    Serial data source causing crash
    User help
    2
    9
    608
    • L
      lesdotcom
      Re: Serial data source causing crash
      Having this same issue with mango crashing upon enabling serial data source. Started after reinstalling windows. Using mango 3.7.7, have tried jdk 8, jdk 11, and jdk 13.
      • MattFoxM
        I'm using AdoptJDK14 on Linux, no idea why you are having problems.
        Is there not anything in the logs?
        Also, look at the version 3 docs about enabling debug logging and show that here in code </> tags. That will enable us to deduce the issue faster
        • L
          lesdotcom
          Here is a snippet of error log. Entire log too long to post here.
          # A fatal error has been detected by the Java Runtime Environment:
          #  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000007110b5db, pid=7112, tid=0x0000000000001bcc
          # JRE version: Java(TM) SE Runtime Environment (8.0_271-b09) (build 1.8.0_271-b09)
          # Java VM: Java HotSpot(TM) 64-Bit Server VM (25.271-b09 mixed mode windows-amd64 compressed oops)
          # Problematic frame:
          # C  [jSSC-2.8_x86_64.dll+0xb5db]
          # Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
          # If you would like to submit a bug report, please visit:
          #   http://bugreport.java.com/bugreport/crash.jsp
          # The crash happened outside the Java Virtual Machine in native code.
          # See problematic frame for where to report the bug.
          ---------------  T H R E A D  ---------------
          Current thread (0x00000280a4ee5800):  JavaThread "high-pool-2-thread-7 --> Datasource subgroup initializer" [_thread_in_native, id=7116, stack(0x000000dd1b500000,0x000000dd1b600000)]
          siginfo: ExceptionCode=0xc0000005, reading address 0xffffffffa3b457b0
          Registers:
          RAX=0xffffffffa3b457b0, RBX=0x000000dd1b5fea60, RCX=0x00007ffbed84c194, RDX=0x0000000000000000
          RSP=0x000000dd1b5fe9f0, RBP=0x000000dd1b5feb70, RSI=0x00000280a4ee59f8, RDI=0x0000000000000e1c
          R8 =0x000000dd1b5fe8e8, R9 =0x000000dd1b5fe9e0, R10=0x0000000000000000, R11=0x0000000000000246
          R12=0x000000dd1b5fec28, R13=0x00000280a19d67b0, R14=0x000000dd1b5feb20, R15=0x00000280a4ee5800
          RIP=0x000000007110b5db, EFLAGS=0x0000000000010202
          Top of Stack: (sp=0x000000dd1b5fe9f0)
          0x000000dd1b5fe9f0:   00000280a162ce00 00000280a19d6720
          0x000000dd1b5fea00:   000000007110b230 000002808a370000
          0x000000dd1b5fea10:   000002808a240000 0000000000000004
          0x000000dd1b5fea20:   00000280a4ee59f8 0000000000000e1c
          0x000000dd1b5fea30:   000000dd1b5feb70 0000000071112590
          0x000000dd1b5fea40:   00000280a4ee5800 000000dd1b5feb20
          0x000000dd1b5fea50:   00000280a19d67b0 000000dd1b5fec28
          0x000000dd1b5fea60:   00000280a19d67b0 00007ffbed7c5d21
          0x000000dd1b5fea70:   000000dd1b5feaa0 000002808a370000
          0x000000dd1b5fea80:   000000dd1b5feb70 0000000000000000
          0x000000dd1b5fea90:   0000000071113500 0000000071113be8
          0x000000dd1b5feaa0:   000000dd1b5fead0 0000000071112641
          0x000000dd1b5feab0:   000000dd1b5fea40 00000280a4ee59f8
          0x000000dd1b5feac0:   0000000000000000 0000000000000000
          0x000000dd1b5fead0:   000000dd1b5feb70 0000000071101595
          0x000000dd1b5feae0:   000000000000001c 0000028000000000
          Instructions: (pc=0x000000007110b5db)
          0x000000007110b5bb:   c5 0f 1f 40 00 55 57 56 53 48 83 ec 28 48 8b 05
          0x000000007110b5cb:   39 33 01 00 48 89 cb 48 85 c0 0f 84 c5 00 00 00
          0x000000007110b5db:   8b 38 85 ff 0f 88 ab 00 00 00 48 8b 05 1c 33 01
          0x000000007110b5eb:   00 48 85 c0 0f 84 bc 00 00 00 8b 30 85 f6 74 57
          Register to memory mapping:
          RAX=0xffffffffa3b457b0 is an unknown value
          RBX=0x000000dd1b5fea60 is pointing into the stack for thread: 0x00000280a4ee5800
          RCX=0x00007ffbed84c194 is an unknown value
          RDX=0x0000000000000000 is an unknown value
          RSP=0x000000dd1b5fe9f0 is pointing into the stack for thread: 0x00000280a4ee5800
          RBP=0x000000dd1b5feb70 is pointing into the stack for thread: 0x00000280a4ee5800
          RSI=0x00000280a4ee59f8 is an unknown value
          RDI=0x0000000000000e1c is an unknown value
          R8 =0x000000dd1b5fe8e8 is pointing into the stack for thread: 0x00000280a4ee5800
          R9 =0x000000dd1b5fe9e0 is pointing into the stack for thread: 0x00000280a4ee5800
          R10=0x0000000000000000 is an unknown value
          R11=0x0000000000000246 is an unknown value
          R12=0x000000dd1b5fec28 is pointing into the stack for thread: 0x00000280a4ee5800
          R13=0x00000280a19d67b0 is an unknown value
          R14=0x000000dd1b5feb20 is pointing into the stack for thread: 0x00000280a4ee5800
          R15=0x00000280a4ee5800 is a thread
          Stack: [0x000000dd1b500000,0x000000dd1b600000],  sp=0x000000dd1b5fe9f0,  free space=1018k
          Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
          C  [jSSC-2.8_x86_64.dll+0x12590]
          C  [jSSC-2.8_x86_64.dll+0x1595]
          C  0x000002808bd6750e
          Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
          j  jssc.SerialNativeInterface.openPort(Ljava/lang/String;Z)J+0
          j  jssc.SerialPort.openPort()Z+65
          j  com.infiniteautomation.mango.io.serial.JsscSerialPortProxy.openImpl()V+65
          j  com.infiniteautomation.mango.io.serial.SerialPortProxy.open()V+53
          j  com.infiniteautomation.mango.io.serial.SerialPortManagerImpl.open(Ljava/lang/String;Ljava/lang/String;ILcom/infiniteautomation/mango/io/serial/FlowControl;Lcom/infiniteautomation/mango/io/serial/FlowControl;Lcom/infiniteautomation/mango/io/serial/DataBits;Lcom/infiniteautomation/mango/io/serial/StopBits;Lcom/infiniteautomation/mango/io/serial/Parity;)Lcom/infiniteautomation/mango/io/serial/SerialPortProxy;+295
          j  com.infiniteautomation.serial.rt.SerialDataSourceRT.connect()Z+143
          j  com.infiniteautomation.serial.rt.SerialDataSourceRT.initialize()V+80
          j  com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup(Lcom/serotonin/m2m2/vo/dataSource/DataSourceVO;)Z+34
          j  com.serotonin.m2m2.rt.DataSourceGroupInitializer$DataSourceSubGroupInitializer.run(J)V+46
          j  com.serotonin.timer.Task.runTask(J)V+126
          j  com.serotonin.timer.TaskWrapper.run()V+8
          j  java.util.concurrent.ThreadPoolExecutor.runWorker(Ljava/util/concurrent/ThreadPoolExecutor$Worker;)V+95
          j  java.util.concurrent.ThreadPoolExecutor$Worker.run()V+5
          j  java.lang.Thread.run()V+11
          v  ~StubRoutines::call_stub
          ---------------  P R O C E S S  ---------------
          Java Threads: ( => current thread )
            0x00000280a4ee6000 JavaThread "high-pool-2-thread-9" [_thread_blocked, id=7052, stack(0x000000dd1b700000,0x000000dd1b800000)]
            0x00000280a4ee9000 JavaThread "high-pool-2-thread-8 --> Datasource subgroup initializer" [_thread_blocked, id=5600, stack(0x000000dd1b600000,0x000000dd1b700000)]
          =>0x00000280a4ee5800 JavaThread "high-pool-2-thread-7 --> Datasource subgroup initializer" [_thread_in_native, id=7116, stack(0x000000dd1b500000,0x000000dd1b600000)]
            0x00000280a4ee7800 JavaThread "high-pool-2-thread-6 --> Datasource subgroup initializer" [_thread_in_native, id=5160, stack(0x000000dd1b400000,0x000000dd1b500000)]
            0x00000280a4ee4800 JavaThread "high-pool-2-thread-5 --> Datasource subgroup initializer" [_thread_blocked, id=480, stack(0x000000dd1b300000,0x000000dd1b400000)]
            0x00000280a4ee4000 JavaThread "high-pool-2-thread-4 --> Datasource subgroup initializer" [_thread_blocked, id=4980, stack(0x000000dd1b200000,0x000000dd1b300000)]
            0x00000280a4ee8800 JavaThread "high-pool-2-thread-3 --> Datasource subgroup initializer" [_thread_blocked, id=8620, stack(0x000000dd1b100000,0x000000dd1b200000)]
            0x00000280a4ee7000 JavaThread "high-pool-2-thread-2 --> Datasource subgroup initializer" [_thread_blocked, id=8088, stack(0x000000dd1b000000,0x000000dd1b100000)]
            0x00000280a1aab800 JavaThread "high-pool-2-thread-1 --> Datasource subgroup initializer" [_thread_blocked, id=4248, stack(0x000000dd1af00000,0x000000dd1b000000)]
            0x00000280a1aad800 JavaThread "Mango Serial Port Event Processor" [_thread_blocked, id=7468, stack(0x000000dd1ae00000,0x000000dd1af00000)]
            0x00000280a1aa9000 JavaThread "Mango shared scheduled executor" daemon [_thread_blocked, id=8188, stack(0x000000dd1ad00000,0x000000dd1ae00000)]
            0x00000280a1aa7800 JavaThread "H2 Log Writer MAH2.199" daemon [_thread_blocked, id=8060, stack(0x000000dd1ac00000,0x000000dd1ad00000)]
            0x00000280a1aaa000 JavaThread "H2 File Lock Watchdog C:/Users/Les/Desktop/Mango 3.7.4 Basement/databases/mah2.199.lock.db" daemon [_thread_blocked, id=6364, stack(0x000000dd1ab00000,0x000000dd1ac00000)]
            0x00000280a1aa8800 JavaThread "Abandoned connection cleanup thread" daemon [_thread_blocked, id=6288, stack(0x000000dd1aa00000,0x000000dd1ab00000)]
            0x00000280a1aad000 JavaThread "Ordered RealTime Timer" [_thread_blocked, id=2800, stack(0x000000dd1a500000,0x000000dd1a600000)]
            0x00000280a1aac000 JavaThread "Connector-Scheduler-773bd77b-1" [_thread_blocked, id=5748, stack(0x000000dd1a300000,0x000000dd1a400000)]
            0x00000280a1aa7000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=268, stack(0x000000dd1a400000,0x000000dd1a500000)]
            0x00000280a1aaa800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=8840, stack(0x000000dd1a200000,0x000000dd1a300000)]
            0x00000280a2057000 JavaThread "jetty-thread-pool-21" [_thread_blocked, id=1276, stack(0x000000dd1a100000,0x000000dd1a200000)]
            0x00000280a2056800 JavaThread "jetty-thread-pool-20" [_thread_blocked, id=2692, stack(0x000000dd1a000000,0x000000dd1a100000)]
            0x00000280a0241000 JavaThread "jetty-thread-pool-19" [_thread_blocked, id=6636, stack(0x000000dd19f00000,0x000000dd1a000000)]
            0x00000280a2055800 JavaThread "jetty-thread-pool-18" [_thread_in_native, id=8720, stack(0x000000dd19e00000,0x000000dd19f00000)]
            0x00000280a13e2800 JavaThread "jetty-thread-pool-17" [_thread_blocked, id=8516, stack(0x000000dd19d00000,0x000000dd19e00000)]
            0x00000280a13e1800 JavaThread "jetty-thread-pool-16" [_thread_blocked, id=5940, stack(0x000000dd19c00000,0x000000dd19d00000)]
            0x00000280a2bd1000 JavaThread "jetty-thread-pool-15-acceptor-0@932fcc0-ServerConnector@773bd77b{HTTP/1.1,[http/1.1, h2c]}{0.0.0.0:8081}" [_thread_in_native, id=8776, stack(0x000000dd19b00000,0x000000dd19c00000)]
            0x00000280a2099000 JavaThread "jetty-thread-pool-14" [_thread_blocked, id=7916, stack(0x000000dd19a00000,0x000000dd19b00000)]
            0x000002809fbf0000 JavaThread "Log4j2-TF-5-AsyncLoggerConfig--2" daemon [_thread_blocked, id=5760, stack(0x000000dd19900000,0x000000dd19a00000)]
            0x000002809e272800 JavaThread "Service Thread" daemon [_thread_blocked, id=6760, stack(0x000000dd19700000,0x000000dd19800000)]
            0x000002809e212000 JavaThread "C1 CompilerThread1" daemon [_thread_blocked, id=376, stack(0x000000dd19600000,0x000000dd19700000)]
            0x000002809e210000 JavaThread "C2 CompilerThread0" daemon [_thread_in_native, id=9104, stack(0x000000dd19500000,0x000000dd19600000)]
            0x000002809e208800 JavaThread "Attach Listener" daemon [_thread_blocked, id=7616, stack(0x000000dd19400000,0x000000dd19500000)]
            0x000002809e205000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=6876, stack(0x000000dd19300000,0x000000dd19400000)]
            0x000002809dd1c000 JavaThread "Finalizer" daemon [_thread_blocked, id=2936, stack(0x000000dd19100000,0x000000dd19200000)]
            0x000002809e1e3800 JavaThread "Reference Handler" daemon [_thread_blocked, id=8920, stack(0x000000dd19000000,0x000000dd19100000)]
            0x000002808a3ac000 JavaThread "main" [_thread_blocked, id=2488, stack(0x000000dd18c00000,0x000000dd18d00000)]
          Other Threads:
            0x000002809e1c2000 VMThread [stack: 0x000000dd18f00000,0x000000dd19000000] [id=5292]
            0x000002809e2f9800 WatcherThread [stack: 0x000000dd19800000,0x000000dd19900000] [id=8204]
          VM state:not at safepoint (normal execution)
          VM Mutex/Monitor currently owned by a thread: None
          heap address: 0x00000000c4000000, size: 960 MB, Compressed Oops mode: 32-bit
          Narrow klass base: 0x0000000000000000, Narrow klass shift: 3
          Compressed class space size: 1073741824 Address: 0x0000000100000000
          Heap:
           PSYoungGen      total 312320K, used 145433K [0x00000000ec000000, 0x0000000100000000, 0x0000000100000000)
            eden space 296960K, 43% used [0x00000000ec000000,0x00000000f3f0e1f0,0x00000000fe200000)
            from space 15360K, 99% used [0x00000000fe200000,0x00000000ff0f8218,0x00000000ff100000)
            to   space 15360K, 0% used [0x00000000ff100000,0x00000000ff100000,0x0000000100000000)
           ParOldGen       total 71680K, used 35453K [0x00000000c4000000, 0x00000000c8600000, 0x00000000ec000000)
            object space 71680K, 49% used [0x00000000c4000000,0x00000000c629f6f8,0x00000000c8600000)
           Metaspace       used 54274K, capacity 55228K, committed 55384K, reserved 1097728K
            class space    used 6422K, capacity 6682K, committed 6784K, reserved 1048576K
          Card table byte_map: [0x000002809b110000,0x000002809b300000] byte_map_base: 0x000002809aaf0000
          Marking Bits: (ParMarkBitMap*) 0x0000000059c67fe0
           Begin Bits: [0x000002809b440000, 0x000002809c340000)
           End Bits:   [0x000002809c340000, 0x000002809d240000)
          Polling page: 0x000002808a4e0000
          CodeCache: size=245760Kb used=15466Kb max_used=16003Kb free=230293Kb
           bounds [0x000002808bd50000, 0x000002808cd00000, 0x000002809ad50000]
           total_blobs=5205 nmethods=4566 adapters=553
           compilation: enabled
          Compilation events (10 events):
          Event: 32.341 Thread 0x000002809e212000 5363   !   2       org.h2.engine.Session::throttle (151 bytes)
          Event: 32.342 Thread 0x000002809e212000 nmethod 5363 0x000002808be632d0 code [0x000002808be63460, 0x000002808be63940]
          Event: 32.347 Thread 0x000002809e212000 5364       2       org.h2.command.Prepared::checkCanceled (38 bytes)
          Event: 32.348 Thread 0x000002809e212000 nmethod 5364 0x000002808bf61850 code [0x000002808bf619e0, 0x000002808bf61d10]
          Event: 32.348 Thread 0x000002809e212000 5365       2       org.h2.command.Command::checkCanceled (19 bytes)
          Event: 32.348 Thread 0x000002809e212000 nmethod 5365 0x000002808c085ad0 code [0x000002808c085c60, 0x000002808c085fa0]
          Event: 32.357 Thread 0x000002809e212000 5366       2       java.util.concurrent.ConcurrentHashMap::tableSizeFor (59 bytes)
          Event: 32.357 Thread 0x000002809e212000 nmethod 5366 0x000002808bfa5410 code [0x000002808bfa5560, 0x000002808bfa56f8]
          Event: 32.362 Thread 0x000002809e212000 5367       2       org.apache.http.util.Args::notNull (33 bytes)
          Event: 32.362 Thread 0x000002809e212000 nmethod 5367 0x000002808c3423d0 code [0x000002808c342560, 0x000002808c342920]
          GC Heap History (10 events):
          Event: 11.226 GC heap before
          {Heap before GC invocations=9 (full 1):
           PSYoungGen      total 259584K, used 2710K [0x00000000ec000000, 0x00000000fcb00000, 0x0000000100000000)
            eden space 245760K, 0% used [0x00000000ec000000,0x00000000ec000000,0x00000000fb000000)
            from space 13824K, 19% used [0x00000000fbd80000,0x00000000fc025a68,0x00000000fcb00000)
            to   space 13824K, 0% used [0x00000000fb000000,0x00000000fb000000,0x00000000fbd80000)
           ParOldGen       total 40960K, used 24770K [0x00000000c4000000, 0x00000000c6800000, 0x00000000ec000000)
            object space 40960K, 60% used [0x00000000c4000000,0x00000000c5830a28,0x00000000c6800000)
           Metaspace       used 20764K, capacity 21046K, committed 21248K, reserved 1067008K
            class space    used 2656K, capacity 2767K, committed 2816K, reserved 1048576K
          Event: 11.456 GC heap after
          Heap after GC invocations=9 (full 1):
           PSYoungGen      total 259584K, used 0K [0x00000000ec000000, 0x00000000fcb00000, 0x0000000100000000)
            from space 13824K, 0% used [0x00000000fbd80000,0x00000000fbd80000,0x00000000fcb00000)
           ParOldGen       total 55296K, used 23744K [0x00000000c4000000, 0x00000000c7600000, 0x00000000ec000000)
            object space 55296K, 42% used [0x00000000c4000000,0x00000000c5730150,0x00000000c7600000)
          Event: 17.658 GC heap before
          {Heap before GC invocations=10 (full 1):
           PSYoungGen      total 259584K, used 245760K [0x00000000ec000000, 0x00000000fcb00000, 0x0000000100000000)
            eden space 245760K, 100% used [0x00000000ec000000,0x00000000fb000000,0x00000000fb000000)
           Metaspace       used 29789K, capacity 30314K, committed 30720K, reserved 1075200K
            class space    used 3834K, capacity 3995K, committed 4096K, reserved 1048576K
          Event: 17.689 GC heap after
          Heap after GC invocations=10 (full 1):
           PSYoungGen      total 259584K, used 10817K [0x00000000ec000000, 0x0000000100000000, 0x0000000100000000)
            from space 13824K, 78% used [0x00000000fb000000,0x00000000fba90518,0x00000000fbd80000)
            to   space 14848K, 0% used [0x00000000ff180000,0x00000000ff180000,0x0000000100000000)
           ParOldGen       total 55296K, used 23752K [0x00000000c4000000, 0x00000000c7600000, 0x00000000ec000000)
            object space 55296K, 42% used [0x00000000c4000000,0x00000000c5732150,0x00000000c7600000)
          Event: 22.160 GC heap before
          {Heap before GC invocations=11 (full 1):
           PSYoungGen      total 259584K, used 69613K [0x00000000ec000000, 0x0000000100000000, 0x0000000100000000)
            eden space 245760K, 23% used [0x00000000ec000000,0x00000000ef96b188,0x00000000fb000000)
           Metaspace       used 34632K, capacity 35114K, committed 35416K, reserved 1081344K
            class space    used 4272K, capacity 4443K, committed 4480K, reserved 1048576K
          Event: 22.186 GC heap after
          Heap after GC invocations=11 (full 1):
           PSYoungGen      total 311808K, used 10971K [0x00000000ec000000, 0x0000000100000000, 0x0000000100000000)
            eden space 296960K, 0% used [0x00000000ec000000,0x00000000ec000000,0x00000000fe200000)
            from space 14848K, 73% used [0x00000000ff180000,0x00000000ffc36cc0,0x0000000100000000)
            to   space 15360K, 0% used [0x00000000fe200000,0x00000000fe200000,0x00000000ff100000)
           ParOldGen       total 55296K, used 23760K [0x00000000c4000000, 0x00000000c7600000, 0x00000000ec000000)
            object space 55296K, 42% used [0x00000000c4000000,0x00000000c5734150,0x00000000c7600000)
          Event: 22.186 GC heap before
          {Heap before GC invocations=12 (full 2):
          Event: 22.645 GC heap after
          Heap after GC invocations=12 (full 2):
           PSYoungGen      total 311808K, used 0K [0x00000000ec000000, 0x0000000100000000, 0x0000000100000000)
            from space 14848K, 0% used [0x00000000ff180000,0x00000000ff180000,0x0000000100000000)
           ParOldGen       total 71680K, used 29163K [0x00000000c4000000, 0x00000000c8600000, 0x00000000ec000000)
            object space 71680K, 40% used [0x00000000c4000000,0x00000000c5c7ac08,0x00000000c8600000)
          Event: 30.295 GC heap before
          {Heap before GC invocations=13 (full 2):
           PSYoungGen      total 311808K, used 296960K [0x00000000ec000000, 0x0000000100000000, 0x0000000100000000)
            eden space 296960K, 100% used [0x00000000ec000000,0x00000000fe200000,0x00000000fe200000)
           Metaspace       used 50136K, capacity 50992K, committed 51160K, reserved 1093632K
            class space    used 5888K, capacity 6118K, committed 6144K, reserved 1048576K
          Event: 30.355 GC heap after
          Heap after GC invocations=13 (full 2):
           PSYoungGen      total 312320K, used 15328K [0x00000000ec000000, 0x0000000100000000, 0x0000000100000000)
          Deoptimization events (10 events):
          Event: 31.881 Thread 0x00000280a1aab800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000002808c0a2d54 method=java.io.DataInputStream.readUnsignedShort()I @ 4
          Event: 31.881 Thread 0x00000280a1aab800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000002808bf0ec20 method=java.io.DataInputStream.readUnsignedShort()I @ 4
          Event: 31.986 Thread 0x00000280a4ee7800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x000002808c7451f4 method=java.lang.Character.isSurrogate(C)Z @ 3
          Event: 31.996 Thread 0x00000280a4ee7800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x000002808cbc62a4 method=java.util.concurrent.ConcurrentHashMap.putVal(Ljava/lang/Object;Ljava/lang/Object;Z)Ljava/lang/Object; @ 331
          Event: 32.001 Thread 0x00000280a4ee7800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x000002808c30a6d4 method=java.util.concurrent.ConcurrentHashMap.transfer([Ljava/util/concurrent/ConcurrentHashMap$Node;[Ljava/util/concurrent/ConcurrentHashMap$Node;)V @ 356
          Event: 32.006 Thread 0x00000280a4ee8800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000002808c018e68 method=java.lang.AbstractStringBuilder.append(Ljava/lang/CharSequence;)Ljava/lang/AbstractStringBuilder; @ 21
          Event: 32.007 Thread 0x00000280a4ee8800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000002808c018e68 method=java.lang.AbstractStringBuilder.append(Ljava/lang/CharSequence;)Ljava/lang/AbstractStringBuilder; @ 21
          Event: 32.008 Thread 0x00000280a4ee8800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000002808c018e68 method=java.lang.AbstractStringBuilder.append(Ljava/lang/CharSequence;)Ljava/lang/AbstractStringBuilder; @ 21
          Classes redefined (0 events):
          No events
          Internal exceptions (10 events):
          Event: 26.765 Thread 0x000002808a3ac000 Exception <a 'java/lang/ClassNotFoundException': org/springframework/beans/factory/BeanFactoryAwareBeanInfo> (0x00000000f5bb15d0) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\classfile\systemDictionary.c
          Event: 26.770 Thread 0x000002808a3ac000 Exception <a 'java/lang/ClassNotFoundException': org/springframework/beans/factory/BeanFactoryAwareCustomizer> (0x00000000f5c0fd30) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\classfile\systemDictionary
          Event: 26.774 Thread 0x000002808a3ac000 Exception <a 'java/lang/ClassNotFoundException': org/springframework/beans/factory/AwareBeanInfo> (0x00000000f5c64e90) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\classfile\systemDictionary.cpp, line 21
          Event: 26.779 Thread 0x000002808a3ac000 Exception <a 'java/lang/ClassNotFoundException': org/springframework/beans/factory/AwareCustomizer> (0x00000000f5cb94c8) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\classfile\systemDictionary.cpp, line
          Event: 26.784 Thread 0x000002808a3ac000 Exception <a 'java/lang/ClassNotFoundException': org/springframework/context/annotation/ImportAwareBeanInfo> (0x00000000f5d15030) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\classfile\systemDictionary.c
          Event: 26.789 Thread 0x000002808a3ac000 Exception <a 'java/lang/ClassNotFoundException': org/springframework/context/annotation/ImportAwareCustomizer> (0x00000000f5d737d8) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\classfile\systemDictionary
          Event: 27.908 Thread 0x000002808a3ac000 Exception <a 'java/lang/IncompatibleClassChangeError': Found class java.lang.Object, but interface was expected> (0x00000000f8445108) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\interpreter\linkResolver
          Event: 28.641 Thread 0x000002808a3ac000 Implicit null exception at 0x000002808cb6986f to 0x000002808cb6e455
          Event: 31.403 Thread 0x000002808a3ac000 Exception <a 'java/lang/NoSuchMethodError': java.lang.Object.lambda$identity$2(Ljava/lang/Object;)Ljava/lang/Object;> (0x00000000f04a89a8) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\interpreter\linkRes
          Event: 31.805 Thread 0x00000280a4ee5800 Exception <a 'sun/nio/fs/WindowsException'> (0x00000000f13e17f8) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\prims\jni.cpp, line 710]
          Events (10 events):
          Event: 32.357 loading class org/apache/http/impl/client/BasicCredentialsProvider
          Event: 32.357 loading class org/apache/http/impl/client/BasicCredentialsProvider done
          Event: 32.358 loading class org/apache/http/impl/client/HttpClientBuilder$2
          Event: 32.358 loading class org/apache/http/impl/client/HttpClientBuilder$2 done
          Event: 32.359 loading class org/apache/http/client/ClientProtocolException
          Event: 32.359 loading class org/apache/http/client/ClientProtocolException done
          Event: 32.360 loading class org/apache/http/conn/ClientConnectionManager
          Event: 32.360 loading class org/apache/http/conn/ClientConnectionManager done
          Event: 32.361 Executing VM operation: RevokeBias
          Event: 32.362 Executing VM operation: RevokeBias done
          • MattFoxM
            According to this error, you are running Java8, please run with a higher version of AdoptJDK and give me the ma.log from your mango log. 3.6+ needs at least version 11.
            I also suggest reinstalling the serial module.
            • L
              lesdotcom
              Here is the JDK 13 log:
              #  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000007110b5db, pid=3832, tid=4616
              # JRE version: Java(TM) SE Runtime Environment (13.0.1+9) (build 13.0.1+9)
              # Java VM: Java HotSpot(TM) 64-Bit Server VM (13.0.1+9, mixed mode, sharing, tiered, compressed oops, g1 gc, windows-amd64)
              # No core dump will be written. Minidumps are not enabled by default on client versions of Windows
              ---------------  S U M M A R Y ------------
              Command Line: -Dma.home=C:\Users\Les\Desktop\Mango 3.7.4 Basement com.serotonin.m2m2.Main
              Host: AMD Athlon(tm) 64 X2 Dual Core Processor 5200+, 2 cores, 3G,  Windows 10 , 64 bit Build 19041 (10.0.19041.662)
              Time: Fri Jan  1 13:36:33 2021 Pacific Standard Time elapsed time: 33 seconds (0d 0h 0m 33s)
              Current thread (0x0000020993d01800):  JavaThread "high-pool-2-thread-7 --> Datasource subgroup initializer" [_thread_in_native, id=4616, stack(0x000000fabd400000,0x000000fabd500000)]
              Stack: [0x000000fabd400000,0x000000fabd500000],  sp=0x000000fabd4fe940,  free space=1018k
              j  java.util.concurrent.ThreadPoolExecutor.runWorker(Ljava/util/concurrent/ThreadPoolExecutor$Worker;)V+92 java.base@13.0.1
              j  java.util.concurrent.ThreadPoolExecutor$Worker.run()V+5 java.base@13.0.1
              j  java.lang.Thread.run()V+11 java.base@13.0.1
              siginfo: EXCEPTION_ACCESS_VIOLATION (0xc0000005), reading address 0xffffffffef7aced9
              RIP=0x000000007110b5db jSSC-2.8_x86_64.dll
              RAX=0xffffffffef7aced9 is an unknown value
              RBX=0x000000fabd4fe9b0 is pointing into the stack for thread: 0x0000020993d01800
              RCX=0x00007ffa653cc194 ntdll.dll
              RDX=0x0 is NULL
              RSP=0x000000fabd4fe940 is pointing into the stack for thread: 0x0000020993d01800
              RBP=0x000000fabd4feac0 is pointing into the stack for thread: 0x0000020993d01800
              RSI=0x0000020993d01b10 points into unknown readable memory: 50 e8 78 2d fa 7f 00 00
              RDI=0x0000000000000d68 is an unknown value
              R8 =0x000000fabd4fe838 is pointing into the stack for thread: 0x0000020993d01800
              R9 =0x000000fabd4fe930 is pointing into the stack for thread: 0x0000020993d01800
              R10=0x0 is NULL
              R12=0x000000fabd4feb80 is pointing into the stack for thread: 0x0000020993d01800
              R13=0x000002099234a9e0 points into unknown readable memory: 00 00 00 00 08 00 00 00
              R14=0x000000fabd4fea70 is pointing into the stack for thread: 0x0000020993d01800
              R15=0x0000020993d01800 is a thread
              Registers:
              RAX=0xffffffffef7aced9, RBX=0x000000fabd4fe9b0, RCX=0x00007ffa653cc194, RDX=0x0000000000000000
              RSP=0x000000fabd4fe940, RBP=0x000000fabd4feac0, RSI=0x0000020993d01b10, RDI=0x0000000000000d68
              R8 =0x000000fabd4fe838, R9 =0x000000fabd4fe930, R10=0x0000000000000000, R11=0x0000000000000246
              R12=0x000000fabd4feb80, R13=0x000002099234a9e0, R14=0x000000fabd4fea70, R15=0x0000020993d01800
              RIP=0x000000007110b5db, EFLAGS=0x0000000000010206
              Top of Stack: (sp=0x000000fabd4fe940)
              0x000000fabd4fe940:   00000209923f56d0 0000020992349c90
              0x000000fabd4fe950:   000000007110b230 00000209ef550000
              0x000000fabd4fe960:   00000209ef650000 0000000000000004
              0x000000fabd4fe970:   0000020993d01b10 0000000000000d68
              0x000000fabd4fe980:   000000fabd4feac0 0000000071112590
              0x000000fabd4fe990:   0000020993d01800 000000fabd4fea70
              0x000000fabd4fe9a0:   000002099234a9e0 000000fabd4feb80
              0x000000fabd4fe9b0:   000002099234a9e0 00007ffa65345d21
              0x000000fabd4fe9c0:   000000fabd4fe9f0 00000209ef550000
              0x000000fabd4fe9d0:   000000fabd4feac0 0000000000000000
              0x000000fabd4fe9e0:   0000000071113500 0000000071113be8
              0x000000fabd4fe9f0:   000000fabd4fea20 0000000071112641
              0x000000fabd4fea00:   000000fabd4fe990 0000020993d01b10
              0x000000fabd4fea10:   0000000000000000 0000000000000000
              0x000000fabd4fea20:   000000fabd4feac0 0000000071101595
              0x000000fabd4fea30:   000000000000001c 0000020900000000
              0x000000007110b4db:   48 85 c0 74 bf 44 8b 03 45 85 c0 0f 84 77 ff ff
              0x000000007110b4eb:   ff eb 9f 66 90 e8 8b fe ff ff 48 89 05 0c 34 01
              0x000000007110b4fb:   00 eb ad 66 90 e8 7b fe ff ff 48 89 05 fc 33 01
              0x000000007110b50b:   00 eb 8b e8 8d fe ff ff c7 03 01 00 00 00 e9 6f
              0x000000007110b51b:   ff ff ff 66 90 55 48 89 e5 56 53 48 83 ec 20 48
              0x000000007110b52b:   8b 05 d7 33 01 00 48 8b 31 48 89 cb 48 85 c0 74
              0x000000007110b53b:   56 44 8b 18 45 85 db 78 42 48 8b 05 bd 33 01 00
              0x000000007110b54b:   48 85 c0 74 50 44 8b 10 45 85 d2 74 1d 48 89 f1
              0x000000007110b55b:   e8 d0 fd ff ff 48 8b 13 48 8d 42 40 48 8b 48 08
              0x000000007110b56b:   48 8b 6a 40 48 8b 60 10 ff e1 48 8b 05 9c 33 01
              0x000000007110b57b:   00 48 85 c0 74 2d 48 89 30 eb da e8 b5 fe ff ff
              0x000000007110b58b:   0f 1f 44 00 00 eb b2 e8 e9 fd ff ff 48 89 05 6a
              0x000000007110b59b:   33 01 00 eb 9c e8 db fd ff ff 48 89 05 5c 33 01
              0x000000007110b5ab:   00 eb a2 e8 3d fd ff ff 48 89 05 5e 33 01 00 eb
              0x000000007110b5fb:   48 8b 05 0e 33 01 00 48 85 c0 0f 84 e5 00 00 00
              0x000000007110b60b:   8b 28 48 8b 35 10 5e 01 00 ff d6 89 c7 89 e9 ff
              0x000000007110b61b:   15 f4 5e 01 00 89 f9 48 89 c5 ff 15 b9 5e 01 00
              0x000000007110b62b:   48 8b 05 de 32 01 00 48 89 2b 48 85 c0 74 46 48
              0x000000007110b63b:   89 da 8b 08 ff 15 d7 5e 01 00 85 c0 74 27 48 83
              0x000000007110b64b:   c4 28 5b 5e 5f 5d c3 48 8b 05 bf 32 01 00 48 85
              0x000000007110b65b:   c0 74 64 48 8b 10 48 89 13 48 89 18 48 83 c4 28
              0x000000007110b66b:   5b 5e 5f 5d c3 48 89 f2 48 83 c4 28 5b 5e 5f 5d
              0x000000007110b67b:   48 ff e2 66 90 e8 8b fc ff ff 48 89 05 84 32 01
              0x000000007110b68b:   00 eb ac 66 90 e8 ab fd ff ff e9 4b ff ff ff 66
              0x000000007110b69b:   0f 1f 44 00 00 e8 db fc ff ff 48 89 05 5c 32 01
              0x000000007110b6ab:   00 e9 2a ff ff ff e8 ca fc ff ff 48 89 05 4b 32
              0x000000007110b6bb:   01 00 e9 33 ff ff ff e8 29 fc ff ff 48 89 05 4a
              0x000000007110b6cb:   32 01 00 48 8b 10 48 85 c0 48 89 13 75 8b e8 12
              Stack slot to memory mapping:
              stack at sp + 0 slots: 0x00000209923f56d0 points into unknown readable memory: b2 e0 1a 92 2e 00 5c 00
              stack at sp + 1 slots: 0x0000020992349c90 points into unknown readable memory: 00 83 56 92 09 02 00 00
              stack at sp + 2 slots: 0x000000007110b230 jSSC-2.8_x86_64.dll
              stack at sp + 3 slots: 0x00000209ef550000 points into unknown readable memory: 00 00 00 00 00 00 00 00
              stack at sp + 4 slots: 0x00000209ef650000 points into unknown readable memory: 00 00 00 00 00 00 00 00
              stack at sp + 5 slots: 0x0000000000000004 is an unknown value
              stack at sp + 6 slots: 0x0000020993d01b10 points into unknown readable memory: 50 e8 78 2d fa 7f 00 00
              stack at sp + 7 slots: 0x0000000000000d68 is an unknown value
              Threads class SMR info:
              _java_thread_list=0x0000020990f3b650, length=36, elements={
              0x00000209ef6cc800, 0x00000209ef79a800, 0x00000209ef79e000, 0x00000209fe038000,
              0x00000209fe039000, 0x00000209fe03a800, 0x00000209fe03d000, 0x00000209fe056000,
              0x00000209feaa8800, 0x00000209feaab000, 0x000002098fc8c000, 0x000002098f2f6000,
              0x000002098fd7f800, 0x0000020990401800, 0x000002098ff0c000, 0x000002099040a800,
              0x000002099040b800, 0x00000209907a0000, 0x000002099069d800, 0x0000020990f9e000,
              0x0000020992136000, 0x0000020992137000, 0x0000020992132800, 0x0000020992130800,
              0x0000020992131000, 0x0000020992134800, 0x0000020992133800, 0x0000020992132000,
              0x0000020992135000, 0x0000020993d01000, 0x0000020993d06000, 0x0000020993d04000,
              0x0000020993d02800, 0x0000020993d01800, 0x0000020993d03800, 0x0000020993d05000
                0x00000209ef6cc800 JavaThread "main" [_thread_blocked, id=1084, stack(0x000000faba700000,0x000000faba800000)]
                0x00000209ef79a800 JavaThread "Reference Handler" daemon [_thread_blocked, id=5256, stack(0x000000fabae00000,0x000000fabaf00000)]
                0x00000209ef79e000 JavaThread "Finalizer" daemon [_thread_blocked, id=4120, stack(0x000000fabaf00000,0x000000fabb000000)]
                0x00000209fe038000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2880, stack(0x000000fabb000000,0x000000fabb100000)]
                0x00000209fe039000 JavaThread "Attach Listener" daemon [_thread_blocked, id=5880, stack(0x000000fabb100000,0x000000fabb200000)]
                0x00000209fe03a800 JavaThread "C2 CompilerThread0" daemon [_thread_in_native, id=6856, stack(0x000000fabb200000,0x000000fabb300000)]
                0x00000209fe03d000 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=5796, stack(0x000000fabb300000,0x000000fabb400000)]
                0x00000209fe056000 JavaThread "Sweeper thread" daemon [_thread_blocked, id=4388, stack(0x000000fabb400000,0x000000fabb500000)]
                0x00000209feaa8800 JavaThread "Service Thread" daemon [_thread_blocked, id=4596, stack(0x000000fabb500000,0x000000fabb600000)]
                0x00000209feaab000 JavaThread "Common-Cleaner" daemon [_thread_blocked, id=1732, stack(0x000000fabb700000,0x000000fabb800000)]
                0x000002098fc8c000 JavaThread "Log4j2-TF-5-AsyncLoggerConfig--2" daemon [_thread_in_native, id=7192, stack(0x000000fabb900000,0x000000fabba00000)]
                0x000002098f2f6000 JavaThread "jetty-thread-pool-16" [_thread_blocked, id=2212, stack(0x000000fabba00000,0x000000fabbb00000)]
                0x000002098fd7f800 JavaThread "jetty-thread-pool-17-acceptor-0@10d72e8d-ServerConnector@8a2a6a{HTTP/1.1,[http/1.1, h2c]}{0.0.0.0:8081}" [_thread_in_native, id=7980, stack(0x000000fabbb00000,0x000000fabbc00000)]
                0x0000020990401800 JavaThread "jetty-thread-pool-18" [_thread_blocked, id=5516, stack(0x000000fabbc00000,0x000000fabbd00000)]
                0x000002098ff0c000 JavaThread "jetty-thread-pool-19" [_thread_blocked, id=4536, stack(0x000000fabbd00000,0x000000fabbe00000)]
                0x000002099040a800 JavaThread "jetty-thread-pool-20" [_thread_blocked, id=5468, stack(0x000000fabbe00000,0x000000fabbf00000)]
                0x000002099040b800 JavaThread "jetty-thread-pool-21" [_thread_blocked, id=6020, stack(0x000000fabbf00000,0x000000fabc000000)]
                0x00000209907a0000 JavaThread "jetty-thread-pool-22" [_thread_blocked, id=4692, stack(0x000000fabc000000,0x000000fabc100000)]
                0x000002099069d800 JavaThread "jetty-thread-pool-23" [_thread_in_native, id=4168, stack(0x000000fabc100000,0x000000fabc200000)]
                0x0000020990f9e000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=1972, stack(0x000000fabc200000,0x000000fabc300000)]
                0x0000020992136000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=6668, stack(0x000000fabc400000,0x000000fabc500000)]
                0x0000020992137000 JavaThread "Connector-Scheduler-8a2a6a-1" [_thread_blocked, id=3920, stack(0x000000fabc500000,0x000000fabc600000)]
                0x0000020992132800 JavaThread "Ordered RealTime Timer" [_thread_blocked, id=6208, stack(0x000000fabc600000,0x000000fabc700000)]
                0x0000020992130800 JavaThread "H2 File Lock Watchdog C:/Users/Les/Desktop/Mango 3.7.4 Basement/databases/mah2.199.lock.db" daemon [_thread_blocked, id=2576, stack(0x000000fabc300000,0x000000fabc400000)]
                0x0000020992131000 JavaThread "H2 Log Writer MAH2.199" daemon [_thread_blocked, id=5932, stack(0x000000fabcb00000,0x000000fabcc00000)]
                0x0000020992134800 JavaThread "Mango shared scheduled executor" daemon [_thread_blocked, id=1420, stack(0x000000fabcc00000,0x000000fabcd00000)]
                0x0000020992133800 JavaThread "Mango Serial Port Event Processor" [_thread_blocked, id=5132, stack(0x000000fabcd00000,0x000000fabce00000)]
                0x0000020992132000 JavaThread "high-pool-2-thread-1 --> Datasource subgroup initializer" [_thread_blocked, id=1684, stack(0x000000fabce00000,0x000000fabcf00000)]
                0x0000020992135000 JavaThread "high-pool-2-thread-2 --> Datasource subgroup initializer" [_thread_blocked, id=2176, stack(0x000000fabcf00000,0x000000fabd000000)]
                0x0000020993d01000 JavaThread "high-pool-2-thread-3 --> Datasource subgroup initializer" [_thread_blocked, id=7152, stack(0x000000fabd000000,0x000000fabd100000)]
                0x0000020993d06000 JavaThread "high-pool-2-thread-4 --> Datasource subgroup initializer" [_thread_blocked, id=7584, stack(0x000000fabd100000,0x000000fabd200000)]
                0x0000020993d04000 JavaThread "high-pool-2-thread-5 --> Datasource subgroup initializer" [_thread_blocked, id=6712, stack(0x000000fabd200000,0x000000fabd300000)]
                0x0000020993d02800 JavaThread "high-pool-2-thread-6 --> Datasource subgroup initializer" [_thread_in_Java, id=5580, stack(0x000000fabd300000,0x000000fabd400000)]
              =>0x0000020993d01800 JavaThread "high-pool-2-thread-7 --> Datasource subgroup initializer" [_thread_in_native, id=4616, stack(0x000000fabd400000,0x000000fabd500000)]
                0x0000020993d03800 JavaThread "high-pool-2-thread-8 --> Datasource subgroup initializer" [_thread_blocked, id=4500, stack(0x000000fabd500000,0x000000fabd600000)]
                0x0000020993d05000 JavaThread "high-pool-2-thread-9" [_thread_blocked, id=4100, stack(0x000000fabd600000,0x000000fabd700000)]
              Other Threads:
                0x00000209ef796000 VMThread "VM Thread" [stack: 0x000000fabad00000,0x000000fabae00000] [id=5924]
                0x00000209feaac800 WatcherThread [stack: 0x000000fabb600000,0x000000fabb700000] [id=572]
                0x00000209ef6fd800 GCTaskThread "GC Thread#0" [stack: 0x000000faba800000,0x000000faba900000] [id=7284]
                0x00000209feaa2800 GCTaskThread "GC Thread#1" [stack: 0x000000fabb800000,0x000000fabb900000] [id=1860]
                0x00000209ef707800 ConcurrentGCThread "G1 Main Marker" [stack: 0x000000faba900000,0x000000fabaa00000] [id=4664]
                0x00000209ef709800 ConcurrentGCThread "G1 Conc#0" [stack: 0x000000fabaa00000,0x000000fabab00000] [id=3664]
                0x00000209ef755800 ConcurrentGCThread "G1 Refine#0" [stack: 0x000000fabab00000,0x000000fabac00000] [id=4032]
                0x00000209ef757800 ConcurrentGCThread "G1 Young RemSet Sampling" [stack: 0x000000fabac00000,0x000000fabad00000] [id=2796]
              Threads with active compile tasks:
              C2 CompilerThread0    33972 5522   !   4       org.springframework.core.annotation.AnnotationUtils::getAnnotatedMethodsInBaseType (163 bytes)
              Heap address: 0x00000000c4000000, size: 960 MB, Compressed Oops mode: 32-bit
              Narrow klass base: 0x0000000800000000, Narrow klass shift: 3
              Compressed class space size: 1073741824 Address: 0x0000000800b40000
              Heap:
               garbage-first heap   total 101376K, used 68255K [0x00000000c4000000, 0x0000000100000000)
                region size 1024K, 7 young (7168K), 4 survivors (4096K)
               Metaspace       used 53908K, capacity 54682K, committed 54784K, reserved 1097728K
                class space    used 6112K, capacity 6369K, committed 6400K, reserved 1048576K
              Heap Regions: E=young(eden), S=young(survivor), O=old, HS=humongous(starts), HC=humongous(continues), CS=collection set, F=free, A=archive, TAMS=top-at-mark-start (previous, next)
              |   0|0x00000000c4000000, 0x00000000c4100000, 0x00000000c4100000|100%| O|  |TAMS 0x00000000c4100000, 0x00000000c4100000| Untracked
              |   1|0x00000000c4100000, 0x00000000c4200000, 0x00000000c4200000|100%| O|  |TAMS 0x00000000c4200000, 0x00000000c4200000| Untracked
              |   2|0x00000000c4200000, 0x00000000c4300000, 0x00000000c4300000|100%| O|  |TAMS 0x00000000c4300000, 0x00000000c4300000| Untracked
              |   3|0x00000000c4300000, 0x00000000c4400000, 0x00000000c4400000|100%| O|  |TAMS 0x00000000c4400000, 0x00000000c4400000| Untracked
              |   4|0x00000000c4400000, 0x00000000c4500000, 0x00000000c4500000|100%| O|  |TAMS 0x00000000c4500000, 0x00000000c4500000| Untracked
              |   5|0x00000000c4500000, 0x00000000c4600000, 0x00000000c4600000|100%|HS|  |TAMS 0x00000000c4600000, 0x00000000c4600000| Complete
              |   6|0x00000000c4600000, 0x00000000c4700000, 0x00000000c4700000|100%| O|  |TAMS 0x00000000c4700000, 0x00000000c4700000| Untracked
              |   7|0x00000000c4700000, 0x00000000c4800000, 0x00000000c4800000|100%| O|  |TAMS 0x00000000c4800000, 0x00000000c4800000| Untracked
              |   8|0x00000000c4800000, 0x00000000c4900000, 0x00000000c4900000|100%|HS|  |TAMS 0x00000000c4900000, 0x00000000c4900000| Complete
              |   9|0x00000000c4900000, 0x00000000c4a00000, 0x00000000c4a00000|100%|HC|  |TAMS 0x00000000c4a00000, 0x00000000c4a00000| Complete
              |  10|0x00000000c4a00000, 0x00000000c4b00000, 0x00000000c4b00000|100%| O|  |TAMS 0x00000000c4b00000, 0x00000000c4b00000| Untracked
              |  11|0x00000000c4b00000, 0x00000000c4c00000, 0x00000000c4c00000|100%| O|  |TAMS 0x00000000c4c00000, 0x00000000c4c00000| Untracked
              |  12|0x00000000c4c00000, 0x00000000c4d00000, 0x00000000c4d00000|100%| O|  |TAMS 0x00000000c4d00000, 0x00000000c4d00000| Untracked
              |  13|0x00000000c4d00000, 0x00000000c4e00000, 0x00000000c4e00000|100%| O|  |TAMS 0x00000000c4e00000, 0x00000000c4e00000| Untracked
              |  14|0x00000000c4e00000, 0x00000000c4f00000, 0x00000000c4f00000|100%| O|  |TAMS 0x00000000c4f00000, 0x00000000c4f00000| Untracked
              |  15|0x00000000c4f00000, 0x00000000c5000000, 0x00000000c5000000|100%| O|  |TAMS 0x00000000c5000000, 0x00000000c5000000| Untracked
              |  16|0x00000000c5000000, 0x00000000c5100000, 0x00000000c5100000|100%|HS|  |TAMS 0x00000000c5100000, 0x00000000c5100000| Complete
              |  17|0x00000000c5100000, 0x00000000c5200000, 0x00000000c5200000|100%|HC|  |TAMS 0x00000000c5200000, 0x00000000c5200000| Complete
              |  18|0x00000000c5200000, 0x00000000c5300000, 0x00000000c5300000|100%|HS|  |TAMS 0x00000000c5300000, 0x00000000c5300000| Complete
              |  19|0x00000000c5300000, 0x00000000c5400000, 0x00000000c5400000|100%|HC|  |TAMS 0x00000000c5400000, 0x00000000c5400000| Complete
              |  20|0x00000000c5400000, 0x00000000c5500000, 0x00000000c5500000|100%| O|  |TAMS 0x00000000c5500000, 0x00000000c5500000| Untracked
              |  21|0x00000000c5500000, 0x00000000c5600000, 0x00000000c5600000|100%| O|  |TAMS 0x00000000c5600000, 0x00000000c5600000| Untracked
              |  22|0x00000000c5600000, 0x00000000c5700000, 0x00000000c5700000|100%| O|  |TAMS 0x00000000c5700000, 0x00000000c5700000| Untracked
              |  23|0x00000000c5700000, 0x00000000c5800000, 0x00000000c5800000|100%| O|  |TAMS 0x00000000c5800000, 0x00000000c5800000| Untracked
              |  24|0x00000000c5800000, 0x00000000c5900000, 0x00000000c5900000|100%| O|  |TAMS 0x00000000c5900000, 0x00000000c5900000| Untracked
              |  25|0x00000000c5900000, 0x00000000c5a00000, 0x00000000c5a00000|100%| O|  |TAMS 0x00000000c5a00000, 0x00000000c5a00000| Untracked
              |  26|0x00000000c5a00000, 0x00000000c5b00000, 0x00000000c5b00000|100%| O|  |TAMS 0x00000000c5b00000, 0x00000000c5b00000| Untracked
              |  27|0x00000000c5b00000, 0x00000000c5c00000, 0x00000000c5c00000|100%| O|  |TAMS 0x00000000c5c00000, 0x00000000c5c00000| Untracked
              |  28|0x00000000c5c00000, 0x00000000c5d00000, 0x00000000c5d00000|100%| O|  |TAMS 0x00000000c5d00000, 0x00000000c5d00000| Untracked
              |  29|0x00000000c5d00000, 0x00000000c5e00000, 0x00000000c5e00000|100%| O|  |TAMS 0x00000000c5e00000, 0x00000000c5e00000| Untracked
              |  30|0x00000000c5e00000, 0x00000000c5f00000, 0x00000000c5f00000|100%| O|  |TAMS 0x00000000c5f00000, 0x00000000c5f00000| Untracked
              |  31|0x00000000c5f00000, 0x00000000c6000000, 0x00000000c6000000|100%| O|  |TAMS 0x00000000c6000000, 0x00000000c6000000| Untracked
              |  32|0x00000000c6000000, 0x00000000c6100000, 0x00000000c6100000|100%| O|  |TAMS 0x00000000c6100000, 0x00000000c6100000| Untracked
              |  33|0x00000000c6100000, 0x00000000c6200000, 0x00000000c6200000|100%| O|  |TAMS 0x00000000c6200000, 0x00000000c6200000| Untracked
              |  34|0x00000000c6200000, 0x00000000c6300000, 0x00000000c6300000|100%| O|  |TAMS 0x00000000c6300000, 0x00000000c6300000| Untracked
              |  35|0x00000000c6300000, 0x00000000c6400000, 0x00000000c6400000|100%| O|  |TAMS 0x00000000c6400000, 0x00000000c6400000| Untracked
              |  36|0x00000000c6400000, 0x00000000c6500000, 0x00000000c6500000|100%| O|  |TAMS 0x00000000c6500000, 0x00000000c6500000| Untracked
              |  37|0x00000000c6500000, 0x00000000c6600000, 0x00000000c6600000|100%| O|  |TAMS 0x00000000c6600000, 0x00000000c6600000| Untracked
              |  38|0x00000000c6600000, 0x00000000c6700000, 0x00000000c6700000|100%| O|  |TAMS 0x00000000c6700000, 0x00000000c6700000| Untracked
              |  39|0x00000000c6700000, 0x00000000c6800000, 0x00000000c6800000|100%| O|  |TAMS 0x00000000c6800000, 0x00000000c6800000| Untracked
              |  40|0x00000000c6800000, 0x00000000c6900000, 0x00000000c6900000|100%| O|  |TAMS 0x00000000c6900000, 0x00000000c6900000| Untracked
              |  41|0x00000000c6900000, 0x00000000c6a00000, 0x00000000c6a00000|100%| O|  |TAMS 0x00000000c6a00000, 0x00000000c6a00000| Untracked
              |  42|0x00000000c6a00000, 0x00000000c6b00000, 0x00000000c6b00000|100%| O|  |TAMS 0x00000000c6a75800, 0x00000000c6b00000| Untracked
              |  43|0x00000000c6b00000, 0x00000000c6c00000, 0x00000000c6c00000|100%| O|  |TAMS 0x00000000c6b00000, 0x00000000c6c00000| Untracked
              |  44|0x00000000c6c00000, 0x00000000c6d00000, 0x00000000c6d00000|100%| O|  |TAMS 0x00000000c6c00000, 0x00000000c6ca1e00| Untracked
              |  45|0x00000000c6d00000, 0x00000000c6e00000, 0x00000000c6e00000|100%| O|  |TAMS 0x00000000c6d00000, 0x00000000c6d00000| Untracked
              |  46|0x00000000c6e00000, 0x00000000c6f00000, 0x00000000c6f00000|100%| O|  |TAMS 0x00000000c6e00000, 0x00000000c6e00000| Untracked
              |  47|0x00000000c6f00000, 0x00000000c7000000, 0x00000000c7000000|100%| O|  |TAMS 0x00000000c6f00000, 0x00000000c6f00000| Untracked
              |  48|0x00000000c7000000, 0x00000000c7100000, 0x00000000c7100000|100%| O|  |TAMS 0x00000000c7000000, 0x00000000c7000000| Untracked
              |  49|0x00000000c7100000, 0x00000000c7200000, 0x00000000c7200000|100%| O|  |TAMS 0x00000000c7100000, 0x00000000c7100000| Untracked
              |  50|0x00000000c7200000, 0x00000000c7300000, 0x00000000c7300000|100%| O|  |TAMS 0x00000000c7200000, 0x00000000c7200000| Untracked
              |  51|0x00000000c7300000, 0x00000000c7400000, 0x00000000c7400000|100%| O|  |TAMS 0x00000000c7300000, 0x00000000c7300000| Untracked
              |  52|0x00000000c7400000, 0x00000000c7500000, 0x00000000c7500000|100%| O|  |TAMS 0x00000000c7400000, 0x00000000c7400000| Untracked
              |  53|0x00000000c7500000, 0x00000000c7600000, 0x00000000c7600000|100%| O|  |TAMS 0x00000000c7500000, 0x00000000c7500000| Untracked
              |  54|0x00000000c7600000, 0x00000000c7700000, 0x00000000c7700000|100%| O|  |TAMS 0x00000000c7600000, 0x00000000c7600000| Untracked
              |  55|0x00000000c7700000, 0x00000000c7800000, 0x00000000c7800000|100%| O|  |TAMS 0x00000000c7700000, 0x00000000c7700000| Untracked
              |  56|0x00000000c7800000, 0x00000000c7800000, 0x00000000c7900000|  0%| F|  |TAMS 0x00000000c7800000, 0x00000000c7800000| Untracked
              |  57|0x00000000c7900000, 0x00000000c7900000, 0x00000000c7a00000|  0%| F|  |TAMS 0x00000000c7900000, 0x00000000c7900000| Untracked
              |  58|0x00000000c7a00000, 0x00000000c7b00000, 0x00000000c7b00000|100%| O|  |TAMS 0x00000000c7a00000, 0x00000000c7a00000| Untracked
              |  59|0x00000000c7b00000, 0x00000000c7c00000, 0x00000000c7c00000|100%| O|  |TAMS 0x00000000c7b00000, 0x00000000c7b00000| Untracked
              |  60|0x00000000c7c00000, 0x00000000c7c00000, 0x00000000c7d00000|  0%| F|  |TAMS 0x00000000c7c00000, 0x00000000c7c00000| Untracked
              |  61|0x00000000c7d00000, 0x00000000c7e00000, 0x00000000c7e00000|100%| O|  |TAMS 0x00000000c7d00000, 0x00000000c7d00000| Untracked
              |  62|0x00000000c7e00000, 0x00000000c7f00000, 0x00000000c7f00000|100%| O|  |TAMS 0x00000000c7e00000, 0x00000000c7e00000| Untracked
              |  63|0x00000000c7f00000, 0x00000000c7fa7c00, 0x00000000c8000000| 65%| O|  |TAMS 0x00000000c7f00000, 0x00000000c7f00000| Untracked
              |  64|0x00000000c8000000, 0x00000000c8000000, 0x00000000c8100000|  0%| F|  |TAMS 0x00000000c8000000, 0x00000000c8000000| Untracked
              |  65|0x00000000c8100000, 0x00000000c8100000, 0x00000000c8200000|  0%| F|  |TAMS 0x00000000c8100000, 0x00000000c8100000| Untracked
              |  66|0x00000000c8200000, 0x00000000c8200000, 0x00000000c8300000|  0%| F|  |TAMS 0x00000000c8200000, 0x00000000c8200000| Untracked
              |  67|0x00000000c8300000, 0x00000000c8400000, 0x00000000c8400000|100%| S|CS|TAMS 0x00000000c8300000, 0x00000000c8300000| Complete
              |  68|0x00000000c8400000, 0x00000000c8500000, 0x00000000c8500000|100%| S|CS|TAMS 0x00000000c8400000, 0x00000000c8400000| Complete
              |  69|0x00000000c8500000, 0x00000000c8600000, 0x00000000c8600000|100%| S|CS|TAMS 0x00000000c8500000, 0x00000000c8500000| Complete
              |  70|0x00000000c8600000, 0x00000000c8700000, 0x00000000c8700000|100%| S|CS|TAMS 0x00000000c8600000, 0x00000000c8600000| Complete
              |  71|0x00000000c8700000, 0x00000000c8700000, 0x00000000c8800000|  0%| F|  |TAMS 0x00000000c8700000, 0x00000000c8700000| Untracked
              |  72|0x00000000c8800000, 0x00000000c8800000, 0x00000000c8900000|  0%| F|  |TAMS 0x00000000c8800000, 0x00000000c8800000| Untracked
              |  73|0x00000000c8900000, 0x00000000c8900000, 0x00000000c8a00000|  0%| F|  |TAMS 0x00000000c8900000, 0x00000000c8900000| Untracked
              |  74|0x00000000c8a00000, 0x00000000c8a00000, 0x00000000c8b00000|  0%| F|  |TAMS 0x00000000c8a00000, 0x00000000c8a00000| Untracked
              |  75|0x00000000c8b00000, 0x00000000c8b00000, 0x00000000c8c00000|  0%| F|  |TAMS 0x00000000c8b00000, 0x00000000c8b00000| Untracked
              |  76|0x00000000c8c00000, 0x00000000c8c00000, 0x00000000c8d00000|  0%| F|  |TAMS 0x00000000c8c00000, 0x00000000c8c00000| Untracked
              |  77|0x00000000c8d00000, 0x00000000c8d00000, 0x00000000c8e00000|  0%| F|  |TAMS 0x00000000c8d00000, 0x00000000c8d00000| Untracked
              |  78|0x00000000c8e00000, 0x00000000c8e00000, 0x00000000c8f00000|  0%| F|  |TAMS 0x00000000c8e00000, 0x00000000c8e00000| Untracked
              |  79|0x00000000c8f00000, 0x00000000c8f00000, 0x00000000c9000000|  0%| F|  |TAMS 0x00000000c8f00000, 0x00000000c8f00000| Untracked
              |  80|0x00000000c9000000, 0x00000000c9000000, 0x00000000c9100000|  0%| F|  |TAMS 0x00000000c9000000, 0x00000000c9000000| Untracked
              |  81|0x00000000c9100000, 0x00000000c9100000, 0x00000000c9200000|  0%| F|  |TAMS 0x00000000c9100000, 0x00000000c9100000| Untracked
              |  82|0x00000000c9200000, 0x00000000c9200000, 0x00000000c9300000|  0%| F|  |TAMS 0x00000000c9200000, 0x00000000c9200000| Untracked
              |  83|0x00000000c9300000, 0x00000000c9300000, 0x00000000c9400000|  0%| F|  |TAMS 0x00000000c9300000, 0x00000000c9300000| Untracked
              |  84|0x00000000c9400000, 0x00000000c9400000, 0x00000000c9500000|  0%| F|  |TAMS 0x00000000c9400000, 0x00000000c9400000| Untracked
              |  85|0x00000000c9500000, 0x00000000c9500000, 0x00000000c9600000|  0%| F|  |TAMS 0x00000000c9500000, 0x00000000c9500000| Untracked
              |  86|0x00000000c9600000, 0x00000000c9600000, 0x00000000c9700000|  0%| F|  |TAMS 0x00000000c9600000, 0x00000000c9600000| Untracked
              |  87|0x00000000c9700000, 0x00000000c9700000, 0x00000000c9800000|  0%| F|  |TAMS 0x00000000c9700000, 0x00000000c9700000| Untracked
              |  88|0x00000000c9800000, 0x00000000c9800000, 0x00000000c9900000|  0%| F|  |TAMS 0x00000000c9800000, 0x00000000c9800000| Untracked
              |  89|0x00000000c9900000, 0x00000000c9900000, 0x00000000c9a00000|  0%| F|  |TAMS 0x00000000c9900000, 0x00000000c9900000| Untracked
              |  90|0x00000000c9a00000, 0x00000000c9a00000, 0x00000000c9b00000|  0%| F|  |TAMS 0x00000000c9a00000, 0x00000000c9a00000| Untracked
              |  91|0x00000000c9b00000, 0x00000000c9b00000, 0x00000000c9c00000|  0%| F|  |TAMS 0x00000000c9b00000, 0x00000000c9b00000| Untracked
              |  92|0x00000000c9c00000, 0x00000000c9c00000, 0x00000000c9d00000|  0%| F|  |TAMS 0x00000000c9c00000, 0x00000000c9c00000| Untracked
              |  93|0x00000000c9d00000, 0x00000000c9d00000, 0x00000000c9e00000|  0%| F|  |TAMS 0x00000000c9d00000, 0x00000000c9d00000| Untracked
              |  94|0x00000000c9e00000, 0x00000000c9e00000, 0x00000000c9f00000|  0%| F|  |TAMS 0x00000000c9e00000, 0x00000000c9e00000| Untracked
              |  95|0x00000000c9f00000, 0x00000000c9f00000, 0x00000000ca000000|  0%| F|  |TAMS 0x00000000c9f00000, 0x00000000c9f00000| Untracked
              |  96|0x00000000ca000000, 0x00000000ca0f1520, 0x00000000ca100000| 94%| E|  |TAMS 0x00000000ca000000, 0x00000000ca000000| Complete
              |  97|0x00000000ca100000, 0x00000000ca200000, 0x00000000ca200000|100%| E|CS|TAMS 0x00000000ca100000, 0x00000000ca100000| Complete
              |  98|0x00000000ca200000, 0x00000000ca300000, 0x00000000ca300000|100%| E|CS|TAMS 0x00000000ca200000, 0x00000000ca200000| Complete
              Card table byte_map: [0x00000209f9ad0000,0x00000209f9cb0000] _byte_map_base: 0x00000209f94b0000
              Marking Bits (Prev, Next): (CMBitMap*) 0x00000209ef6ff468, (CMBitMap*) 0x00000209ef6ff428
               Prev Bits: [0x00000209fad90000, 0x00000209fbc90000)
               Next Bits: [0x00000209f9e90000, 0x00000209fad90000)
              Polling page: 0x00000209f0f50000
              Metaspace:
              Usage:
                Non-class:     47.18 MB capacity,    46.68 MB ( 99%) used,   422.95 KB ( <1%) free+waste,    94.75 KB ( <1%) overhead.
                    Class:      6.22 MB capacity,     5.97 MB ( 96%) used,   216.35 KB (  3%) free+waste,    39.88 KB ( <1%) overhead.
                     Both:     53.40 MB capacity,    52.64 MB ( 99%) used,   639.30 KB (  1%) free+waste,   134.63 KB ( <1%) overhead.
              • L
                lesdotcom
                Also reinstalled serial module and serial data source, still crashes with serial data source enabled
                • MattFoxM
                  Ok, let's hope one of the mango team here jump in and take a look. This looks like some sort of conflict.
                  • L
                    lesdotcom
                    Also happens with Z-wave module. Seems like anything that is tied to a serial port.
                    • MattFoxM
                      Are you running as administrator?
                      I wonder if that will influence anything...
