<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Serial data source causing crash]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/4810/serial-data-source-causing-crash">Serial data source causing crash</a></p>
<p dir="auto">Having this same issue with mango crashing upon enabling serial data source.  Started after reinstalling windows.  Using mango 3.7.7, have tried jdk 8, jdk 11, and jdk 13.</p>
]]></description><link>https://forum.mango-os.com/topic/5046/serial-data-source-causing-crash</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 22:13:09 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5046.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 Jan 2021 05:45:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Serial data source causing crash on Tue, 12 Jan 2021 21:25:21 GMT]]></title><description><![CDATA[<p dir="auto">Are you running as administrator?<br />
I wonder if that will influence anything...</p>
<p dir="auto">Fox</p>
]]></description><link>https://forum.mango-os.com/post/26175</link><guid isPermaLink="true">https://forum.mango-os.com/post/26175</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Tue, 12 Jan 2021 21:25:21 GMT</pubDate></item><item><title><![CDATA[Reply to Serial data source causing crash on Tue, 12 Jan 2021 20:42:23 GMT]]></title><description><![CDATA[<p dir="auto">Also happens with Z-wave module.  Seems like anything that is tied to a serial port.</p>
]]></description><link>https://forum.mango-os.com/post/26174</link><guid isPermaLink="true">https://forum.mango-os.com/post/26174</guid><dc:creator><![CDATA[lesdotcom]]></dc:creator><pubDate>Tue, 12 Jan 2021 20:42:23 GMT</pubDate></item><item><title><![CDATA[Reply to Serial data source causing crash on Tue, 12 Jan 2021 02:47:24 GMT]]></title><description><![CDATA[<p dir="auto">Ok, let's hope one of the mango team here jump in and take a look. This looks like some sort of conflict.</p>
]]></description><link>https://forum.mango-os.com/post/26168</link><guid isPermaLink="true">https://forum.mango-os.com/post/26168</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Tue, 12 Jan 2021 02:47:24 GMT</pubDate></item><item><title><![CDATA[Reply to Serial data source causing crash on Fri, 08 Jan 2021 21:23:14 GMT]]></title><description><![CDATA[<p dir="auto">Also reinstalled serial module and serial data source, still crashes with serial data source enabled</p>
]]></description><link>https://forum.mango-os.com/post/26156</link><guid isPermaLink="true">https://forum.mango-os.com/post/26156</guid><dc:creator><![CDATA[lesdotcom]]></dc:creator><pubDate>Fri, 08 Jan 2021 21:23:14 GMT</pubDate></item><item><title><![CDATA[Reply to Serial data source causing crash on Wed, 13 Jan 2021 07:50:27 GMT]]></title><description><![CDATA[<p dir="auto">Here is the JDK 13 log:</p>
<pre><code>#
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000007110b5db, pid=3832, tid=4616
# JRE version: Java(TM) SE Runtime Environment (13.0.1+9) (build 13.0.1+9)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (13.0.1+9, mixed mode, sharing, tiered, compressed oops, g1 gc, windows-amd64)
# Problematic frame:
# C  [jSSC-2.8_x86_64.dll+0xb5db]
# No core dump will be written. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
#   http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
---------------  S U M M A R Y ------------
Command Line: -Dma.home=C:\Users\Les\Desktop\Mango 3.7.4 Basement com.serotonin.m2m2.Main
Host: AMD Athlon(tm) 64 X2 Dual Core Processor 5200+, 2 cores, 3G,  Windows 10 , 64 bit Build 19041 (10.0.19041.662)
Time: Fri Jan  1 13:36:33 2021 Pacific Standard Time elapsed time: 33 seconds (0d 0h 0m 33s)
---------------  T H R E A D  ---------------
Current thread (0x0000020993d01800):  JavaThread "high-pool-2-thread-7 --&gt; Datasource subgroup initializer" [_thread_in_native, id=4616, stack(0x000000fabd400000,0x000000fabd500000)]
Stack: [0x000000fabd400000,0x000000fabd500000],  sp=0x000000fabd4fe940,  free space=1018k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  jssc.SerialNativeInterface.openPort(Ljava/lang/String;Z)J+0
j  jssc.SerialPort.openPort()Z+65
j  com.infiniteautomation.mango.io.serial.JsscSerialPortProxy.openImpl()V+65
j  com.infiniteautomation.mango.io.serial.SerialPortProxy.open()V+53
j  com.infiniteautomation.mango.io.serial.SerialPortManagerImpl.open(Ljava/lang/String;Ljava/lang/String;ILcom/infiniteautomation/mango/io/serial/FlowControl;Lcom/infiniteautomation/mango/io/serial/FlowControl;Lcom/infiniteautomation/mango/io/serial/DataBits;Lcom/infiniteautomation/mango/io/serial/StopBits;Lcom/infiniteautomation/mango/io/serial/Parity;)Lcom/infiniteautomation/mango/io/serial/SerialPortProxy;+295
j  com.infiniteautomation.serial.rt.SerialDataSourceRT.connect()Z+143
j  com.infiniteautomation.serial.rt.SerialDataSourceRT.initialize()V+80
j  com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup(Lcom/serotonin/m2m2/vo/dataSource/DataSourceVO;)Z+34
j  com.serotonin.m2m2.rt.DataSourceGroupInitializer$DataSourceSubGroupInitializer.run(J)V+46
j  com.serotonin.timer.Task.runTask(J)V+126
j  com.serotonin.timer.TaskWrapper.run()V+8
j  java.util.concurrent.ThreadPoolExecutor.runWorker(Ljava/util/concurrent/ThreadPoolExecutor$Worker;)V+92 java.base@13.0.1
j  java.util.concurrent.ThreadPoolExecutor$Worker.run()V+5 java.base@13.0.1
j  java.lang.Thread.run()V+11 java.base@13.0.1
v  ~StubRoutines::call_stub
siginfo: EXCEPTION_ACCESS_VIOLATION (0xc0000005), reading address 0xffffffffef7aced9
Register to memory mapping:
RIP=0x000000007110b5db jSSC-2.8_x86_64.dll
RAX=0xffffffffef7aced9 is an unknown value
RBX=0x000000fabd4fe9b0 is pointing into the stack for thread: 0x0000020993d01800
RCX=0x00007ffa653cc194 ntdll.dll
RDX=0x0 is NULL
RSP=0x000000fabd4fe940 is pointing into the stack for thread: 0x0000020993d01800
RBP=0x000000fabd4feac0 is pointing into the stack for thread: 0x0000020993d01800
RSI=0x0000020993d01b10 points into unknown readable memory: 50 e8 78 2d fa 7f 00 00
RDI=0x0000000000000d68 is an unknown value
R8 =0x000000fabd4fe838 is pointing into the stack for thread: 0x0000020993d01800
R9 =0x000000fabd4fe930 is pointing into the stack for thread: 0x0000020993d01800
R10=0x0 is NULL
R11=0x0000000000000246 is an unknown value
R12=0x000000fabd4feb80 is pointing into the stack for thread: 0x0000020993d01800
R13=0x000002099234a9e0 points into unknown readable memory: 00 00 00 00 08 00 00 00
R14=0x000000fabd4fea70 is pointing into the stack for thread: 0x0000020993d01800
R15=0x0000020993d01800 is a thread
Registers:
RAX=0xffffffffef7aced9, RBX=0x000000fabd4fe9b0, RCX=0x00007ffa653cc194, RDX=0x0000000000000000
RSP=0x000000fabd4fe940, RBP=0x000000fabd4feac0, RSI=0x0000020993d01b10, RDI=0x0000000000000d68
R8 =0x000000fabd4fe838, R9 =0x000000fabd4fe930, R10=0x0000000000000000, R11=0x0000000000000246
R12=0x000000fabd4feb80, R13=0x000002099234a9e0, R14=0x000000fabd4fea70, R15=0x0000020993d01800
RIP=0x000000007110b5db, EFLAGS=0x0000000000010206
Top of Stack: (sp=0x000000fabd4fe940)
0x000000fabd4fe940:   00000209923f56d0 0000020992349c90
0x000000fabd4fe950:   000000007110b230 00000209ef550000
0x000000fabd4fe960:   00000209ef650000 0000000000000004
0x000000fabd4fe970:   0000020993d01b10 0000000000000d68
0x000000fabd4fe980:   000000fabd4feac0 0000000071112590
0x000000fabd4fe990:   0000020993d01800 000000fabd4fea70
0x000000fabd4fe9a0:   000002099234a9e0 000000fabd4feb80
0x000000fabd4fe9b0:   000002099234a9e0 00007ffa65345d21
0x000000fabd4fe9c0:   000000fabd4fe9f0 00000209ef550000
0x000000fabd4fe9d0:   000000fabd4feac0 0000000000000000
0x000000fabd4fe9e0:   0000000071113500 0000000071113be8
0x000000fabd4fe9f0:   000000fabd4fea20 0000000071112641
0x000000fabd4fea00:   000000fabd4fe990 0000020993d01b10
0x000000fabd4fea10:   0000000000000000 0000000000000000
0x000000fabd4fea20:   000000fabd4feac0 0000000071101595
0x000000fabd4fea30:   000000000000001c 0000020900000000
Instructions: (pc=0x000000007110b5db)
0x000000007110b4db:   48 85 c0 74 bf 44 8b 03 45 85 c0 0f 84 77 ff ff
0x000000007110b4eb:   ff eb 9f 66 90 e8 8b fe ff ff 48 89 05 0c 34 01
0x000000007110b4fb:   00 eb ad 66 90 e8 7b fe ff ff 48 89 05 fc 33 01
0x000000007110b50b:   00 eb 8b e8 8d fe ff ff c7 03 01 00 00 00 e9 6f
0x000000007110b51b:   ff ff ff 66 90 55 48 89 e5 56 53 48 83 ec 20 48
0x000000007110b52b:   8b 05 d7 33 01 00 48 8b 31 48 89 cb 48 85 c0 74
0x000000007110b53b:   56 44 8b 18 45 85 db 78 42 48 8b 05 bd 33 01 00
0x000000007110b54b:   48 85 c0 74 50 44 8b 10 45 85 d2 74 1d 48 89 f1
0x000000007110b55b:   e8 d0 fd ff ff 48 8b 13 48 8d 42 40 48 8b 48 08
0x000000007110b56b:   48 8b 6a 40 48 8b 60 10 ff e1 48 8b 05 9c 33 01
0x000000007110b57b:   00 48 85 c0 74 2d 48 89 30 eb da e8 b5 fe ff ff
0x000000007110b58b:   0f 1f 44 00 00 eb b2 e8 e9 fd ff ff 48 89 05 6a
0x000000007110b59b:   33 01 00 eb 9c e8 db fd ff ff 48 89 05 5c 33 01
0x000000007110b5ab:   00 eb a2 e8 3d fd ff ff 48 89 05 5e 33 01 00 eb
0x000000007110b5bb:   c5 0f 1f 40 00 55 57 56 53 48 83 ec 28 48 8b 05
0x000000007110b5cb:   39 33 01 00 48 89 cb 48 85 c0 0f 84 c5 00 00 00
0x000000007110b5db:   8b 38 85 ff 0f 88 ab 00 00 00 48 8b 05 1c 33 01
0x000000007110b5eb:   00 48 85 c0 0f 84 bc 00 00 00 8b 30 85 f6 74 57
0x000000007110b5fb:   48 8b 05 0e 33 01 00 48 85 c0 0f 84 e5 00 00 00
0x000000007110b60b:   8b 28 48 8b 35 10 5e 01 00 ff d6 89 c7 89 e9 ff
0x000000007110b61b:   15 f4 5e 01 00 89 f9 48 89 c5 ff 15 b9 5e 01 00
0x000000007110b62b:   48 8b 05 de 32 01 00 48 89 2b 48 85 c0 74 46 48
0x000000007110b63b:   89 da 8b 08 ff 15 d7 5e 01 00 85 c0 74 27 48 83
0x000000007110b64b:   c4 28 5b 5e 5f 5d c3 48 8b 05 bf 32 01 00 48 85
0x000000007110b65b:   c0 74 64 48 8b 10 48 89 13 48 89 18 48 83 c4 28
0x000000007110b66b:   5b 5e 5f 5d c3 48 89 f2 48 83 c4 28 5b 5e 5f 5d
0x000000007110b67b:   48 ff e2 66 90 e8 8b fc ff ff 48 89 05 84 32 01
0x000000007110b68b:   00 eb ac 66 90 e8 ab fd ff ff e9 4b ff ff ff 66
0x000000007110b69b:   0f 1f 44 00 00 e8 db fc ff ff 48 89 05 5c 32 01
0x000000007110b6ab:   00 e9 2a ff ff ff e8 ca fc ff ff 48 89 05 4b 32
0x000000007110b6bb:   01 00 e9 33 ff ff ff e8 29 fc ff ff 48 89 05 4a
0x000000007110b6cb:   32 01 00 48 8b 10 48 85 c0 48 89 13 75 8b e8 12
Stack slot to memory mapping:
stack at sp + 0 slots: 0x00000209923f56d0 points into unknown readable memory: b2 e0 1a 92 2e 00 5c 00
stack at sp + 1 slots: 0x0000020992349c90 points into unknown readable memory: 00 83 56 92 09 02 00 00
stack at sp + 2 slots: 0x000000007110b230 jSSC-2.8_x86_64.dll
stack at sp + 3 slots: 0x00000209ef550000 points into unknown readable memory: 00 00 00 00 00 00 00 00
stack at sp + 4 slots: 0x00000209ef650000 points into unknown readable memory: 00 00 00 00 00 00 00 00
stack at sp + 5 slots: 0x0000000000000004 is an unknown value
stack at sp + 6 slots: 0x0000020993d01b10 points into unknown readable memory: 50 e8 78 2d fa 7f 00 00
stack at sp + 7 slots: 0x0000000000000d68 is an unknown value
---------------  P R O C E S S  ---------------
Threads class SMR info:
_java_thread_list=0x0000020990f3b650, length=36, elements={
0x00000209ef6cc800, 0x00000209ef79a800, 0x00000209ef79e000, 0x00000209fe038000,
0x00000209fe039000, 0x00000209fe03a800, 0x00000209fe03d000, 0x00000209fe056000,
0x00000209feaa8800, 0x00000209feaab000, 0x000002098fc8c000, 0x000002098f2f6000,
0x000002098fd7f800, 0x0000020990401800, 0x000002098ff0c000, 0x000002099040a800,
0x000002099040b800, 0x00000209907a0000, 0x000002099069d800, 0x0000020990f9e000,
0x0000020992136000, 0x0000020992137000, 0x0000020992132800, 0x0000020992130800,
0x0000020992131000, 0x0000020992134800, 0x0000020992133800, 0x0000020992132000,
0x0000020992135000, 0x0000020993d01000, 0x0000020993d06000, 0x0000020993d04000,
0x0000020993d02800, 0x0000020993d01800, 0x0000020993d03800, 0x0000020993d05000
Java Threads: ( =&gt; current thread )
  0x00000209ef6cc800 JavaThread "main" [_thread_blocked, id=1084, stack(0x000000faba700000,0x000000faba800000)]
  0x00000209ef79a800 JavaThread "Reference Handler" daemon [_thread_blocked, id=5256, stack(0x000000fabae00000,0x000000fabaf00000)]
  0x00000209ef79e000 JavaThread "Finalizer" daemon [_thread_blocked, id=4120, stack(0x000000fabaf00000,0x000000fabb000000)]
  0x00000209fe038000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2880, stack(0x000000fabb000000,0x000000fabb100000)]
  0x00000209fe039000 JavaThread "Attach Listener" daemon [_thread_blocked, id=5880, stack(0x000000fabb100000,0x000000fabb200000)]
  0x00000209fe03a800 JavaThread "C2 CompilerThread0" daemon [_thread_in_native, id=6856, stack(0x000000fabb200000,0x000000fabb300000)]
  0x00000209fe03d000 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=5796, stack(0x000000fabb300000,0x000000fabb400000)]
  0x00000209fe056000 JavaThread "Sweeper thread" daemon [_thread_blocked, id=4388, stack(0x000000fabb400000,0x000000fabb500000)]
  0x00000209feaa8800 JavaThread "Service Thread" daemon [_thread_blocked, id=4596, stack(0x000000fabb500000,0x000000fabb600000)]
  0x00000209feaab000 JavaThread "Common-Cleaner" daemon [_thread_blocked, id=1732, stack(0x000000fabb700000,0x000000fabb800000)]
  0x000002098fc8c000 JavaThread "Log4j2-TF-5-AsyncLoggerConfig--2" daemon [_thread_in_native, id=7192, stack(0x000000fabb900000,0x000000fabba00000)]
  0x000002098f2f6000 JavaThread "jetty-thread-pool-16" [_thread_blocked, id=2212, stack(0x000000fabba00000,0x000000fabbb00000)]
  0x000002098fd7f800 JavaThread "jetty-thread-pool-17-acceptor-0@10d72e8d-ServerConnector@8a2a6a{HTTP/1.1,[http/1.1, h2c]}{0.0.0.0:8081}" [_thread_in_native, id=7980, stack(0x000000fabbb00000,0x000000fabbc00000)]
  0x0000020990401800 JavaThread "jetty-thread-pool-18" [_thread_blocked, id=5516, stack(0x000000fabbc00000,0x000000fabbd00000)]
  0x000002098ff0c000 JavaThread "jetty-thread-pool-19" [_thread_blocked, id=4536, stack(0x000000fabbd00000,0x000000fabbe00000)]
  0x000002099040a800 JavaThread "jetty-thread-pool-20" [_thread_blocked, id=5468, stack(0x000000fabbe00000,0x000000fabbf00000)]
  0x000002099040b800 JavaThread "jetty-thread-pool-21" [_thread_blocked, id=6020, stack(0x000000fabbf00000,0x000000fabc000000)]
  0x00000209907a0000 JavaThread "jetty-thread-pool-22" [_thread_blocked, id=4692, stack(0x000000fabc000000,0x000000fabc100000)]
  0x000002099069d800 JavaThread "jetty-thread-pool-23" [_thread_in_native, id=4168, stack(0x000000fabc100000,0x000000fabc200000)]
  0x0000020990f9e000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=1972, stack(0x000000fabc200000,0x000000fabc300000)]
  0x0000020992136000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=6668, stack(0x000000fabc400000,0x000000fabc500000)]
  0x0000020992137000 JavaThread "Connector-Scheduler-8a2a6a-1" [_thread_blocked, id=3920, stack(0x000000fabc500000,0x000000fabc600000)]
  0x0000020992132800 JavaThread "Ordered RealTime Timer" [_thread_blocked, id=6208, stack(0x000000fabc600000,0x000000fabc700000)]
  0x0000020992130800 JavaThread "H2 File Lock Watchdog C:/Users/Les/Desktop/Mango 3.7.4 Basement/databases/mah2.199.lock.db" daemon [_thread_blocked, id=2576, stack(0x000000fabc300000,0x000000fabc400000)]
  0x0000020992131000 JavaThread "H2 Log Writer MAH2.199" daemon [_thread_blocked, id=5932, stack(0x000000fabcb00000,0x000000fabcc00000)]
  0x0000020992134800 JavaThread "Mango shared scheduled executor" daemon [_thread_blocked, id=1420, stack(0x000000fabcc00000,0x000000fabcd00000)]
  0x0000020992133800 JavaThread "Mango Serial Port Event Processor" [_thread_blocked, id=5132, stack(0x000000fabcd00000,0x000000fabce00000)]
  0x0000020992132000 JavaThread "high-pool-2-thread-1 --&gt; Datasource subgroup initializer" [_thread_blocked, id=1684, stack(0x000000fabce00000,0x000000fabcf00000)]
  0x0000020992135000 JavaThread "high-pool-2-thread-2 --&gt; Datasource subgroup initializer" [_thread_blocked, id=2176, stack(0x000000fabcf00000,0x000000fabd000000)]
  0x0000020993d01000 JavaThread "high-pool-2-thread-3 --&gt; Datasource subgroup initializer" [_thread_blocked, id=7152, stack(0x000000fabd000000,0x000000fabd100000)]
  0x0000020993d06000 JavaThread "high-pool-2-thread-4 --&gt; Datasource subgroup initializer" [_thread_blocked, id=7584, stack(0x000000fabd100000,0x000000fabd200000)]
  0x0000020993d04000 JavaThread "high-pool-2-thread-5 --&gt; Datasource subgroup initializer" [_thread_blocked, id=6712, stack(0x000000fabd200000,0x000000fabd300000)]
  0x0000020993d02800 JavaThread "high-pool-2-thread-6 --&gt; Datasource subgroup initializer" [_thread_in_Java, id=5580, stack(0x000000fabd300000,0x000000fabd400000)]
=&gt;0x0000020993d01800 JavaThread "high-pool-2-thread-7 --&gt; Datasource subgroup initializer" [_thread_in_native, id=4616, stack(0x000000fabd400000,0x000000fabd500000)]
  0x0000020993d03800 JavaThread "high-pool-2-thread-8 --&gt; Datasource subgroup initializer" [_thread_blocked, id=4500, stack(0x000000fabd500000,0x000000fabd600000)]
  0x0000020993d05000 JavaThread "high-pool-2-thread-9" [_thread_blocked, id=4100, stack(0x000000fabd600000,0x000000fabd700000)]
Other Threads:
  0x00000209ef796000 VMThread "VM Thread" [stack: 0x000000fabad00000,0x000000fabae00000] [id=5924]
  0x00000209feaac800 WatcherThread [stack: 0x000000fabb600000,0x000000fabb700000] [id=572]
  0x00000209ef6fd800 GCTaskThread "GC Thread#0" [stack: 0x000000faba800000,0x000000faba900000] [id=7284]
  0x00000209feaa2800 GCTaskThread "GC Thread#1" [stack: 0x000000fabb800000,0x000000fabb900000] [id=1860]
  0x00000209ef707800 ConcurrentGCThread "G1 Main Marker" [stack: 0x000000faba900000,0x000000fabaa00000] [id=4664]
  0x00000209ef709800 ConcurrentGCThread "G1 Conc#0" [stack: 0x000000fabaa00000,0x000000fabab00000] [id=3664]
  0x00000209ef755800 ConcurrentGCThread "G1 Refine#0" [stack: 0x000000fabab00000,0x000000fabac00000] [id=4032]
  0x00000209ef757800 ConcurrentGCThread "G1 Young RemSet Sampling" [stack: 0x000000fabac00000,0x000000fabad00000] [id=2796]
Threads with active compile tasks:
C2 CompilerThread0    33972 5522   !   4       org.springframework.core.annotation.AnnotationUtils::getAnnotatedMethodsInBaseType (163 bytes)
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap address: 0x00000000c4000000, size: 960 MB, Compressed Oops mode: 32-bit
Narrow klass base: 0x0000000800000000, Narrow klass shift: 3
Compressed class space size: 1073741824 Address: 0x0000000800b40000
Heap:
 garbage-first heap   total 101376K, used 68255K [0x00000000c4000000, 0x0000000100000000)
  region size 1024K, 7 young (7168K), 4 survivors (4096K)
 Metaspace       used 53908K, capacity 54682K, committed 54784K, reserved 1097728K
  class space    used 6112K, capacity 6369K, committed 6400K, reserved 1048576K
Heap Regions: E=young(eden), S=young(survivor), O=old, HS=humongous(starts), HC=humongous(continues), CS=collection set, F=free, A=archive, TAMS=top-at-mark-start (previous, next)
|   0|0x00000000c4000000, 0x00000000c4100000, 0x00000000c4100000|100%| O|  |TAMS 0x00000000c4100000, 0x00000000c4100000| Untracked
|   1|0x00000000c4100000, 0x00000000c4200000, 0x00000000c4200000|100%| O|  |TAMS 0x00000000c4200000, 0x00000000c4200000| Untracked
|   2|0x00000000c4200000, 0x00000000c4300000, 0x00000000c4300000|100%| O|  |TAMS 0x00000000c4300000, 0x00000000c4300000| Untracked
|   3|0x00000000c4300000, 0x00000000c4400000, 0x00000000c4400000|100%| O|  |TAMS 0x00000000c4400000, 0x00000000c4400000| Untracked
|   4|0x00000000c4400000, 0x00000000c4500000, 0x00000000c4500000|100%| O|  |TAMS 0x00000000c4500000, 0x00000000c4500000| Untracked
|   5|0x00000000c4500000, 0x00000000c4600000, 0x00000000c4600000|100%|HS|  |TAMS 0x00000000c4600000, 0x00000000c4600000| Complete
|   6|0x00000000c4600000, 0x00000000c4700000, 0x00000000c4700000|100%| O|  |TAMS 0x00000000c4700000, 0x00000000c4700000| Untracked
|   7|0x00000000c4700000, 0x00000000c4800000, 0x00000000c4800000|100%| O|  |TAMS 0x00000000c4800000, 0x00000000c4800000| Untracked
|   8|0x00000000c4800000, 0x00000000c4900000, 0x00000000c4900000|100%|HS|  |TAMS 0x00000000c4900000, 0x00000000c4900000| Complete
|   9|0x00000000c4900000, 0x00000000c4a00000, 0x00000000c4a00000|100%|HC|  |TAMS 0x00000000c4a00000, 0x00000000c4a00000| Complete
|  10|0x00000000c4a00000, 0x00000000c4b00000, 0x00000000c4b00000|100%| O|  |TAMS 0x00000000c4b00000, 0x00000000c4b00000| Untracked
|  11|0x00000000c4b00000, 0x00000000c4c00000, 0x00000000c4c00000|100%| O|  |TAMS 0x00000000c4c00000, 0x00000000c4c00000| Untracked
|  12|0x00000000c4c00000, 0x00000000c4d00000, 0x00000000c4d00000|100%| O|  |TAMS 0x00000000c4d00000, 0x00000000c4d00000| Untracked
|  13|0x00000000c4d00000, 0x00000000c4e00000, 0x00000000c4e00000|100%| O|  |TAMS 0x00000000c4e00000, 0x00000000c4e00000| Untracked
|  14|0x00000000c4e00000, 0x00000000c4f00000, 0x00000000c4f00000|100%| O|  |TAMS 0x00000000c4f00000, 0x00000000c4f00000| Untracked
|  15|0x00000000c4f00000, 0x00000000c5000000, 0x00000000c5000000|100%| O|  |TAMS 0x00000000c5000000, 0x00000000c5000000| Untracked
|  16|0x00000000c5000000, 0x00000000c5100000, 0x00000000c5100000|100%|HS|  |TAMS 0x00000000c5100000, 0x00000000c5100000| Complete
|  17|0x00000000c5100000, 0x00000000c5200000, 0x00000000c5200000|100%|HC|  |TAMS 0x00000000c5200000, 0x00000000c5200000| Complete
|  18|0x00000000c5200000, 0x00000000c5300000, 0x00000000c5300000|100%|HS|  |TAMS 0x00000000c5300000, 0x00000000c5300000| Complete
|  19|0x00000000c5300000, 0x00000000c5400000, 0x00000000c5400000|100%|HC|  |TAMS 0x00000000c5400000, 0x00000000c5400000| Complete
|  20|0x00000000c5400000, 0x00000000c5500000, 0x00000000c5500000|100%| O|  |TAMS 0x00000000c5500000, 0x00000000c5500000| Untracked
|  21|0x00000000c5500000, 0x00000000c5600000, 0x00000000c5600000|100%| O|  |TAMS 0x00000000c5600000, 0x00000000c5600000| Untracked
|  22|0x00000000c5600000, 0x00000000c5700000, 0x00000000c5700000|100%| O|  |TAMS 0x00000000c5700000, 0x00000000c5700000| Untracked
|  23|0x00000000c5700000, 0x00000000c5800000, 0x00000000c5800000|100%| O|  |TAMS 0x00000000c5800000, 0x00000000c5800000| Untracked
|  24|0x00000000c5800000, 0x00000000c5900000, 0x00000000c5900000|100%| O|  |TAMS 0x00000000c5900000, 0x00000000c5900000| Untracked
|  25|0x00000000c5900000, 0x00000000c5a00000, 0x00000000c5a00000|100%| O|  |TAMS 0x00000000c5a00000, 0x00000000c5a00000| Untracked
|  26|0x00000000c5a00000, 0x00000000c5b00000, 0x00000000c5b00000|100%| O|  |TAMS 0x00000000c5b00000, 0x00000000c5b00000| Untracked
|  27|0x00000000c5b00000, 0x00000000c5c00000, 0x00000000c5c00000|100%| O|  |TAMS 0x00000000c5c00000, 0x00000000c5c00000| Untracked
|  28|0x00000000c5c00000, 0x00000000c5d00000, 0x00000000c5d00000|100%| O|  |TAMS 0x00000000c5d00000, 0x00000000c5d00000| Untracked
|  29|0x00000000c5d00000, 0x00000000c5e00000, 0x00000000c5e00000|100%| O|  |TAMS 0x00000000c5e00000, 0x00000000c5e00000| Untracked
|  30|0x00000000c5e00000, 0x00000000c5f00000, 0x00000000c5f00000|100%| O|  |TAMS 0x00000000c5f00000, 0x00000000c5f00000| Untracked
|  31|0x00000000c5f00000, 0x00000000c6000000, 0x00000000c6000000|100%| O|  |TAMS 0x00000000c6000000, 0x00000000c6000000| Untracked
|  32|0x00000000c6000000, 0x00000000c6100000, 0x00000000c6100000|100%| O|  |TAMS 0x00000000c6100000, 0x00000000c6100000| Untracked
|  33|0x00000000c6100000, 0x00000000c6200000, 0x00000000c6200000|100%| O|  |TAMS 0x00000000c6200000, 0x00000000c6200000| Untracked
|  34|0x00000000c6200000, 0x00000000c6300000, 0x00000000c6300000|100%| O|  |TAMS 0x00000000c6300000, 0x00000000c6300000| Untracked
|  35|0x00000000c6300000, 0x00000000c6400000, 0x00000000c6400000|100%| O|  |TAMS 0x00000000c6400000, 0x00000000c6400000| Untracked
|  36|0x00000000c6400000, 0x00000000c6500000, 0x00000000c6500000|100%| O|  |TAMS 0x00000000c6500000, 0x00000000c6500000| Untracked
|  37|0x00000000c6500000, 0x00000000c6600000, 0x00000000c6600000|100%| O|  |TAMS 0x00000000c6600000, 0x00000000c6600000| Untracked
|  38|0x00000000c6600000, 0x00000000c6700000, 0x00000000c6700000|100%| O|  |TAMS 0x00000000c6700000, 0x00000000c6700000| Untracked
|  39|0x00000000c6700000, 0x00000000c6800000, 0x00000000c6800000|100%| O|  |TAMS 0x00000000c6800000, 0x00000000c6800000| Untracked
|  40|0x00000000c6800000, 0x00000000c6900000, 0x00000000c6900000|100%| O|  |TAMS 0x00000000c6900000, 0x00000000c6900000| Untracked
|  41|0x00000000c6900000, 0x00000000c6a00000, 0x00000000c6a00000|100%| O|  |TAMS 0x00000000c6a00000, 0x00000000c6a00000| Untracked
|  42|0x00000000c6a00000, 0x00000000c6b00000, 0x00000000c6b00000|100%| O|  |TAMS 0x00000000c6a75800, 0x00000000c6b00000| Untracked
|  43|0x00000000c6b00000, 0x00000000c6c00000, 0x00000000c6c00000|100%| O|  |TAMS 0x00000000c6b00000, 0x00000000c6c00000| Untracked
|  44|0x00000000c6c00000, 0x00000000c6d00000, 0x00000000c6d00000|100%| O|  |TAMS 0x00000000c6c00000, 0x00000000c6ca1e00| Untracked
|  45|0x00000000c6d00000, 0x00000000c6e00000, 0x00000000c6e00000|100%| O|  |TAMS 0x00000000c6d00000, 0x00000000c6d00000| Untracked
|  46|0x00000000c6e00000, 0x00000000c6f00000, 0x00000000c6f00000|100%| O|  |TAMS 0x00000000c6e00000, 0x00000000c6e00000| Untracked
|  47|0x00000000c6f00000, 0x00000000c7000000, 0x00000000c7000000|100%| O|  |TAMS 0x00000000c6f00000, 0x00000000c6f00000| Untracked
|  48|0x00000000c7000000, 0x00000000c7100000, 0x00000000c7100000|100%| O|  |TAMS 0x00000000c7000000, 0x00000000c7000000| Untracked
|  49|0x00000000c7100000, 0x00000000c7200000, 0x00000000c7200000|100%| O|  |TAMS 0x00000000c7100000, 0x00000000c7100000| Untracked
|  50|0x00000000c7200000, 0x00000000c7300000, 0x00000000c7300000|100%| O|  |TAMS 0x00000000c7200000, 0x00000000c7200000| Untracked
|  51|0x00000000c7300000, 0x00000000c7400000, 0x00000000c7400000|100%| O|  |TAMS 0x00000000c7300000, 0x00000000c7300000| Untracked
|  52|0x00000000c7400000, 0x00000000c7500000, 0x00000000c7500000|100%| O|  |TAMS 0x00000000c7400000, 0x00000000c7400000| Untracked
|  53|0x00000000c7500000, 0x00000000c7600000, 0x00000000c7600000|100%| O|  |TAMS 0x00000000c7500000, 0x00000000c7500000| Untracked
|  54|0x00000000c7600000, 0x00000000c7700000, 0x00000000c7700000|100%| O|  |TAMS 0x00000000c7600000, 0x00000000c7600000| Untracked
|  55|0x00000000c7700000, 0x00000000c7800000, 0x00000000c7800000|100%| O|  |TAMS 0x00000000c7700000, 0x00000000c7700000| Untracked
|  56|0x00000000c7800000, 0x00000000c7800000, 0x00000000c7900000|  0%| F|  |TAMS 0x00000000c7800000, 0x00000000c7800000| Untracked
|  57|0x00000000c7900000, 0x00000000c7900000, 0x00000000c7a00000|  0%| F|  |TAMS 0x00000000c7900000, 0x00000000c7900000| Untracked
|  58|0x00000000c7a00000, 0x00000000c7b00000, 0x00000000c7b00000|100%| O|  |TAMS 0x00000000c7a00000, 0x00000000c7a00000| Untracked
|  59|0x00000000c7b00000, 0x00000000c7c00000, 0x00000000c7c00000|100%| O|  |TAMS 0x00000000c7b00000, 0x00000000c7b00000| Untracked
|  60|0x00000000c7c00000, 0x00000000c7c00000, 0x00000000c7d00000|  0%| F|  |TAMS 0x00000000c7c00000, 0x00000000c7c00000| Untracked
|  61|0x00000000c7d00000, 0x00000000c7e00000, 0x00000000c7e00000|100%| O|  |TAMS 0x00000000c7d00000, 0x00000000c7d00000| Untracked
|  62|0x00000000c7e00000, 0x00000000c7f00000, 0x00000000c7f00000|100%| O|  |TAMS 0x00000000c7e00000, 0x00000000c7e00000| Untracked
|  63|0x00000000c7f00000, 0x00000000c7fa7c00, 0x00000000c8000000| 65%| O|  |TAMS 0x00000000c7f00000, 0x00000000c7f00000| Untracked
|  64|0x00000000c8000000, 0x00000000c8000000, 0x00000000c8100000|  0%| F|  |TAMS 0x00000000c8000000, 0x00000000c8000000| Untracked
|  65|0x00000000c8100000, 0x00000000c8100000, 0x00000000c8200000|  0%| F|  |TAMS 0x00000000c8100000, 0x00000000c8100000| Untracked
|  66|0x00000000c8200000, 0x00000000c8200000, 0x00000000c8300000|  0%| F|  |TAMS 0x00000000c8200000, 0x00000000c8200000| Untracked
|  67|0x00000000c8300000, 0x00000000c8400000, 0x00000000c8400000|100%| S|CS|TAMS 0x00000000c8300000, 0x00000000c8300000| Complete
|  68|0x00000000c8400000, 0x00000000c8500000, 0x00000000c8500000|100%| S|CS|TAMS 0x00000000c8400000, 0x00000000c8400000| Complete
|  69|0x00000000c8500000, 0x00000000c8600000, 0x00000000c8600000|100%| S|CS|TAMS 0x00000000c8500000, 0x00000000c8500000| Complete
|  70|0x00000000c8600000, 0x00000000c8700000, 0x00000000c8700000|100%| S|CS|TAMS 0x00000000c8600000, 0x00000000c8600000| Complete
|  71|0x00000000c8700000, 0x00000000c8700000, 0x00000000c8800000|  0%| F|  |TAMS 0x00000000c8700000, 0x00000000c8700000| Untracked
|  72|0x00000000c8800000, 0x00000000c8800000, 0x00000000c8900000|  0%| F|  |TAMS 0x00000000c8800000, 0x00000000c8800000| Untracked
|  73|0x00000000c8900000, 0x00000000c8900000, 0x00000000c8a00000|  0%| F|  |TAMS 0x00000000c8900000, 0x00000000c8900000| Untracked
|  74|0x00000000c8a00000, 0x00000000c8a00000, 0x00000000c8b00000|  0%| F|  |TAMS 0x00000000c8a00000, 0x00000000c8a00000| Untracked
|  75|0x00000000c8b00000, 0x00000000c8b00000, 0x00000000c8c00000|  0%| F|  |TAMS 0x00000000c8b00000, 0x00000000c8b00000| Untracked
|  76|0x00000000c8c00000, 0x00000000c8c00000, 0x00000000c8d00000|  0%| F|  |TAMS 0x00000000c8c00000, 0x00000000c8c00000| Untracked
|  77|0x00000000c8d00000, 0x00000000c8d00000, 0x00000000c8e00000|  0%| F|  |TAMS 0x00000000c8d00000, 0x00000000c8d00000| Untracked
|  78|0x00000000c8e00000, 0x00000000c8e00000, 0x00000000c8f00000|  0%| F|  |TAMS 0x00000000c8e00000, 0x00000000c8e00000| Untracked
|  79|0x00000000c8f00000, 0x00000000c8f00000, 0x00000000c9000000|  0%| F|  |TAMS 0x00000000c8f00000, 0x00000000c8f00000| Untracked
|  80|0x00000000c9000000, 0x00000000c9000000, 0x00000000c9100000|  0%| F|  |TAMS 0x00000000c9000000, 0x00000000c9000000| Untracked
|  81|0x00000000c9100000, 0x00000000c9100000, 0x00000000c9200000|  0%| F|  |TAMS 0x00000000c9100000, 0x00000000c9100000| Untracked
|  82|0x00000000c9200000, 0x00000000c9200000, 0x00000000c9300000|  0%| F|  |TAMS 0x00000000c9200000, 0x00000000c9200000| Untracked
|  83|0x00000000c9300000, 0x00000000c9300000, 0x00000000c9400000|  0%| F|  |TAMS 0x00000000c9300000, 0x00000000c9300000| Untracked
|  84|0x00000000c9400000, 0x00000000c9400000, 0x00000000c9500000|  0%| F|  |TAMS 0x00000000c9400000, 0x00000000c9400000| Untracked
|  85|0x00000000c9500000, 0x00000000c9500000, 0x00000000c9600000|  0%| F|  |TAMS 0x00000000c9500000, 0x00000000c9500000| Untracked
|  86|0x00000000c9600000, 0x00000000c9600000, 0x00000000c9700000|  0%| F|  |TAMS 0x00000000c9600000, 0x00000000c9600000| Untracked
|  87|0x00000000c9700000, 0x00000000c9700000, 0x00000000c9800000|  0%| F|  |TAMS 0x00000000c9700000, 0x00000000c9700000| Untracked
|  88|0x00000000c9800000, 0x00000000c9800000, 0x00000000c9900000|  0%| F|  |TAMS 0x00000000c9800000, 0x00000000c9800000| Untracked
|  89|0x00000000c9900000, 0x00000000c9900000, 0x00000000c9a00000|  0%| F|  |TAMS 0x00000000c9900000, 0x00000000c9900000| Untracked
|  90|0x00000000c9a00000, 0x00000000c9a00000, 0x00000000c9b00000|  0%| F|  |TAMS 0x00000000c9a00000, 0x00000000c9a00000| Untracked
|  91|0x00000000c9b00000, 0x00000000c9b00000, 0x00000000c9c00000|  0%| F|  |TAMS 0x00000000c9b00000, 0x00000000c9b00000| Untracked
|  92|0x00000000c9c00000, 0x00000000c9c00000, 0x00000000c9d00000|  0%| F|  |TAMS 0x00000000c9c00000, 0x00000000c9c00000| Untracked
|  93|0x00000000c9d00000, 0x00000000c9d00000, 0x00000000c9e00000|  0%| F|  |TAMS 0x00000000c9d00000, 0x00000000c9d00000| Untracked
|  94|0x00000000c9e00000, 0x00000000c9e00000, 0x00000000c9f00000|  0%| F|  |TAMS 0x00000000c9e00000, 0x00000000c9e00000| Untracked
|  95|0x00000000c9f00000, 0x00000000c9f00000, 0x00000000ca000000|  0%| F|  |TAMS 0x00000000c9f00000, 0x00000000c9f00000| Untracked
|  96|0x00000000ca000000, 0x00000000ca0f1520, 0x00000000ca100000| 94%| E|  |TAMS 0x00000000ca000000, 0x00000000ca000000| Complete
|  97|0x00000000ca100000, 0x00000000ca200000, 0x00000000ca200000|100%| E|CS|TAMS 0x00000000ca100000, 0x00000000ca100000| Complete
|  98|0x00000000ca200000, 0x00000000ca300000, 0x00000000ca300000|100%| E|CS|TAMS 0x00000000ca200000, 0x00000000ca200000| Complete
Card table byte_map: [0x00000209f9ad0000,0x00000209f9cb0000] _byte_map_base: 0x00000209f94b0000
Marking Bits (Prev, Next): (CMBitMap*) 0x00000209ef6ff468, (CMBitMap*) 0x00000209ef6ff428
 Prev Bits: [0x00000209fad90000, 0x00000209fbc90000)
 Next Bits: [0x00000209f9e90000, 0x00000209fad90000)
Polling page: 0x00000209f0f50000
Metaspace:
Usage:
  Non-class:     47.18 MB capacity,    46.68 MB ( 99%) used,   422.95 KB ( &lt;1%) free+waste,    94.75 KB ( &lt;1%) overhead.
      Class:      6.22 MB capacity,     5.97 MB ( 96%) used,   216.35 KB (  3%) free+waste,    39.88 KB ( &lt;1%) overhead.
       Both:     53.40 MB capacity,    52.64 MB ( 99%) used,   639.30 KB (  1%) free+waste,   134.63 KB ( &lt;1%) overhead.
]]></description><link>https://forum.mango-os.com/post/26155</link><guid isPermaLink="true">https://forum.mango-os.com/post/26155</guid><dc:creator><![CDATA[lesdotcom]]></dc:creator><pubDate>Wed, 13 Jan 2021 07:50:27 GMT</pubDate></item><item><title><![CDATA[Reply to Serial data source causing crash on Fri, 08 Jan 2021 16:42:49 GMT]]></title><description><![CDATA[<p dir="auto">According to this error, you are running Java8, please run with a higher version of AdoptJDK and give me the ma.log from your mango log. 3.6+ needs at least version 11.<br />
I also suggest reinstalling the serial module.</p>
]]></description><link>https://forum.mango-os.com/post/26154</link><guid isPermaLink="true">https://forum.mango-os.com/post/26154</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Fri, 08 Jan 2021 16:42:49 GMT</pubDate></item><item><title><![CDATA[Reply to Serial data source causing crash on Fri, 08 Jan 2021 14:04:58 GMT]]></title><description><![CDATA[<p dir="auto">Here is a snippet of error log.  Entire log too long to post here.</p>
<pre><code>#
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000007110b5db, pid=7112, tid=0x0000000000001bcc
# JRE version: Java(TM) SE Runtime Environment (8.0_271-b09) (build 1.8.0_271-b09)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.271-b09 mixed mode windows-amd64 compressed oops)
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
Current thread (0x00000280a4ee5800):  JavaThread "high-pool-2-thread-7 --&gt; Datasource subgroup initializer" [_thread_in_native, id=7116, stack(0x000000dd1b500000,0x000000dd1b600000)]
siginfo: ExceptionCode=0xc0000005, reading address 0xffffffffa3b457b0
Registers:
RAX=0xffffffffa3b457b0, RBX=0x000000dd1b5fea60, RCX=0x00007ffbed84c194, RDX=0x0000000000000000
RSP=0x000000dd1b5fe9f0, RBP=0x000000dd1b5feb70, RSI=0x00000280a4ee59f8, RDI=0x0000000000000e1c
R8 =0x000000dd1b5fe8e8, R9 =0x000000dd1b5fe9e0, R10=0x0000000000000000, R11=0x0000000000000246
R12=0x000000dd1b5fec28, R13=0x00000280a19d67b0, R14=0x000000dd1b5feb20, R15=0x00000280a4ee5800
RIP=0x000000007110b5db, EFLAGS=0x0000000000010202
Top of Stack: (sp=0x000000dd1b5fe9f0)
0x000000dd1b5fe9f0:   00000280a162ce00 00000280a19d6720
0x000000dd1b5fea00:   000000007110b230 000002808a370000
0x000000dd1b5fea10:   000002808a240000 0000000000000004
0x000000dd1b5fea20:   00000280a4ee59f8 0000000000000e1c
0x000000dd1b5fea30:   000000dd1b5feb70 0000000071112590
0x000000dd1b5fea40:   00000280a4ee5800 000000dd1b5feb20
0x000000dd1b5fea50:   00000280a19d67b0 000000dd1b5fec28
0x000000dd1b5fea60:   00000280a19d67b0 00007ffbed7c5d21
0x000000dd1b5fea70:   000000dd1b5feaa0 000002808a370000
0x000000dd1b5fea80:   000000dd1b5feb70 0000000000000000
0x000000dd1b5fea90:   0000000071113500 0000000071113be8
0x000000dd1b5feaa0:   000000dd1b5fead0 0000000071112641
0x000000dd1b5feab0:   000000dd1b5fea40 00000280a4ee59f8
0x000000dd1b5feac0:   0000000000000000 0000000000000000
0x000000dd1b5fead0:   000000dd1b5feb70 0000000071101595
0x000000dd1b5feae0:   000000000000001c 0000028000000000
RAX=0xffffffffa3b457b0 is an unknown value
RBX=0x000000dd1b5fea60 is pointing into the stack for thread: 0x00000280a4ee5800
RCX=0x00007ffbed84c194 is an unknown value
RDX=0x0000000000000000 is an unknown value
RSP=0x000000dd1b5fe9f0 is pointing into the stack for thread: 0x00000280a4ee5800
RBP=0x000000dd1b5feb70 is pointing into the stack for thread: 0x00000280a4ee5800
RSI=0x00000280a4ee59f8 is an unknown value
RDI=0x0000000000000e1c is an unknown value
R8 =0x000000dd1b5fe8e8 is pointing into the stack for thread: 0x00000280a4ee5800
R9 =0x000000dd1b5fe9e0 is pointing into the stack for thread: 0x00000280a4ee5800
R10=0x0000000000000000 is an unknown value
R12=0x000000dd1b5fec28 is pointing into the stack for thread: 0x00000280a4ee5800
R13=0x00000280a19d67b0 is an unknown value
R14=0x000000dd1b5feb20 is pointing into the stack for thread: 0x00000280a4ee5800
R15=0x00000280a4ee5800 is a thread
Stack: [0x000000dd1b500000,0x000000dd1b600000],  sp=0x000000dd1b5fe9f0,  free space=1018k
C  [jSSC-2.8_x86_64.dll+0x12590]
C  [jSSC-2.8_x86_64.dll+0x1595]
C  0x000002808bd6750e
j  java.util.concurrent.ThreadPoolExecutor.runWorker(Ljava/util/concurrent/ThreadPoolExecutor$Worker;)V+95
  0x00000280a4ee6000 JavaThread "high-pool-2-thread-9" [_thread_blocked, id=7052, stack(0x000000dd1b700000,0x000000dd1b800000)]
  0x00000280a4ee9000 JavaThread "high-pool-2-thread-8 --&gt; Datasource subgroup initializer" [_thread_blocked, id=5600, stack(0x000000dd1b600000,0x000000dd1b700000)]
=&gt;0x00000280a4ee5800 JavaThread "high-pool-2-thread-7 --&gt; Datasource subgroup initializer" [_thread_in_native, id=7116, stack(0x000000dd1b500000,0x000000dd1b600000)]
  0x00000280a4ee7800 JavaThread "high-pool-2-thread-6 --&gt; Datasource subgroup initializer" [_thread_in_native, id=5160, stack(0x000000dd1b400000,0x000000dd1b500000)]
  0x00000280a4ee4800 JavaThread "high-pool-2-thread-5 --&gt; Datasource subgroup initializer" [_thread_blocked, id=480, stack(0x000000dd1b300000,0x000000dd1b400000)]
  0x00000280a4ee4000 JavaThread "high-pool-2-thread-4 --&gt; Datasource subgroup initializer" [_thread_blocked, id=4980, stack(0x000000dd1b200000,0x000000dd1b300000)]
  0x00000280a4ee8800 JavaThread "high-pool-2-thread-3 --&gt; Datasource subgroup initializer" [_thread_blocked, id=8620, stack(0x000000dd1b100000,0x000000dd1b200000)]
  0x00000280a4ee7000 JavaThread "high-pool-2-thread-2 --&gt; Datasource subgroup initializer" [_thread_blocked, id=8088, stack(0x000000dd1b000000,0x000000dd1b100000)]
  0x00000280a1aab800 JavaThread "high-pool-2-thread-1 --&gt; Datasource subgroup initializer" [_thread_blocked, id=4248, stack(0x000000dd1af00000,0x000000dd1b000000)]
  0x00000280a1aad800 JavaThread "Mango Serial Port Event Processor" [_thread_blocked, id=7468, stack(0x000000dd1ae00000,0x000000dd1af00000)]
  0x00000280a1aa9000 JavaThread "Mango shared scheduled executor" daemon [_thread_blocked, id=8188, stack(0x000000dd1ad00000,0x000000dd1ae00000)]
  0x00000280a1aa7800 JavaThread "H2 Log Writer MAH2.199" daemon [_thread_blocked, id=8060, stack(0x000000dd1ac00000,0x000000dd1ad00000)]
  0x00000280a1aaa000 JavaThread "H2 File Lock Watchdog C:/Users/Les/Desktop/Mango 3.7.4 Basement/databases/mah2.199.lock.db" daemon [_thread_blocked, id=6364, stack(0x000000dd1ab00000,0x000000dd1ac00000)]
  0x00000280a1aa8800 JavaThread "Abandoned connection cleanup thread" daemon [_thread_blocked, id=6288, stack(0x000000dd1aa00000,0x000000dd1ab00000)]
  0x00000280a1aad000 JavaThread "Ordered RealTime Timer" [_thread_blocked, id=2800, stack(0x000000dd1a500000,0x000000dd1a600000)]
  0x00000280a1aac000 JavaThread "Connector-Scheduler-773bd77b-1" [_thread_blocked, id=5748, stack(0x000000dd1a300000,0x000000dd1a400000)]
  0x00000280a1aa7000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=268, stack(0x000000dd1a400000,0x000000dd1a500000)]
  0x00000280a1aaa800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=8840, stack(0x000000dd1a200000,0x000000dd1a300000)]
  0x00000280a2057000 JavaThread "jetty-thread-pool-21" [_thread_blocked, id=1276, stack(0x000000dd1a100000,0x000000dd1a200000)]
  0x00000280a2056800 JavaThread "jetty-thread-pool-20" [_thread_blocked, id=2692, stack(0x000000dd1a000000,0x000000dd1a100000)]
  0x00000280a0241000 JavaThread "jetty-thread-pool-19" [_thread_blocked, id=6636, stack(0x000000dd19f00000,0x000000dd1a000000)]
  0x00000280a2055800 JavaThread "jetty-thread-pool-18" [_thread_in_native, id=8720, stack(0x000000dd19e00000,0x000000dd19f00000)]
  0x00000280a13e2800 JavaThread "jetty-thread-pool-17" [_thread_blocked, id=8516, stack(0x000000dd19d00000,0x000000dd19e00000)]
  0x00000280a13e1800 JavaThread "jetty-thread-pool-16" [_thread_blocked, id=5940, stack(0x000000dd19c00000,0x000000dd19d00000)]
  0x00000280a2bd1000 JavaThread "jetty-thread-pool-15-acceptor-0@932fcc0-ServerConnector@773bd77b{HTTP/1.1,[http/1.1, h2c]}{0.0.0.0:8081}" [_thread_in_native, id=8776, stack(0x000000dd19b00000,0x000000dd19c00000)]
  0x00000280a2099000 JavaThread "jetty-thread-pool-14" [_thread_blocked, id=7916, stack(0x000000dd19a00000,0x000000dd19b00000)]
  0x000002809fbf0000 JavaThread "Log4j2-TF-5-AsyncLoggerConfig--2" daemon [_thread_blocked, id=5760, stack(0x000000dd19900000,0x000000dd19a00000)]
  0x000002809e272800 JavaThread "Service Thread" daemon [_thread_blocked, id=6760, stack(0x000000dd19700000,0x000000dd19800000)]
  0x000002809e212000 JavaThread "C1 CompilerThread1" daemon [_thread_blocked, id=376, stack(0x000000dd19600000,0x000000dd19700000)]
  0x000002809e210000 JavaThread "C2 CompilerThread0" daemon [_thread_in_native, id=9104, stack(0x000000dd19500000,0x000000dd19600000)]
  0x000002809e208800 JavaThread "Attach Listener" daemon [_thread_blocked, id=7616, stack(0x000000dd19400000,0x000000dd19500000)]
  0x000002809e205000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=6876, stack(0x000000dd19300000,0x000000dd19400000)]
  0x000002809dd1c000 JavaThread "Finalizer" daemon [_thread_blocked, id=2936, stack(0x000000dd19100000,0x000000dd19200000)]
  0x000002809e1e3800 JavaThread "Reference Handler" daemon [_thread_blocked, id=8920, stack(0x000000dd19000000,0x000000dd19100000)]
  0x000002808a3ac000 JavaThread "main" [_thread_blocked, id=2488, stack(0x000000dd18c00000,0x000000dd18d00000)]
Other Threads:
  0x000002809e1c2000 VMThread [stack: 0x000000dd18f00000,0x000000dd19000000] [id=5292]
  0x000002809e2f9800 WatcherThread [stack: 0x000000dd19800000,0x000000dd19900000] [id=8204]
heap address: 0x00000000c4000000, size: 960 MB, Compressed Oops mode: 32-bit
Narrow klass base: 0x0000000000000000, Narrow klass shift: 3
Compressed class space size: 1073741824 Address: 0x0000000100000000
Heap:
 PSYoungGen      total 312320K, used 145433K [0x00000000ec000000, 0x0000000100000000, 0x0000000100000000)
  eden space 296960K, 43% used [0x00000000ec000000,0x00000000f3f0e1f0,0x00000000fe200000)
  from space 15360K, 99% used [0x00000000fe200000,0x00000000ff0f8218,0x00000000ff100000)
  to   space 15360K, 0% used [0x00000000ff100000,0x00000000ff100000,0x0000000100000000)
 ParOldGen       total 71680K, used 35453K [0x00000000c4000000, 0x00000000c8600000, 0x00000000ec000000)
  object space 71680K, 49% used [0x00000000c4000000,0x00000000c629f6f8,0x00000000c8600000)
 Metaspace       used 54274K, capacity 55228K, committed 55384K, reserved 1097728K
  class space    used 6422K, capacity 6682K, committed 6784K, reserved 1048576K
Card table byte_map: [0x000002809b110000,0x000002809b300000] byte_map_base: 0x000002809aaf0000
Marking Bits: (ParMarkBitMap*) 0x0000000059c67fe0
 Begin Bits: [0x000002809b440000, 0x000002809c340000)
 End Bits:   [0x000002809c340000, 0x000002809d240000)
Polling page: 0x000002808a4e0000
CodeCache: size=245760Kb used=15466Kb max_used=16003Kb free=230293Kb
 bounds [0x000002808bd50000, 0x000002808cd00000, 0x000002809ad50000]
 total_blobs=5205 nmethods=4566 adapters=553
 compilation: enabled
Compilation events (10 events):
Event: 32.341 Thread 0x000002809e212000 5363   !   2       org.h2.engine.Session::throttle (151 bytes)
Event: 32.342 Thread 0x000002809e212000 nmethod 5363 0x000002808be632d0 code [0x000002808be63460, 0x000002808be63940]
Event: 32.347 Thread 0x000002809e212000 5364       2       org.h2.command.Prepared::checkCanceled (38 bytes)
Event: 32.348 Thread 0x000002809e212000 nmethod 5364 0x000002808bf61850 code [0x000002808bf619e0, 0x000002808bf61d10]
Event: 32.348 Thread 0x000002809e212000 5365       2       org.h2.command.Command::checkCanceled (19 bytes)
Event: 32.348 Thread 0x000002809e212000 nmethod 5365 0x000002808c085ad0 code [0x000002808c085c60, 0x000002808c085fa0]
Event: 32.357 Thread 0x000002809e212000 5366       2       java.util.concurrent.ConcurrentHashMap::tableSizeFor (59 bytes)
Event: 32.357 Thread 0x000002809e212000 nmethod 5366 0x000002808bfa5410 code [0x000002808bfa5560, 0x000002808bfa56f8]
Event: 32.362 Thread 0x000002809e212000 5367       2       org.apache.http.util.Args::notNull (33 bytes)
Event: 32.362 Thread 0x000002809e212000 nmethod 5367 0x000002808c3423d0 code [0x000002808c342560, 0x000002808c342920]
GC Heap History (10 events):
Event: 11.226 GC heap before
{Heap before GC invocations=9 (full 1):
 PSYoungGen      total 259584K, used 2710K [0x00000000ec000000, 0x00000000fcb00000, 0x0000000100000000)
  eden space 245760K, 0% used [0x00000000ec000000,0x00000000ec000000,0x00000000fb000000)
  from space 13824K, 19% used [0x00000000fbd80000,0x00000000fc025a68,0x00000000fcb00000)
  to   space 13824K, 0% used [0x00000000fb000000,0x00000000fb000000,0x00000000fbd80000)
 ParOldGen       total 40960K, used 24770K [0x00000000c4000000, 0x00000000c6800000, 0x00000000ec000000)
  object space 40960K, 60% used [0x00000000c4000000,0x00000000c5830a28,0x00000000c6800000)
 Metaspace       used 20764K, capacity 21046K, committed 21248K, reserved 1067008K
  class space    used 2656K, capacity 2767K, committed 2816K, reserved 1048576K
Event: 11.456 GC heap after
Heap after GC invocations=9 (full 1):
 PSYoungGen      total 259584K, used 0K [0x00000000ec000000, 0x00000000fcb00000, 0x0000000100000000)
  from space 13824K, 0% used [0x00000000fbd80000,0x00000000fbd80000,0x00000000fcb00000)
 ParOldGen       total 55296K, used 23744K [0x00000000c4000000, 0x00000000c7600000, 0x00000000ec000000)
  object space 55296K, 42% used [0x00000000c4000000,0x00000000c5730150,0x00000000c7600000)
Event: 17.658 GC heap before
{Heap before GC invocations=10 (full 1):
 PSYoungGen      total 259584K, used 245760K [0x00000000ec000000, 0x00000000fcb00000, 0x0000000100000000)
  eden space 245760K, 100% used [0x00000000ec000000,0x00000000fb000000,0x00000000fb000000)
 Metaspace       used 29789K, capacity 30314K, committed 30720K, reserved 1075200K
  class space    used 3834K, capacity 3995K, committed 4096K, reserved 1048576K
Event: 17.689 GC heap after
Heap after GC invocations=10 (full 1):
 PSYoungGen      total 259584K, used 10817K [0x00000000ec000000, 0x0000000100000000, 0x0000000100000000)
  from space 13824K, 78% used [0x00000000fb000000,0x00000000fba90518,0x00000000fbd80000)
  to   space 14848K, 0% used [0x00000000ff180000,0x00000000ff180000,0x0000000100000000)
 ParOldGen       total 55296K, used 23752K [0x00000000c4000000, 0x00000000c7600000, 0x00000000ec000000)
  object space 55296K, 42% used [0x00000000c4000000,0x00000000c5732150,0x00000000c7600000)
Event: 22.160 GC heap before
{Heap before GC invocations=11 (full 1):
 PSYoungGen      total 259584K, used 69613K [0x00000000ec000000, 0x0000000100000000, 0x0000000100000000)
  eden space 245760K, 23% used [0x00000000ec000000,0x00000000ef96b188,0x00000000fb000000)
 Metaspace       used 34632K, capacity 35114K, committed 35416K, reserved 1081344K
  class space    used 4272K, capacity 4443K, committed 4480K, reserved 1048576K
Event: 22.186 GC heap after
Heap after GC invocations=11 (full 1):
 PSYoungGen      total 311808K, used 10971K [0x00000000ec000000, 0x0000000100000000, 0x0000000100000000)
  eden space 296960K, 0% used [0x00000000ec000000,0x00000000ec000000,0x00000000fe200000)
  from space 14848K, 73% used [0x00000000ff180000,0x00000000ffc36cc0,0x0000000100000000)
  to   space 15360K, 0% used [0x00000000fe200000,0x00000000fe200000,0x00000000ff100000)
 ParOldGen       total 55296K, used 23760K [0x00000000c4000000, 0x00000000c7600000, 0x00000000ec000000)
  object space 55296K, 42% used [0x00000000c4000000,0x00000000c5734150,0x00000000c7600000)
Event: 22.186 GC heap before
{Heap before GC invocations=12 (full 2):
Event: 22.645 GC heap after
Heap after GC invocations=12 (full 2):
 PSYoungGen      total 311808K, used 0K [0x00000000ec000000, 0x0000000100000000, 0x0000000100000000)
  from space 14848K, 0% used [0x00000000ff180000,0x00000000ff180000,0x0000000100000000)
 ParOldGen       total 71680K, used 29163K [0x00000000c4000000, 0x00000000c8600000, 0x00000000ec000000)
  object space 71680K, 40% used [0x00000000c4000000,0x00000000c5c7ac08,0x00000000c8600000)
Event: 30.295 GC heap before
{Heap before GC invocations=13 (full 2):
 PSYoungGen      total 311808K, used 296960K [0x00000000ec000000, 0x0000000100000000, 0x0000000100000000)
  eden space 296960K, 100% used [0x00000000ec000000,0x00000000fe200000,0x00000000fe200000)
 Metaspace       used 50136K, capacity 50992K, committed 51160K, reserved 1093632K
  class space    used 5888K, capacity 6118K, committed 6144K, reserved 1048576K
Event: 30.355 GC heap after
Heap after GC invocations=13 (full 2):
 PSYoungGen      total 312320K, used 15328K [0x00000000ec000000, 0x0000000100000000, 0x0000000100000000)
Deoptimization events (10 events):
Event: 31.881 Thread 0x00000280a1aab800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000002808c0a2d54 method=java.io.DataInputStream.readUnsignedShort()I @ 4
Event: 31.881 Thread 0x00000280a1aab800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000002808bf0ec20 method=java.io.DataInputStream.readUnsignedShort()I @ 4
Event: 31.986 Thread 0x00000280a4ee7800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x000002808c7451f4 method=java.lang.Character.isSurrogate(C)Z @ 3
Event: 31.996 Thread 0x00000280a4ee7800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x000002808cbc62a4 method=java.util.concurrent.ConcurrentHashMap.putVal(Ljava/lang/Object;Ljava/lang/Object;Z)Ljava/lang/Object; @ 331
Event: 32.001 Thread 0x00000280a4ee7800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x000002808c30a6d4 method=java.util.concurrent.ConcurrentHashMap.transfer([Ljava/util/concurrent/ConcurrentHashMap$Node;[Ljava/util/concurrent/ConcurrentHashMap$Node;)V @ 356
Event: 32.006 Thread 0x00000280a4ee8800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000002808c018e68 method=java.lang.AbstractStringBuilder.append(Ljava/lang/CharSequence;)Ljava/lang/AbstractStringBuilder; @ 21
Event: 32.007 Thread 0x00000280a4ee8800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000002808c018e68 method=java.lang.AbstractStringBuilder.append(Ljava/lang/CharSequence;)Ljava/lang/AbstractStringBuilder; @ 21
Event: 32.008 Thread 0x00000280a4ee8800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000002808c018e68 method=java.lang.AbstractStringBuilder.append(Ljava/lang/CharSequence;)Ljava/lang/AbstractStringBuilder; @ 21
Classes redefined (0 events):
No events
Internal exceptions (10 events):
Event: 26.765 Thread 0x000002808a3ac000 Exception &lt;a 'java/lang/ClassNotFoundException': org/springframework/beans/factory/BeanFactoryAwareBeanInfo&gt; (0x00000000f5bb15d0) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\classfile\systemDictionary.c
Event: 26.770 Thread 0x000002808a3ac000 Exception &lt;a 'java/lang/ClassNotFoundException': org/springframework/beans/factory/BeanFactoryAwareCustomizer&gt; (0x00000000f5c0fd30) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\classfile\systemDictionary
Event: 26.774 Thread 0x000002808a3ac000 Exception &lt;a 'java/lang/ClassNotFoundException': org/springframework/beans/factory/AwareBeanInfo&gt; (0x00000000f5c64e90) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\classfile\systemDictionary.cpp, line 21
Event: 26.779 Thread 0x000002808a3ac000 Exception &lt;a 'java/lang/ClassNotFoundException': org/springframework/beans/factory/AwareCustomizer&gt; (0x00000000f5cb94c8) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\classfile\systemDictionary.cpp, line
Event: 26.784 Thread 0x000002808a3ac000 Exception &lt;a 'java/lang/ClassNotFoundException': org/springframework/context/annotation/ImportAwareBeanInfo&gt; (0x00000000f5d15030) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\classfile\systemDictionary.c
Event: 26.789 Thread 0x000002808a3ac000 Exception &lt;a 'java/lang/ClassNotFoundException': org/springframework/context/annotation/ImportAwareCustomizer&gt; (0x00000000f5d737d8) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\classfile\systemDictionary
Event: 27.908 Thread 0x000002808a3ac000 Exception &lt;a 'java/lang/IncompatibleClassChangeError': Found class java.lang.Object, but interface was expected&gt; (0x00000000f8445108) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\interpreter\linkResolver
Event: 28.641 Thread 0x000002808a3ac000 Implicit null exception at 0x000002808cb6986f to 0x000002808cb6e455
Event: 31.403 Thread 0x000002808a3ac000 Exception &lt;a 'java/lang/NoSuchMethodError': java.lang.Object.lambda$identity$2(Ljava/lang/Object;)Ljava/lang/Object;&gt; (0x00000000f04a89a8) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\interpreter\linkRes
Event: 31.805 Thread 0x00000280a4ee5800 Exception &lt;a 'sun/nio/fs/WindowsException'&gt; (0x00000000f13e17f8) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u271\605\hotspot\src\share\vm\prims\jni.cpp, line 710]
Events (10 events):
Event: 32.357 loading class org/apache/http/impl/client/BasicCredentialsProvider
Event: 32.357 loading class org/apache/http/impl/client/BasicCredentialsProvider done
Event: 32.358 loading class org/apache/http/impl/client/HttpClientBuilder$2
Event: 32.358 loading class org/apache/http/impl/client/HttpClientBuilder$2 done
Event: 32.359 loading class org/apache/http/client/ClientProtocolException
Event: 32.359 loading class org/apache/http/client/ClientProtocolException done
Event: 32.360 loading class org/apache/http/conn/ClientConnectionManager
Event: 32.360 loading class org/apache/http/conn/ClientConnectionManager done
Event: 32.361 Executing VM operation: RevokeBias
Event: 32.362 Executing VM operation: RevokeBias done
]]></description><link>https://forum.mango-os.com/post/26153</link><guid isPermaLink="true">https://forum.mango-os.com/post/26153</guid><dc:creator><![CDATA[lesdotcom]]></dc:creator><pubDate>Fri, 08 Jan 2021 14:04:58 GMT</pubDate></item><item><title><![CDATA[Reply to Serial data source causing crash on Thu, 07 Jan 2021 21:47:28 GMT]]></title><description><![CDATA[<p dir="auto">I'm using AdoptJDK14 on Linux, no idea why you are having problems.<br />
Is there not anything in the logs?<br />
Also, look at the version 3 docs about enabling debug logging and show that here in code &lt;/&gt; tags. That will enable us to deduce the issue faster</p>
]]></description><link>https://forum.mango-os.com/post/26151</link><guid isPermaLink="true">https://forum.mango-os.com/post/26151</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Thu, 07 Jan 2021 21:47:28 GMT</pubDate></item></channel></rss>
