<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Licence questions]]></title><description><![CDATA[<p dir="auto">Dear All</p>
<p dir="auto">I have a few questions about  license, i bought a comercial license and we want create a fresh new instance of mango and transfer the license, there is a simple way to do this?, I know there is a form to fill for change the GUID. i have to contact helpdesk of mango everytime that we need this?. I need to move a few datapoints and dashboards from the old instance, which currently have the license, to the new one, when the license is transfered how to i can move those data? i can reach the old instance?</p>
<p dir="auto">Sorry for all the question, i new in mango.<br />
Thanks for all the comments and advices.</p>
]]></description><link>https://forum.mango-os.com/topic/4777/licence-questions</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 13:32:18 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4777.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Apr 2020 16:53:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Licence questions on Fri, 24 Apr 2020 07:20:18 GMT]]></title><description><![CDATA[<p dir="auto">Hi Christiaan</p>
<p dir="auto">If you need to keep your time-series data on the new instance you will need to use the full backups on the SQL and NoSQL DBS.</p>
<p dir="auto">If time-series data is not required you can use the JSON export and just move over what you require.</p>
]]></description><link>https://forum.mango-os.com/post/25066</link><guid isPermaLink="true">https://forum.mango-os.com/post/25066</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Fri, 24 Apr 2020 07:20:18 GMT</pubDate></item><item><title><![CDATA[Reply to Licence questions on Fri, 24 Apr 2020 06:57:04 GMT]]></title><description><![CDATA[<p dir="auto">Hi Cristian,</p>
<p dir="auto">you can make a configuration backup</p>
<p dir="auto"><img src="https://camo.nodebb.org/4dfbaa7d5bbe69fea748539ac6e92b7222ba3413?url=https%3A%2F%2Fi.imgur.com%2Fq934zYs.png" alt="0_1587711652244_6c1b1f8a-4dea-4dae-ad79-2afa9c884683-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">and import this file in a new Mango installation without the history-values,<br />
If you want the history-values, make a backup from the noSQL-db</p>
<p dir="auto"><img src="https://camo.nodebb.org/b8f91ed609f064c2d9fb669e2fe411f1885959fa?url=https%3A%2F%2Fi.imgur.com%2FhHb7KIy.png" alt="0_1587711940129_df5aed0a-7c1a-4762-b8dc-3e1f9f2880f5-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">To import this backup in the new system check the help via ?</p>
<p dir="auto"><img src="https://camo.nodebb.org/b598db3f8d01a210f7bd5a7fb88ba749bd301bb0?url=https%3A%2F%2Fi.imgur.com%2FuTLreDI.png" alt="0_1587712279777_6ba873e8-6581-4927-ad7c-f547f5e5353b-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">If you have a new system and want only import a few data-sources, you can export this inside the old ui-system via xml:</p>
<p dir="auto"><img src="https://camo.nodebb.org/cebe859ba939e744182878f58317390205fc72e7?url=https%3A%2F%2Fi.imgur.com%2FpeJC6od.png" alt="0_1587712471405_51205179-d272-4d1d-a82a-f1377627a4c6-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/25065</link><guid isPermaLink="true">https://forum.mango-os.com/post/25065</guid><dc:creator><![CDATA[Ralf]]></dc:creator><pubDate>Fri, 24 Apr 2020 06:57:04 GMT</pubDate></item><item><title><![CDATA[Reply to Licence questions on Fri, 24 Apr 2020 00:21:16 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the info, there is a way to transfer only some data?, i mean, just need a few data sources and dashboards. And start fresh with that?</p>
<p dir="auto">Thanks a lot for the advices.</p>
<p dir="auto">Cristian.</p>
]]></description><link>https://forum.mango-os.com/post/25063</link><guid isPermaLink="true">https://forum.mango-os.com/post/25063</guid><dc:creator><![CDATA[Cristian Herrera]]></dc:creator><pubDate>Fri, 24 Apr 2020 00:21:16 GMT</pubDate></item><item><title><![CDATA[Reply to Licence questions on Wed, 22 Apr 2020 06:37:59 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/cristian-herrera" aria-label="Profile: Cristian-Herrera">@<bdi>Cristian-Herrera</bdi></a>  each mango instance has its own globally unique ID.  The licence is linked to this ID.  The only way to transfer this licence is to fill out a licence transfer form.</p>
]]></description><link>https://forum.mango-os.com/post/25056</link><guid isPermaLink="true">https://forum.mango-os.com/post/25056</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Wed, 22 Apr 2020 06:37:59 GMT</pubDate></item><item><title><![CDATA[Reply to Licence questions on Wed, 22 Apr 2020 00:56:58 GMT]]></title><description><![CDATA[<p dir="auto">Make a SQL database backup and export the configuration backup as well. This will allow you to transfer all of your settings then import them into your new instance.</p>
<p dir="auto">i have to contact helpdesk of mango everytime that we need this?</p>
<p dir="auto">I don't believe so you should be able to move everything. However if the GUID of the instance changes, then you'll need to have your license amended.</p>
<p dir="auto">i can reach the old instance?</p>
<p dir="auto">Not if it goes into free mode and you exceed the allowed maximum permitted points/use license only modules.</p>
<p dir="auto">Fox</p>
]]></description><link>https://forum.mango-os.com/post/25055</link><guid isPermaLink="true">https://forum.mango-os.com/post/25055</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Wed, 22 Apr 2020 00:56:58 GMT</pubDate></item></channel></rss>
