    Licence questions
    6 Posts 4 Posters 2.3k Views 4 Watching
      Cristian Herrera
      Dear All
      I have a few questions about license, i bought a comercial license and we want create a fresh new instance of mango and transfer the license, there is a simple way to do this?, I know there is a form to fill for change the GUID. i have to contact helpdesk of mango everytime that we need this?. I need to move a few datapoints and dashboards from the old instance, which currently have the license, to the new one, when the license is transfered how to i can move those data? i can reach the old instance?
      Sorry for all the question, i new in mango.
      Thanks for all the comments and advices.
        Make a SQL database backup and export the configuration backup as well. This will allow you to transfer all of your settings then import them into your new instance.
        I don't believe so you should be able to move everything. However if the GUID of the instance changes, then you'll need to have your license amended.
        Not if it goes into free mode and you exceed the allowed maximum permitted points/use license only modules.
          Hi @Cristian-Herrera each mango instance has its own globally unique ID. The licence is linked to this ID. The only way to transfer this licence is to fill out a licence transfer form.
            Cristian Herrera
            Thanks for the info, there is a way to transfer only some data?, i mean, just need a few data sources and dashboards. And start fresh with that?
            Thanks a lot for the advices.
            Cristian.
              Ralf
              Hi Cristian,
              you can make a configuration backup
              and import this file in a new Mango installation without the history-values,
              If you want the history-values, make a backup from the noSQL-db
              To import this backup in the new system check the help via ?
              If you have a new system and want only import a few data-sources, you can export this inside the old ui-system via xml:
                Hi Christiaan
                If you need to keep your time-series data on the new instance you will need to use the full backups on the SQL and NoSQL DBS.
                If time-series data is not required you can use the JSON export and just move over what you require.
