round of updates as we've run into this issue two more times.
        The most recent time we had the issue an app restart did stop the error from being written to the ma.log, but the corrupt file was still hanging around. After several days it did go away, so it seems whatever process Mango uses to clean up the files eventually worked.
        While working with the support team we were pointed to look for other programs that could possibly lock one of the data files while NoSQL is trying to write to it. If that happens, this issue could occur.
        I checked with our infrastructure team and they had an antivirus program that was performing checks on the NoSQL database directory. The antivirus has been disabled for that folder now.
        I also found this post about Windows Indexing locking files: https://techcommunity.microsoft.com/t5/windows-blog-archive/the-case-of-the-mysterious-locked-file/ba-p/723349 Because of this I made sure to uncheck the "Allow files in this folder to have contents indexed..." option as that could have also contributed to the file being locked when NoSQL needed to write to it.
        So far things are good since making those updates. Hopefully this helps anyone that may run into this.
        Chad
        • cmusselmC Offline
          cmusselm
          Well, this error keeps coming back. We thought things were cleared up as it was good for a month or more, but now we've gotten it twice within a couple weeks of each other.
          One thing we've observed is that every time the error has happened, it's been a scripting datasource using httpBuilder that has the error. I found this by going through all of these data sources and clicking the Validate button, and the there's always one that will get the error:
          java.lang.RuntimeException: java.io.FileNotFoundException: C:\Databases\mangoTSDB\67\33597\771.data.rev (Access is denied)
          The full error in the ma.log is:
          FATAL 2022-07-18T14:57:57,169 [high-pool-2-thread-29880 --> NoSQL Batch Writer 0] - Should never happen, data loss for unknown reason
          Here's a look at the scripting data source's code. Is there anything we're doing that should be modified to stop this error? We're hitting the Runtime Status endpoint so we can get are more complete history of poll durations, aborted poll, average poll time, etc.
          Is this something we shouldn't be doing and using a different method to get this information from the app?
          var xid = "dataSourceXID";
          var noRec = 2; //Used to know how many records to get from the runtime status
          ## Set parameters to retrieve data source runtime status from the API
          var url = "https://ourdomain.com/rest/v2/data-sources/status/"+xid;
          var headers = {Accept: "application/json, text/plain, */*",
          Authorization: "Bearer ourauthcode"};
          var params = {};
          hitAPI(url, headers, params, parseContent, xid, noRec);
          ## Function to hit the API and retrieve the data set
          function hitAPI(url, headers, params, callback, xid, noRec) {
              HttpBuilder.get(url,headers,params)
              .err(function(status, headers, content) { //setErrorCallback for linguistic completion
              	        print("");
                      	print("Fail Status: " + status);
                      	print("Fail Headers: " + headers);
                      	print("Fail Content: " + content);
                  callback(status, headers, content, xid, noRec);
              }).excp(function(exception) { //setExceptionCallback
              	throw exception.getMessage();
              }).execute();
          } //End function getAPI
          function parseContent (status, headers, content, xid, noRec) {
              var content = JSON.parse(content);
              //Logic here to parse through the results and set data point values
          } //End function parseContent
          Any help or insights are appreciated.
          Chad
            CraigWeb @cmusselm
            @cmusselm
            Could mango have been started as an administrator within the last month? It seems like the same error, most probably the same cause?
            cmusselmC 1 Reply Last reply Reply Quote 0
            • cmusselmC Offline
              cmusselm @CraigWeb
              @CraigWeb Thanks for the reply. I don't think that's the case. We only start the app via a Windows service which runs as Local System account.
              The fact that each time this happens, we found a scripting data source that hits the /data-sources/status endpoint with the error seemed odd, and made us wonder if that endpoint could be contributing to the error.
              Is there any way to pull that data differently? It doesn't seem to be set up like a normal data point. If we could reference it's history (More than the previous 10) we may be able to bypass the scripting DS that we currently use to get this info.
              Chad
                terrypacker @cmusselm
                @cmusselm a few thoughts for you.
                • You might be able to get this information via setting up the Internal Data Source to have a point that tracks what you are looking for. However I don't easily see how the status endpoint being hit will affect the shard files...
                • Did you triple check your antivirus software, it might be locking that file?
                • cmusselmC Offline
                  cmusselm @terrypacker
                  @terrypacker I'll check again with our infrastructure team to ensure that all antivirus software has the DB directories excluded, and that no other software could be hitting them.
                  For the internal data points, I have posted a couple questions about them in 2020, but based on the answers, they don't work the way we would need for our client.
                  https://forum.mango-os.com/topic/4925/poll-success-percentage-over-what-timeframe
                  https://forum.mango-os.com/topic/4948/question-on-internal-metric-previous-sequential-successful-polls
                  I wouldn't think that this endpoint is causing the issue, but it seems odd that every time this happens, a Data Source calling that endpoint is generating the error. Do you know where the Data Source Runtime Status data is kept? Is it somewhere in the NoSQL file structure, and is there a way that we could tell Mango to keep more than the previous 10 data point values? If we could get it to store the previous 2 - 4 weeks, then we could probably use the status endpoint and not need a new data source to store its data for longer periods.
                  Chad
                    @cmusselm
                    It's only in memory (cached on the running data source).
                    This is hard coded to keep the last 10 poll statistics only.
                    Just to be sure I read through the status endpoint code and I can't see how it would affect a shard. So either this is an impressive coincidence or we are missing something.
                    • cmusselmC Offline
                      cmusselm
                      For tracking purposes, I wanted to let you know that we got another corrupt file a night or two ago. It again was from one of our Runtime scripts. I went through every one and clicked the validate button, and sure enough one complained about the file.
                      I've run out of ideas on what could be locking the file outside of Mango. I'll ask if our infrastructure team can do another sweep of the system to see if anything sticks out.
                      Chad
                      • cmusselmC Offline
                        cmusselm
                        We've now had 3 more files get corrupted, all are trying to be written to by our scripting datasources that hit the /data-source/status endpoint.
                        Is there a way to get this looked into more closely? Should I open a support ticket?
                        100% of these errors have been with datasources we use to hit the status endpoint.
                        ERROR 2022-08-30T17:12:49,279 [high-pool-2-thread-159790 --> Polling Data Source: datasource_name_here-runtime_status] - Uncaught Task Exception
                        com.serotonin.ShouldNeverHappenException: java.lang.RuntimeException: java.io.FileNotFoundException: C:\Databases\mangoTSDB\3\41918\773.data.rev (Access is denied)
                        ERROR 2022-08-30T17:12:52,544 [high-pool-2-thread-159645 --> Polling Data Source: datasource_name_here-runtime_status] - Uncaught Task Exception
                        com.serotonin.ShouldNeverHappenException: java.lang.RuntimeException: java.io.FileNotFoundException: C:\Databases\mangoTSDB\54\33945\773.data.rev (Access is denied)
                        ERROR 2022-08-30T17:12:56,294 [high-pool-2-thread-159759 --> Polling Data Source: datasource_name_here-runtime_status] - Uncaught Task Exception
                        com.serotonin.ShouldNeverHappenException: java.lang.RuntimeException: java.io.FileNotFoundException: C:\Databases\mangoTSDB\78\23157\773.data.rev (Access is denied)
                        Chad
                          MattFox @cmusselm
                          @cmusselm Push for a support ticket.
                          It's the only way to get ahold of them now.
                          • cmusselmC Offline
                            cmusselm
                            @MattFox You're probably right. I'll do that here soon. As of now, I'm trying to re-create the issue in our test environment. We have 150+ scripts that run every 6 seconds to get the runtime info for various data sources in prod.
                            Hopefully doing this in test will yield similar issues and can help with additional troubleshooting.
                            • cmusselmC Offline
                              cmusselm
                              One thing we're doing that could be contributing to this is using .set inside a for loop when we have pulled multiple runtime records.
                                      for (var i = noRec; i > 0; i--) {
                                          var pollDuration = content.latestPolls[successLen-i].duration/1000;
                                          var pollTime = content.latestPolls[successLen-i].startTime;
                                          varPollDuration.set(pollDuration, epoch(pollTime));
                                      } //End for
                              We're going to replace this with an API call the /point-values to see if pushing the array of values and time to the data point will help resolve this.
                              I'll post an update when done and tested out.
                                MattFox @cmusselm
                                @cmusselm talking from experience, if you start hammering the api, you can get dashboard connection issues.
                                Using the java calls is far better as it is more direct.
                                Perhaps try inserting a RuntimeManager.sleep() call instead?
                                Space out each write with ten milliseconds to give your system enough time between writes.
                                That and perhaps increase the cache size of those points to ten if you have not done so already.
                                • cmusselmC Offline
                                  cmusselm
                                  @MattFox Thanks for the insight. I'll definitely explore that and let you know what happens.
                                  Chad
                                  • cmusselmC Offline
                                    cmusselm
                                    Quick update on my progress.
                                    It took a little longer that desired, but we were finally able to get the corrupt files cleared out, and all of our Runtime DS Scripts updated with the sleep that @MattFox suggested, as well as caching 10 DPs for those points.
                                    Hopefully all is good, and we don't see corrupt files any longer. I'll give it a month or so and post an update to hopefully close this out once and for all.
                                    Chad
                                      MattFox @cmusselm
                                      @cmusselm Good Luck!
                                      • cmusselmC Offline
                                        cmusselm
                                        It's been well over a month and we haven't seen the issue come back. I think it's safe to say the problem is resolved.
                                        Thanks @MattFox for the suggestions and being active in the forum! Your posts have helped me more than you know.
                                          MattFox @cmusselm
                                          @cmusselm Thanks for letting me know!
